74LVC2G00GXX
74LVC2G00GXX
    NEXPERIA(安世)
    X2SON8_1.35X0.8MM
    IC GATE NAND 2CH 2-INP 8X2SON
74LVC2G00GXX 数据手册
74LVC2G00 Dual 2-input NAND gate Rev. 15 — 3 July 2017 1 Product data sheet General description The 74LVC2G00 provides a 2-input NAND gate function. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices as translators in a mixed 3.3 V and 5 V environment. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2 Features and benefits • • • • • • • • • • • • 3 Wide supply voltage range from 1.65 V to 5.5 V 5 V tolerant outputs for interfacing with 5 V logic High noise immunity ±24 mA output drive (VCC = 3.0 V) CMOS low power consumption Complies with JEDEC standard: – JESD8-7 (1.65 V to 1.95 V) – JESD8-5 (2.3 V to 2.7 V) – JESD8-B/JESD36 (2.7 V to 3.6 V) Latch-up performance exceeds 250 mA Direct interface with TTL levels Inputs accept voltages up to 5 V ESD protection: – HBM JESD22-A114F exceeds 2 000 V – MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC2G00DP -40 °C to +125 °C TSSOP8 plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm SOT505-2 74LVC2G00DC -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; body width 2.3 mm SOT765-1 74LVC2G00 Nexperia Dual 2-input NAND gate Type number Package Temperature range Name Description Version 74LVC2G00GT -40 °C to +125 °C XSON8 plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm SOT833-1 74LVC2G00GF -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1 x 0.5 mm SOT1089 74LVC2G00GM -40 °C to +125 °C XQFN8 plastic, extremely thin quad flat package; no leads; 8 terminals; body 1.6 x 1.6 x 0.5 mm SOT902-2 74LVC2G00GN -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.2 x 1.0 x 0.35 mm SOT1116 74LVC2G00GS -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1.0 x 0.35 mm SOT1203 74LVC2G00GX -40 °C to +125 °C X2SON8 plastic thermal enhanced extremely thin small outline SOT1233 package; no leads; 8 terminals; body 1.35 x 0.8 x 0.35 mm 4 Marking Table 2. Marking codes Type number Marking code 74LVC2G00DP V2G00 74LVC2G00DC V00 74LVC2G00GT V00 74LVC2G00GF VA 74LVC2G00GM V00 74LVC2G00GN VA 74LVC2G00GS VA 74LVC2G00GX VA [1] 5 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. Functional diagram & 1A 1B 2A 2B 1Y 2Y 001aah748 Figure 1.  Logic symbol 74LVC2G00 Product data sheet & 001aah749 Figure 2.  IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 B Y A mna099 Figure 3.  Logic diagram (one gate) © Nexperia B.V. 2017. All rights reserved. 2 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate 6 Pinning information 6.1 Pinning 74LVC2G00 1A 1 8 VCC 1B 2 7 1Y 2Y 3 6 2B GND 4 5 2A 74LVC2G00 1A 1 8 VCC 1B 2 7 1Y 2Y 3 6 2B GND 4 5 2A 001aab737 Transparent top view 001aab736 Figure 4.  Pin configuration SOT505-2 and SOT765-1 Figure 5.  Pin configuration SOT833-1, SOT1089, SOT1116 and SOT1203 74LVC2G00 1 74LVC2G00 8 1Y VCC terminal 1 index area 7 1A 1A 1 2B 2 6 1B 2A 3 5 2Y 4 GND Product data sheet 2 6 2B 5 2A 4 GND 2Y 3 001aae980 aaa-023988 Transparent top view 74LVC2G00 1Y VCC 1B Figure 6.  Pin configuration SOT902-2 7 8 Transparent top view Figure 7.  Pin configuration SOT1233 All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate 6.2 Pin description Table 3. Pin description Symbol Pin Description SOT505-2, SOT765-1, SOT833-1, SOT1089, SOT1116, SOT1203 and SOT1233 SOT902-2 1A, 2A 1, 5 7, 3 data input 1B, 2B 2, 6 6, 2 data input GND 4 4 ground (0 V) 1Y, 2Y 7, 3 1, 5 data output VCC 8 8 supply voltage 7 Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level. Output Input nA nB nY L L H L H H H L H H H L 74LVC2G00 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate 8 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI VO Conditions Min Max Unit -0.5 +6.5 V input voltage [1] -0.5 +6.5 V output voltage [1] -0.5 VCC + 0.5 V [1] [2] -0.5 +6.5 V -50 - mA Active mode Power-down mode IIK input clamping current VI < 0 V IOK output clamping current VO < 0 V or VO > VCC - ±50 mA IO output current VO = 0 V to VCC - ±50 mA ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C - 300 mW Ptot [1] [2] [3] total power dissipation Tamb = -40 °C to +125 °C [3] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K. For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K. For XSON8 and XQFN8 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K. For X2SON8 package: above 118 °C the value of Ptot derates linearly with 7.7 mW/K. 9 Recommended operating conditions Table 6. Operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature Δt/ΔV input transition rise and fall rate 74LVC2G00 Product data sheet Min Max 1.65 5.5 V 0 5.5 V Active mode 0 VCC V Power-down mode 0 5.5 V -40 +125 °C VCC = 1.65 V to 2.7 V - 20 ns/V VCC = 2.7 V to 5.5 V - 10 ns/V All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 Unit © Nexperia B.V. 2017. All rights reserved. 5 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate 10 Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ [1] Max Unit Tamb = -40 °C to +85 °C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VCC = 1.65 V to 1.95 V 0.65 x VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7 x VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3 x VCC V VCC - 0.1 - - V IO = -4 mA; VCC = 1.65 V 1.2 1.53 - V IO = -8 mA; VCC = 2.3 V 1.9 2.13 - V IO = -12 mA; VCC = 2.7 V 2.2 2.50 - V IO = -24 mA; VCC = 3.0 V 2.3 2.60 - V IO = -32 mA; VCC = 4.5 V 3.8 4.10 - V IO = 100 μA; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - 0.08 0.45 V IO = 8 mA; VCC = 2.3 V - 0.14 0.3 V IO = 12 mA; VCC = 2.7 V - 0.19 0.4 V IO = 24 mA; VCC = 3.0 V - 0.37 0.55 V IO = 32 mA; VCC = 4.5 V - 0.43 0.55 V VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 5.5 V VOL LOW-level output voltage 0.35 x VCC V VI = VIH or VIL II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - ±0.1 ±1 μA IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V - ±0.1 ±2 μA ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - 0.1 4 μA ΔICC additional supply current per pin; VI = VCC - 0.6 V; VCC = 2.3 V to 5.5 V; IO = 0 A - 5 500 μA CI input capacitance - 2.5 - pF 74LVC2G00 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate Symbol Parameter Conditions Min Typ [1] Max Unit Tamb = -40 °C to +125 °C VIH HIGH-level input voltage VIL LOW-level input voltage VOH HIGH-level output voltage VCC = 1.65 V to 1.95 V 0.65 x VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7 x VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3 x VCC V VCC - 0.1 - - V IO = -4 mA; VCC = 1.65 V 0.95 - - V IO = -8 mA; VCC = 2.3 V 1.7 - - V IO = -12 mA; VCC = 2.7 V 1.9 - - V IO = -24 mA; VCC = 3.0 V 2.0 - - V IO = -32 mA; VCC = 4.5 V 3.4 - - V IO = 100 μA; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.80 V VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 5.5 V VOL LOW-level output voltage 0.35 x VCC V VI = VIH or VIL II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - ±1 μA IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V - - ±2 μA ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - - 4 μA ΔICC additional supply current per pin; VI = VCC - 0.6 V; VCC = 2.3 V to 5.5 V; IO = 0 A - - 500 μA [1] All typical values are measured at Tamb = 25 °C. 74LVC2G00 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate 11 Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground 0 V); for test circuit see Figure 9. Symbol Parameter tpd Conditions -40 °C to +85 °C Min Typ VCC = 1.65 V to 1.95 V 1.2 VCC = 2.3 V to 2.7 V power dissipation -40 °C to +125 °C Unit Max Min Max 3.5 8.6 1.2 10.8 ns 0.7 2.3 4.8 0.7 6.0 ns VCC = 2.7 V 0.7 3.0 5.6 0.7 7.0 ns VCC = 3.0 V to 3.6 V 0.7 2.2 4.3 0.7 5.4 ns VCC = 4.5 V to 5.5 V 0.5 1.8 3.3 0.5 4.2 ns - 14 - - - pF propagation delay nA, nB to nY; see Figure 8 CPD [1] per gate; VI = GND to VCC [2] [3] capacitance [1] [2] [3] Typical values are measured at nominal VCC and at Tamb = 25 °C. tpd is the same as tPLH and tPHL CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + ∑(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑(CL x VCC x fo) = sum of outputs. 11.1 Waveforms and test circuit VI VM nA, nB input GND t PHL t PLH VOH nY output VM 001aae972 VOL Measurement points are given in Table 9. VOL and VOH are typical output voltage levels that occur with the output load. Figure 8.  