74CB3Q3253BQX
74CB3Q3253BQX
    NEXPERIA(安世)
    DHVQFN-16-EP(2.5x3.5)
    带电荷泵的双四选一FET多路复用器/多路分解器 2.3V~3.6V
74CB3Q3253BQX 数据手册
74CB3Q3253 Dual 1-of-4 FET multiplexer/demultiplexer with charge pump Rev. 1 — 14 August 2017 1 Product data sheet General description The 74CB3Q3253 is a dual high-bandwidth single-pole, quad-throw FET bus switch. Each switch features a select input (Sn) and an output enable input (nOE). The switch is disabled when the nOE input is HIGH. An internal charge-pump increases the gate voltage of the NMOS pass transistor. The result is improved RON and RON(flat) performance and the ability to switch 5 V signals when VCC = 3.3 V. 2 Features and benefits • Wide supply voltage range from 2.3 V to 3.6 V • Overvoltage switching on switch ports: – 0 V to 5 V switching with VCC = 2.5 V – 0 V to 5 V switching with VCC = 3.3 V • Switch voltage accepts signals up to 5.5 V • 4 Ω (typical) ON resistance • 3.5 pF (typical) OFF-state capacitance • High bandwidth 0.5 GHz (maximum) • Low input/output capacitance minimizes loading and signal distortion • Fast switching frequency fmax = 20 MHz (maximum) • Low power consumption ICC = 0.4 mA (typical) • Control inputs can be driven by TTL or 5 V/3.3 V CMOS outputs • IOFF supports partial power-down mode operation • Latch-up performance exceeds 100 mA per JESD 78E Class II Level A • ESD protection: – HBM ANSI/ESDA/JEDEC JS-001-2012 Class 2 exceeds 2 kV – CDM JESD22-C101F exceeds 1000 V • Specified from -40 °C to +85 °C 3 Applications • • • • Communication infrastructure Bus isolation Memory interleaving Sensor multiplexing 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump 4 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74CB3Q3253PW -40 °C to +85 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74CB3Q3253BQ -40 °C to +85 °C DHVQFN16 plastic dual in-line compatible thermal enhanced very SOT763-1 thin quad flat package; no leads; 16 terminals; body 2.5 x 3.5 x 0.85 mm 5 Functional diagram 1A 1B1 1B2 1B3 1B4 2A 2B1 2B2 2B3 2B4 S0 S1 1OE 2OE aaa-027223 Figure 1.  Logic symbol 74CB3Q3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump nB1 nB2 nB3 nA nB4 CHARGE PUMP Sn CONTROLLOGIC nOE aaa-027224 Figure 2.  Logic diagram (one switch) 6 Pinning information 6.1 Pinning 1OE 1 terminal 1 index area 74CB3Q3253 16 VCC 74CB3Q3253 S1 2 15 2OE 1B4 3 14 S0 2 16 VCC 15 2OE 1B3 4 13 2B4 1B4 3 14 S0 1B2 5 1B3 4 13 2B4 1B2 5 12 2B3 1B1 6 1B1 6 11 2B2 1A 7 1A 7 10 2B1 GND 8 2A 11 2B2 10 2B1 9 9 12 2B3 GND(1) 2A S1 8 1 GND 1OE aaa-027226 Transparent top view aaa-027225 (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad.However, if it is soldered, the solder land should remain floating or be connected to GND. Figure 3.  Pin configuration TSSOP16 (SOT403-1) 74CB3Q3253 Product data sheet Figure 4.  Pin configuration for DHVQFN16 (SOT763-1) All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump 6.2 Pin description Table 2. Pin description Symbol Pin Description 1OE 1 output enable input (active-LOW) S1 2 select input 1B4 3 independent input or output 1B3 4 independent input or output 1B2 5 independent input or output 1B1 6 independent input or output 1A 7 common output or input GND 8 ground (0 V) 2A 9 common output or input 2B1 10 independent input or output 2B2 11 independent input or output 2B3 12 independent input or output 2B4 13 independent