74CB3Q3257
4-bit 1-of-2 FET multiplexer/demultiplexer with charge pump
Rev. 1 — 14 August 2017
1
Product data sheet
General description
The 74CB3Q3257 is a quad high-bandwidth single-pole, double-throw FET bus switch.
The device features one select input (S) and one output enable input (OE). The switch is
disabled when the OE input is HIGH. An internal charge-pump increases the gate voltage
of the NMOS pass transistor. The result is improved RON and RON(flat) performance and
the ability to switch 5 V signals when VCC = 3.3 V.
2
Features and benefits
• Wide supply voltage range from 2.3 V to 3.6 V
• Overvoltage switching on switch ports:
– 0 V to 5 V switching with VCC = 2.5 V
– 0 V to 5 V switching with VCC = 3.3 V
• 4 Ω (typical) ON resistance
• 3.5 pF (typical) OFF-state capacitance
• High bandwidth 0.5 GHz (maximum)
• Low input/output capacitance minimizes loading and signal distortion
• Fast switching frequency fmax = 20 MHz (maximum)
• Low power consumption ICC = 0.4 mA (typical)
• Control inputs can be driven by TTL or 5 V/3.3 V CMOS outputs
• IOFF supports partial power-down mode operation
• Latch-up performance exceeds 100 mA per JESD 78E Class II Level A
• ESD protection:
– HBM ANSI/ESDA/JEDEC JS-001-2012 Class 2 exceeds 2 kV
– CDM JESD22-C101F exceeds 1000 V
• Specified from -40 °C to +85 °C
3
Applications
Communication infrastructure
Bus isolation
Memory interleaving
Sensor multiplexing
74CB3Q3257
Nexperia
4
Ordering information
Table 1. Ordering information
Type number
74CB3Q3257PW
Package
Temperature
range
Name
Description
Version
-40 °C to +85 °C
TSSOP16
plastic thin shrink small outline package; 16 leads;
SOT403-1
body width 4.4 mm
74CB3Q3257BQ
-40 °C to +85 °C
DHVQFN16
plastic dual in-line compatible thermal enhanced very SOT763-1
thin quad flat package; no leads; 16 terminals;
body 2.5 x 3.5 x 0.85 mm
5
Functional diagram
1A
1B1
1B2
2A
2B1
2B2
3A
3B1
3B2
4A
4B1
4B2
S
OE
aaa-027232
Figure 1. Logic symbol
74CB3Q3257
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2017. All rights reserved.
2 / 17
74CB3Q3257
Nexperia
nB1
nA
nB2
CHARGE
PUMP
S
CONTROLLOGIC
OE
aaa-027233
Figure 2. Logic diagram (one switch)
6
Pinning information
6.1 Pinning
1
S
terminal 1
index area
74CB3Q3257
16 VCC
74CB3Q3257
1B1
2
15 OE
1B2
3
14 4B1
2
16 VCC
15 OE
1A
4
13 4B2
1B2
3
14 4B1
2B1
5
1A
4
13 4B2
2B1
5
12 4A
2B2
6
2B2
6
11 3B1
2A
7
2A
7
10 3B2
GND
8
3A
11 3B1
10 3B2
9
9
12 4A
GND(1)
3A
1B1
8
1
GND
S
aaa-027235
Transparent top view
aaa-027234
(1) This is not a supply pin. The substrate is attached
to this pad using conductive die attach material. There
is no electrical or mechanical requirement to solder this
pad.However, if it is soldered, the solder land should remain
floating or be connected to GND.
Figure 3. Pin configuration TSSOP16 (SOT403-1)
74CB3Q3257
Product data sheet
Figure 4. Pin configuration for DHVQFN16 (SOT763-1)
3 / 17
74CB3Q3257
Nexperia
6.2 Pin description
Table 2. Pin description
Symbol
Pin
Description
S
1
select input
1B1
2
independent input or output
1B2
3
1A
4
common output or input
2B1
5
2B2
6
2A
7
GND
8
ground (0 V)
3A
9
3B2
10
3B1
11
4A
12
4B2
13
4B1
14
OE
15
output enable input (active-LOW)
VCC
16
supply voltage
7
Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Input
Channel on
S
OE
L
L
nA = nB1
H
L
nA = nB2
X
H
Z (switch off)
74CB3Q3257
Product data sheet
4 / 17
74CB3Q3257
Nexperia
8
Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
Conditions
S, OE input
Min
Max
Un
it
-0.5
+4.6
V
[1]
-0.5
+7.0
V
[2]
-0.5
+7.0
V
VSW
switch voltage
IIK
input clamping current
VI < -0.5 V
-50
mA
ISK
switch clamping current
VI < -0.5 V
-50
mA
ISW
switch current
±120
mA
ICC
supply current
+100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
500
mW
Min
Max
Unit
2.3
3.6
V
V
V
-40
+85
°C
VCC = 2.3 V to 2.7 V
ns/V
VCC = 2.7 V to 3.6 V
ns/V
Ptot
[1]
[2]
[3]
total power dissipation
Tamb = -40 °C to +85 °C
[3]
The minimum input voltage rating may be exceeded if the input current rating is observed.
