74AVC9112
1-to-4 fan-out buffer
Rev. 1 — 23 April 2018
1
Product data sheet
General description
The 74AVC9112 is a 1-to-4 fan-out buffer suitable for use in clock distribution. It has
a data input (A), four data outputs (Yn) and an output enable input (OE). VCC can be
supplied at any voltage between 0.8 V and 3.6 V. A HIGH on OE causes all outputs to be
pulled LOW via pull-down resistors, a LOW on OE disconnects the pull-down resistors
and enables all outputs.
Schmitt trigger action at all inputs makes the circuit tolerant for slower input rise and fall
time.
The IOFF circuitry disables the output, preventing any damaging backflow current through
the device when it is powered down.
2
Features and benefits
• Wide supply voltage range:
– VCC: 0.8 V to 3.6 V
• Complies with JEDEC standards:
– JESD8-12 (0.8 V to 1.3 V)
– JESD8-11 (0.9 V to 1.65 V)
– JESD8-7 (1.2 V to 1.95 V)
– JESD8-5 (1.8 V to 2.7 V)
– JESD8-B (2.7 V to 3.6 V)
• ESD protection:
– HBM ANSI/ESDA/JEDEC JS-001 Class 3B exceeds 8 kV
– CDM JESD22-C101 exceeds 1000 V
• Maximum data rates:
– 380 Mbit/s (3.3 V)
– 200 Mbit/s (2.5 V)
– 200 Mbit/s (1.8 V)
– 150 Mbit/s (1.5 V)
– 100 Mbit/s (1.2 V)
• Latch-up performance exceeds 100 mA per JESD 78 Class II
• Inputs accept voltages up to 3.6 V
• Specified from -40 °C to +85 °C and -40 °C to +125 °C
74AVC9112
Nexperia
3
Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
74AVC9112DC
-40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package; 8 leads; SOT765-1
body width 2.3 mm
74AVC9112GT
-40 °C to +125 °C
XSON8
plastic extremely thin small outline package; no leads; SOT833-1
8 terminals; body 1 x 1.95 x 0.5 mm
4
Version
Marking
Table 2. Marking codes
Type number
Marking code
74AVC9112DC
Bb
74AVC9112GT
Bb
5
Functional diagram
A
2
8
Y4
Rpd
7
Y3
Rpd
OE
3
6
Y2
Rpd
5
Y1
Rpd
aaa-027818
Figure 1. Logic symbol
74AVC9112
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2018. All rights reserved.
2 / 16
74AVC9112
Nexperia
6
Pinning information
6.1 Pinning
74AVC9112
VCC
1
8
Y4
A
2
7
Y3
OE
3
6
Y2
GND
4
5
Y1
74AVC9112
VCC
1
8
Y4
A
2
7
Y3
OE
3
6
Y2
GND
4
5
Y1
aaa-027819
Transparent top view
aaa-027820
Figure 2. Pin configuration SOT765-1 (VSSOP8)
Figure 3. Pin configuration SOT833-1 (XSON8)
6.2 Pin description
Table 3. Pin description
Symbol
Pin
Description
VCC
1
supply voltage
A
2
data input
OE
3
output enable input (active LOW)
GND
4
ground (0 V)
Y1, Y2, Y3, Y4
5, 6, 7, 8
data outputs
7
Functional description
Table 4. Function table
[1]
Inputs
Output
OE
A
Yn
L
L
L
L
H
H
H
X
L
[1] H = HIGH voltage level;
L = LOW voltage level;
X = don’t care.
74AVC9112
Product data sheet
3 / 16
74AVC9112
Nexperia
8
Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
Conditions
output voltage
Max
Unit
-0.5
+4.6
V
[1]
-0.5
+4.6
V
OE = LOW
[1] [2]
-0.5
VCC + 0.5
V
OE = HIGH
[1]
-0.5
+4.6
V
input voltage
VO
Min
IIK
input clamping current
VI < 0 V
-50
mA
IOK
output clamping current
VO < 0 V
-50
mA
IO
output current
VO = 0 V to VCC
±50
mA
ICC
supply current
100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
[1]
[2]
[3]
[4]
Tamb = -40 °C to +125 °C
SOT765-1 package
[3]
250
mW
SOT833-1 package
[4]
250
mW
The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed.
VCC + 0.5 V should not exceed 4.6 V.
For SOT765-1 package: above 99 °C, the value of Ptot derates linearly with 4.9 mW/K.
For SOT833-1 package: above 68 °C, the value of Ptot derates linearly with 3.1 mW/K.