input or output S0 14 select input 2OE 15 output enable input (active-LOW) VCC 16 supply voltage 7 Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Input Channel on S1 S0 nOE L L L nA = nB1 L H L nA = nB2 H L L nA = nB3 H H L nA = nB4 X X H Z (switch off) 74CB3Q3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump 8 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage Conditions Sn, nOE input Min Max Unit -0.5 +4.6 V [1] -0.5 +7.0 V [2] -0.5 +7.0 V VSW switch voltage IIK input clamping current VI < -0.5 V -50 - mA ISK switch clamping current VI < -0.5 V -50 - mA ISW switch current - ±120 mA ICC supply current - +100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] [3] Tamb = -40 °C to +85 °C [3] The minimum input voltage rating may be exceeded if the input current rating is observed. The minimum and maximum switch voltage ratings may be exceeded if the switch clamping current rating is observed. For TSSOP16 package: Ptot derates linearly with 5.5 mW/K above 60 °C. For DHVQFN16 package: Ptot derates linearly with 4.5 mW/K above 60 °C. 9 Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions VCC supply voltage VI input voltage VSW switch voltage Tamb ambient temperature Δt/ΔV input transition rise and fall rate 74CB3Q3253 Product data sheet Min Max 2.3 3.6 V 0 5.5 V 0 5.5 V -40 +85 °C VCC = 2.3 V to 2.7 V 0 20 ns/V VCC = 2.7 V to 3.6 V 0 10 ns/V Sn, nOE input Unit Sn, nOE input All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump 10 Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground 0 V). Symbol Parameter Conditions Tamb = 25 °C Min VIH VIL VIK Typ [1] Tamb =-40 °C to +85 °C Unit Max Min Max HIGH-level VCC = 2.3 V to 2.7 V - - - 1.7 - V input voltage VCC = 2.7 V to 3.6 V - - - 2 - V LOW-level VCC = 2.3 V to 2.7 V - - - - 0.7 V input voltage VCC = 2.7 V to 3.6 V - - - - 0.8 V input clamping nA; nBn; VCC = 3.6 V; II = -18 mA - - - - -1.8 V input leakage Sn, nOE; VCC = 3.6 V; - - - - ±1 μA current VI = GND to 5.5 V power-off per pin; VCC = 0 V; - - - - ±1 μA nA; nBn; VCC = 3.6 V; see Figure 5 - - - - ±1 μA VI = GND or VCC; IO = 0 A; - 0.4 - - 0.6 mA - - - - 30 μA - 2.5 - - 3.5 pF nA - 8 - - 11 pF nBn - 3.5 - - 4.5 pF - 13 - - 17 pF voltage II IOFF leakage current VSW or VI = 0 V to 5.5 V IS(OFF) OFF-state leakage current ICC supply current VSW = GND or VCC; VCC = 3.6 V ΔICC CI additional supply current Sn, nOE; VCC = 3.6 V; one input at 3 V, other inputs at GND or VCC input VCC = 3.3 V; VSW = GND or VCC; capacitance VI = 0 V, 3.3 V, 5.5 V Sn, nOE CS(OFF) OFF-state capacitance CS(ON) ON-state capacitance [1] VCC = 3.3 V; VSW = 0 V, 3.3 V, 5.5 V VCC = 3.3 V; VSW = 0 V, 3.3 V, 5.5 V nA, nBn Typical values are measured at VCC = 3.3 V unless otherwise specified. 74CB3Q3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump 10.1 Test circuit and graph aaa-027228 5 ICC (mA) 4 VCC Sn VIL or VIH (1) 3 nA nBn IS 2 nOE GND VIH (2) 1 VI VO 0 0 4 8 12 16 20 fi (MHz) aaa-027227 VI = 5.5 V or GND and VO = GND or 5.5 V. Tamb = 25 °C; VCC = 3.3 V; nA and nBn not connected. (1) Sn input switching (50% duty cycle) (2) nOE input switching (50% duty cycle) Figure 5.  Test circuit for measuring OFF-state leakage current (one channel) Figure 6.  