The minimum and maximum switch voltage ratings may be exceeded if the switch clamping current rating is observed.
For TSSOP16 package: Ptot derates linearly with 5.5 mW/K above 60 °C.
For DHVQFN16 package: Ptot derates linearly with 4.5 mW/K above 60 °C.
9
Recommended operating conditions
Table 5. Recommended operating conditions
Symb
ol
Parameter
VCC
supply voltage
VI
input voltage
VSW
switch voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
74CB3Q3257
Product data sheet
Conditions
S, OE input
S, OE input
5 / 17
74CB3Q3257
Nexperia
10 Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground 0 V).
Symbol Parameter
Conditions
Tamb = 25 °C
Min
Typ
[1]
Tamb =-40 °C to +85°C Unit
Max
Min
Max
HIGH-level
input voltage
1.7
V
2
V
LOW-level
input voltage
0.7
V
0.8
V
VIK
input clamping
voltage
nA, nBn; VCC = 3.6 V; II = -18 mA
-1.8
V
II
input leakage
current
S, OE; VCC = 3.6 V;
VI = GND to 5.5 V
±1
μA
IOFF
power-off
per pin; VCC = 0 V;
leakage current VSW or VI = 0 V to 5.5 V
±1
μA
IS(OFF)
OFF-state
nA, nBn; VCC = 3.6 V; see Figure 5
leakage current
±1
μA
ICC
supply current
VI = GND or VCC; IO = 0 A;
VSW = GND or VCC; VCC = 3.6 V
0.4
0.6
mA
ΔICC
additional
supply current
S, OE; VCC = 3.6 V; one input at
3 V, other inputs at GND or VCC
30
μA
CI
input
capacitance
VCC = 3.3 V; VSW = GND or VCC;
VI = 0 V, 3.3 V, 5,5 V
2.5
3.5
pF
nA
5.5
7
pF
nBn
3.5
5
pF
10.5
13
pF
VIH
VIL
S, OE
CS(OFF)
CS(ON)
OFF-state
capacitance
ON-state
capacitance
VCC = 3.3 V; VSW = 0 V, 3.3 V, 5.5 V
VCC = 3.3 V;
nA, nBn
[1]
Typical values are measured at VCC = 3.3 V unless otherwise specified.
74CB3Q3257
Product data sheet
6 / 17
74CB3Q3257
Nexperia
10.1 Test circuit and graph
aaa-027237
10
ICC
(mA)
8
VCC
S
VIL or VIH
6
nA
nBn
(1)
IS
4
OE
(2)
GND
VIH
2
VI
VO
8
12
16
fi (MHz)
aaa-027236
VI = 5.5 V or GND and VO = GND or 5.5 V
Tamb = 25 °C; VCC = 3.3 V; nA and nBn not connected.
(1) S input switching (50% duty cycle)
(2) OE input switching (50% duty cycle)
Figure 5. Test circuit for measuring OFF-state leakage
current (one channel)
Figure 6. Typical supply current as function of (S, OE)
input frequency
10.2 ON resistance
Table 7. ON resistance
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7.
Symbol Parameter
RON
Conditions
Tamb = 25 °C
Min
Typ
Max
Min
Max
Unit
ON resistance VCC = 2.3 V; see Figure 8
VI = 0 V; ISW = 30 mA
[1]
4
8
Ω
VI = 1.7 V; ISW = -15 mA
[1]
4.4
9
Ω
[2]
4
6
Ω
VI = 2.4 V; ISW = -15 mA
[2]
4.7
8
Ω
VCC = 3.0 V; see Figure 8
[1]
[2]
Typical values are measured at VCC = 2.5 V.
Typical values are measured at VCC = 3.3 V.
74CB3Q3257
Product data sheet
7 / 17
74CB3Q3257
Nexperia
10.3 ON resistance test circuit and graph
aaa-027239
16
RON
(Ω)
VSW
VCC
12
S
VIL or VIH
nA
nBn
(1)
8
(2)
OE
GND
VIL
4
ISW
VI
2
3
aaa-027238
RON = VSW / ISW
4
VI (V)
5
Tamb = 25 °C
(1) VCC = 2.5 V
(2) VCC = 3.3 V
Figure 7. Test circuit for measuring ON resistance (one Figure 8. Typical ON resistance as a function of input
channel)
voltage
11 Dynamic characteristics
Table 8. Dynamic characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 11.