9
Recommended operating conditions
Table 6. Recommended operating conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
74AVC9112
Product data sheet
Min
Max
Unit
0.8
3.6
V
V
OE = LOW
VCC
V
OE = HIGH
V
-40
+125
°C
ns/V
VCC = 0.8 V to 3.6 V
4 / 16
74AVC9112
Nexperia
10 Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
VOH
Parameter
Conditions
HIGH-level output voltage
Tamb = 25 °C
LOW-level output voltage
Min
Typ
Max
0.69
V
0.07
V
VI = VIH or VIL
IO = -1.5 mA; VCC = 0.8 V
VOL
Unit
VI = VIH or VIL
IO = 1.5 mA; VCC = 0.8 V
II
input leakage current
A, OE input; VI = 0 V or 3.6 V;
±0.025
±0.25
μA
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
±0.1
±1
μA
Rpd
pull-down resistance
50
kΩ
CI
input capacitance
A, OE input; VI = 0 V or 3.3 V;
VCC = 3.3 V
1.2
pF
CO
output capacitance
Yn; VO = 3.3 V or 0 V; VCC = 3.3 V
4.7
pF
Table 8. Static characteristics
Symbol Parameter
VIH
VIL
VOH
Conditions
Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Unit
Min
Max
Min
Max
0.70VCC
0.70VCC
V
VCC = 1.1 V to 1.95 V
0.65VCC
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.6
1.6
V
VCC = 3.0 V to 3.6 V
2
2
V
0.30VCC
0.30VCC
V
0.35VCC
0.35VCC
V
0.7
0.7
V
0.8
0.8
V
VCC - 0.1
VCC - 0.1
V
IO = -3 mA; VCC = 1.1 V
0.85
0.85
V
IO = -6 mA; VCC = 1.4 V
1.05
1.05
V
IO = -8 mA; VCC = 1.65 V
1.2
1.2
V
IO = -9 mA; VCC = 2.3 V
1.75
1.75
V
IO = -12 mA; VCC = 3.0 V
2.3
2.3
V
HIGH-level input A, OE input
voltage
VCC = 0.8 V
LOW-level input A, OE input
voltage
VCC = 0.8 V
HIGH-level
output voltage
74AVC9112
Product data sheet
VI = VIH or VIL
IO = -100 μA;
5 / 16
74AVC9112
Nexperia
Symbol Parameter
VOL
LOW-level
output voltage
Conditions
Min
Max
Min
Max
IO = 100 μA;
0.1
0.1
V
IO = 3 mA; VCC = 1.1 V
0.25
0.25
V
IO = 6 mA; VCC = 1.4 V
0.35
0.35
V
IO = 8 mA; VCC = 1.65 V
0.45
0.45
V
IO = 9 mA; VCC = 2.3 V
0.55
0.55
V
IO = 12 mA; VCC = 3.0 V
0.7
0.7
V
VI = VIH or VIL
II
input leakage
current
±1
±5
μA
IOFF
power-off
leakage current
±5
±30
μA
ICC
supply current
VI = 0 V or VCC; IO = 0 A;
8
50
μA
11 Dynamic characteristics
Table 9. Typical dynamic characteristics
[1]
Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 6; for waveforms, see Figure 4 and Figure 5.
Symbol
Parameter
Conditions
Tamb = 25 °C; VCC = 0.8 V
Unit
tpd
propagation delay
A to Yn
31
ns
tdis
disable time
OE to Yn
25
ns
ten
enable time
OE to Yn
36
ns
[1] tpd is the same as tPLH and tPHL;
tdis is the same as tPLZ and tPHZ;
ten is the same as tPZL and tPZH.
74AVC9112
Product data sheet
6 / 16
74AVC9112
Nexperia
Table 10. Dynamic characteristics
[1]
Symbol
Parameter
Conditions
VCC
Unit
1.2 V±0.1 V
1.5 V±0.1 V
1.8 V±0.15 V
2.5 V±0.2 V
3.3 V±0.3 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
0.9
14.7
0.7
9.5
0.6
7.6
0.5
5.4
0.4
4.4
ns
tpd
propagation A to Yn
delay
tdis
disable time OE to Yn
1.0
14.7
0.8
9.7
0.8
8.8
0.6
6.5
0.7
6.9
ns
ten
enable time OE to Yn
1.0
15.8
0.7
9.9
0.6
7.9
0.5
5.5
0.5
4.5
ns
tsk(o)
output skew between any
time
output
0.7
0.4
0.3
0.2
0.2
ns
0.9
15.7
0.7
10.4
0.6
8.3
0.5
5.9
0.4
4.9
ns
tpd
propagation A to Yn
delay
tdis
1.0
16.5
0.8
11.0
0.8
10.0
0.6
7.5
0.7
7.7
ns
ten
1.0
16.9
0.7
10.9
0.6
8.7
0.6
6.1
0.5
4.9
ns
tsk(o)
time
output
0.9
0.5
0.4
0.3
0.2
ns
Table 11. Typical power dissipation capacitance at Tamb = 25 °C
Symbol
CPD
Parameter
[1] [2]
Conditions
VCC
Unit
0.8 V
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
power dissipation
Yn; outputs enabled
35
35
36
37
40
45
pF
capacitance
Yn; outputs disabled
2.0
2.2
2.3
2.4
2.6
2.7
pF
[1] CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = load capacitance in pF;
VCC = supply voltage in V;
2
Σ(CL × VCC × fo) = sum of the outputs.
