74LVC8T595
Dual supply 8-bit serial-in/serial-out or parallel-out shift
register; 3-state
Rev. 1 — 9 May 2017
1
Product data sheet
General description
The 74LVC8T595 is an 8-bit serial-in/serial or parallel-out shift register with a storage
register and 3-state outputs. Both the shift and storage register have separate clocks.
Data is shifted on the positive-going transitions of the SHCP input. The data in the shift
register is transferred to the storage register on a positive-going transition of the STCP
input. If both clocks are connected together, the shift register is always one clock pulse
ahead of the storage register.
VCC(A) and VCC(B) can be supplied at any voltage between 1.1 V and 5.5 V making the
device suitable for translating between any of the voltage nodes (1.2 V, 1.5 V, 1.8 V,
2.5 V, 3.3 V and 5.0 V). Pins MR, SHCP, STCP, OE, DS and Q7S are referenced to
VCC(A) and pins Qn are referenced to VCC(B).
The device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing any damaging backflow current through the
device when it is powered down. In suspend mode when VCC(A) is at GND level, the Qn
outputs are in the high-impedance OFF-state.
2
Features and benefits
• Wide supply voltage range:
– VCC(A): 1.1 V to 5.5 V
– VCC(B): 1.1 V to 5.5 V
• High noise immunity
• Complies with JEDEC standards:
– JESD8-12A (1.1 V to 1.3 V)
– JESD8-11A (1.4 V to 1.6 V)
– JESD8-7 (1.65 V to 1.95 V)
– JESD8-5 (2.3 V to 2.7 V)
– JESD8C (3.0 V to 3.6 V)
– JESD12-6 (4.5 V to 5.5 V)
• ESD protection:
– HBM ANSI/ESDA/JEDEC JS-001 Class 3A exceeds 4000V
– CDM JESD22-C101E exceeds 1000 V
• Suspend mode
• Latch-up performance exceeds 100 mA per JESD 78 Class II
• ±24 mA output drive (VCC(A) = VCC(B) = 3.0 V)
• Inputs accept voltages up to 5.5 V
• IOFF circuitry provides partial Power-down mode operation
• Multiple package options
• Specified from -40 °C to +85 °C and -40 °C to +125 °C
74LVC8T595
Nexperia
Dual supply 8-bit serial-in/serial-out or parallel-out shift register; 3-state
3
Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74LVC8T595PW
-40 °C to +125 °C
TSSOP20
plastic thin shrink small outline package;
20 leads; body width 4.4 mm
SOT360-1
74LVC8T595BQ
-40 °C to +125 °C
DHVQFN20
plastic dual in-line compatible thermal
enhanced very thin quad flat package; no leads;
20 terminals; body 2.5 x 4.5 x 0.85 mm
SOT764-1
4
Functional diagram
VCC(A)
16
17
SHCP
STCP
Q7S
Q0
Q1
19
Q2
DS
Q3
Q4
Q5
Q5
Q7
MR
15
14
2
19
DS
16
SHCP
15
MR
8-STAGE SHIFT REGISTER
3
4
5
Q7S
17
STCP
18
OE
8-BIT STORAGE REGISTER
6
7
8
3-STATE OUTPUTS
VCC(B)
9
OE
18
Q0 Q1 Q2 Q3
Q4 Q5 Q6 Q7
2
6
3
4
aaa-026283
Figure 1. Logic symbol
74LVC8T595
Product data sheet
14
5
7
8
9
aaa-026284
Figure 2. Functional diagram
All information provided in this document is subject to legal disclaimers.
Rev. 1 — 9 May 2017
© Nexperia B.V. 2017. All rights reserved.
2 / 33
74LVC8T595
Nexperia
VCC(A)
STAGE 0
DS
D
STAGES 1 TO 6
Q
D
STAGE 7
Q
D
FF0
Q
Q7S
FF7
CP R
CP R
SHCP
MR
D
Q
D
FF8
Q
FF15
CP
CP
STCP
OE
VCC(B)
Q0
Q1 Q2 Q3 Q4 Q5 Q6
Q7
aaa-026285
Figure 3. Logic diagram
SHCP
DS
STCP
MR
OE
Z-state
Q0
Z-state
Q1
Z-state
Q6
Z-state
Q7
Q7S
mna556
Figure 4. Timing diagram
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
3 / 33
74LVC8T595
Nexperia
5
Pinning information
5.1 Pinning
VCC(B)
1
terminal 1
index area
74LVC8T595
20 VCC(A)
74LVC8T595
Q0
2
19 DS
Q1
3
18 OE
Q2
4
17 STCP
VCC(B)
1
20 VCC(A)
Q0
2
19 DS
Q1
3
18 OE
Q3
5
16 SHCP
6
15 MR
17 STCP
Q3
5
16 SHCP
Q5
7
Q4
6
15 MR
Q5
7
14 Q7S
Q6
8
Q6
8
13 GND
Q7
9
Q7
9
12 GND
GND 10
11 GND
14 Q7S
GND(1)
13 GND
12 GND
GND 11
4
GND 10
Q2
Q4
aaa-026287
Transparent top view
aaa-026286
(1) This is not a supply pin. The substrate is attached to
this pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to GND.
Figure 5. Pin configuration SOT360-1 (TSSOP20)
Figure 6. Pin configuration SOT764-1 (DHVQFN20)
5.2 Pin description
Table 2. Pin description
Symbol
Pin
Description
VCC(B)
1
supply voltage B (Qn outputs)
Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7 2, 3, 4, 5, 6, 7, 8, 9 data output
GND
10, 11, 12, 13
ground (0 V)
Q7S
14
serial data output
MR
15
master reset input (active LOW)
SHCP
16
shift register clock input
STCP
17
storage register clock input
OE
18
output enable input (active LOW)
DS
19
serial data input
VCC(A)
supply voltage A (MR, SHCP, STCP, OE, DS inputs and Q7S
output)
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
4 / 33
74LVC8T595
Nexperia
6
Functional description
Table 3. Function table
Supply
voltage
[1]
Input
Output
Function
VCC(A), VCC(B) SHCP STCP OE
MR
DS
Q7S
Qn
1.2 V to 5.5 V
X
X
L
L
X
L
NC
a LOW-state on MR only affects the shift
register
1.2 V to 5.5 V
X
L
L
X
L
L
empty shift register loaded into storage
register
1.2 V to 5.5 V
X
X
H
L
X
L
Z
shift register clear; parallel outputs in highimpedance OFF-state
1.2 V to 5.5 V
X
L
H
H
Q6S
NC
logic HIGH-state shifted into shift register
stage 0. Contents of all shift register
stages shifted through, e.g. previous state
of stage 6 (internal Q6S) appears on the
serial output (Q7S).
