74LVC1G97
Low-power configurable multiple function gate
Rev. 6 — 8 August 2018
Product data sheet
1. General description
The 74LVC1G97 is a configurable multiple function gate with Schmitt-trigger inputs. The device can
be configured as any of the following logic functions MUX, AND, OR, NAND, NOR, inverter and
buffer; using the 3-bit input. All inputs can be connected to VCC or GND.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices
as translators in mixed 3.3 V and 5 V environments.
This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry
disables the output, preventing the damaging backflow current through the device when it is
powered down.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant input/output for interfacing with 5 V logic
High noise immunity
Complies with JEDEC standard:
• JESD8-7 (1.65 V to 1.95 V)
• JESD8-5 (2.3 V to 2.7 V)
• JESD8B/JESD36 (2.7 V to 3.6 V).
±24 mA output drive (VCC = 3.0 V)
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
• CDM JESD22-C101E exceeds 1000 V
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
Multiple package options
Specified from -40 °C to +85 °C and -40 °C to +125 °C.
74LVC1G97
Nexperia
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74LVC1G97GW
-40 °C to +125 °C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74LVC1G97GV
-40 °C to +125 °C
SC-74
plastic surface mounted package; 6 leads
SOT457
74LVC1G97GM
-40 °C to +125 °C
XSON6
plastic extremely thin small outline package;
no leads; 6 terminals; body 1 × 1.45 × 0.5 mm
SOT886
74LVC1G97GF
-40 °C to +125 °C
XSON6
no leads; 6 terminals; body 1 × 1 × 0.5 mm
SOT891
74LVC1G97GN
-40 °C to +125 °C
XSON6
extremely thin small outline package; no leads;
6 terminals; body 0.9 × 1.0 × 0.35 mm
SOT1115
74LVC1G97GS
-40 °C to +125 °C
XSON6
6 terminals; body 1.0 × 1.0 × 0.35 mm
SOT1202
74LVC1G97GX
-40 °C to +125 °C
X2SON6
plastic thermal enhanced extremely thin
small outline package; no leads; 6 terminals;
body 1.0 × 0.8 × 0.35 mm
SOT1255
4. Marking
Table 2. Marking
Type number
Marking code [1]
74LVC1G97GW
YV
74LVC1G97GV
Y97
74LVC1G97GM
YV
74LVC1G97GF
YV
74LVC1G97GN
YV
74LVC1G97GS
YV
74LVC1G97GX
YV
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
A
3
4
B
C
Fig. 1.
1
Y
6
001aad998
Logic symbol
74LVC1G97
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 20
74LVC1G97
Nexperia
6. Pinning information
6.1. Pinning
74LVC1G97
74LVC1G97
B
1
6
C
GND
2
5
VCC
A
3
4
Y
B
1
6
C
GND
2
5
VCC
A
3
4
Y
001aan191
001aan190
Fig. 2.
Transparent top view
Pin configuration SOT363 (SC-88)
and SOT457 (SC-74)
Fig. 3.
Pin configuration SOT886 (XSON6)
74LVC1G97
74LVC1G97
B
1
B
1
6
C
GND
2
5
VCC
A
3
4
Y
2
GND
5
3
A
001aan192
VCC
4
Y
Fig. 4.
C
6
aaa-025870
Pin configuration SOT891, SOT1115,
and SOT1202 (XSON6)
Fig. 5.
Pin configuration SOT1255 (X2SON6)
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
B
1
data input
GND
2
ground (0 V)
A
3
data input
Y
4
data output
VCC
5
supply voltage
C
6
data input
74LVC1G97
Product data sheet
3 / 20
74LVC1G97
Nexperia
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level.
Output
Input
C
B
A
Y
L
L
L
L
L
L
H
L
L
H
L
H
L
H
H
H
H
L
L
L
H
L
H
H
H
H
L
L
H
H
H
H
7.1. Logic configurations
Table 5. Function selection table
Logic function
Figure
2-input MUX
see Fig. 6
2-input AND
see Fig. 7
2-input OR with one input inverted
see Fig. 8
2-input NAND with one input inverted
see Fig. 8
2-input AND with one input inverted
see Fig. 9
2-input NOR with one input inverted
see Fig. 9
2-input OR
see Fig. 10
Inverter
see Fig. 11
Buffer
see Fig. 12
VCC
B
B
Y
A
A
C
Fig. 6.
1
6
2
5
3
4
VCC
C
A
C
Y
A
Y
1
6
2
5
3
4
Y
001aae003
001aae002
2-input MUX
C
Fig. 7.