[2] fi = 10 MHz;
VI = GND to VCC;
tr = tf = 1 ns;
CL = 0 pF;
RL = ∞ Ω.
74AVC9112
Product data sheet
7 / 16
74AVC9112
Nexperia
11.1 Waveforms and test circuit
VI
A input
VM
VM
GND
tPHL
tPLH
VOH
Yn output
VM
VM
VOL
aaa-027817
Measurement points are given in Table 12.
VOL and VOH are typical output voltage levels that occur with the output load.
Figure 4. The data input (A) to output (Yn) propagation delay times
VI
OE input
VM
GND
tPLZ
output
LOW-to-OFF
OFF-to-LOW
tPZL
VOH
VM
VX
VOL
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
tPZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
aaa-019808
Figure 5. Enable and disable times
Table 12. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
VY
0.8 V to 1.6 V
0.5VCC
0.5VCC
VOL + 0.1 V
VOH - 0.1 V
1.65 V to 2.7 V
0.5VCC
0.5VCC
VOL + 0.15 V
VOH - 0.15 V
3.0 V to 3.6 V
0.5VCC
0.5VCC
VOL + 0.3 V
VOH - 0.3 V
74AVC9112
Product data sheet
8 / 16
74AVC9112
Nexperia
VI
negative
pulse
tW
90 %
VM
VM
10 %
0V
tf
tr
VI
positive
pulse
0V
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 13
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance.
VEXT = External voltage for measuring switching times.
Figure 6. Test circuit for measuring switching times
Table 13. Test data
Supply voltage
Input
Load
VCC
VI
Δt/ΔV
0.8 V to 1.6 V
VCC
1.65 V to 2.7 V
3.0 V to 3.6 V
[1]
VEXT
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
≤ 1.0 ns/V
15 pF
2 kΩ
open
GND
2VCC
VCC
≤ 1.0 ns/V
15 pF
2 kΩ
open
GND
2VCC
VCC
≤ 1.0 ns/V
15 pF
2 kΩ
open
GND
2VCC
[1] dV/dt ≥ 1.0 V/ns
74AVC9112
Product data sheet
9 / 16
74AVC9112
Nexperia
11.2 Typical propagation delay characteristics
aaa-019810
30
(1)
tpd
(ns)
24
18
12
(2)
(3)
(4)
(5)
(6)
6
24
36
48
CL (pF)
60
(1) VCC = 0.8 V
(2) VCC = 1.2 V
(3) VCC = 1.5 V
(4) VCC = 1.8 V
(5) VCC = 2.5 V
(6) VCC = 3.3 V
Figure 7. Typical propagation delay versus load capacitance; Tamb = 25 °C
74AVC9112
Product data sheet
10 / 16
74AVC9112
Nexperia
12 Package outline
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
max.
max
nom
min
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
w
y
0.2
0.08
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Figure 8. Package outline SOT765-1 (VSSOP8)
74AVC9112
Product data sheet
11 / 16
74AVC9112
Nexperia
XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm
1
2
SOT833-1
b
4
3
4×
(2)
L
L1
e
8
7
6
e1
5
e1
e1
8×
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A(1)
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.25
0.17
2.0
1.9
1.05
0.95
0.6
0.5
0.35
0.27
0.40
0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT833-1
MO-252
EUROPEAN
PROJECTION
ISSUE DATE
07-11-14
07-12-07
Figure 9. Package outline SOT833-1 (XSON8)
74AVC9112
Product data sheet
12 / 16
74AVC9112
Nexperia
13 Abbreviations
Table 14. Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
14 Revision history
Table 15. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AVC9112 v.1
20180423
Product data sheet
74AVC9112
Product data sheet
13 / 16
74AVC9112
Nexperia
15 Legal information
15.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74AVC9112
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
14 / 16
74AVC9112
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74AVC9112
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
15 / 16
74AVC9112
Nexperia
Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
11.1
11.2
12
13
14
15
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 2
Marking .................................................................2
Functional diagram ............................................. 2
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 3
Functional description ........................................3
Limiting values .................................................... 4
Recommended operating conditions ................ 4
Static characteristics .......................................... 5
Dynamic characteristics .....................................6
Waveforms and test circuit ................................ 8
Typical propagation delay characteristics ........ 10
Package outline .................................................11
Abbreviations .................................................... 13
Revision history ................................................ 13
Legal information .............................................. 14
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 23 April 2018
Document identifier: 74AVC9112