1.2 V to 5.5 V
X
L
H
X
NC
QnS
contents of shift register stages (internal
QnS) are transferred to the storage
register and parallel output stages
1.2 V to 5.5 V
L
H
X
Q6S
QnS
contents of shift register shifted through;
previous contents of the shift register is
transferred to the storage register and the
X
X
X
X
X
X
Z
suspend mode
GND
[1]
[2]
[2]
H = HIGH voltage state;
L = LOW voltage state;
↑ = LOW-to-HIGH transition;
X = don’t care;
NC = no change;
Z = high-impedance OFF-state.
When VCC(A) is at GND level, the device goes into suspend mode.
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
5 / 33
74LVC8T595
Nexperia
7
Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC(A)
Min
Max
Unit
supply voltage A
-0.5
+6.5
V
VCC(B)
supply voltage B
-0.5
+6.5
V
IIK
input clamping current
-50
-0.5
+6.5
VI
input voltage
IOK
output clamping current
VO
output voltage
Conditions
VI < 0 V
[1]
VO < 0 V
-50
-0.5
VCCO + 0.5
V
Suspend or 3-state mode
[1]
-0.5
+6.5
V
[2]
±50
mA
100
mA
-100
mA
-65
+150
°C
500
mW
Active mode
output current
VO = 0 V to VCCO
ICC
supply current
ICC(A) or ICC(B)
IGND
ground current
Tstg
storage temperature
[1]
[2]
[3]
[4]
total power dissipation
V
[1] [2] [3]
IO
Ptot
mA
Tamb = -40 °C to +125 °C
[4]
mA
The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed.
VCCO is the supply voltage associated with the output.
VCCO + 0.5 V should not exceed 6.5 V
For TSSOP20 package: above 60 °C the value of Ptot derates linearly with 5.5 mW/K.
For DHVQFN20 package: above 60 °C the value of Ptot derates linearly with 4.5 mW/K.
8
Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
VCC(A)
Min
Max
supply voltage A
1.1
5.5
V
VCC(B)
supply voltage B
1.1
5.5
V
VI
input voltage
V
VCCO
V
V
-40
+125
°C
VCC(A) = 1.1 V to 1.3 V
ns/V
VCC(A) = 1.4 V to 1.95 V
ns/V
VCC(A) = 2.3 V to 2.7 V
ns/V
VCC(A) = 3 V to 3.6 V
10
ns/V
VCC(A) = 4.5 V to 5.5 V
5
ns/V
VO
Conditions
Active mode
output voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
[1]
[1]
Unit
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
6 / 33
74LVC8T595
Nexperia
9
Static characteristics
Table 6. Typical static characteristics at Tamb = 25 °C
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
VOH
HIGH-level output
voltage
VI = VIH or VIL
LOW-level output
voltage
VI = VIH or VIL
input leakage
current
MR, SHCP, STCP, OE and DS inputs;
OFF-state output
current
Qn outputs; VO = 0 V or VCC(B)
VOL
II
IOZ
IOFF
power-off leakage
current
Min
Typ
Max
[1]
1.09
V
[1]
0.07
V
±1
μA
VCC(B) = 1.1 V to 5.5 V
±1
μA
suspend mode; VCC(A) = 0 V; VCC(B) = 5.5 V
±1
μA
±1
μA
±1
μA
3
pF
IO = -3 mA; VCCO = 1.2 V
IO = 3 mA; VCCO = 1.2 V
Unit
VI = 0 V to 5.5 V; VCC(A) = 1.1 V to 5.5 V
[1]
inputs, Q7S output;
VI or VO = 0 V to 5.5 V;
VCC(A) = 0 V; VCC(B) = 1.1 V to 5.5 V
Qn outputs;
VCC(B) = 0 V; VCC(A) = 1.1 V to 5.5 V
CI
input capacitance
VI = 0 V or 3.3 V; VCC(A) = VCC(B) = 3.3 V
[1]
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
7 / 33
74LVC8T595
Nexperia
Table 7. Static characteristics
Symbol Parameter
VIH
VIL
VOH
Conditions
-40 °C to +85 °C
Min
Max
Min
Max
Unit
HIGH-level
0.65VCC(A)
0.65VCC(A)
V
input voltage
VCC(A) = 1.4 V to 1.6 V
0.65VCC(A)
0.65VCC(A)
V
VCC(A) = 1.65 V to 1.95 V
0.65VCC(A)
0.65VCC(A)
V
1.7
1.7
V
VCC(A) = 3.0 V to 3.6 V
2.0
2.0
V
0.7VCC(A)
0.7VCC(A)
V
LOW-level
0.35VCC(A)
0.35VCC(A) V
input voltage
0.35VCC(A)
0.35VCC(A) V
0.35VCC(A)
0.35VCC(A) V
0.7
0.7
V
0.8
0.8
V
0.3VCC(A)
VCCO - 0.1
VCCO - 0.1
V
IO = -2 mA; VCCO = 1.1 V
0.825
0.825
V
IO = -6 mA; VCCO = 1.4 V
1.0
1.0
V
IO = -8 mA; VCCO = 1.65 V
1.2
1.2
V
