74HC109D-Q100J
74HC109D-Q100J
    NEXPERIA(安世)
    SOIC-16
    IC FF JK TYPE DUAL 1BIT 16SO
74HC109D-Q100J 数据手册
74HC109-Q100; 74HCT109-Q100 Dual JK flip-flop with set and reset; positive-edge-trigger Rev. 1 — 28 September 2016 Product data sheet 1. General description The 74HC109-Q100; 74HCT109-Q100 is a dual positive edge triggered JK flip-flop featuring individual nJ and nK inputs. It has clock (nCP) inputs, set (nSD) and reset (nRD) inputs and complementary nQ and nQ outputs. The set and reset are asynchronous active LOW inputs and operate independently of the clock input. The nJ and nK inputs control the state changes of the flip-flops as described in the mode select function table. The nJ and nK inputs must be stable one set-up time prior to the LOW-to-HIGH clock transition for predictable operation. The JK design allows operation as a D-type flip-flop by connecting the nJ and nK inputs together. Inputs include clamp diodes. It enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Schmitt-trigger action in the clock input makes the circuit highly tolerant to slower clock rise and fall times. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Input levels:  For 74HC109-Q100: CMOS level  For 74HCT109-Q100: TTL level  J and K inputs for easy D-type flip-flop  Toggle flip-flop or “do nothing” mode  Specified in compliance with JEDEC standard no. 7A  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 ) 74HC109-Q100; 74HCT109-Q100 Nexperia Dual JK flip-flop with set and reset; positive-edge-trigger 3. Ordering information Table 1. Ordering information Type number Package 74HC109D-Q100 Temperature range Name Description 40 C to +125 C SO16 Version plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74HCT109D-Q100 4. Functional diagram   6' 6'       6' 4 4 4 &3 &3 &3 )) 4 . 4 . 4 . 5'     Fig 1.   &   .    5 5' 5'    -     6 6 - Logic symbol Fig 2.  . 5 D PQD  & E PQD IEC logic symbol 4 & & & & . 4 - & & & & 6 5 & &3 & Fig 3. DDD Logic diagram (one flip-flop) 74HC_HCT109_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 2 of 17 74HC109-Q100; 74HCT109-Q100 Nexperia Dual JK flip-flop with set and reset; positive-edge-trigger 5. Pinning information 5.1 Pinning +&4 +&74 5'   9&& -   5' .   - &3   . 6'   &3 4   6' 4   4 *1'   4 DDD Fig 4. Pin configuration for SO16 5.2 Pin description Table 2. Pin description Symbol Pin Description 1RD, 2RD 1, 15 asynchronous reset input (active LOW) 1J, 2J 2, 14 synchronous input 1K, 2K 3, 13 synchronous input 1CP, 2CP 4, 12 clock input (LOW-to-HIGH; edge-triggered) 1SD, 2SD 5, 11 asynchronous set input (active LOW) 1Q, 2Q 6, 10 true flip-flop output 1Q, 2Q 7, 9 complement flip-flop output GND 8 ground (0 V) VCC 16 supply voltage 74HC_HCT109_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 3 of 17 74HC109-Q100; 74HCT109-Q100 Nexperia Dual JK flip-flop with set and reset; positive-edge-trigger 6. Functional description Table 3. Function selection[1] Operating modes Input Output nSD nRD nCP nJ nK nQ nQ Asynchronous set L H X X X H L Asynchronous reset H L X X X L H Undetermined L L X X X H H Toggle H H  h l q q Load 0 (reset) H H  l l L H Load 1 (set) H H  h h H L Hold no change H H  l h q q [1] H = HIGH voltage level h = HIGH voltage level one set-up time before the LOW-to-HIGH CP transition L = LOW voltage level l = LOW voltage level one set-up time before the LOW-to-HIGH CP transition q = lower case letters indicate the state of the referenced output one set-up