74LV1T02
2-input single supply translating NOR gate
Rev. 2 — 3 December 2019
Product data sheet
1. General description
The 74LV1T02 is a single, level translating 2-input NOR gate. The low threshold inputs support
1.8 V input logic at VCC = 3.3 V and can be used in 1.8 V to 3.3 V level up translation. In addition,
the 5 V tolerant input pins enable level down translation (3.3 V to 2.5 V output at VCC = 2.5 V). The
output level is referenced to the supply voltage and supports 1.8 V, 2.5 V, 3.3 V and 5.0 V CMOS
levels. The wide VCC range permits the generation of output levels to connect to controllers or
processors.
2. Features and benefits
Single supply voltage translator at 1.8 V, 2.5 V, 3.3 V and 5.0 V
Up translation
• 1.2 V to 1.8 V at VCC = 1.8 V
• 1.5 V to 2.5 V at VCC = 2.5 V
• 1.8 V to 3.3 V at VCC = 3.3 V
• 3.3 V to 5.0 V at VCC = 5.0 V
Down translation
• 3.3 V to 1.8 V at VCC = 1.8 V
• 3.3 V to 2.5 V at VCC = 2.5 V
• 5.0 V to 3.3 V at VCC = 3.3 V
5 V tolerant inputs
Latch-up performance exceeds 250 mA per JESD 78 Class II
ESD protection:
• HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV
• CDM JESD22-C101 exceeds 1 kV
Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3. Applications
Portable applications
PC and notebooks
Industrial controller
Telecom
74LV1T02
Nexperia
4. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range Name
Description
Version
74LV1T02GW
-40 °C to +125 °C
TSSOP5 plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74LV1T02GV
-40 °C to +125 °C
SC-74A
SOT753
74LV1T02GX
-40 °C to +125 °C
X2SON5 plastic thermal enhanced extremely thin small outline
package; no leads; 5 terminals; body 0.8 x 0.8 x 0.35 mm
plastic surface-mounted package; 5 leads
SOT1226
5. Marking
Table 2. Marking
Type number
Marking code[1]
74LV1T02GW
SF
74LV1T02GV
SF
74LV1T02GX
SF
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
6. Functional diagram
1
B
2
A
Y
1
4
2
Logic symbol
74LV1T02
Product data sheet
4
mna104
mna103
Fig. 1.
B
≥1
Fig. 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Y
A
Fig. 3.
mna105
Logic diagram
Nexperia B.V. 2019. All rights reserved
2 / 13
74LV1T02
Nexperia
7. Pinning information
7.1. Pinning
74LV1T02
B
1
A
2
GND
3
74LV1T02
5
VCC
B
1
VCC
4
Y
3
GND
4
2
A
Y
aaa-027727
aaa-027726
Fig. 4.
5
Pin configuration SOT353-1 (TSSOP5) and
SOT753 (SC-74A)
Transparent top view
Fig. 5.
Pin configuration SOT1226 (X2SON5)
7.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
B
1
data input
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
8. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level
Output
Input
A
B
Y
L
L
H
L
H
L
H
L
L
H
H
L
74LV1T02
Product data sheet
3 / 13
74LV1T02
Nexperia
9. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
output HIGH or LOW state
output in power-off state
Min
Max
Unit
-0.5
+7.0
V
[1]
-0.5
+7.0
V
[2][3]
-0.5
VCC + 0.5
V
[2]
-0.5
4.6
V
-20
mA
IIK
input clamping current
VI < 0 V
IOK
output clamping current
VO < 0 V or VO > VCC
±20
mA
IO
output current
VO = 0 V to VCC
±25
mA
ICC
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
[1]
[2]
[3]
[4]
Tamb = -40 °C to +125 °C
[4]
If the input current ratings are observed, the minimum input voltage ratings may be exceeded.
If the output current ratings are observed, the output voltage ratings may be exceeded.
This value is limited to 7 V maximum.
For SOT353-1 package: above 74 °C the value of Ptot derates linearly with 3.3 mW/K.
For SOT753 package: above 85 °C the value of Ptot derates linearly with 3.8 mW/K.
For SOT1226 package: above 67 °C the value of Ptot derates linearly with 3.0 mW/K.
10. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
74LV1T02
Product data sheet
Conditions
VCC = 1.8 V to 5.0 V
Min
Typ
Max
Unit
1.6
5.0
5.5
V
V
VCC
V
-40
+25
+125
°C
ns/V
4 / 13
74LV1T02
Nexperia
11. Static characteristics
Table 7. Static characteristics
Symbol
VIH
VIL
VOH
VOL
Parameter
HIGH-level
input voltage
LOW-level
input voltage
Conditions
25 °C
Unit
Max
Min
Max
Min
Max
0.94
1.0
1.0
V
VCC = 2.0 V
0.99
1.03
1.03
V
VCC = 2.25 V to 2.5 V
1.135
1.18
1.18
V
VCC = 2.75 V
1.21
1.23
1.23
V
VCC = 3.0 V to 3.3 V
1.35
1.37
1.37
V
VCC = 3.6 V
1.47
1.48
1.48
V
VCC = 4.5 V to 5.0 V
2.02
2.03
2.03
V
VCC = 5.5 V
2.10
2.11
2.11
V
VCC = 1.65 V to 2.0 V
0.58
0.55
0.55
V
VCC = 2.25 V to 2.75 V
0.75
0.71
0.71
V
VCC = 3.0 V to 3.6 V
0.80
0.65
0.65
V
VCC = 4.5 V to 5.5 V
0.80
0.80
0.80
V
VCC-0.1
VCC-0.1
VCC-0.1
V
VCC = 1.65 V; IO = -2 mA
1.28
1.21
1.21
V
VCC = 1.8 V; IO = -2 mA
1.5
1.45
1.45
V
VCC = 2.3 V; IO = -2.3 mA
2.0
2.0
2.0
V
VCC = 2.3 V; IO = -3 mA
2.0
1.93
1.93
V
VCC = 2.5 V; IO = -3 mA
2.25
2.15
2.15
V
VCC = 3.0 V; IO = -3 mA
2.78
2.7
2.7
V
VCC = 3.0 V; IO = -5.5 mA
2.6
2.49
2.49
V
VCC = 3.3 V; IO = -5.5 mA
2.9
2.8
2.8
V
VCC = 4.5 V; IO = -4 mA
4.2
4.1
4.1
V
VCC = 4.5 V; IO = -8 mA
4.1
3.95
3.95
V
VCC = 5.0 V; IO = -8 mA
4.6
4.5
4.5
V
0.1
0.1
0.1
V
VCC = 1.65 V; IO = 2 mA
0.2
0.25
0.25
V
VCC = 2.3 V; IO = 2.3 mA
0.1
0.15
0.15
V
VCC = 2.3 V; IO = 3 mA
0.15
0.2
0.2
V
VCC = 3.0 V; IO = 3 mA
0.1
0.15
0.15
V
VCC = 3.0 V; IO = 5.5 mA
0.2
0.252
0.252
V
VCC = 4.5 V; IO = 4 mA
0.15
0.2
0.2
V
VCC = 4.5 V; IO = 8 mA
0.3
0.35
0.35
V
±0.1
±1
±1
μA
1
10
10
μA
VCC = 1.65 V to 1.8 V
VI = VIH or VIL
LOW-level
output voltage
VCC = 1.65 V to 5.5 V;
IO = 20 μA
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 1.8 V, 2.5 V, 3.3 V, 5.0 V
Product data sheet
-40 °C to +125 °C
Min
VI = VIH or VIL;
HIGH-level
output voltage
IO = -20 μA
74LV1T02
-40 °C to +85 °C
VI = VCC or GND;
VCC = 0 V to 5.5 V
5 / 13
74LV1T02
Nexperia
Symbol
ΔICC
Parameter
Conditions
25 °C
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Max
Min
Max
Min
Max
per input pin; VCC = 1.8 V;
additional
supply current VI = 0.3 V or 1.1 V; IO = 0 A;
other pins at VCC or GND
10
10
10
μA
per input pin; VCC = 5.5 V;
VI = 0.3 V or 3.4 V; IO = 0 A;
1.35
1.5
1.5
mA
12. Dynamic characteristics
Table 8. Dynamic characteristics
GND = 0 V. For test circuit, see Fig. 7.
Symbol Parameter
Conditions
25 °C
Min
Typ
Max
Min
Max
Min
Max
6.6
10.1
11.4
12.2
ns
VCC = 1.8 V; CL = 30 pF
7.6
11.9
13.4
14.3
ns
VCC = 2.5 V; CL = 15 pF
4.6
6.8
7.7
8.2
ns
VCC = 2.5 V; CL = 30 pF
5.4
7.9
9.0
9.6
ns
VCC = 3.3 V; CL = 15 pF
3.8
5.5
6.1
6.5
ns
VCC = 3.3 V; CL = 30 pF
4.4
6.3
7.0
7.5
ns
VCC = 5.0 V; CL = 15 pF
3.2
4.1
4.5
4.7
ns
VCC = 5.0 V; CL = 30 pF
3.7
4.7
5.1
5.4
ns
propagation A, B to Y; see Fig. 6
delay
VCC = 1.8 V; CL = 15 pF
tpd
-40 °C to +85 °C -40 °C to +125 °C Unit
[1]
CI
input
VI = VCC or GND; VCC = 3.3 V
capacitance
1.5
10
10
10
pF
CO
output
VO = VCC or GND; VCC = 3.3 V
capacitance
2.5
pF
CPD
per buffer; VI = GND to VCC;
power
dissipation CL = 30 pF; f = 10 MHz
capacitance
VCC = 1.8 V
4.2
pF
VCC = 2.5 V
5.7
pF
VCC = 3.3 V
7.7
pF
VCC = 5.0 V
12.0
pF
[1]
[2]
[2]
tpd is the same as tPLH and tPHL.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + ∑(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL x VCC x fo) = sum of the outputs.
