74AXP1T32
Dual supply 2-input OR gate
Rev. 2 — 22 March 2019
Product data sheet
1. General description
The 74AXP1T32 is a dual supply 2-input OR gate. It features two inputs (A, B), an output (Y) and
dual supply pins (VCCI and VCCO). The inputs are referenced to VCCI and the output is referenced
to VCCO. All inputs can be connected directly to VCCI or GND. VCCI can be supplied at any voltage
between 0.7 V and 2.75 V. VCCO can be supplied at any voltage between 1.2 V and 5.5 V. This
feature allows voltage level translation.
Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall times.
This device ensures very low static and dynamic power consumption across the entire supply
range and is fully specified for partial power down applications using IOFF. The IOFF circuitry
disables the output, preventing the potentially damaging backflow current through the device when
it is powered down.
2. Features and benefits
Wide supply voltage range:
• VCCI: 0.7 V to 2.75 V
• VCCO: 1.2 V to 5.5 V
Low input capacitance; CI = 0.6 pF (typical)
Low output capacitance; CO = 1.8 pF (typical)
Low dynamic power consumption; CPD = 0.5 pF at VCCI = 1.2 V (typical)
Low dynamic power consumption; CPD = 7.1 pF at VCCO = 3.3 V (typical)
Low static power consumption; ICCI = 0.5 μA (85 °C maximum)
Low static power consumption; ICCO = 1.8 μA (85 °C maximum)
High noise immunity
Complies with JEDEC standard:
• JESD8-12A.01 (1.1 V to 1.3 V; A, B input)
• JESD8-11A.01 (1.4 V to 1.6 V)
• JESD8-7A (1.65 V to 1.95 V)
• JESD8-5A.01 (2.3 V to 2.7 V)
• JESD8-C (2.7 V to 3.6 V; Y output)
• JESD12-6 (4.5 V to 5.5 V; Y output)
ESD protection:
• HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV
• CDM JESD22-C101E exceeds 1000 V
Latch-up performance exceeds 100 mA per JESD78D Class II
Inputs accept voltages up to 2.75 V
Low noise overshoot and undershoot < 10 % of VCCO
IOFF circuitry provides partial power-down mode operation
Specified from -40 °C to +85 °C
74AXP1T32
Nexperia
3. Ordering information
Table 1. Ordering information
Type number
Package
74AXP1T32GX
Temperature range Name
Description
Version
-40 °C to +85 °C
plastic thermal enhanced extremely thin small outline
package; no leads; 6 terminals; body 1.0 x 0.8 x 0.35 mm
SOT1255
X2SON6
4. Marking
Table 2. Marking
Type number
Marking code[1]
74AXP1T32GX
rT
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
B
5
3
B
A
Y
Y
4
A
VCCI
VCCO
aaa-025599
aaa-025598
Fig. 1.
Logic symbol
Fig. 2.
Logic diagram
6. Pinning information
6.1. Pinning
74AXP1T32
VCCI
VCCO
1
6
GND
2
3
A
5
B
4
Y
aaa-025601
Transparent top view
Fig. 3.
Pin configuration SOT1255 (X2SON6)
74AXP1T32
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 14
74AXP1T32
Nexperia
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
VCCI
1
input supply voltage
GND
2
ground (0 V)
A
3
data input A
Y
4
data output Y
B
5
data input B
VCCO
6
output supply voltage
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level; X = Don’t care; Z = high-impedance OFF-state.
Supply voltage
Output
Input
VCCI
VCCO
A
B
Y
0.7 V to 2.75 V
1.2 V to 5.5 V
L
L
L
0.7 V to 2.75 V
1.2 V to 5.5 V
L
H
H
0.7 V to 2.75 V
1.2 V to 5.5 V
H
L
H
0.7 V to 2.75 V
1.2 V to 5.5 V
H
H
H
GND
1.2 V to 5.5 V
X
X
Z
0.7 V to 2.75 V
GND
X
X
Z
GND
GND
X
X
Z
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCCI
Conditions
Min
Max
Unit
-0.5
3.3
V
VCCO
-0.5
6.0
V
IIK
input clamping current
-50
VI
input voltage
-0.5
3.3
IOK
output clamping current
VO < 0 V
-50
VO
output voltage
Active mode
VI < 0 V
[1]
mA
V
mA
[1][2]
-0.5
[1]
-0.5
6.0
V
±25
mA
Power-down or 3-state mode
IO
output current
ICCI
input supply current
50
mA
ICCO
output supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
74AXP1T32
Product data sheet
VO = 0 V to VCCO
VCCO + 0.5 V
3 / 14
74AXP1T32
Nexperia
Symbol
Parameter
Conditions
Ptot
total power dissipation
Tamb = -40 °C to +85 °C
[1]
[2]
[3]
Min
Max
Unit
250
mW
[3]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
VCCO + 0.5 V should not exceed 6.0 V.