time before the LOW-to-HIGH CP transition X = don’t care  = LOW-to-HIGH CP transition 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max 0.5 +7 Unit V IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA IO output current 0.5 V < VO < VCC + 0.5 V - 25 mA ICC supply current - +50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot [1] SO16 package [1] For SO16 package: above 70 C, the value of Ptot derates linearly with 8 mW/K. 74HC_HCT109_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 4 of 17 74HC109-Q100; 74HCT109-Q100 Nexperia Dual JK flip-flop with set and reset; positive-edge-trigger 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC109-Q100 Min Typ 74HCT109-Q100 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC109-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1 - 1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 4.0 - 40 - 80 A 74HC_HCT109_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 5 of 17 74HC109-Q100; 74HCT109-Q100 Nexperia Dual JK flip-flop with set and reset; positive-edge-trigger Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter CI 25 C Conditions input capacitance 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - 3.5 - - - - - pF 74HCT109-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V IO = 4.0 mA 3.98 4.32 - 3.84 - 3.7 - V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 5.2 mA; VCC = 5.5 V - 0.15 0.26 - 0.33 - 0.4 V VOL II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1 - 1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 A ICC additional supply current per input pin; VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V - 35 126 - 157.5 - 171.5 A - 3.5 - - - - - pF nJ, nK, nSD, nRD and nCP inputs CI input capacitance 74HC_HCT109_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 6 of 17 74HC109-Q100; 74HCT109-Q100 Nexperia Dual JK flip-flop with set and reset; positive-edge-trigger 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 7. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Min Typ[1] Max Min Max Min Max - 50 175 - 220 - 265 Unit 74HC109-Q100 tpd propagation delay [2] nCP to nQ, nQ; see Figure 5 VCC = 2.0 V tPLH tPHL tPHL tPLH VCC = 4.5 V - 18 35 - 44 - 53 ns VCC = 5 V; CL = 15 pF - 15 - - - - - ns VCC = 6.0 V - 14 30 - 37 - 45 ns LOW to HIGH nSD to nQ, see Figure 6 propagation VCC = 2.0 V delay VCC = 4.5 V - 30 120 - 150 - 180 ns - 11 24 - 30 - 36 ns VCC = 5 V; CL = 15 pF - 12 - - - - - ns VCC = 6.0 V - 9 20 - 26 - 31 ns HIGH to LOW nSD to nQ; see Figure 6 propagation VCC = 2.0 V delay VCC = 4.5 V - 41 155 - 195 - 235 ns - 15 31 - 39 - 47 ns VCC = 5 V; CL = 15 pF - 12 - - - - - ns VCC = 6.0 V - 12 26 - 33 - 40 ns HIGH to LOW nRD to nQ; see Figure 6 propagation VCC = 2.0 V delay VCC = 4.5 V - 41 185 - 230 - 280 ns - 15 37 - 46 - 56 ns VCC = 5 V; CL = 15 pF - 12 - - - - - ns VCC = 6.0 V - 12 31 - 39 - 48 ns LOW to HIGH nRD to nQ; see Figure 6 propagation VCC = 2.0 V delay VCC = 4.5 V - 39 170 - 215 - 255 ns - 14 34 - 43 - 51 ns VCC = 5 V; CL = 15 pF - 12 - - - - - ns - 11 29 - 37 - 43 ns VCC = 6.0 V tt ns transition time 74HC_HCT109_Q100 Product data sheet nQ, nQ; see Figure 5 [3] VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 7 of 17 74HC109-Q100; 74HCT109-Q100 Nexperia Dual JK flip-flop with set and reset; positive-edge-trigger Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 7. Symbol Parameter tW pulse width 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max VCC = 2.0 V 80 