IO = -12 mA; VCCO = 2.3 V
1.9
1.9
V
IO = -24 mA; VCCO = 3.0 V
2.4
2.4
V
IO = -24 mA; VCCO = 4.5 V
3.85
3.85
V
3.8
3.8
V
IO = 100 μA;
VCCO = 1.1 V to 4.5 V
0.1
0.1
V
IO = 2 mA; VCCO = 1.1 V
0.275
0.275
V
IO = 6 mA; VCCO = 1.4 V
0.3
0.3
V
IO = 8 mA; VCCO = 1.65 V
0.45
0.45
V
IO = 12 mA; VCCO = 2.3 V
0.3
0.3
V
IO = 24 mA; VCCO = 3.0 V
0.55
0.55
V
IO = 24 mA; VCCO = 4.5 V
0.50
0.50
V
IO = 32 mA; VCCO = 4.5 V
0.55
0.55
V
HIGH-level
output voltage
LOW-level
output voltage
74LVC8T595
Product data sheet
0.3VCC(A) V
[1]
VI = VIH
IO = -100 μA;
IO = -32 mA; VCCO = 4.5 V
VOL
-40 °C to +125 °C
[1]
VI = VIL
Rev. 1 — 9 May 2017
8 / 33
74LVC8T595
Nexperia
Symbol Parameter
II
IOZ
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Max
Min
Max
±2
±10
μA
±2
±10
μA
suspend mode;
±2
±10
μA
±2
±10
μA
±2
±10
μA
VCC(A), VCC(B) = 1.1 V to 5.5 V
2
5
μA
VCC(A) = 5.5 V; VCC(B) = 0 V
2
5
μA
-1
-2
μA
9
24
μA
VCC(B) = 5.5 V; VCC(A) = 0 V
9
24
μA
VCC(B) = 0 V; VCC(A) = 5.5 V
-1
-2
μA
MR, SHCP, STCP, OE inputs;
one input at VCC(A) - 0.6 V;
DS input at VCC(A) or GND;
Qn = open
50
75
μA
DS input at VCC(A) - 0.6 V;
Qn = open
50
75
μA
input leakage
VI = 0 V to 5.5 V;
current
OFF-state
output current
IOFF
Conditions
power-off
inputs, Q7S output;
leakage
current
VCC(A) = 0 V;
Qn outputs;
VCC(B) = 0 V;
ICC
supply current
VCC(A) domain;
VI = 0 V or VCC(A); IO = 0 A
VCC(B) domain;
ΔICC
[1]
additional
per input;
supply current
VCC(A), VCC(B) = 3.0 V to 5.5 V
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
9 / 33
74LVC8T595
Nexperia
10 Dynamic characteristics
Table 8. Typical power dissipation capacitance at VCC(A) = VCC(B) and Tamb = 25 °C
[1] [2]
Symbol Parameter
CPD
[1]
[2]
Conditions
VCC(A) and VCC(B)
Unit
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
5.0 V
power dissipation
inputs
31
31
32
33
36
43
pF
capacitance
outputs
105
104
103
101
99
98
pF
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + Σ(CL × VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of the outputs.
fi = 10 MHz; VI = GND to VCC; tr = tf = 1 ns; CL = 0 pF; RL = ∞ Ω.
Table 9. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 13; for waveforms see Figure 7 up to Figure 12.
Symbol Parameter
Conditions
VCC(A)
1.2 V ± 0.1 V
Unit
1.5 V ± 0.1 V
1.8 V ± 0.15 V
Min
Typ
Max
Min
Typ
Max
Min
Typ
Max
5.8
21.3
38.9
4.5
14.2
20.9
3.7
10.9
16.7 ns
14.7 ns
Tamb = +25 °C; VCC(B) = 1.1 V to 5.5V
[1]
tpd
propagation delay
SHCP to Q7S
tPHL
HIGH to LOW
MR to Q7S
5.9
22.7
42.1
4.5
14.8
18.9
3.7
11.2
SHCP, STCP
6.9
1.9
3.5
1.4
2.6
1.1
ns
MR LOW
12.4
3.5
5.6
2.1
3.9
1.5
ns
DS to SHCP
3.0
1.1
2.6
0.5
2.3
0.3
ns
MR to STCP
15.5
7.2
7.9
4.0
5.5
2.8
ns
SHCP to
13.5
5.4
6.5
3.0
4.9
2.1
ns
propagation delay
tW
pulse width
HIGH or LOW
tsu
set-up time
STCP
th
hold time
DS to SHCP
3.0
±0.4
2.0
±0.2
1.5
±0.1
ns
trec
recovery time
MR to SHCP
2.0
-0.4
1.5
-0.2
1.3
-0.2
ns
fmax
maximum frequency SHCP
45
73
75
99
90
120
MHz
[1]
tpd is the same as tPHL, tPLH.
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
10 / 33
74LVC8T595
Nexperia
Table 10. Dynamic characteristics
Symbol Parameter
Conditions
VCC(A)
2.5 V ± 0.2 V
Unit
3.3 V ± 0.3 V
5.0 V ± 0.5 V
Min
Typ
Max
Min
Typ
Max
Min
Typ
Max
2.7
7.3
11.5
2.3
5.6
9.1
1.9
4.1
6.6
ns
[1]
tpd
propagation delay
SHCP to Q7S
tPHL
HIGH to LOW
MR to Q7S
2.9
7.4
10.0
2.4
5.7
7.9
2.1
4.4
6.1
ns
SHCP, STCP
1.6
0.7
1.4
0.6
1.0
0.5
ns
MR LOW
2.5
1.0
1.6
0.8
1.4
0.6
ns
DS to SHCP
1.9
0.2
1.5
0.1
1.1
0.1
ns
MR to STCP
3.2
1.7
2.4
1.3
2.2
1.1
ns
SHCP to
2.8
1.2
1.9
0.9
1.4
0.6
ns
propagation delay
tW
pulse width
HIGH or LOW
tsu
set-up time
STCP
th