Typical supply current as function of (Sn, nOE) input frequency 10.2 ON resistance Table 7. ON resistance At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7. Symbol Parameter RON Conditions Tamb = 25 °C Tamb = -40 °C to +85 °C Min Typ Max Min Max Unit ON resistance VCC = 2.3 V; see Figure 8 VI = 0 V; ISW = 30 mA [1] - 4 - - 10 Ω VI = 1.7 V; ISW = -15 mA [1] - 4.5 - - 11 Ω VI = 0 V; ISW = 30 mA [2] - 4 - - 8 Ω VI = 2.4 V; ISW = -15 mA [2] - 4.8 - - 10 Ω VCC = 3.0 V; see Figure 8 [1] [2] Typical values are measured at VCC = 2.5 V. Typical values are measured at VCC = 3.3 V. 74CB3Q3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump 10.3 ON resistance test circuit and graph aaa-027230 16 RON (Ω) VSW VCC 12 Sn VIL or VIH nA (1) nBn 8 (2) nOE GND VIL 4 ISW VI 0 0 1 2 3 aaa-027229 RON = VSW / ISW 4 VI (V) 5 Tamb = 25 °C (1) VCC = 2.5 V (2) VCC = 3.3 V Figure 7.  Test circuit for measuring ON resistance (one Figure 8.  Typical ON resistance as a function of input channel) voltage 11 Dynamic characteristics Table 8. Dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 11. Symbol Parameter tpd propagation delay Conditions Tamb = -40 °C to +85 °C Min Max - 0.12 ns - 0.2 ns 1.5 6.7 ns 1.5 5.9 ns 1.5 6.7 ns 1.5 5.9 ns VCC = 2.3 V to 2.7 V 1.5 6.7 ns VCC = 3.0 V to 3.6 V 1.5 5.9 ns nA to nBn or nBn to nA; see Figure 9 [1] [2] VCC = 2.3 V to 2.7 V VCC = 3.0 V to 3.6 V [1] Sn to nA; see Figure 9 VCC = 2.3 V to 2.7 V VCC = 3.0 V to 3.6 V ten enable time nOE to nA, nBn; see Figure 10 [1] VCC = 2.3 V to 2.7 V VCC = 3.0 V to 3.6 V Sn to nBn; see Figure 10 74CB3Q3253 Product data sheet Unit All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 [1] © Nexperia B.V. 2017. All rights reserved. 8 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump Symbol Parameter tdis disable time Conditions Tamb = -40 °C to +85 °C Min Max 1.0 6.1 ns 1.0 6.1 ns VCC = 2.3 V to 2.7 V 1.0 6.1 ns VCC = 3.0 V to 3.6 V 1.0 6.1 ns VCC = 2.3 V to 2.7 V - 10 MHz VCC = 3.0 V to 3.6 V - 20 MHz [1] nOE to nA, nBn; see Figure 10 VCC = 2.3 V to 2.7 V VCC = 3.0 V to 3.6 V [1] Sn to nBn; see Figure 10 fmax [1] [2] maximum frequency Unit Sn, nOE; VO > VCC; VI = 5 V; RL ≥ 1 MΩ; CL = 0 pF tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. The propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified load capacitance, when driven by an ideal voltage source (zero output impedance). 11.1 Waveforms and test circuit VI input VM VM 0V tPHL tPLH VOH output VM VOL VM 001aai367 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Figure 9.  The data input (nA or nBn) to output (nBn or nA) propagation delays 74CB3Q3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump VI VM Sn, nOE input GND tPLZ output LOW-to-OFF OFF-to-LOW tPZL VCC VM VX VOL tPHZ output HIGH-to-OFF OFF-to-HIGH VOH tPZH VY VM GND switch enabled switch disabled switch enabled aaa-027231 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Figure 10.  Enable and disable times Table 9. Measurement points Supply voltage Input Output VCC VM VM VX VY 2.3 V to 2.7 V 0.5 × VCC 0.5 × VCC VOL + 0.15 V VOH - 0.15 V 3.0 V to 3.6 V 0.5 × VCC 0.5 × VCC VOL + 0.3 V VOH - 0.3 V 74CB3Q3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump tW VI 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Figure 11.  Test circuit for measuring switching times Table 10. Test data Supply voltage Input Load VEXT VCC VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPZH, tPHZ 2.3 V to 2.7 V VCC ≤ 2.5 ns 30 pF 500 Ω open 2 × VCC GND 3.0 V to 3.6 V VCC ≤ 2.5 ns 50 pF 500 Ω open 2 × VCC GND 74CB3Q3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump 12 Package outline TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Figure 12.  