19 - 100 - 120 - ns VCC = 4.5 V 16 7 - 20 - 24 - ns VCC = 6.0 V 14 6 - 17 - 20 - ns VCC = 2.0 V 80 14 - 100 - 120 - ns VCC = 4.5 V 16 5 - 20 - 24 - ns VCC = 6.0 V 14 4 - 17 - 20 - ns VCC = 2.0 V 70 19 - 90 - 105 - ns VCC = 4.5 V 14 7 - 18 - 21 - ns VCC = 6.0 V 12 6 - 15 - 18 - ns VCC = 2.0 V 70 17 - 90 - 105 - ns VCC = 4.5 V 14 6 - 18 - 21 - ns VCC = 6.0 V 12 5 - 15 - 18 - ns VCC = 2.0 V 5 0 - 5 - 5 - ns VCC = 4.5 V 5 0 - 5 - 5 - ns VCC = 6.0 V 5 0 - 5 - 5 - ns VCC = 2.0 V 6 22 - 5 - 4 - MHz VCC = 4.5 V 30 68 - 24 - 20 - MHz - 75 - - - - - MHz 35 81 - 28 - 24 - MHz - 20 - - - - - pF nCP HIGH or LOW; see Figure 5 nSD, nRD HIGH or LOW; see Figure 6 trec tsu th fmax recovery time nSD, nRD to nCP; see Figure 6 set-up time hold time maximum frequency nJ and nK to nCP; see Figure 5 nJ and nK to nCP; see Figure 5 nCP; see Figure 5 VCC = 5 V; CL = 15 pF VCC = 6.0 V CPD power dissipation capacitance 74HC_HCT109_Q100 Product data sheet CL = 50 pF; f = 1 MHz; VI = GND to VCC [4] All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 8 of 17 74HC109-Q100; 74HCT109-Q100 Nexperia Dual JK flip-flop with set and reset; positive-edge-trigger Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 7. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max VCC = 4.5 V - 20 35 - 44 - 53 ns VCC = 5 V; CL = 15 pF - 17 - - - - ns LOW to HIGH nSD to nQ, see Figure 6 propagation VCC = 4.5 V delay VCC = 5 V; CL = 15 pF - 13 26 - 33 - 39 ns - 14 - - - - - ns HIGH to LOW nSD to nQ; see Figure 6 propagation VCC = 4.5 V delay VCC = 5 V; CL = 15 pF - 19 35 - 44 - 53 ns - 14 - - - - - ns - 19 35 - 44 - 53 ns - 15 - - - - - ns - 16 32 - 40 - 48 ns - 15 - - - - - ns - 7 15 - 19 - 22 ns 18 9 - 23 - 27 - ns 16 8 - 20 - 24 - ns 16 8 - 20 - 24 - ns 18 8 - 23 - 27 - ns 3 3 - 3 - 3 - ns 27 55 - 22 - 18 - MHz - 61 - - - - - MHz 74HCT109-Q100 tpd tPLH tPHL tPHL tPLH tt tW propagation delay [2] nCP to nQ, nQ; see Figure 5 HIGH to LOW nRD to nQ; see Figure 6 propagation VCC = 4.5 V delay VCC = 5 V; CL = 15 pF LOW to HIGH nRD to nQ; see Figure 6 propagation VCC = 4.5 V delay VCC = 5 V; CL = 15 pF transition time nQ, nQ; see Figure 5 pulse width nCP HIGH or LOW; see Figure 5 [3] VCC = 4.5 V VCC = 4.5 V nSD, nRD HIGH or LOW; see Figure 6 VCC = 4.5 V trec recovery time nSD, nRD to nCP; see Figure 6 VCC = 4.5 V tsu set-up time nJ and nK to nCP; see Figure 5 VCC = 4.5 V th hold time nJ and nK to nCP; see Figure 5 fmax maximum frequency nCP; see Figure 5 VCC = 4.5 V VCC = 4.5 V VCC = 5 V; CL = 15 pF 74HC_HCT109_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 9 of 17 74HC109-Q100; 74HCT109-Q100 Nexperia Dual JK flip-flop with set and reset; positive-edge-trigger Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 7. Symbol Parameter CPD power dissipation capacitance 25 C Conditions [4] CL = 50 pF; f = 1 MHz; VI = GND to VCC  1.5 V [1] All typical values are measured at Tamb = 25 C. [2] tpd is the same as tPLH and tPHL. 40 C to +85 C 40 C to +125 C Min Typ[1] Max Min Max Min Max - 22 - - - - - [3] tt is the same as tTHL and tTLH. [4] CPD is used to determine the dynamic power dissipation (PD in W). Unit pF PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 11. Waveforms 9, Q-Q.LQSXW 90 *1' WK WK WVX WVX IPD[ 9, Q&3LQSXW 90 *1' W: W3/+ W3+/ 92+   90 Q4RXWSXW  92/  W7/+ W7+/ W3+/ W3/+ 92+   90 Q4RXWSXW  92/  W7/+ W7+/ DDD Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 5. Clock propagation delays, output transition time, pulse width, set-up, hold