74AVC9112GTX
74AVC9112GTX
    NEXPERIA(安世)
    XSON8_1.95X1MM
    1 至 4 扇出缓冲器 XSON8
74AVC9112GTX 数据手册
74AVC9112 1-to-4 fan-out buffer Rev. 1 — 23 April 2018 1 Product data sheet General description The 74AVC9112 is a 1-to-4 fan-out buffer suitable for use in clock distribution. It has a data input (A), four data outputs (Yn) and an output enable input (OE). VCC can be supplied at any voltage between 0.8 V and 3.6 V. A HIGH on OE causes all outputs to be pulled LOW via pull-down resistors, a LOW on OE disconnects the pull-down resistors and enables all outputs. Schmitt trigger action at all inputs makes the circuit tolerant for slower input rise and fall time. The IOFF circuitry disables the output, preventing any damaging backflow current through the device when it is powered down. 2 Features and benefits • Wide supply voltage range: – VCC: 0.8 V to 3.6 V • Complies with JEDEC standards: – JESD8-12 (0.8 V to 1.3 V) – JESD8-11 (0.9 V to 1.65 V) – JESD8-7 (1.2 V to 1.95 V) – JESD8-5 (1.8 V to 2.7 V) – JESD8-B (2.7 V to 3.6 V) • ESD protection: – HBM ANSI/ESDA/JEDEC JS-001 Class 3B exceeds 8 kV – CDM JESD22-C101 exceeds 1000 V • Maximum data rates: – 380 Mbit/s (3.3 V) – 200 Mbit/s (2.5 V) – 200 Mbit/s (1.8 V) – 150 Mbit/s (1.5 V) – 100 Mbit/s (1.2 V) • Latch-up performance exceeds 100 mA per JESD 78 Class II • Inputs accept voltages up to 3.6 V • Specified from -40 °C to +85 °C and -40 °C to +125 °C 74AVC9112 Nexperia 1-to-4 fan-out buffer 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description 74AVC9112DC -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; SOT765-1 body width 2.3 mm 74AVC9112GT -40 °C to +125 °C XSON8 plastic extremely thin small outline package; no leads; SOT833-1 8 terminals; body 1 x 1.95 x 0.5 mm 4 Version Marking Table 2. Marking codes Type number Marking code 74AVC9112DC Bb 74AVC9112GT Bb 5 Functional diagram A 2 8 Y4 Rpd 7 Y3 Rpd OE 3 6 Y2 Rpd 5 Y1 Rpd aaa-027818 Figure 1. Logic symbol 74AVC9112 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 April 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 16 74AVC9112 Nexperia 1-to-4 fan-out buffer 6 Pinning information 6.1 Pinning 74AVC9112 VCC 1 8 Y4 A 2 7 Y3 OE 3 6 Y2 GND 4 5 Y1 74AVC9112 VCC 1 8 Y4 A 2 7 Y3 OE 3 6 Y2 GND 4 5 Y1 aaa-027819 Transparent top view aaa-027820 Figure 2. Pin configuration SOT765-1 (VSSOP8) Figure 3. Pin configuration SOT833-1 (XSON8) 6.2 Pin description Table 3. Pin description Symbol Pin Description VCC 1 supply voltage A 2 data input OE 3 output enable input (active LOW) GND 4 ground (0 V) Y1, Y2, Y3, Y4 5, 6, 7, 8 data outputs 7 Functional description Table 4. Function table [1] Inputs Output OE A Yn L L L L H H H X L [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 74AVC9112 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 April 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 16 74AVC9112 Nexperia 1-to-4 fan-out buffer 8 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI Conditions output voltage Max Unit -0.5 +4.6 V [1] -0.5 +4.6 V OE = LOW [1] [2] -0.5 VCC + 0.5 V OE = HIGH [1] -0.5 +4.6 V input voltage VO Min IIK input clamping current VI < 0 V -50 - mA IOK output clamping current VO < 0 V -50 - mA IO output current VO = 0 V to VCC - ±50 mA ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation [1] [2] [3] [4] Tamb = -40 °C to +125 °C SOT765-1 package [3] - 250 mW SOT833-1 package [4] - 250 mW The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed. VCC + 0.5 V should not exceed 4.6 V. For SOT765-1 package: above 99 °C, the value of Ptot derates linearly with 4.9 mW/K. For SOT833-1 package: above 68 °C, the value of Ptot derates linearly with 3.1 