hold time
DS to SHCP
1.5
±0.1
1.0
±0.1
1.0
±0.1
ns
trec
recovery time
MR to SHCP
1.0
-0.1
1.0
-0.1
1.0
-0.1
ns
fmax
135
160
175
194
195
250
MHz
[1]
Table 11. Dynamic characteristics for temperature +25 °C
[1]
Symbol Parameter
Conditions
VCC(B)
1.2 V ± 0.1 V
Unit
1.5 V ± 0.1 V
1.8 V ± 0.15 V
Min
Typ
Max
Min
Typ
Max
Min
Typ
Max
VCC(A) = 1.2 V ± 0.1 V
tpd
propagation delay
STCP to Qn
6.2
23.7
46.4
5.3
19.1
35.4
4.8
16.9
31.6 ns
tdis
disable time
OE to Qn
3.6
12.7
25.1
3.0
9.7
15.6
3.1
9.0
14.4 ns
ten
enable time
OE to Qn
5.8
20.9
40.0
4.6
15.1
26.2
3.9
12.6
21.7 ns
fmax
maximum frequency STCP
35
69
45
88
45
110
tsk(o)
output skew time
3.0
2.3
1.9
74LVC8T595
Product data sheet
Q0 to Q7
[2]
Rev. 1 — 9 May 2017
MHz
ns
11 / 33
74LVC8T595
Nexperia
Symbol Parameter
Conditions
VCC(B)
1.2 V ± 0.1 V
Unit
1.5 V ± 0.1 V
1.8 V ± 0.15 V
Min
Typ
Max
Min
Typ
Max
Min
Typ
Max
VCC(A) = 1.5 V ± 0.1 V
tpd
propagation delay
STCP to Qn
5.7
20.2
32.1
4.9
15.5
23.3
4.3
13.3
20.0 ns
tdis
disable time
OE to Qn
3.4
11.4
20.1
2.8
8.3
13.2
2.8
7.6
11.7 ns
ten
enable time
OE to Qn
5.5
19.9
38.7
4.2
13.9
24.1
3.6
11.3
19.3 ns
fmax
45
73
70
95
90
120
2.7
2.0
1.7
tsk(o)
output skew time
[2]
Q0 to Q7
MHz
ns
VCC(A) = 1.8 V ± 0.15 V
tpd
propagation delay
STCP to Qn
5.4
18.7
30.3
4.5
14.0
21.4
4
11.8
18.3 ns
tdis
disable time
OE to Qn
3.2
10.8
19.4
2.6
7.8
12.6
2.6
7.0
11.0 ns
ten
enable time
OE to Qn
5.4
19.4
38.1
4.1
13.4
23.7
3.5
10.7
18.7 ns
fmax
45
75
70
98
90
125
2.7
2.0
1.6
tsk(o)
output skew time
[2]
Q0 to Q7
MHz
ns
VCC(A) = 2.5 V ± 0.2 V
tpd
propagation delay
STCP to Qn
5.1
17.3
28.3
4.2
12.6
19.5
3.6
10.4
16.3 ns
tdis
disable time
OE to Qn
3.0
10.3
18.8
2.4
7.2
11.9
2.4
6.4
10.3 ns
ten
enable time
OE to Qn
5.3
18.9
37.7
4.1
13.0
23.3
3.4
10.2
18.1 ns
fmax
45
76
70
100
90
128
2.6
2.0
1.6
tsk(o)
output skew time
[2]
Q0 to Q7
MHz
ns
VCC(A) = 3.3 V ± 0.3 V
tpd
propagation delay
STCP to Qn
4.9
16.7
27.6
4.0
12.0
18.7
3.4
9.8
15.4 ns
tdis
disable time
OE to Qn
3.0
10.0
18.4
2.3
6.9
11.4
2.3
6.1
10.0 ns
ten
enable time
OE to Qn
5.3
18.8
37.6
4.1
12.9
23.0
3.4
10.1
18.0 ns
fmax
45
76
70
101
90
130
2.6
2.0
1.6
tsk(o)
output skew time
[2]
Q0 to Q7
MHz
ns
VCC(A) = 5.0 V ± 0.5 V
tpd
propagation delay
STCP to Qn
4.8
16.1
27.5
3.9
11.4
18.0
3.3
9.2
14.8 ns
tdis
disable time
OE to Qn
2.8
9.6
19.4
2.2
6.6
11.3
2.3
5.9
9.6
ten
enable time
OE to Qn
5.4
18.7
38.3
4.1
12.8
23.1
3.4
10.1
18.3 ns
fmax
45
77
70
102
90
132
2.7
2.0
1.6
tsk(o)
[1]
[2]
output skew time
Q0 to Q7
[2]
ns
MHz
ns
tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH.
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
12 / 33
74LVC8T595
Nexperia
Table 12. Dynamic characteristics for temperature +25 °C
[1]
Symbol Parameter
Conditions
VCC(B)
2.5 V ± 0.2 V
Unit
3.3 V ± 0.3 V
5.0 V ± 0.5 V
Min
Typ
Max
Min
Typ
Max
Min
Typ
Max
tpd
propagation delay
STCP to Qn
4.2
14.5
27.9
3.8
13.4
26.3
3.5
12.4
24.9 ns
tdis
disable time
OE to Qn
2.6
7.4
12.0
2.9
7.7
12.4
2.4
6.6
11.3 ns
ten
enable time
OE to Qn
3.3
10.1
16.8
2.9
9.2
15.8
2.7
8.9
15.9 ns
fmax
45
131
45
139
45
144
tsk(o)
output skew time
1.4
1.2
1.0
[2]
Q0 to Q7
MHz
ns
tpd
propagation delay
STCP to Qn
3.7
10.9
16.2
3.3
9.7
14.5
3.0
8.7
13.0 ns
tdis
disable time
OE to Qn
2.2
6.0
9.2
2.6
6.2
9.4
2.1
5.0
8.1
ten
enable time
OE to Qn
2.9
8.6
14.1
2.6
7.5
12.1
2.4
6.7
10.6 ns
fmax
130
144
130
187
130
224
tsk(o)
output skew time
1.2
1.0
0.7
[2]
Q0 to Q7
ns
MHz
ns
tpd
propagation delay
STCP to Qn
3.4
9.4
14.4
3.0
8.2
12.6
2.7
7.2
10.9 ns
tdis
disable time
OE to Qn
2.0
5.3
8.3
2.4
5.5
8.5
1.9
4.3
7.2
ns
ten
enable time