Symbol Parameter
tpd
propagation
delay
Conditions
Min
Max
0.12
ns
VCC = 3.0 V to 3.6 V
0.20
ns
1.5
6.5
ns
1.5
5.5
ns
nA to nBn or nBn to nA; see Figure 9
[1] [2]
[1]
S to nA; see Figure 9
74CB3Q3257
Product data sheet
Unit
8 / 17
74CB3Q3257
Nexperia
Symbol Parameter
ten
enable time
Conditions
Min
Max
1.5
6.5
ns
1.5
5.5
ns
1.5
6.5
ns
1.5
5.5
ns
1.0
6.0
ns
1.0
6.0
ns
1.0
6.0
ns
1.0
6.0
ns
10
MHz
MHz
[1]
OE to nA, nBn; see Figure 10
[1]
S to nBn; see Figure 10
tdis
disable time
[1]
[1]
fmax
maximum
frequency
[1]
[2]
Unit
S, OE; VO > VCC; VI = 5 V; RL ≥ 1 MΩ; CL = 0 pF
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
The propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified load capacitance, when driven by an
ideal voltage source (zero output impedance).
11.1 Waveforms and test circuit
VI
input
VM
VM
0V
tPHL
tPLH
VOH
output
VM
VOL
VM
001aai367
Measurement points are given in Table 9.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Figure 9. The data input (nA or nBn) to output (nBn or nA) propagation delays
74CB3Q3257
Product data sheet
9 / 17
74CB3Q3257
Nexperia
VI
VM
S, OE input
GND
tPLZ
output
LOW-to-OFF
OFF-to-LOW
tPZL
VCC
VM
VX
VOL
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
tPZH
VY
VM
GND
switch
enabled
switch
disabled
switch
enabled
aaa-027240
Figure 10. Enable and disable times
Table 9. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
VY
2.3 V to 2.7 V
0.5 × VCC
0.5 × VCC
VOL + 0.15 V
VOH - 0.15 V
3.0 V to 3.6 V
0.5 × VCC
0.5 × VCC
VOL + 0.3 V
VOH - 0.3 V
74CB3Q3257
Product data sheet
10 / 17
74CB3Q3257
Nexperia
tW
VI
90 %
negative
pulse
VM
VM
10 %
0V
tf
tr
tr
VI
tf
90 %
positive
pulse
VM
VM
10 %
0V
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Figure 11. Test circuit for measuring switching times
Table 10. Test data
Supply voltage Input
Load
VEXT
VCC
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPZH, tPHZ
2.3 V to 2.7 V
VCC
≤ 2.5 ns
30 pF
500 Ω
open
2 × VCC
GND
3.0 V to 3.6 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
74CB3Q3257
Product data sheet
11 / 17
74CB3Q3257
Nexperia
12 Package outline
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Figure 12. Package outline SOT403-1 (TSSOP16)
74CB3Q3257
Product data sheet
12 / 17
74CB3Q3257
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
B
D
A
A
E
A1
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
b
2
y
y1 C
v M C A B
w M C
7
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
0.5
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Figure 13. Package outline SOT763-1 (DHVQFN16)
74CB3Q3257
Product data sheet
13 / 17
74CB3Q3257
Nexperia
13 Abbreviations
Table 11. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal Oxide Semiconductor
ESD
ElectroStatic Discharge
HBM
Human Body Model
14 Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74CB3Q3257 v.1
20170814
Product data sheet
74CB3Q3257
Product data sheet
14 / 17
74CB3Q3257
Nexperia
15 Legal information
15.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74CB3Q3257
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
15 / 17
74CB3Q3257
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74CB3Q3257
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
16 / 17
74CB3Q3257
Nexperia
Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
10.1
10.2
10.3
11
11.1
12
13
14
15
General description ............................................ 1
Features and benefits .........................................1
Applications .........................................................1
Ordering information .......................................... 2
Functional diagram ............................................. 2
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 4
Functional description ........................................4
Limiting values .................................................... 5
Recommended operating conditions ................ 5
Static characteristics .......................................... 6
Test circuit and graph ........................................7
ON resistance ....................................................7
ON resistance test circuit and graph ................. 8
Dynamic characteristics .....................................8
Waveforms and test circuit ................................ 9
Package outline .................................................12
Abbreviations .................................................... 14
Revision history ................................................ 14
Legal information .............................................. 15
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 14 August 2017
Document identifier: 74CB3Q3257