mW/K. 9 Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature Δt/ΔV input transition rise and fall rate 74AVC9112 Product data sheet Min Max Unit 0.8 3.6 V 0 3.6 V OE = LOW 0 VCC V OE = HIGH 0 3.6 V -40 +125 °C 0 200 ns/V VCC = 0.8 V to 3.6 V All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 April 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 16 74AVC9112 Nexperia 1-to-4 fan-out buffer 10 Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol VOH Parameter Conditions HIGH-level output voltage Tamb = 25 °C LOW-level output voltage Min Typ Max - 0.69 - V - 0.07 - V VI = VIH or VIL IO = -1.5 mA; VCC = 0.8 V VOL Unit VI = VIH or VIL IO = 1.5 mA; VCC = 0.8 V II input leakage current A, OE input; VI = 0 V or 3.6 V; VCC = 0.8 V to 3.6 V - ±0.025 ±0.25 μA IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - ±0.1 ±1 μA Rpd pull-down resistance - 50 - kΩ CI input capacitance A, OE input; VI = 0 V or 3.3 V; VCC = 3.3 V - 1.2 - pF CO output capacitance Yn; VO = 3.3 V or 0 V; VCC = 3.3 V - 4.7 - pF Table 8. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH Conditions Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Unit Min Max Min Max 0.70VCC - 0.70VCC - V VCC = 1.1 V to 1.95 V 0.65VCC - 0.65VCC - V VCC = 2.3 V to 2.7 V 1.6 - 1.6 - V VCC = 3.0 V to 3.6 V 2 - 2 - V - 0.30VCC - 0.30VCC V VCC = 1.1 V to 1.95 V - 0.35VCC - 0.35VCC V VCC = 2.3 V to 2.7 V - 0.7 - 0.7 V VCC = 3.0 V to 3.6 V - 0.8 - 0.8 V VCC - 0.1 - VCC - 0.1 - V IO = -3 mA; VCC = 1.1 V 0.85 - 0.85 - V IO = -6 mA; VCC = 1.4 V 1.05 - 1.05 - V IO = -8 mA; VCC = 1.65 V 1.2 - 1.2 - V IO = -9 mA; VCC = 2.3 V 1.75 - 1.75 - V IO = -12 mA; VCC = 3.0 V 2.3 - 2.3 - V HIGH-level input A, OE input voltage VCC = 0.8 V LOW-level input A, OE input voltage VCC = 0.8 V HIGH-level output voltage 74AVC9112 Product data sheet VI = VIH or VIL IO = -100 μA; VCC = 0.8 V to 3.6 V All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 April 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 16 74AVC9112 Nexperia 1-to-4 fan-out buffer Symbol Parameter VOL LOW-level output voltage Conditions Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Unit Min Max Min Max IO = 100 μA; VCC = 0.8 V to 3.6 V - 0.1 - 0.1 V IO = 3 mA; VCC = 1.1 V - 0.25 - 0.25 V IO = 6 mA; VCC = 1.4 V - 0.35 - 0.35 V IO = 8 mA; VCC = 1.65 V - 0.45 - 0.45 V IO = 9 mA; VCC = 2.3 V - 0.55 - 0.55 V IO = 12 mA; VCC = 3.0 V - 0.7 - 0.7 V VI = VIH or VIL II input leakage current A, OE input; VI = 0 V or 3.6 V; VCC = 0.8 V to 3.6 V - ±1 - ±5 μA IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - ±5 - ±30 μA ICC supply current VI = 0 V or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - 8 - 50 μA 11 Dynamic characteristics Table 9. Typical dynamic characteristics [1] Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 6; for waveforms, see Figure 4 and Figure 5. Symbol Parameter Conditions Tamb = 25 °C; VCC = 0.8 V Unit tpd propagation delay A to Yn 31 ns tdis disable time OE to Yn 25 ns ten enable time OE to Yn 36 ns [1] tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. 74AVC9112 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 April 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 16 74AVC9112 Nexperia 1-to-4 fan-out buffer Table 10. Dynamic characteristics [1] Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 6; for waveforms, see Figure 4 and Figure 5. Symbol Parameter Conditions VCC Unit 1.2 V±0.1 V 1.5 V±0.1 V 1.8 V±0.15 V 2.5 V±0.2 V 3.3 V±0.3 V Min Max Min Max Min Max Min Max Min Max 0.9 14.7 0.7 9.5 0.6 7.6 0.5 5.4 0.4 4.4 ns Tamb = -40 °C to +85 °C tpd propagation A to Yn delay tdis disable time OE to Yn 1.0 14.7 0.8 9.7 0.8 8.8 0.6 6.5 0.7 