2-input AND gate
VCC
A
C
A
C
Y
Y
A
1
6
2
5
3
4
VCC
C
B
C
Y
B
C
Y
Y
B
1
6
2
5
3
4
001aae004
Fig. 8.
Product data sheet
Y
001aae005
2-input NAND gate with input A inverted or
2-input OR gate with input C inverted
74LVC1G97
C
Fig. 9.
2-input NOR gate with input B inverted or
2-input AND gate with input C inverted
4 / 20
74LVC1G97
Nexperia
VCC
VCC
B
B
C
Y
1
6
2
5
3
4
C
C
Y
Y
1
6
2
5
3
4
C
Y
001aae007
001aae006
Fig. 10. 2-input OR gate
Fig. 11. Inverter
VCC
B
B
Y
1
6
2
5
3
4
Y
001aae008
Fig. 12. Buffer
8. Limiting values
Table 6. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+6.5
V
-50
[1]
-0.5
+6.5
V
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO > VCC or VO < 0 V
±50
mA
VO
output voltage
Active mode
[1][2]
-0.5
+6.5
V
Power-down mode
[1][2]
-0.5
+6.5
V
±50
mA
+100
mA
VI < 0 V
IO
output current
ICC
supply current
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
[1]
[2]
[3]
VO = 0 V to VCC
mA
Tamb = -40 °C to +125 °C
[3]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
For SC-88 and SC-74 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 and X2SON6 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 7. Recommended operating conditions
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC
supply voltage
1.65
5.5
V
VI
input voltage
V
VO
output voltage
Active mode
VCC
V
VCC = 0 V; Power-down mode
V
-40
+125
°C
Tamb
ambient temperature
74LVC1G97
Product data sheet
5 / 20
74LVC1G97
Nexperia
10. Static characteristics
Table 8. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VOL
LOW-level output
voltage
VOH
HIGH-level output
voltage
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ [1]
Max
Min
Max
IO = 100 μA;
VCC = 1.65 V to 5.5 V
0.1
0.1
V
IO = 4 mA; VCC = 1.65 V
0.45
0.7
V
IO = 8 mA; VCC = 2.3 V
0.3
0.45
V
IO = 12 mA; VCC = 2.7 V
0.4
0.6
V
IO = 24 mA; VCC = 3.0 V
0.55
0.8
V
IO = 32 mA; VCC = 4.5 V
0.55
0.8
V
VCC - 0.1
VCC - 0.1
V
IO = -4 mA; VCC = 1.65 V
1.2
0.95
V
IO = -8 mA; VCC = 2.3 V
1.9
1.7
V
IO = -12 mA; VCC = 2.7 V
2.2
1.9
V
IO = -24 mA; VCC = 3.0 V
2.3
2.0
V
IO = -32 mA; VCC = 4.5 V
VI = VCC or GND
VI = VCC or GND
IO = -100 μA;
3.8
3.4
V
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
±0.1
±1
±1
μA
IOFF
power-off leakage
current
VI or VO = 5.5 V; VCC = 0 V
±0.1
±2
±2
μA
ICC
supply current
VI = 5.5 V or GND; IO = 0 A;
0.1
4
4
μA
ΔICC
additional supply
current
VI = VCC - 0.6 V; IO = 0 A;
VCC = 2.3 V to 5.5 V
5
500
500
μA
CI
input capacitance
2.5
pF
[1]
Typical values are measured at maximum VCC and Tamb = 25 °C.
74LVC1G97
Product data sheet
6 / 20
74LVC1G97
Nexperia
11. Dynamic characteristics
Table 9. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 14.
Symbol Parameter
tpd
propagation delay
CPD
[1]
[2]
[3]
Conditions
power dissipation
capacitance
-40 °C to +85 °C
-40 °C to +125 °C Unit
Min
Typ [1]
Max
Min
Max
VCC = 1.65 V to 1.95 V
1.0
6.0
14.4
1.0
18.0
ns
VCC = 2.3 V to 2.7 V
0.5
3.5
8.3
0.5
10.4
ns
VCC = 2.7 V
0.5
4.2
8.5
0.5
10.6
ns
VCC = 3.0 V to 3.6 V
0.5
3.8
6.3
0.5
7.9
ns
VCC = 4.5 V to 5.5 V
0.5
3.0
5.1
0.5
6.4
ns
22
pF
A, B, C to Y; see Fig. 13
[2]
VCC = 3.3 V; VI = GND to VCC [3]
Typical values are measured at nominal VCC and at Tamb = 25 °C.
tpd is the same as tPLH and tPHL
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL × VCC × fo) = sum of outputs.