OE to Qn
2.7
8.0
13.3
2.4
6.7
11.1
2.2
5.8
9.4
ns
fmax
130
151
165
197
205
237
tsk(o)
output skew time
1.2
0.9
0.7
ns
[2]
Q0 to Q7
MHz
tpd
propagation delay
STCP to Qn
3.0
7.9
12.4
2.6
6.7
10.5
2.3
5.7
8.8
ns
tdis
disable time
OE to Qn
1.9
4.6
7.5
2.2
4.8
7.5
1.7
3.5
6.0
ns
ten
enable time
OE to Qn
2.7
7.4
12.6
2.3
6.0
10.2
2.0
4.9
8.2
ns
fmax
130
156
165
210
215
252
tsk(o)
output skew time
1.2
0.9
0.7
ns
[2]
Q0 to Q7
MHz
tpd
propagation delay
STCP to Qn
2.8
7.3
11.5
2.4
6.1
9.6
2.1
5.0
7.9
ns
tdis
disable time
OE to Qn
1.8
4.4
7.1
2.1
4.5
7.1
1.6
3.2
5.5
ns
ten
enable time
OE to Qn
2.6
7.2
12.3
2.3
5.8
10.0
2.0
4.6
7.8
ns
fmax
130
159
165
213
215
255
tsk(o)
output skew time
1.2
0.9
0.7
74LVC8T595
Product data sheet
Q0 to Q7
[2]
Rev. 1 — 9 May 2017
MHz
ns
13 / 33
74LVC8T595
Nexperia
Symbol Parameter
Conditions
VCC(B)
2.5 V ± 0.2 V
Unit
3.3 V ± 0.3 V
5.0 V ± 0.5 V
Min
Typ
Max
Min
Typ
Max
Min
Typ
Max
tpd
propagation delay
STCP to Qn
2.7
6.8
10.9
2.3
5.5
8.9
1.8
4.4
7.2
ns
tdis
disable time
OE to Qn
1.7
4.1
6.8
2.0
4.3
6.7
1.4
2.9
5.1
ns
ten
enable time
OE to Qn
2.7
7.2
12.4
2.3
5.8
10.0
2.0
4.6
7.7
ns
fmax
130
159
165
213
215
254
1.1
0.9
0.7
tsk(o)
[1]
[2]
output skew time
Q0 to Q7
[2]
MHz
ns
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
14 / 33
74LVC8T595
Nexperia
Table 13. Dynamic characteristics
Symbol Parameter
Conditions
VCC(A)
Unit
1.2 V ± 0.1 V
1.5 V ± 0.1 V
1.8 V ± 0.15 V
2.5 V ± 0.2 V
3.3 V ± 0.3 V
5.0 V ± 0.5 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
3.4
42.1
2.7
22.1
2.1
17.7
1.5
12.4
1.3
9.8
1.0
7.2
ns
Tamb = -40 °C to +85 °C; VCC(B) = 1.1 V to 5.5V
[1]
tpd
propagation delay
SHCP to Q7S
tPHL
HIGH to LOW
MR to Q7S
3.6
43.6
2.7
20.2
2.2
16.0
1.7
11.0
1.4
8.7
1.3
6.6
ns
SHCP, STCP
7.8
4.8
3.3
2.0
1.7
1.3
ns
MR LOW
12.8
6.2
4.4
2.8
2.3
1.4
ns
DS to SHCP
4.5
3.0
2.6
2.3
1.9
1.5
ns
MR to STCP
16.5
9.1
6.1
3.6
2.9
2.3
ns
SHCP to
13.5
7.7
5.4
3.2
2.3
1.8
ns
propagation delay
tW
pulse width
HIGH or LOW
tsu
set-up time
STCP
th
hold time
DS to SHCP
3.0
2.0
1.5
1.5
1.0
1.0
ns
trec
recovery time
MR to SHCP
2.2
1.7
1.5
1.2
1.2
1.2
ns
fmax
40
70
90
130
160
175
MHz
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
15 / 33
74LVC8T595
Nexperia
Symbol Parameter
Conditions
VCC(A)
Unit
1.2 V ± 0.1 V
1.5 V ± 0.1 V
1.8 V ± 0.15 V
2.5 V ± 0.2 V
3.3 V ± 0.3 V
5.0 V ± 0.5 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
3.4
42.1
2.7
22.7
2.1
18.3
1.5
12.9
1.3
10.3
1.0
7.6
ns
Tamb = -40 °C to +125 °C; VCC(B) = 1.1 V to 5.5V
[1]
tpd
propagation delay
SHCP to Q7S
tPHL
HIGH to LOW
MR to Q7S
3.6
44.3
2.7
21.0
2.2
16.7
1.7
11.5
1.4
9.1
1.3
7.0
ns
SHCP, STCP
8.4
5.3
3.8
2.5
1.9
1.4
ns
MR LOW
13.3
6.9
5.2
3.1
2.4
1.6
ns
DS to SHCP
4.5
3.0
2.6
2.3
1.9
1.5
ns
MR to STCP
16.5
9.5
6.8
4.2
3.1
2.4
ns
SHCP to
14.2
8.0
6.2
3.6
2.3
1.8
ns
propagation delay
tW
pulse width
HIGH or LOW
tsu
set-up time
STCP
th
hold time
DS to SHCP
3.5
2.5
2.0
2.0
1.5
1.2
ns
trec
recovery time
MR to SHCP
2.4
1.9
1.7
1.4
1.4
1.4
ns
fmax
40
70
85
120
150
170
MHz
[1]
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
16 / 33
74LVC8T595
Nexperia
Table 14. Dynamic characteristics for temperature range -40 °C to +85 °C
[1]
Symbol Parameter
Conditions
VCC(B)
Unit
1.2 V ± 0.1 V
1.5 V ± 0.1 V
1.8 V ± 0.15 V
2.5 V ± 0.2 V
3.3 V ± 0.3 V
5.0 V ± 0.5 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
tpd
propagation delay
STCP to Qn
3.8
48.3
3.2
36.7
2.8
33.0
2.4
29.2
2.2
27.7
2.0
26.0
ns
tdis
disable time
OE to Qn
2.1
26.6
1.8
17.2
1.8
15.8
1.5
13.1
1.8
13.4
1.4
12.3
ns
ten
enable time
OE to Qn
3.5
42.1
2.7
27.0