Input (nA, nB) to output (nY) propagation delays 74LVC2G00 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate Table 9. Measurement points Supply voltage Input Output VCC VM VM 1.65 V to 1.95 V 0.5 x VCC 0.5 x VCC 2.3 V to 2.7 V 0.5 x VCC 0.5 x VCC 2.7 V 1.5 V 1.5 V 3.0 V to 3.6 V 1.5 V 1.5 V 4.5 V to 5.5 V 0.5 x VCC 0.5 x VCC VI negative pulse tW 90 % VM 0V VI tf tr tr tf 90 % positive pulse 0V VM 10 % VM VM 10 % tW VEXT VCC PULSE GENERATOR VI RL VO DUT RT CL RL 001aae235 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = Test voltage for switching times. Figure 9.  Test circuit for measuring switching times Table 10. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open 74LVC2G00 Product data sheet VEXT Load All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate 12 Package outline TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm D E A SOT505-2 X c HE y v M A Z 5 8 A A2 pin 1 index (A3) A1 θ Lp L 1 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e HE L Lp v w y Z(1) θ mm 1.1 0.15 0.00 0.95 0.75 0.25 0.38 0.22 0.18 0.08 3.1 2.9 3.1 2.9 0.65 4.1 3.9 0.5 0.47 0.33 0.2 0.13 0.1 0.70 0.35 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT505-2 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 02-01-16 --- Figure 10.  Package outline SOT505-2 (TSSOP8) 74LVC2G00 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D SOT765-1 E A X c y HE v A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 detail X 4 e L w bp 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm A max. max nom min 1 A1 A2 0.15 0.85 0.00 0.60 A3 0.12 D(1) E(2) 0.27 0.23 2.1 2.4 0.17 0.08 1.9 2.2 bp c e HE 0.5 3.2 3.0 L 0.4 Lp Q 0.40 0.21 0.15 0.19 v 0.2 w 0.08 y 0.1 Z(1) θ 0.4 8° 0.1 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version SOT765-1 References IEC JEDEC JEITA sot765-1_po European projection Issue date 07-06-02 16-05-31 MO-187 Figure 11.  Package outline SOT765-1 (VSSOP8) 74LVC2G00 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm 1 2 SOT833-1 b 4 3 4× (2) L L1 e 8 7 6 e1 5 e1 e1 8× A (2) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max A1 max b D E e e1 L L1 mm 0.5 0.04 0.25 0.17 2.0 1.9 1.05 0.95 0.6 0.5 0.35 0.27 0.40 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT833-1 --- MO-252 --- EUROPEAN PROJECTION ISSUE DATE 07-11-14 07-12-07 Figure 12.  Package outline SOT833-1 (XSON8) 74LVC2G00 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1 x 0.5 mm SOT1089 E terminal 1 index area D A A1 detail X (4×)(2) e L (8×)(2) b 4 5 e1 1 terminal 1 index area 8 L1 X 0 0.5 scale Dimensions Unit mm max nom min 1 mm A(1) 0.5 A1 b D E e e1 L L1 0.04 0.20 1.40 1.05 0.35 0.40 0.15 1.35 1.00 0.55 0.35 0.30 0.35 0.12 1.30 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version SOT1089 sot1089_po References IEC JEDEC JEITA European projection Issue date 10-04-09 10-04-12 MO-252 Figure 13.  Package outline SOT1089 (XSON8) 74LVC2G00 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate XQFN8: plastic, extremely thin quad flat package; no leads; 8 terminals; body 1.6 x 1.6 x 0.5 mm SOT902-2 X D B A terminal 1 index area E A A1 detail X e v w b 4 3 C C A B C y1 C y 5 e1 terminal 1 index area 2 6 L 1 7 k 8 L2 L k metal area not for soldering L3 L1 0 1 Dimensions Unit(1) mm max nom min 2 mm scale A 0.5 A1 b D E e e1 0.05 0.25 1.65 1.65 0.20 1.60 1.60 0.55 0.00 0.15 1.55 1.55 0.5 k 0.2 L L1 L2 L3 0.35 0.15 0.25 0.35 0.30 0.10 0.20 0.30 0.25 0.05 0.15 0.25 v 0.1 w y y1 0.05 0.05 0.05 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. References Outline version IEC JEDEC JEITA SOT902-2 --- MO-255 --- sot902-2_po European projection Issue date 16-07-14 16-11-08 Figure 14.  Package outline SOT902-2 (XQFN8) 74LVC2G00 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.2 x 1.0 x 0.35 mm 1 2 SOT1116 b 4 3 (4×)(2) L L1 e 8 7 e1 6 e1 5 e1 (8×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 max 0.35 0.04 0.20 1.25 1.05 nom 0.15 1.20 1.00 0.55 min 0.12 1.15 0.95 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1116_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1116 Figure 15.  