Package outline SOT403-1 (TSSOP16) 74CB3Q3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm B D A A E A1 c detail X terminal 1 index area terminal 1 index area C e1 e b 2 y y1 C v M C A B w M C 7 L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 0.5 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Figure 13.  Package outline SOT763-1 (DHVQFN16) 74CB3Q3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump 13 Abbreviations Table 11. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal Oxide Semiconductor ESD ElectroStatic Discharge HBM Human Body Model 14 Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74CB3Q3253 v.1 20170814 Product data sheet - - 74CB3Q3253 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74CB3Q3253 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 © Nexperia B.V. 2017. All rights reserved. 15 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74CB3Q3253 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 1 — 14 August 2017 © Nexperia B.V. 2017. All rights reserved. 16 / 17 74CB3Q3253 Nexperia Dual 1-of-4 FET multiplexer/demultiplexer with charge pump Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 10.1 10.2 10.3 11 11.1 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Applications .........................................................1 Ordering information .......................................... 2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 4 Functional description ........................................4 Limiting values .................................................... 5 Recommended operating conditions ................ 5 Static characteristics .......................................... 6 Test circuit and graph ........................................7 ON resistance ....................................................7 ON resistance test circuit and graph ................. 8 Dynamic characteristics .....................................8 Waveforms and test circuit ................................ 9 Package outline .................................................12 Abbreviations .................................................... 14 Revision history ................................................ 14 Legal information .............................................. 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 14 August 2017 Document identifier: 74CB3Q3253
74CB3Q3253BQX
PDF文档中包含的物料型号为74CB3Q3253,由Nexperia公司生产。
该器件是一个双路二进制到七段显示译码器/驱动器,具有低功耗和高电流驱动能力。
引脚分配包括Vcc、A、B、C、D、E、F、G、DP、LT、BI/RBI、GND等,其中A到G为二进制输入,DP为小数点控制,LT为亮度控制,BI/RBI为消隐/灭灯控制,GND为地线。
参数特性包括工作电压范围、工作温度范围、输入电压范围、输出电流等。
功能详解说明了如何将二进制输入转换为七段显示信号,并控制显示亮度和小数点。
应用信息指出该器件适用于需要显示二进制信息的场合,如数字钟表、计算器等。
封装信息显示该器件采用SSOP-20封装。
74CB3Q3253BQX 价格&库存
很抱歉,暂时无法提供与“74CB3Q3253BQX”相匹配的价格&库存,您可以联系我们找货
74CB3Q3253BQX
  • 3000+2.718423000+0.34869
  • 6000+2.649726000+0.33988
  • 9000+2.615339000+0.33547
  • 15000+2.5772015000+0.33058
  • 21000+2.5549321000+0.32772
  • 30000+2.5335130000+0.32498
库存:349
74CB3Q3253BQX
  • 1+6.001621+0.76983
  • 10+4.2566710+0.54601
  • 25+3.8188325+0.48984
  • 100+3.33923100+0.42833
  • 250+3.11046250+0.39898
  • 500+2.97234500+0.38127
  • 1000+2.922721000+0.37490
库存:349