For X2SON6 package: above 118 °C, the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol
Parameter
Conditions
Min
Max
Unit
VCCI
VCCO
0.7
2.75
V
1.2
5.5
V
VI
input voltage
V
VO
output voltage
Active mode
VCCO
V
V
-40
+85
°C
ns/V
Tamb
ambient temperature
Δt/ΔV
input transition rise
and fall rate
VCCI = 0.7 V to 2.75 V
10. Static characteristics
Table 7. Static characteristics
At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
Conditions
Tamb = 25 °C
Min
Typ
Max
Min
Max
VCCI = 0.75 V to 0.85 V
0.75VCCI
0.75VCCI
V
VCCI = 1.1 V to 1.95 V
0.65VCCI
0.65VCCI
V
VCCI = 2.3 V to 2.7 V
1.6
1.6
V
0.25VCCI
0.25VCCI
V
0.35VCCI
0.35VCCI
V
0.7
0.7
V
1.05
V
IO = -2 mA; VCCO = 1.2 V
HIGH-level
output voltage I = -3 mA; V
O
CCO = 1.4 V
[1]
1.05
1.05
V
IO = -4.5 mA; VCCO = 1.65 V
1.2
1.2
V
IO = -8 mA; VCCO = 2.3 V
1.7
1.7
V
IO = -10 mA; VCCO = 3.0 V
2.2
2.2
V
IO = -12 mA; VCCO = 4.5 V
3.7
3.7
V
0.18
V
0.35
0.35
V
IO = 4.5 mA; VCCO = 1.65 V
0.45
0.45
V
IO = 8 mA; VCCO = 2.3 V
0.7
0.7
V
IO = 10 mA; VCCO = 3.0 V
0.8
0.8
V
IO = 2 mA; VCCO = 1.2 V
LOW-level
output voltage I = 3 mA; V
O
CCO = 1.4 V
[1]
IO = 12 mA; VCCO = 4.5 V
II
input leakage
current
74AXP1T32
Product data sheet
Tamb = -40 °C to +85 °C Unit
VI = 0 V to 2.75 V;
VCCI = 0 V to 2.75 V
[1]
0.8
0.8
V
±0.001
±0.1
±0.5
μA
4 / 14
74AXP1T32
Nexperia
Symbol Parameter
Conditions
Tamb = 25 °C
Min
Typ
Max
Min
Max
IOZ
OFF-state
output current
VO = 0 V to 5.5 V;
VCCO = 1.2 V to 5.5 V
±0.001
±0.1
±0.5
μA
IOFF
power-off
leakage
current
inputs; VI = 0 V to 2.75 V;
[1]
VCCI = 0 V; VCCO = 0 V to 5.5 V
±0.01
±0.1
±0.5
μA
output; VO = 0 V to 5.5 V;
VCCO = 0 V;
VCCI = 0 V to 2.75 V;
VI = 0 V to 2.75 V
[1]
±0.01
±0.1
±0.5
μA
additional
power-off
leakage
current
inputs; VI = 0 V or 2.75 V;
VCCI = 0 V to 0.1 V;
VCCO = 0 V to 5.5 V
[1]
±0.02
±0.1
±0.5
μA
output; VO = 0 V or 5.5 V;
VCCO = 0 V to 0.1 V;
VI = 0 V or 2.75 V
[1]
±0.02
±0.1
±0.5
μA
ΔIOFF
[1]
Typical values are measured at VCCI = VCCO = 1.2 V unless otherwise specified.