2.2
22.6
1.9
18.0
1.7
17.0
1.6
17.2
ns
fmax
30
40
40
40
40
40
tsk(o)
output skew time
3.5
2.5
2.0
1.5
1.2
1.0
ns
Q0 to Q7
[2]
MHz
tpd
propagation delay
STCP to Qn
3.5
34.2
2.9
25.6
2.5
22.4
2.1
18.5
1.9
16.8
1.7
15.1
ns
tdis
disable time
OE to Qn
2.0
21.6
1.7
14.8
1.7
13.1
1.3
10.3
1.6
10.4
1.3
9.0
ns
ten
enable time
OE to Qn
3.3
38.9
2.6
25.0
2.1
20.3
1.7
15.1
1.5
13.2
1.4
11.7
ns
fmax
40
65
80
105
105
105
tsk(o)
output skew time
3.1
2.2
1.8
1.3
1.0
0.8
ns
Q0 to Q7
[2]
MHz
tpd
propagation delay
STCP to Qn
3.3
31.8
2.7
23.4
2.3
20.4
1.9
16.4
1.7
14.5
1.5
12.8
ns
tdis
disable time
OE to Qn
1.9
20.9
1.5
14.2
1.6
12.4
1.2
9.4
1.4
9.4
1.1
8.0
ns
ten
enable time
OE to Qn
3.3
38.6
2.4
24.5
2.0
19.7
1.6
14.4
1.4
12.1
1.3
10.5
ns
fmax
40
65
80
120
145
155
tsk(o)
output skew time
3.1
2.2
1.8
1.2
1.0
0.8
74LVC8T595
Product data sheet
Q0 to Q7
[2]
Rev. 1 — 9 May 2017
MHz
ns
17 / 33
74LVC8T595
Nexperia
Symbol Parameter
Conditions
VCC(B)
Unit
1.2 V ± 0.1 V
1.5 V ± 0.1 V
1.8 V ± 0.15 V
2.5 V ± 0.2 V
3.3 V ± 0.3 V
5.0 V ± 0.5 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
tpd
propagation delay
STCP to Qn
3.1
29.6
2.5
21.2
2.1
18.1
1.7
14.0
1.5
12.1
1.3
10.2
ns
tdis
disable time
OE to Qn
1.8
20.2
1.4
13.2
1.4
11.6
1.1
8.5
1.3
8.3
1.0
6.6
ns
ten
enable time
OE to Qn
3.2
37.7
2.4
24.0
2.0
19.1
1.5
13.5
1.3
11.1
1.2
9.0
ns
fmax
40
65
80
120
145
180
3.1
2.2
1.8
1.2
1.0
0.7
ns
tsk(o)
output skew time
Q0 to Q7
[2]
MHz
tpd
propagation delay
STCP to Qn
3.0
29.1
2.4
20.3
2.0
17.2
1.6
13.0
1.4
11.0
1.2
9.1
ns
tdis
disable time
OE to Qn
1.7
19.7
1.3
13.0
1.4
11.2
1.0
8.1
1.3
7.9
0.9
6.0
ns
ten
enable time
OE to Qn
3.2
38.1
2.4
23.7
2.0
19.0
1.5
13.3
1.3
10.7
1.2
8.5
ns
fmax
40
65
80
120
145
190
3.0
2.2
1.8
1.2
1.0
0.7
ns
tsk(o)
output skew time
Q0 to Q7
[2]
MHz
tpd
propagation delay
STCP to Qn
2.9
29.1
2.3
19.6
1.9
16.3
1.5
12.2
1.3
10.2
1.1
8.2
ns
tdis
disable time
OE to Qn
1.6
20.6
1.3
12.6
1.3
10.9
0.9
7.7
1.2
7.5
0.8
5.6
ns
ten
enable time
OE to Qn
3.3
38.9
2.5
23.8
2.0
19.1
1.6
13.3
1.4
10.6
1.2
8.3
ns
fmax
40
65
80
120
145
190
3.0
2.2
1.7
1.2
0.9
0.7
tsk(o)
[1]
[2]
output skew time
Q0 to Q7
[2]
MHz
ns
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
18 / 33
74LVC8T595
Nexperia
Table 15. Dynamic characteristics for temperature range -40 °C to +125 °C
[1]
Symbol Parameter
Conditions
VCC(B)
Unit
1.2 V ± 0.1 V
1.5 V ± 0.1 V
1.8 V ± 0.15 V
2.5 V ± 0.2 V
3.3 V ± 0.3 V
5.0 V ± 0.5 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
tpd
propagation delay
STCP to Qn
3.8
48.3
3.2
37.4
2.8
34.0
2.4
30.4
2.2
28.6
2.0
27.0
ns
tdis
disable time
OE to Qn
2.1
27.6
1.8
18.0
1.8
16.5
1.5
13.7
1.8
14.1
1.4
12.8
ns
ten
enable time
OE to Qn
3.5
42.1
2.7
27.6
2.2
23.2
1.9
18.6
1.7
17.8
1.6
18.0
ns
fmax
30
40
40
40
40
40
tsk(o)
output skew time
3.6
2.6
2.1
1.5
1.3
1.0
ns
Q0 to Q7
[2]
MHz
tpd
propagation delay
STCP to Qn
3.5
34.4
2.9
26.3
2.5
23.3
2.1
19.6
1.9
17.7
1.7
16.1
ns
tdis
disable time
OE to Qn
2.0
22.7
1.7
15.7
1.7
14.0
1.3
11.0
1.6
11.0
1.3
9.5
ns
ten
enable time
OE to Qn
3.3
38.9
2.6
25.5
2.1
20.8
1.7
15.8
1.5
13.8
1.4
12.3
ns
fmax
40
65
75
95
95
95
tsk(o)
output skew time
3.1
2.2
1.8
1.3
1.0
0.8
ns
Q0 to Q7
[2]
MHz
tpd
propagation delay
STCP to Qn
3.3
32.1
2.7
24.1
2.3
21.1
1.9
17.3
1.7
15.3
1.5
13.6
ns
tdis
disable time
OE to Qn
1.9
21.9
1.5
14.9
1.6
13.2
1.2
10.1
1.4
10.0
1.1
8.4
ns
ten
enable time
OE to Qn
3.3
38.6
2.4
24.8
2.0
20.3
1.6
14.9
1.4
12.7
1.3
11.0
ns
fmax
40
65
75
105
140
140
tsk(o)
output skew time
3.1
2.2
1.8
1.2
1.0
0.8
74LVC8T595
Product data sheet
Q0 to Q7
[2]
Rev. 1 — 9 May 2017