11.1. Waveforms and test circuit
VI
A, B, C input
VM
VM
GND
t PHL
t PLH
VOH
VM
Y output
VM
VOL
t PLH
t PHL
VOH
Y output
VM
VOL
VM
001aab593
Measurement points are given in Table 10.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 13. Input A, B and C to output Y propagation delay times
74LVC1G97
Product data sheet
7 / 20
74LVC1G97
Nexperia
Table 10. Measurement points
Supply voltage
Input
Output
VCC
VM
VI
VM
1.65 V to 1.95 V
0.5VCC
VCC
0.5VCC
2.3 V to 2.7 V
0.5VCC
VCC
0.5VCC
2.7 V
1.5 V
2.7 V
1.5 V
3.0 V to 3.6 V
1.5 V
2.7 V
1.5 V
4.5 V to 5.5 V
0.5VCC
VCC
0.5VCC
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
mna616
Measurement points are given in Table 11.
Definitions test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 14. Test circuit for measuring switching times
Table 11. Measurement points
Supply voltage
Input
VEXT
Load
VCC
VI
tr = tf
CL
RL
tPLH, tPHL
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
open
2.3 to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
4.5 V to 5.5 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
74LVC1G97
Product data sheet
8 / 20
74LVC1G97
Nexperia
12. Transfer characteristics
Table 12. Transfer characteristics
Symbol Parameter
VT+
positive-going
threshold voltage
VT-
negative-going
threshold voltage
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ [1]
Max
Min
Max
VCC = 1.8 V
0.70
1.02
1.20
0.67
1.20
V
VCC = 2.3 V
1.11
1.42
1.60
1.08
1.60
V
VCC = 3.0 V, see Fig. 19
1.50
1.79
2.00
1.47
2.00
V
VCC = 4.5 V
2.16
2.52
2.74
2.13
2.74
V
VCC = 5.5 V
2.61
2.99
3.33
2.58
3.33
V
VCC = 1.8 V
0.30
0.53
0.72
0.30
0.75
V
VCC = 2.3 V
0.58
0.77
1.00
0.58
1.03
V
0.80
1.04
1.30
0.80
1.33
V
VCC = 4.5 V
1.21
1.55
1.90
1.21
1.93
V
VCC = 5.5 V
1.45
1.86
2.29
1.45
2.32
V
VCC = 1.8 V
0.30
0.48
0.62
0.23
0.62
V
VCC = 2.3 V
0.40
0.64
0.80
0.34
0.80
V
0.50
0.75
1.00
0.44
1.00
V
VCC = 4.5 V
0.71
0.97
1.20
0.65
1.20
V
VCC = 5.5 V
0.71
1.13
1.40
0.65
1.40
V
See Fig. 15, Fig. 16,
Fig. 17 and Fig. 18
Fig. 17 and Fig. 18
hysteresis voltage (VT+ - VT-).
Fig. 17 and Fig. 18
VH
[1]
Conditions
Typical values are measured at Tamb = 25 °C.
74LVC1G97
Product data sheet
9 / 20
74LVC1G97
Nexperia
12.1. Waveforms transfer characteristics
VO
VT+
VI
VT-
VO
VI
VH
VT+
VH
VT-
mna208
VT+ and VT- limits are at 70 % and 20 %.
mna207
Fig. 15. Transfer characteristic
Fig. 16. Definition of VT+, VT- and VH
VO
VT+
VI
VH
VT-
VO
VI
VH
VT-
VT+
mnb155
mnb154
Fig. 17. Transfer characteristic
Fig. 18. Definition of VT+, VT- and VH
001aab594
16
I CC
(mA)
12
8
4
2
VI (V)
3
Fig. 19. Typical 74LVC1G97 transfer characteristic; VCC = 3.0 V
74LVC1G97
Product data sheet
10 / 20
74LVC1G97
Nexperia
13. Package outline
Plastic surface-mounted package; 6 leads
SOT363
D
B
E
y
A
X
HE
6
5
v M A
4
Q
pin 1
index
A
1
2
e1
A1
3
bp
c
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.1
0.8
0.1
0.30
0.20
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.25
0.15
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT363
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-08
06-03-16
SC-88
Fig. 20. Package outline SOT363 (SC-88)
74LVC1G97
Product data sheet
11 / 20
74LVC1G97
Nexperia
Plastic surface-mounted package (TSOP6); 6 leads
D
SOT457
B
E
y
A
X
HE
6
5
v M A
4
Q
pin 1
index
A
A1
1
2
c
3
Lp
e
bp
w M B
detail X
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.1
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT457
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-11-07
06-03-16
SC-74
Fig. 21. Package outline SOT457 (SC-74)
74LVC1G97
Product data sheet
12 / 20
74LVC1G97
Nexperia
SOT886
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm
b
1
2
3
4x
(2)
L
L1
e
6
5
e1
4
e1
6x
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
0.5
A1
b
D
E
0.04 0.25 1.50 1.05
0.20 1.45 1.00
0.17 1.40 0.95
e
e1
0.6
0.5
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
Outline
version
SOT886
sot886_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
04-07-22
12-01-05
MO-252
Fig. 22. Package outline SOT886 (XSON6)
74LVC1G97
Product data sheet
13 / 20
74LVC1G97
Nexperia
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm
1
SOT891
b
3
2
4×
(1)