Table 8. Static characteristics supply current
Symbol Parameter
Conditions
ICCI
VI = 0 V or VCCI;
input supply
current
ICCO
ΔICCI
[1]
[2]
[3]
output supply
current
additional input
supply current
Unit
Typ 25 °C
Max 25 °C
Typ 85 °C
Max 85 °C
VCCI = 0.7 V to 1.3 V
[1]
1
100
10
300
nA
VCCI = 1.3 V to 2.75 V
[2]
1
100
nA
VCCI = 2.75 V; VCCO = 0 V
1
100
nA
VCCI = 0 V; VCCO = 5.5 V
1
100
1
100
nA
VI = 0 V or VCCI; IO = 0 A;
see Table 9
VCCO = 1.2 V to 3.6 V
[1]
0.001
1.0
0.01
1.2
μA
VCCO = 3.6 V to 5.5 V
[3]
0.8
1.5
1.0
1.8
μA
0.001
0.1
0.003
0.2
μA
VCCI = 0 V; VCCO = 3.6 V
0.2
0.6
0.3
0.8
μA
0.4
0.8
0.5
1.0
μA
2
100
14
150
μA
VI = VCCI - 0.5 V; VCCI = 2.5 V
Typical values are measured at VCCI = VCCO = 2.5 V.
Typical values are measured at VCCI = 1.2 V and VCCO = 5.0 V.
Table 9. Typical output supply current (ICCO)
VCCI
VCCO
Unit
0V
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
5.0 V
0V
5
200
400
nA
0.8 V
1
10
150
200
300
500
800
nA
1.2 V
1
1
5
200
300
500
800
nA
1.5 V
1
1
5
100
300
500
800
nA
1.8 V
1
1
5
100
300
500
800
nA
2.5 V
1
1
5
100
100
500
800
nA
74AXP1T32
Product data sheet
5 / 14
74AXP1T32
Nexperia
11. Dynamic characteristics
Table 10. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit, see Fig. 11; for waveform, see Fig. 4.
Symbol Parameter
Conditions
VCCO
1.2 V
Unit
1.5 V ± 0.1 V
1.8 V ± 0.15 V
Typ[1]
Min
Typ[1]
Max
Min
Typ[1]
Max
23
3
18
73
3
16
69
ns
VCCI = 1.1 V to 1.3 V
16.9
3.1
10.8
19.9
2.8
8.7
15.9
ns
VCCI = 1.4 V to 1.6 V
16.0
2.8
9.9
18.2
2.5
7.8
13.2
ns
VCCI = 1.65 V to 1.95 V
15.6
2.7
9.5
17.3
2.4
7.3
11.8
ns
15.2
2.5
9.0
16.8
2.2
6.9
11.0
ns
23
3
18
148
3
16
145
ns
16.9
3.1
10.8
19.9
2.8
8.7
15.9
ns
16.0
2.8
9.9
18.2
2.5
7.8
13.2
ns
15.6
2.7
9.5
17.3
2.4
7.3
11.8
ns
15.2
2.5
9.0
16.8
2.2
6.9
11.0
ns
1.0
1.0
ns
Tamb = 25 °C
[2]
propagation A, B to Y
delay
tpd
[2]
delay
tpd
tt
[1]
[2]
[3]
transition
time
VCCI = 0.75 V to 2.7 V
[3]
Typical values are measured at nominal supply voltages and Tamb = +25 °C.
tpd is the same as tPLH and tPHL.
tt is the same as tTHL and tTLH.