MHz
ns
19 / 33
74LVC8T595
Nexperia
Symbol Parameter
Conditions
VCC(B)
Unit
1.2 V ± 0.1 V
1.5 V ± 0.1 V
1.8 V ± 0.15 V
2.5 V ± 0.2 V
3.3 V ± 0.3 V
5.0 V ± 0.5 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
tpd
propagation delay
STCP to Qn
3.1
29.7
2.5
21.8
2.1
18.8
1.7
14.7
1.5
12.7
1.3
10.8
ns
tdis
disable time
OE to Qn
1.8
21.2
1.4
14.2
1.4
12.4
1.1
9.1
1.3
8.8
1.0
7.0
ns
ten
enable time
OE to Qn
3.2
37.7
2.4
24.4
2.0
19.7
1.5
14.1
1.3
11.6
1.2
9.4
ns
fmax
40
65
75
105
140
175
3.1
2.2
1.8
1.2
1.0
0.7
ns
tsk(o)
output skew time
Q0 to Q7
[2]
MHz
tpd
propagation delay
STCP to Qn
3.0
29.1
2.4
20.8
2.0
17.7
1.6
13.5
1.4
11.6
1.2
9.6
ns
tdis
disable time
OE to Qn
1.7
20.9
1.3
13.8
1.4
12.1
1.0
8.7
1.3
8.3
0.9
6.4
ns
ten
enable time
OE to Qn
3.2
38.1
2.4
24.3
2.0
19.5
1.5
13.7
1.3
11.2
1.2
8.9
ns
fmax
40
65
75
105
140
175
3.0
2.2
1.8
1.2
1.0
0.7
ns
tsk(o)
output skew time
Q0 to Q7
[2]
MHz
tpd
propagation delay
STCP to Qn
2.9
29.1
2.3
20.0
1.9
16.7
1.5
12.7
1.3
10.6
1.1
9.0
ns
tdis
disable time
OE to Qn
1.6
21.7
1.3
13.6
1.3
11.7
0.9
8.3
1.2
7.9
0.8
6.0
ns
ten
enable time
OE to Qn
3.3
38.9
2.5
24.3
2.0
19.5
1.6
13.8
1.4
11.0
1.2
8.6
ns
fmax
40
65
75
105
140
175
3.0
2.2
1.7
1.2
0.9
0.7
tsk(o)
[1]
[2]
output skew time
Q0 to Q7
[2]
MHz
ns
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
20 / 33
74LVC8T595
Nexperia
10.1 Waveforms and test circuit
1/fmax
VI
SHCP input
VM
GND
tW
t PHL
t PLH
VOH
VM
Q7S output
VOL
mna557
Measurement points are given in Table 16.
VOL and VOH are typical output voltage levels that occur with the output load.
Figure 7. The shift clock (SHCP) to serial data output (Q7S) propagation delays, the shift clock pulse width and
maximum shift clock frequency
VI
SHCP input
VM
GND
1/fmax
t su
VI
STCP input
VM
GND
tW
t PHL
t PLH
VOH
VM
Qn output
VOL
mna558
Figure 8. The storage clock (STCP) to parallel data output (Qn) propagation delays, the storage clock pulse width
and the shift clock to storage clock set-up time
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
21 / 33
74LVC8T595
Nexperia
VI
VM
SHCP input
GND
t su
t su
th
th
VI
VM
DS input
GND
VOH
VM
Q7S output
VOL
mna560
Figure 9. The data set-up and hold times for the serial data input (DS)
VI
MR input
GND
VI
STCP input
VM
tsu
VM
GND
VOH
Qn outputs
VM
VOL
001aaf571
Figure 10. The master reset (MR) to storage clock (STCP) set-up time
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
22 / 33
74LVC8T595
Nexperia
VI
VM
MR input
GND
tW
t rec
VI
SHCP input
VM
GND
t PHL
VOH
VM
Q7S output
VOL
mna561
Figure 11. The master reset (MR) pulse width, the master reset to serial data output (Q7S) propagation delays and
the master reset to shift clock (SHCP) recovery time
VI
VM
OE input
GND
tPLZ
output
LOW-to-OFF
OFF-to-LOW
tPZL
VCC
VM
VX
VOL
tPHZ
VOH
output
HIGH-to-OFF
OFF-to-HIGH
tPZH
VY
VM
GND
outputs
enabled
outputs
enabled
outputs
disabled
001aae821
VOL and VOH are typical output voltage drops that occur with the output load.
Figure 12. 3-state enable and disable times
Table 16. Measurement points
Supply voltage
Input
Output
VCC(A), VCC(B)
VM
VM (Qn)
VM (Q7S)
VX
VY
1.1 V to 1.6 V
0.5VCC(A)
0.5VCC(B)
0.5VCC(A)
VOL + 0.1 V
VOH - 0.1 V
1.65 V to 2.7 V
0.5VCC(A)
0.5VCC(B)
0.5VCC(A)
VOL + 0.15 V
VOH - 0.15 V
3.0 V to 5.5 V
0.5VCC(A)
0.5VCC(B)
0.5VCC(A)
VOL + 0.3 V
VOH - 0.3 V
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
23 / 33
74LVC8T595
Nexperia
tW
VI
90 %
negative
pulse
VM
VM
10 %
0V
tf
tr
tr
VI
tf
90 %
positive
pulse
VM
VM
10 %
0V
tW
VEXT
VCC
VI
G
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 17 .