L
L1
e
6
5
e1
4
e1
6×
A
(1)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.20
0.12
1.05
0.95
1.05
0.95
0.55
0.35
0.35
0.27
0.40
0.32
Note
1. Can be visible in some manufacturing processes.
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-04-06
07-05-15
SOT891
Fig. 23. Package outline SOT891 (XSON6)
74LVC1G97
Product data sheet
14 / 20
74LVC1G97
Nexperia
XSON6: extremely thin small outline package; no leads;
6 terminals; body 0.9 x 1.0 x 0.35 mm
1
SOT1115
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
max 0.35 0.04 0.20 0.95 1.05
nom
0.15 0.90 1.00 0.55
min
0.12 0.85 0.95
e1
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
sot1115_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1115
Fig. 24. Package outline SOT1115 (XSON6)
74LVC1G97
Product data sheet
15 / 20
74LVC1G97
Nexperia
6 terminals; body 1.0 x 1.0 x 0.35 mm
1
SOT1202
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.05 1.05
0.35 0.40
nom
0.15 1.00 1.00 0.55 0.35 0.30 0.35
min
0.12 0.95 0.95
0.27 0.32
Note
Outline
version
sot1202_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1202
Fig. 25. Package outline SOT1202 (XSON6)
74LVC1G97
Product data sheet
16 / 20
74LVC1G97
Nexperia
X2SON6: plastic thermal enhanced extremely thin small outline package; no leads;
6 terminals; body 1.0 x 0.8 x 0.35 mm
SOT1255
X
A
D
B
A
pin 1
ID area
E
A1
detail X
C
e1
b
(4x)
4
3
y1 C
A B
v
y
L
(4x)
2
5
Dh
(2x)
1
6
e2
1 mm
scale
Unit
mm
A
A1
D
Dh
E
e1
e2
b
L
v
y
y1
max 0.35 0.04 1.05 0.30 0.85
0.30 0.25
nom 0.32 0.02 1.00 0.25 0.80 0.60 0.40 0.25 0.20 0.10 0.05 0.05
0.22 0.17
min 0.30 0.00 0.95 0.22 0.75
sot1255_po
Outline
version
References
IEC
JEDEC
JEITA
European
projection
Issue date
15-07-20
15-07-22
SOT1255
Fig. 26. Package outline SOT1255 (X2SON6)
74LVC1G97
Product data sheet
17 / 20
74LVC1G97
Nexperia
14. Abbreviations
Table 13. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
15. Revision history
Table 14. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC1G97 v.6
20180808
Product data sheet
74LVC1G97 v.5
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
74LVC1G97 v.5
20161212
Modifications:
74LVC1G97 v.4
20140910
Modifications:
74LVC1G97 v.3
20111207
Product data sheet
74LVC1G97 v.2
74LVC1G97 v.2
20110309
Product data sheet
74LVC1G97 v.1
74LVC1G97 v.1
20101221
Product data sheet
74LVC1G97
Product data sheet
Product data sheet
74LVC1G97 v.4
Table 8: The maximum limits for leakage current and supply current have changed.
•Type number 74LVC1G97GX (X2SON6/SOT1255) added.
Product data sheet
74LVC1G97 v.3
Package outline drawing of SOT886 (Fig. 22) modified.
18 / 20
74LVC1G97
Nexperia
16. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74LVC1G97
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
19 / 20
74LVC1G97
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................2
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................3
6.1. Pinning.........................................................................3
6.2. Pin description............................................................. 3
7. Functional description................................................. 4
7.1. Logic configurations.....................................................4
8. Limiting values............................................................. 5
9. Recommended operating conditions..........................5
10. Static characteristics..................................................6
11. Dynamic characteristics.............................................7
11.1. Waveforms and test circuit........................................ 7
12. Transfer characteristics............................................. 9
12.1. Waveforms transfer characteristics..........................10
13. Package outline........................................................ 11
14. Abbreviations............................................................ 18
15. Revision history........................................................18
16. Legal information......................................................19
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 8 August 2018
74LVC1G97
Product data sheet
20 / 20