6.9 ns ten enable time OE to Yn 1.0 15.8 0.7 9.9 0.6 7.9 0.5 5.5 0.5 4.5 ns tsk(o) output skew between any time output - 0.7 - 0.4 - 0.3 - 0.2 - 0.2 ns 0.9 15.7 0.7 10.4 0.6 8.3 0.5 5.9 0.4 4.9 ns Tamb = -40 °C to +125 °C tpd propagation A to Yn delay tdis disable time OE to Yn 1.0 16.5 0.8 11.0 0.8 10.0 0.6 7.5 0.7 7.7 ns ten enable time OE to Yn 1.0 16.9 0.7 10.9 0.6 8.7 0.6 6.1 0.5 4.9 ns tsk(o) output skew between any time output - 0.9 - 0.5 - 0.4 - 0.3 - 0.2 ns [1] tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. Table 11. Typical power dissipation capacitance at Tamb = 25 °C Symbol CPD Parameter [1] [2] Conditions VCC Unit 0.8 V 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V power dissipation Yn; outputs enabled 35 35 36 37 40 45 pF capacitance Yn; outputs disabled 2.0 2.2 2.3 2.4 2.6 2.7 pF [1] CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = load capacitance in pF; VCC = supply voltage in V; 2 Σ(CL × VCC × fo) = sum of the outputs. [2] fi = 10 MHz; VI = GND to VCC; tr = tf = 1 ns; CL = 0 pF; RL = ∞ Ω. 74AVC9112 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 April 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 16 74AVC9112 Nexperia 1-to-4 fan-out buffer 11.1 Waveforms and test circuit VI A input VM VM GND tPHL tPLH VOH Yn output VM VM VOL aaa-027817 Measurement points are given in Table 12. VOL and VOH are typical output voltage levels that occur with the output load. Figure 4. The data input (A) to output (Yn) propagation delay times VI OE input VM GND tPLZ output LOW-to-OFF OFF-to-LOW tPZL VOH VM VX VOL tPHZ output HIGH-to-OFF OFF-to-HIGH VOH tPZH VY VM GND outputs enabled outputs disabled outputs enabled aaa-019808 Measurement points are given in Table 12. VOL and VOH are typical output voltage levels that occur with the output load. Figure 5. Enable and disable times Table 12. Measurement points Supply voltage Input Output VCC VM VM VX VY 0.8 V to 1.6 V 0.5VCC 0.5VCC VOL + 0.1 V VOH - 0.1 V 1.65 V to 2.7 V 0.5VCC 0.5VCC VOL + 0.15 V VOH - 0.15 V 3.0 V to 3.6 V 0.5VCC 0.5VCC VOL + 0.3 V VOH - 0.3 V 74AVC9112 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 April 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 16 74AVC9112 Nexperia 1-to-4 fan-out buffer VI negative pulse tW 90 % VM VM 10 % 0V tf tr VI positive pulse 0V tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 13 RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance. VEXT = External voltage for measuring switching times. Figure 6. Test circuit for measuring switching times Table 13. Test data Supply voltage Input Load VCC VI Δt/ΔV 0.8 V to 1.6 V VCC 1.65 V to 2.7 V 3.0 V to 3.6 V [1] VEXT CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ ≤ 1.0 ns/V 15 pF 2 kΩ open GND 2VCC VCC ≤ 1.0 ns/V 15 pF 2 kΩ open GND 2VCC VCC ≤ 1.0 ns/V 15 pF 2 kΩ open GND 2VCC [1] dV/dt ≥ 1.0 V/ns 74AVC9112 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 April 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 16 74AVC9112 Nexperia 1-to-4 fan-out buffer 11.2 Typical propagation delay characteristics aaa-019810 30 (1) tpd (ns) 24 18 12 (2) (3) (4) (5) (6) 6 0 0 12 24 36 48 CL (pF) 60 (1) VCC = 0.8 V (2) VCC = 1.2 V (3) VCC = 1.5 V (4) VCC = 1.8 V (5) VCC = 2.5 V (6) VCC = 3.3 V Figure 7. Typical propagation delay versus load capacitance; Tamb = 25 °C 74AVC9112 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 April 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 16 74AVC9112 Nexperia 1-to-4 fan-out buffer 12 Package outline VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D SOT765-1 E A X c y HE v A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 detail X 4 e L w bp 