times, and maximum frequency 74HC_HCT109_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 10 of 17 74HC109-Q100; 74HCT109-Q100 Nexperia Dual JK flip-flop with set and reset; positive-edge-trigger 9, 90 Q&3LQSXW *1' WUHF 9, 90 Q6'LQSXW *1' W: W: 9, 90 Q5'LQSXW *1' W3/+ W3+/ 92+ 90 Q4RXWSXW 92/ 92+ 90 Q4RXWSXW 92/ W3+/ W3/+ DDD Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. Table 8. Set and reset propagation delays, pulse widths and recovery time Measurement points Type Input Output VM VM 74HC109-Q100 0.5VCC 0.5VCC 74HCT109-Q100 1.3 V 1.3 V 74HC_HCT109_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 11 of 17 74HC109-Q100; 74HCT109-Q100 Nexperia Dual JK flip-flop with set and reset; positive-edge-trigger 9, QHJDWLYH SXOVH W:  90 90  *1' WI 9, WI  SRVLWLYH SXOVH *1' WU WU 90 90  W: 9&& * 9, 92 '87 57 &/ DDK  Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. Fig 7. Table 9. Test circuit for measuring switching times Test data Type Input Load Test VI tr, tf CL 74HC109-Q100 VCC 6 ns 15 pF, 50 pF tPLH, tPHL 74HCT109-Q100 3V 6 ns 15 pF, 50 pF tPLH, tPHL 74HC_HCT109_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 12 of 17 74HC109-Q100; 74HCT109-Q100 Nexperia Dual JK flip-flop with set and reset; positive-edge-trigger 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG Fig 8. 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Package outline SOT109-1 (SO16) 74HC_HCT109_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 13 of 17 74HC109-Q100; 74HCT109-Q100 Nexperia Dual JK flip-flop with set and reset; positive-edge-trigger 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT109_Q100 v.1 20160928 Product data sheet - - 74HC_HCT109_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 14 of 17 74HC109-Q100; 74HCT109-Q100 Nexperia Dual JK flip-flop with set and reset; positive-edge-trigger 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT109_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 15 of 17 Nexperia 74HC109-Q100; 74HCT109-Q100 Dual JK flip-flop with set and reset; positive-edge-trigger No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT109_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 September 2016 © Nexperia B.V. 2017. All rights reserved 16 of 17 Nexperia 74HC109-Q100; 74HCT109-Q100 Dual JK flip-flop with set and reset; positive-edge-trigger 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14 Legal information. . . . . . . . . . . . . . . . . . . . . . . 15 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Contact information. . . . . . . . . . . . . . . . . . . . . 16 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 28 September 2016
74HC109D-Q100J 价格&库存
很抱歉,暂时无法提供与“74HC109D-Q100J”相匹配的价格&库存,您可以联系我们找货
74HC109D-Q100J
  • 2500+1.641942500+0.21269
  • 5000+1.594515000+0.20655
  • 7500+1.570767500+0.20347
  • 12500+1.5444512500+0.20006
  • 17500+1.5290617500+0.19807
  • 25000+1.5142825000+0.19616
库存:1782
74HC109D-Q100J
74HC109D-Q100J
  • 1+3.970811+0.51436
  • 10+2.7977110+0.36241
  • 25+2.4926425+0.32289
  • 100+2.15822100+0.27957
  • 250+1.99881250+0.25892
  • 500+1.90277500+0.24648
  • 1000+1.826671000+0.23662
库存:1782
74HC109D-Q100J
  • 1+3.800021+0.49224
  • 10+2.6397310+0.34194
  • 25+2.3513225+0.30458
  • 100+2.03557100+0.26368
  • 250+1.88545250+0.24424
  • 500+1.79506500+0.23253
  • 1000+1.723311000+0.22323
库存:1782
74HC109D-Q100J
    • 1+1.47474
    • 10+1.16435
    • 30+1.03140
    • 100+0.86552
    • 500+0.79164
    • 1000+0.74726