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Figure 13. Test circuit for measuring switching times
Table 17. Test data
Supply voltage
Input
VCC(A), VCC(B)
VI
Δt/ΔV
1.1 V to 5.5 V
VCC(A)
≤ 1.0 ns/V
[1]
Load
[1]
VEXT
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
15 pF
2 kΩ
open
GND
2VCC(B)
dV/dt ≥ 1.0 V/ns
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
24 / 33
74LVC8T595
Nexperia
10.2 Typical propagation delay characteristics
tPHL
(ns)
aaa-024634
30
25
(1)
tPLH
(ns)
aaa-024633
30
(1)
25
(2)
(3)
(4)
15
(4)
(5)
15
(5)
(6)
(6)
10
10
5
5
10
15
30
CL (pF)
10
15
30
CL (pF)
a. HIGH to LOW propagation delay (STCP to Qn)
b. LOW to HIGH propagation delay (STCP to Qn)
(1) VCC(B) = 1.2 V
(2) VCC(B) = 1.5 V
(3) VCC(B) = 1.8 V
(4) VCC(B) = 2.5 V
(5) VCC(B) = 3.3 V
(6) VCC(B) = 5.0 V
35
Figure 14. Typical propagation delay versus load capacitance; VCC(A) = 1.2 V; Tamb = 25 °C
tPHL
(ns)
aaa-024636
30
tPLH
(ns)
25
aaa-024635
30
25
(1)
(1)
(2)
15
(3)
15
(3)
(4)
(5)
(4)
(5)
10
10
(6)
(6)
5
10
15
30
CL (pF)
35
10
15
30
CL (pF)
(1) VCC(B) = 1.2 V
(4) VCC(B) = 2.5 V
(2) VCC(B) = 1.5 V
(5) VCC(B) = 3.3 V
(3) VCC(B) = 1.8 V
(6) VCC(B) = 5.0 V
35
Figure 15. Typical propagation delay versus load capacitance; VCC(A) = 1.5 V; Tamb = 25 °C
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
25 / 33
74LVC8T595
Nexperia
tPHL
(ns)
aaa-024638
30
tPLH
(ns)
25
aaa-024637
30
25
(1)
(1)
(2)
15
15
(3)
(4)
(5)
10
(3)
(4)
(5)
(6)
10
(6)
5
10
15
30
CL (pF)
10
15
30
CL (pF)
(1) VCC(B) = 1.2 V
(4) VCC(B) = 2.5 V
(2) VCC(B) = 1.5 V
(5) VCC(B) = 3.3 V
(3) VCC(B) = 1.8 V
(6) VCC(B) = 5.0 V
35
Figure 16. Typical propagation delay versus load capacitance; VCC(A) = 1.8 V; Tamb = 25 °C
tPHL
(ns)
aaa-024640
30
tPLH
(ns)
25
aaa-024639
30
25
15
(2)
15
(2)
(3)
(3)
10
10
(4)
(4)
(5)
(5)
(6)
5
10
15
30
CL (pF)
(6)
5
35
10
15
30
CL (pF)
(1) VCC(B) = 1.2 V
(4) VCC(B) = 2.5 V
(2) VCC(B) = 1.5 V
(5) VCC(B) = 3.3 V
(3) VCC(B) = 1.8 V
(6) VCC(B) = 5.0 V
35
Figure 17. Typical propagation delay versus load capacitance; VCC(A) = 2.5 V; Tamb = 25 °C
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
26 / 33
74LVC8T595
Nexperia
tPHL
(ns)
aaa-024642
30
tPLH
(ns)
25
aaa-024641
30
25
15
(2)
15
(2)
(3)
(3)
10
(4)
(5)
(6)
5
10
15
30
CL (pF)
(4)
(5)
(6)
5
10
15
30
CL (pF)
(1) VCC(B) = 1.2 V
(4) VCC(B) = 2.5 V
(2) VCC(B) = 1.5 V
(5) VCC(B) = 3.3 V
(3) VCC(B) = 1.8 V
(6) VCC(B) = 5.0 V
35
Figure 18. Typical propagation delay versus load capacitance; VCC(A) = 3.3 V; Tamb = 25 °C
tPHL
(ns)
aaa-024644
30
tPLH
(ns)
25
25
15
(3)
(6)
10
15
30
CL (pF)
(2)
(3)
10
(4)
(5)
5
(1)
15
(2)
10
aaa-024643
30
(4)
(5)
(6)
5
35
10
15
30
CL (pF)
(1) VCC(B) = 1.2 V
(4) VCC(B) = 2.5 V
(2) VCC(B) = 1.5 V
(5) VCC(B) = 3.3 V
(3) VCC(B) = 1.8 V
(6) VCC(B) = 5.0 V
35
Figure 19. Typical propagation delay versus load capacitance; VCC(A) = 5 V; Tamb = 25 °C
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
27 / 33
74LVC8T595
Nexperia
11 Package outline
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
D
SOT360-1
E
A
X
c
HE
y
v M A
Z
11
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
10
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Figure 20. Package outline SOT360-1 (TSSOP20)
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
28 / 33
74LVC8T595
Nexperia
DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
B
D
SOT764-1
A
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
e1
C
e
b
2
9
v
w
C A B
C
y1 C
y
L
1
10
Eh
e
19
12
X
Dh
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A(1)
A1
b
max 1.00 0.05 0.30
nom 0.90 0.02 0.25
min 0.80 0.00 0.18
c
D(1)
Dh
E(1)
Eh
e
e1
L
v
0.2
4.6
4.5
4.4
3.15
3.00
2.85
2.6
2.5
2.4
1.15
1.00
0.85
0.5
3.5
0.5
0.4
0.3
0.1
w
y
0.05 0.05
y1
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
References
Outline
version
IEC
JEDEC
JEITA
SOT764-1
MO-241
sot764-1_po
European
projection
Issue date
03-01-27
14-12-12
Figure 21. Package outline SOT764-1 (DHVQFN20)
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
29 / 33
74LVC8T595
Nexperia
12 Abbreviations
Table 18. Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
13 Revision history
Table 19. Table 19. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC8T595 v.1
20170509
Product data sheet
74LVC8T595
Product data sheet
Rev. 1 — 9 May 2017
30 / 33
74LVC8T595
Nexperia
14 Legal information
14.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
14.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74LVC8T595
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Rev. 1 — 9 May 2017
31 / 33
74LVC8T595
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74LVC8T595
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
14.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Rev. 1 — 9 May 2017
32 / 33
74LVC8T595
Nexperia
Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
10.1
10.2
11
12
13
14
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 2
Functional diagram ............................................. 2
Pinning information ............................................ 4
Pinning ............................................................... 4
Pin description ................................................... 4
Functional description ........................................5
Limiting values .................................................... 6
Recommended operating conditions ................ 6
Static characteristics .......................................... 7
Dynamic characteristics ...................................10
Waveforms and test circuit .............................. 21
Typical propagation delay characteristics ........ 25
Package outline .................................................28
Abbreviations .................................................... 30
Revision history ................................................ 30
Legal information .............................................. 31
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 9 May 2017
Document identifier: 74LVC8T595