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm A max. max nom min 1 A1 A2 0.15 0.85 0.00 0.60 A3 0.12 D(1) E(2) 0.27 0.23 2.1 2.4 0.17 0.08 1.9 2.2 bp c e HE 0.5 3.2 3.0 L 0.4 Lp Q 0.40 0.21 0.15 0.19 v w y 0.2 0.08 0.1 Z(1) θ 0.4 8° 0.1 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version SOT765-1 References IEC JEDEC JEITA sot765-1_po European projection Issue date 07-06-02 16-05-31 MO-187 Figure 8. Package outline SOT765-1 (VSSOP8) 74AVC9112 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 April 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 16 74AVC9112 Nexperia 1-to-4 fan-out buffer XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm 1 2 SOT833-1 b 4 3 4× (2) L L1 e 8 7 6 e1 5 e1 e1 8× A (2) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max A1 max b D E e e1 L L1 mm 0.5 0.04 0.25 0.17 2.0 1.9 1.05 0.95 0.6 0.5 0.35 0.27 0.40 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT833-1 --- MO-252 --- EUROPEAN PROJECTION ISSUE DATE 07-11-14 07-12-07 Figure 9. Package outline SOT833-1 (XSON8) 74AVC9112 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 April 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 16 74AVC9112 Nexperia 1-to-4 fan-out buffer 13 Abbreviations Table 14. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model 14 Revision history Table 15. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AVC9112 v.1 20180423 Product data sheet - - 74AVC9112 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 April 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 16 74AVC9112 Nexperia 1-to-4 fan-out buffer 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74AVC9112 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 April 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 16 74AVC9112 Nexperia 1-to-4 fan-out buffer Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74AVC9112 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 1 — 23 April 2018 © Nexperia B.V. 2018. All rights reserved. 15 / 16 74AVC9112 Nexperia 1-to-4 fan-out buffer Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 11.2 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Marking .................................................................2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................3 Limiting values .................................................... 4 Recommended operating conditions ................ 4 Static characteristics .......................................... 5 Dynamic characteristics .....................................6 Waveforms and test circuit ................................ 8 Typical propagation delay characteristics ........ 10 Package outline .................................................11 Abbreviations .................................................... 13 Revision history ................................................ 13 Legal information .............................................. 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 23 April 2018 Document identifier: 74AVC9112
74AVC9112GTX 价格&库存
很抱歉,暂时无法提供与“74AVC9112GTX”相匹配的价格&库存,您可以联系我们找货
74AVC9112GTX
    • 696+1.25680
    • 1000+1.13952
    • 3000+1.11676
    库存:4574
    74AVC9112GTX
    • 5000+1.161505000+0.14084
    • 10000+1.1316110000+0.13722
    • 15000+1.1166215000+0.13540
    • 25000+1.1000125000+0.13338
    • 35000+1.0903235000+0.13221
    • 50000+1.0809950000+0.13108
    库存:5961
    74AVC9112GTX
    • 1+2.824141+0.34244
    • 10+1.9593210+0.23758
    • 25+1.7416625+0.21119
    • 100+1.49970100+0.18185
    • 250+1.38456250+0.16789
    • 500+1.31527500+0.15949
    • 1000+1.258121000+0.15256
    • 2500+1.197852500+0.14525
    库存:5961