Table 11. Dynamic characteristics
Symbol Parameter
Conditions
VCCO
Unit
2.5 V ± 0.2 V
3.3 V ± 0.3 V
5.0 V ± 0.5 V
Min Typ[1] Max
Min Typ[1] Max
Min Typ[1] Max
Tamb = 25 °C
tpd
[2]
delay
2
14
69
2
14
77
2
15
89
ns
2.4
6.9
10.9
2.2
6.3
9.6
2.1
6.0
9.1
ns
2.1
6.0
9.1
2.0
5.4
8.2
1.9
5.0
7.7
ns
2.0
5.6
8.6
1.8
4.9
7.6
1.8
4.6
7.2
ns
1.9
5.1
8.0
1.7
4.5
7.0
1.6
4.1
6.5
ns
2
14
164
2
14
191
2
15
222 ns
2.4
6.9
10.9
2.2
6.3
9.6
2.1
6.0
9.1
ns
2.1
6.0
9.1
2.0
5.4
8.2
1.9
5.0
7.7
ns
2.0
5.6
8.6
1.8
4.9
7.6
1.8
4.6
7.2
ns
1.9
5.1
8.0
1.7
4.5
7.0
1.6
4.1
6.5
ns
tpd
[2]
delay
74AXP1T32
Product data sheet
6 / 14
74AXP1T32
Nexperia
Symbol Parameter
tt
[1]
[2]
[3]
transition
time
Conditions
VCCO
[3]
Unit
2.5 V ± 0.2 V
3.3 V ± 0.3 V
5.0 V ± 0.5 V
Min Typ[1] Max
Min Typ[1] Max
Min Typ[1] Max
1.0
1.0
1.0
ns
Typical values are measured at nominal supply voltages and tamb = +25 °C.
Table 12. Typical dynamic characteristics at Tamb = 25 °C
Symbol Parameter
CPD
power
dissipation
capacitance
Conditions
VCCO
Unit
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
5.0 V
VCCI = 0.8 V
0.5
0.5
0.5
0.5
0.5
0.5
pF
VCCI = 1.2 V
0.5
0.5
0.5
0.5
0.5
0.5
pF
VCCI = 1.5 V
0.5
0.5
0.5
0.5
0.5
0.5
pF
VCCI = 1.8 V
0.6
0.6
0.6
0.6
0.6
0.6
pF
VCCI = 2.5 V
0.8
0.8
0.8
0.8
0.8
0.8
pF
VCCI = 0.8 V
6.7
6.8
6.8
6.9
7.5
9.5
pF
VCCI = 1.2 V
6.8
6.9
7.0
7.0
7.1
7.6
pF
VCCI = 1.5 V
6.9
6.9
6.9
7.0
7.1
7.6
pF
VCCI = 1.8 V
6.9
6.9
6.9
7.0
7.2
7.6
pF
VCCI = 2.5 V
6.9
7.0
7.0
7.0
7.2
7.6
pF
fi = 1 MHz; RL = ∞ Ω; VI = 0 V to VCCI
[1]
input supply
[2]
output supply
[3]
CI
input
capacitance
VI = 0 V or VCCI; VCCI = 0 V to 2.7 V
0.6
0.6
0.6
0.6
0.6
0.6
pF
CO
output
capacitance
VO = 0 V; VCCO = 0 V
1.8
1.8
1.8
1.8
1.8
1.8
pF
[1]
[2]
[3]
CPD is used to determine the dynamic power dissipation (PD in μW).
Power dissipated from input supply (VCCI)
2
PD = CPD x VCCI × fi x N where:
CPD = power dissipation capacitance of the input supply.
VCCI = input supply voltage in V;
fi = input frequency in MHz;
N = number of inputs switching;
Power dissipated from output supply (VCCO)
2
PD = (CL + CPD) x VCCO x fo where:
CL = load capacitance in pF;
CPD = power dissipation capacitance of the output supply.
VCCO = output supply voltage in V;
fo = output frequency in MHz;
74AXP1T32
Product data sheet
7 / 14
74AXP1T32
Nexperia
11.1. Waveform, graphs and test circuit
VI
A, B input
VM
VM
GND
tPLH
VOH
tPHL
90 %
Y output
90 %
VM
VM
10 %
VOL
10 %
tTLH
tTHL
aaa-025602
Measurement points are given in Table 13.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 4.
Input A, B to output Y propagation delay times and output transition times
Table 13. Measurement points
Supply voltage
Output
Input
VCCI
VCCO
VM
VM
VI
0.75 V to 2.7 V
1.2 V to 5.5 V
0.5VCCO
0.5VCCI
VCCI
aaa-018538
6
tpd
(ns)
aaa-018539
6
(3)
tpd
(ns)
(3)
(2)
(2)
4
4
(1)
(1)
2
2
60
90
CL (pF)
Tamb = -40 °C to +85 °C unless otherwise specified.
(1) Minimum: VCCO = 5.5 V
(2) Typical: Tamb = 25 °C; VCCO = 5 V
(3) Maximum: VCCO = 4.5 V
Fig. 5.