74LV1T02
Product data sheet
6 / 13
74LV1T02
Nexperia
12.1. Waveforms and test circuit
VI
VM
A, B input
GND
t PHL
t PLH
VOH
VM
Y output
VOL
mna612
Measurement points are given in Table 9.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 6.
The input A, B to output Y propagation delays
Table 9. Measurement points
Input
Output
VM
VM
0.5VI
0.5VCC
VI
negative
pulse
VEXT
tW
90 %
90 %
VM
VM
10 %
0V
tf
positive
pulse
0V
G
tr
tr
VI
VCC
10 %
VI
DUT
tf
90 %
VO
RT
90 %
VM
RL
CL
VM
10 %
10 %
tW
aaa-027728
Test data is given in Table 10.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
RL = Load resistance
VEXT = External voltage for measuring switching times
Fig. 7.
Test circuit for measuring switching times
Table 10. Test data
Supply voltage Input
Load
VEXT
VCC
VI
Δt/ΔV [1]
fmax
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
1.8 V
VCC
≤ 1.0 ns/V
15 MHz
15 pF, 30 pF
1 kΩ
open
GND
VCC
2.5 V
VCC
≤ 1.0 ns/V
25 MHz
15 pF, 30 pF
1 kΩ
open
GND
VCC
3.3 V
3V
≤ 1.0 ns/V
50 MHz
15 pF, 30 pF
1 kΩ
open
GND
VCC
5.0 V
3V
≤ 1.0 ns/V
50 MHz
15 pF, 30 pF
1 kΩ
open
GND
VCC
[1]
dV/dt ≥ 1.0 V/ns
74LV1T02
Product data sheet
7 / 13
74LV1T02
Nexperia
13. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
D
E
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
e
e1
L
w M
bp
detail X
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
Fig. 8.
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Package outline SOT353-1 (TSSOP5)
74LV1T02
Product data sheet
8 / 13
74LV1T02
Nexperia
Plastic surface-mounted package; 5 leads
SOT753
D
B
E
y
A
X
HE
5
v M A
4
Q
A
A1
c
1
2
3
Lp
detail X
bp
e
w M B
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.100
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT753
Fig. 9.
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-04-16
06-03-16
SC-74A
Package outline SOT753 (SC-74A)
74LV1T02
Product data sheet
9 / 13
74LV1T02
Nexperia
X2SON5: plastic thermal enhanced extremely thin small outline package; no leads;
D
A
B
SOT1226
X
A
E
A1
A3
detail X
terminal 1
index area
e
v
w
b
1
2
terminal 1
index area
C
C A B
C
y1 C
y
k
D
h
3
L
5
4
1 mm
scale
Dimensions
Unit
mm
A(1)
A1
A3
D
Dh
E
b
e
k
L
max 0.35 0.04 0.128 0.85 0.30 0.85 0.27
0.27
nom
0.80 0.25 0.80 0.22 0.48
0.22
min
0.040 0.75 0.20 0.75 0.17
0.20 0.17
v
0.1
w
y
y1
0.05 0.05 0.05
Note
1. Dimension A is including plating thickness.
2. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
Outline
version
References
IEC
JEDEC
EIAJ
sot1226_po
European
projection
Issue date
12-04-10
12-04-25
SOT1226
Fig. 10. Package outline SOT1226 (X2SON5)
74LV1T02
Product data sheet
10 / 13
74LV1T02
Nexperia
14. Abbreviations
Table 11. Abbreviations
Acronym
Description
CDM
Charge Device Model
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
15. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LV1T02 v.2
20191203
Product data sheet
74LV1T02 v.1
Modifications:
74LV1T02 v.1
20171128
74LV1T02
Product data sheet
Type number 74LV1T02GV (SOT753/SC-74A) added.
Table 5: Derating values for Ptot total power dissipation updated.
Product data sheet
11 / 13
74LV1T02
Nexperia
16. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74LV1T02
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
12 / 13
74LV1T02
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................2
5. Marking.......................................................................... 2
6. Functional diagram.......................................................2
7. Pinning information......................................................3
7.1. Pinning.........................................................................3
7.2. Pin description............................................................. 3
8. Functional description................................................. 3
9. Limiting values............................................................. 4
10. Recommended operating conditions........................4
11. Static characteristics..................................................5
12. Dynamic characteristics............................................ 6
12.1. Waveforms and test circuit........................................ 7
13. Package outline.......................................................... 8
14. Abbreviations............................................................ 11
15. Revision history........................................................11
16. Legal information......................................................12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 3 December 2019
74LV1T02
Product data sheet
13 / 13