Package outline SOT1116 (XSON8) 74LVC2G00 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 15 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1.0 x 0.35 mm SOT1203 b 1 2 3 (4×)(2) 4 L L1 e 8 7 6 e1 e1 5 e1 (8×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.40 1.05 0.35 0.40 nom 0.15 1.35 1.00 0.55 0.35 0.30 0.35 min 0.12 1.30 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1203_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1203 Figure 16.  Package outline SOT1203 (XSON8) 74LVC2G00 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 16 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate X2SON8: plastic thermal enhanced extremely thin small outline package; no leads; 8 terminals; body 1.35 x 0.8 x 0.35 mm SOT1233 X A B D A E A1 detail X pin 1 index area e e 1 2 pin 1 index area C b (6x) 8 v w 3 C A B C y 4 Dh L (6x) 7 6 b1 (2x) 5 y1 C e1 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 max 0.35 0.04 nom 0.32 min 0.30 0.00 b 0.25 0.20 0.15 b1 D Dh E 1.40 0.27 0.85 0.15 1.35 0.22 0.80 (ref) 1.30 0.17 0.75 e 0.5 e1 L 0.27 0.54 0.22 0.17 v 0.1 w y y1 0.05 0.05 0.05 sot1233_po Outline version SOT1233 References IEC JEDEC JEITA European projection Issue date 16-04-21 17-01-05 --- Figure 17.  Package outline SOT1233 (X2SON8) 74LVC2G00 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 17 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate 13 Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14 Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC2G00 v.15 20170703 Product data sheet - 74LVC2G00 v.14 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. • Figure 17: Package outline drawing for SOT1233 has changed. • Type number 74LVC2G00GD removed. 74LVC2G00 v.14 20161212 Modifications: • Table 7: The maximum limits for leakage current and supply current have changed. 74LVC2G00 v.13 20161028 Modifications: • Added type number 74LVC2G00GX (SOT1233/X2SON8) 74LVC2G00 v.12 20130408 Modifications: • For type number 74LVC2G00GD XSON8U has changed to XSON8. 74LVC2G00 v.11 20120622 Modifications: • For type number 74LVC2G00GM the SOT code has changed to SOT902-2. 74LVC2G00 v.10 20111130 Modifications: • Legal pages updated. 74LVC2G00 v.9 20100608 74LVC2G00 v.8 Product data sheet Product data sheet Product data sheet Product data sheet - 74LVC2G00 v.13 74LVC2G00 v.12 74LVC2G00 v.11 74LVC2G00 v.10 - 74LVC2G00 v.9 Product data sheet - 74LVC2G00 v.8 20091026 Product data sheet - 74LVC2G00 v.7 74LVC2G00 v.7 20080610 Product data sheet - 74LVC2G00 v.6 74LVC2G00 v.6 20080220 Product data sheet - 74LVC2G00 v.5 74LVC2G00 v.5 20070904 Product data sheet - 74LVC2G00 v.4 74LVC2G00 v.4 20060515 Product data sheet - 74LVC2G00 v.3 74LVC2G00 v.3 20050201 Product specification - 74LVC2G00 v.2 74LVC2G00 v.2 20040923 Product specification - 74LVC2G00 v.1 74LVC2G00 v.1 20031117 Product specification - - 74LVC2G00 Product data sheet Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 18 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74LVC2G00 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 19 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74LVC2G00 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 15 — 3 July 2017 © Nexperia B.V. 2017. All rights reserved. 20 / 21 74LVC2G00 Nexperia Dual 2-input NAND gate Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Marking .................................................................2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 4 Functional description ........................................4 Limiting values .................................................... 5 Recommended operating conditions ................ 5 Static characteristics .......................................... 6 Dynamic characteristics .....................................8 Waveforms and test circuit ................................ 8 Package outline .................................................10 Abbreviations .................................................... 18 Revision history ................................................ 18 Legal information .............................................. 19 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 3 July 2017 Document identifier: 74LVC2G00
74LVC2G00GXX 价格&库存
很抱歉,暂时无法提供与“74LVC2G00GXX”相匹配的价格&库存,您可以联系我们找货