Additional propagation delay versus load
capacitance
74AXP1T32
Product data sheet
60
90
CL (pF)
120
(1) Minimum: VCCO = 3.6 V
(2) Typical: Tamb = 25 °C; VCCO = 3.3 V
(3) Maximum: VCCO = 3 V
Fig. 6.
capacitance
8 / 14
74AXP1T32
Nexperia
aaa-018540
(3)
8
aaa-018541
12
(3)
tpd
(ns)
tpd
(ns)
6
(2)
4
8
(2)
(1)
(1)
4
2
60
90
CL (pF)
(1) Minimum: VCCO = 2.7 V
(2) Typical: Tamb = 25 °C; VCCO = 2.5 V
(3) Maximum: VCCO = 2.3 V
Fig. 7.
capacitance
60
90
CL (pF)
120
(1) Minimum: VCCO = 1.95 V
(2) Typical: Tamb = 25 °C; VCCO = 1.8 V
(3) Maximum: VCCO = 1.65 V
Fig. 8.
capacitance
aaa-018542
18
(3)
tpd
(ns)
aaa-018543
18
12
tpd
(ns)
(2)
12
6
(1)
6
60
90
CL (pF)
120
(1) Minimum: VCCO = 1.6 V
(2) Typical: Tamb = 25 °C; VCCO = 1.5 V
(3) Maximum: VCCO = 1.4 V
Fig. 9.
capacitance
74AXP1T32
Product data sheet
60
90
CL (pF)
120
Tamb = 25 °C; VCCO = 1.2 V.
Fig. 10. Additional propagation delay versus load
capacitance
9 / 14
74AXP1T32
Nexperia
tW
VI
90 %
negative
pulse
VM
VM
10 %
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
VM
VM
10 %
0V
tW
VCCI VCCO
PULSE
GENERATOR
VI
DUT
VO
RT
CL
RL
aaa-018544
Test data is given in Table 14.
Definitions test circuit:
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
RL = Load resistance.
Fig. 11. Test circuit for measuring switching times
Table 14. Test data
Supply voltage
Load
Input
VCCI
VCCO
CL
RL
tr, tf
VI
0.75 V to 2.7 V
1.2 V to 5.5 V
5 pF
5 kΩ
≤3.0 ns
VCCI
74AXP1T32
Product data sheet
10 / 14
74AXP1T32
Nexperia
12. Package outline
X2SON6: plastic thermal enhanced extremely thin small outline package; no leads;
SOT1255
X
A
D
B
A
pin 1
ID area
E
A1
detail X
C
e1
b
(4x)
4
3
y1 C
A B
v
y
L
(4x)
2
5
Dh
(2x)
1
6
e2
1 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
A1
D
Dh
E
e1
e2
b
L
v
y
y1
max 0.35 0.04 1.05 0.30 0.85
0.30 0.25
nom 0.32 0.02 1.00 0.25 0.80 0.60 0.40 0.25 0.20 0.10 0.05 0.05
0.22 0.17
min 0.30 0.00 0.95 0.22 0.75
sot1255_po
Outline
version
References
IEC
JEDEC
JEITA
European
projection
Issue date
15-07-20
15-07-22
SOT1255
Fig. 12. Package outline SOT1255 (X2SON6)
74AXP1T32
Product data sheet
11 / 14
74AXP1T32
Nexperia
13. Abbreviations
Table 15. Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
14. Revision history
Table 16. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AXP1T32 v.2
20190322
Product data sheet
74AXP1T32 v.1
Modifications:
74AXP1T32 v.1
74AXP1T32
Product data sheet
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74AXP1T32GW (SOT363) removed.
20161107
Product data sheet
12 / 14
74AXP1T32
Nexperia
15. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74AXP1T32
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
13 / 14
74AXP1T32
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................2
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................2
6.1. Pinning.........................................................................2
6.2. Pin description............................................................. 3
7. Functional description................................................. 3
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................4
10. Static characteristics..................................................4
11. Dynamic characteristics.............................................6
11.1. Waveform, graphs and test circuit............................. 8
12. Package outline........................................................ 11
13. Abbreviations............................................................ 12
14. Revision history........................................................12
15. Legal information......................................................13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 22 March 2019
74AXP1T32
Product data sheet
14 / 14
