74AUP3G14DCH
74AUP3G14DCH
    NEXPERIA(安世)
    VSSOP8_2.1X2.4MM
    IC INVERT SCHMITT 3CH 3IN 8VSSOP
74AUP3G14DCH 数据手册
74AUP3G14 Low-power triple Schmitt trigger inverter Rev. 2 — 6 October 2016 Product data sheet 1. General description The 74AUP3G14 provides three inverting buffers with Schmitt trigger action which accept standard input signals. They are capable of transforming slowly changing input signals into sharply defined, jitter-free output signals. This device ensures a very low static and dynamic power consumption across the entire VCC range from 0.8 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. The inputs switch at different points for positive and negative-going signals. The difference between the positive voltage VT+ and the negative voltage VT is defined as the input hysteresis voltage VH. 2. Features and benefits  Wide supply voltage range from 0.8 V to 3.6 V  High noise immunity  ESD protection:  HBM JESD22-A114F Class 3A exceeds 5000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Low static power consumption; ICC = 0.9 A (maximum)  Latch-up performance exceeds 100 mA per JESD 78 Class II  Inputs accept voltages up to 3.6 V  Low noise overshoot and undershoot < 10 % of VCC  IOFF circuitry provides partial Power-down mode operation  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 3. Applications  Wave and pulse shaper  Astable multivibrator  Monostable multivibrator 74AUP3G14 Nexperia Low-power triple Schmitt trigger inverter 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AUP3G14DC 40 C to +125 C VSSOP8 plastic very thin shrink small outline package; 8 leads; SOT765-1 body width 2.3 mm 74AUP3G14GT 40 C to +125 C XSON8 plastic extremely thin small outline package; no leads; SOT833-1 8 terminals; body 1  1.95  0.5 mm 74AUP3G14GM 40 C to +125 C XQFN8 plastic, extremely thin quad flat package; no leads; 8 terminals; body 1.6  1.6  0.5 mm SOT902-2 74AUP3G14GN 40 C to +125 C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.2  1.0  0.35 mm SOT1116 74AUP3G14GS 40 C to +125 C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35  1.0  0.35 mm SOT1203 5. Marking Table 2. Marking Type number Marking code[1] 74AUP3G14DC pK 74AUP3G14GT pK 74AUP3G14GM pK 74AUP3G14GN pK 74AUP3G14GS pK [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 6. Functional diagram $ < < $ $ < $ Logic symbol 74AUP3G14 Product data sheet PQD DDK DDK Fig 1. < Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 2 — 6 October 2016 Fig 3. Logic diagram (one Schmitt trigger) © Nexperia B.V. 2017. All rights reserved 2 of 21 74AUP3G14 Nexperia Low-power triple Schmitt trigger inverter 7. Pinning information 7.1 Pinning $83* $   9&& <   < $   $ *1'   < $83* $   9&& <   < $   $ *1'   < DDD 7UDQVSDUHQWWRSYLHZ DDD Fig 4. Pin configuration SOT765-1 Fig 5. Pin configuration SOT833-1, SOT1116 and SOT1203 $83* <  $ <  9&& WHUPLQDO LQGH[DUHD $   <   $ *1'   DDD 7UDQVSDUHQWWRSYLHZ Fig 6. Pin configuration SOT902-2 7.2 Pin description Table 3. Symbol Pin description Pin Description SOT765-1, SOT833-1, SOT1116 and SOT1203 SOT902-2 1A, 2A, 3A 1, 3, 6 7, 5, 2 data input 1Y, 2Y, 3Y 7, 5, 2 1, 3, 6 data output GND 4 4 ground (0 V) VCC 8 8 supply voltage 74AUP3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 6 October 2016 © Nexperia B.V. 2017. All rights reserved 3 of 21 74AUP3G14 Nexperia Low-power triple Schmitt trigger inverter 8. Functional description Table 4. Function table[1] Input Output nA nY L H H L [1] H = HIGH voltage level; L = LOW voltage level. 9. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] VO < 0 V VO output voltage Active mode and Power-down mode IO output current VO = 0 V to VCC [1] Min Max Unit 0.5 +4.6 V 50 - 0.5 +4.6 50 - 0.5 +4.6 V - 20 mA mA V mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 250 mW total power dissipation Ptot Tamb = 40 C to +125 C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For VSSOP8 package: above 110 C the value of Ptot derates linearly with 8 mW/K. For XSON8 and XQFN8 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 10. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb Conditions Min Max Unit 0.8 3.6 V 0 3.6 V Active mode 0 VCC V Power-down mode; VCC = 0 V 0 3.6 V 40 +125 C ambient temperature 74AUP3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 6 October 2016 © Nexperia B.V. 2017. All rights reserved 4 of 21 74AUP3G14 Nexperia Low-power triple Schmitt trigger inverter 11. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.75  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.11 - - V IO = 1.9 mA; VCC = 1.65 V 1.32 - - V IO = 2.3 mA; VCC = 2.3 V 2.05 - - V IO = 3.1 mA; VCC = 2.3 V 1.9 - - V IO = 2.7 mA; VCC = 3.0 V 2.72 - - V IO = 4.0 mA; VCC = 3.0 V 2.6 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - IO = 1.7 mA; VCC = 1.4 V - - 0.31 V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V Tamb = 25 C VOH VOL HIGH-level output voltage LOW-level output voltage VI = VT+ or VT VI = VT+ or VT 0.3  VCC V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.1 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.2 A IOFF additional power-off leakage VI or VO = 0 V to 3.6 V; current VCC = 0 V to 0.2 V - - 0.2 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.5 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 40 A CI input capacitance VI = GND or VCC; VCC = 0 V to 3.6 V - 1.1 - pF CO output capacitance VO = GND; VCC = 0 V - 1.7 - pF IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.7  VCC - - V Tamb = 40 C to +85 C VOH HIGH-level output voltage 74AUP3G14 Product data sheet VI = VT+ or VT IO = 1.7 mA; VCC = 1.4 V 1.03 - - V IO = 1.9 mA; VCC = 1.65 V 1.30 - - V IO = 2.3 mA; VCC = 2.3 V 1.97 - - V IO = 3.1 mA; VCC = 2.3 V 1.85 - - V IO = 2.7 mA; VCC = 3.0 V 2.67 - - V IO = 4.0 mA; VCC = 3.0 V 2.55 - - V All information provided in this document is subject to legal disclaimers. Rev. 2 — 6 October 2016 © Nexperia B.V. 2017. All rights reserved 5 of 21 74AUP3G14 Nexperia Low-power triple Schmitt trigger inverter Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VOL VI = VT+ or VT LOW-level output voltage Min Typ Max Unit IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V 0.3  VCC V IO = 1.1 mA; VCC = 1.1 V - - IO = 1.7 mA; VCC = 1.4 V - - 0.37 V IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V - - 0.5 A II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V VI or VO = 0 V to 3.6 V; VCC = 0 V IOFF power-off leakage current - - 0.5 A IOFF additional power-off leakage VI or VO = 0 V to 3.6 V; current VCC = 0 V to 0.2 V - - 0.6 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.9 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 50 A IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.11 - - V IO = 1.1 mA; VCC = 1.1 V 0.6  VCC - - V IO = 1.7 mA; VCC = 1.4 V 0.93 - - V IO = 1.9 mA; VCC = 1.65 V 1.17 - - V IO = 2.3 mA; VCC = 2.3 V 1.77 - - V IO = 3.1 mA; VCC = 2.3 V 1.67 - - V IO = 2.7 mA; VCC = 3.0 V 2.40 - - V IO = 4.0 mA; VCC = 3.0 V 2.30 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - IO = 1.7 mA; VCC = 1.4 V - - 0.41 V IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V Tamb = 40 C to +125 C VOH VOL HIGH-level output voltage LOW-level output voltage VI = VT+ or VT VI = VT+ or VT 0.33  VCC V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.75 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.75 A 74AUP3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 6 October 2016 © Nexperia B.V. 2017. All rights reserved 6 of 21 74AUP3G14 Nexperia Low-power triple Schmitt trigger inverter Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit IOFF additional power-off leakage VI or VO = 0 V to 3.6 V; current VCC = 0 V to 0.2 V - - 0.75 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 1.4 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 75 A 12. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) - 19.9 - - - - ns VCC = 1.1 V to 1.3 V 2.7 5.9 11.0 2.4 11.1 11.2 ns VCC = 1.4 V to 1.6 V 2.6 4.3 6.6 2.4 7.1 7.4 ns VCC = 1.65 V to 1.95 V 2.1 3.7 5.4 2.0 6.0 6.2 ns VCC = 2.3 V to 2.7 V 2.0 3.0 4.1 1.7 4.5 4.7 ns VCC = 3.0 V to 3.6 V 1.9 2.8 3.6 1.5 3.9 4.0 ns - 23.4 - - - - ns VCC = 1.1 V to 1.3 V 2.9 6.8 12.7 2.8 12.8 12.9 ns VCC = 1.4 V to 1.6 V 2.8 5.0 7.7 2.6 8.2 8.6 ns VCC = 1.65 V to 1.95 V 2.7 4.2 6.2 2.5 6.7 7.1 ns VCC = 2.3 V to 2.7 V 2.3 3.6 4.8 2.1 5.2 5.5 ns VCC = 3.0 V to 3.6 V 2.1 3.3 4.3 2.0 4.5 4.7 ns - 26.9 - - - - ns VCC = 1.1 V to 1.3 V 3.3 7.6 14.3 3.0 14.5 14.7 ns VCC = 1.4 V to 1.6 V 3.3 5.5 8.6 2.9 9.4 9.8 ns VCC = 1.65 V to 1.95 V 2.8 4.7 7.0 2.8 7.7 8.1 ns VCC = 2.3 V to 2.7 V 2.7 4.0 5.5 2.4 5.9 6.2 ns VCC = 3.0 V to 3.6 V 2.6 3.8 4.8 2.2 5.2 5.4 ns CL = 5 pF tpd propagation delay nA to nY; see Figure 7 [2] VCC = 0.8 V CL = 10 pF tpd propagation delay nA to nY; see Figure 7 [2] VCC = 0.8 V CL = 15 pF tpd propagation delay nA to nY; see Figure 7 VCC = 0.8 V 74AUP3G14 Product data sheet [2] All information provided in this document is subject to legal disclaimers. Rev. 2 — 6 October 2016 © Nexperia B.V. 2017. All rights reserved 7 of 21 74AUP3G14 Nexperia Low-power triple Schmitt trigger inverter Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) - 37.3 - - - - ns 4.0 9.8 18.7 3.9 19.6 20.0 ns CL = 30 pF propagation delay nA to nY; see Figure 7 tpd [2] VCC = 0.8 V VCC = 1.1 V to 1.3 V VCC = 1.4 V to 1.6 V 3.7 7.1 11.2 3.8 12.3 12.9 ns VCC = 1.65 V to 1.95 V 3.6 6.0 9.1 3.6 10.0 10.6 ns VCC = 2.3 V to 2.7 V 3.5 5.2 6.9 3.2 7.5 7.9 ns VCC = 3.0 V to 3.6 V 3.3 4.8 6.1 3.1 7.1 7.4 ns VCC = 0.8 V - 2.6 - - - - pF VCC = 1.1 V to 1.3 V - 2.7 - - - - pF VCC = 1.4 V to 1.6 V - 2.9 - - - - pF VCC = 1.65 V to 1.95 V - 3.1 - - - - pF VCC = 2.3 V to 2.7 V - 3.7 - - - - pF VCC = 3.0 V to 3.6 V - 4.3 - - - - pF CL = 5 pF, 10 pF, 15 pF and 30 pF power dissipation capacitance CPD fi = 1 MHz; VI = GND to VCC [3][4] [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPLH and tPHL. [3] All specified values are the average typical values over all stated loads. [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 74AUP3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 6 October 2016 © Nexperia B.V. 2017. All rights reserved 8 of 21 74AUP3G14 Nexperia Low-power triple Schmitt trigger inverter 13. Waveforms 9, 90 Q$LQSXW 90 *1' W 3+/ W 3/+ 92+ 90 Q
74AUP3G14DCH 价格&库存
很抱歉,暂时无法提供与“74AUP3G14DCH”相匹配的价格&库存,您可以联系我们找货
