74LVCH16373ADGVJ
74LVCH16373ADGVJ
    NEXPERIA(安世)
    TSSOP48_12.5X6.1MM
    锁存器 TSSOP48_12.5X6.1MM 1.2V~3.6V
74LVCH16373ADGVJ 数据手册
74LVC16373A; 74LVCH16373A 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state Rev. 9 — 15 February 2019 Product data sheet 1. General description The 74LVC16373A and 74LVCH16373A are 16-bit D-type transparent latches featuring separate D-type inputs with bus hold (74LVCH16373A only) for each latch and 3-state outputs for bus-oriented applications. One Latch Enable (LE) input and one Output Enable (OE) are provided for each octal. Inputs can be driven from either 3.3 V or 5 V devices. When disabled, up to 5.5 V can be applied to the outputs. These features allow the use of these devices in mixed 3.3 V and 5 V applications. The device consists of two sections of eight D-type transparent latches with 3-state true outputs. When LE is HIGH, data at the Dn inputs enter the latches. In this condition, the latches are transparent, that is, the latch outputs change each time its corresponding D-input changes. The latches store the information that was present at the D-inputs one set-up time (tsu) preceding the HIGH-to-LOW transition of LE. When OE is LOW, the contents of the eight latches are available at the outputs. When OE is HIGH, the outputs go to the high impedance OFF-state. Operation of the OE input does not affect the state of the latches. Bus hold on the data inputs eliminates the need for external pull-up resistors to hold unused inputs. 2. Features and benefits • • • • • • • • • • • 5 V tolerant inputs/outputs for interfacing with 5 V logic Wide supply voltage range from 1.2 V to 3.6 V CMOS low power consumption Multibyte flow-through standard pinout architecture Multiple low inductance supply pins for minimum noise and ground bounce Direct interface with TTL levels All data inputs have bus hold (74LVCH16373A only) High-impedance when VCC = 0 V Complies with JEDEC standard: • JESD8-7A (1.65 V to 1.95 V) • JESD8-5A (2.3 V to 2.7 V) • JESD8-C/JESD36 (2.7 V to 3.6 V) ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-B exceeds 200 V • CDM ANSI/ESDA/Jedec JS-002 exceeds 1000 V Specified from -40 °C to +85 °C and -40 °C to +125 °C 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version -40 °C to +125 °C TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 74LVC16373ADL -40 °C to +125 °C SSOP48 plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 74LVC16373ADGV -40 °C to +125 °C TSSOP48 [1] plastic thin shrink small outline package; 48 leads; body width 4.4 mm; lead pitch 0.4 mm 74LVC16373ADGG 74LVCH16373ADGG 74LVCH16373ADGV [1] SOT480-1 Also known as TVSOP48. 4. Functional diagram 1 24 1OE 1OE 2OE 2OE 1LE 47 1D0 1Q0 2 46 1D1 1Q1 3 44 1D2 1Q2 5 43 1D3 1Q3 6 41 1D4 1Q4 8 40 1D5 1Q5 9 38 1D6 1Q6 11 37 1D7 1Q7 12 36 2D0 2Q0 13 35 2D1 2Q1 14 33 2D2 2Q2 16 32 2D3 2Q3 17 30 2D4 2Q4 19 29 2D5 2Q5 20 27 2D6 2Q6 22 26 2D7 2Q7 23 1LE 2LE 48 25 2LE 1D0 1D1 1D2 1D3 1D4 1D5 1D6 1D7 2D0 2D1 2D2 2D3 2D4 2D5 2D6 2D7 Fig. 1. Logic symbol 74LVC_LVCH16373A Product data sheet 1 48 24 25 47 46 1EN C3 2EN C4 3D 2 1 3 44 5 43 6 41 8 40 9 38 11 37 12 36 13 35 4D 2 14 33 16 32 17 30 19 29 20 27 22 26 23 mgu768 1Q0 1Q1 1Q2 1Q3 1Q4 1Q5 1Q6 1Q7 2Q0 2Q1 2Q2 2Q3 2Q4 2Q5 2Q6 2Q7 mgu770 Fig. 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 2 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state 1D0 D 1Q0 Q 2D0 D LATCH 1 LE 2Q0 Q LATCH 9 LE LE 1LE 2LE 1OE 2OE to 7 other channels LE to 7 other channels mgu769 Fig. 3. Logic diagram VCC data input to internal circuit mgu771 Fig. 4. Bus hold circuit 74LVC_LVCH16373A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 3 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state 5. Pinning information 5.1. Pinning 1OE 1 48 1LE 1Q0 2 47 1D0 1Q1 3 46 1D1 GND 4 45 GND 1Q2 5 44 1D2 1Q3 6 43 1D3 VCC 7 42 VCC 1Q4 8 41 1D4 1Q5 9 40 1D5 GND 10 39 GND 1Q6 11 38 1D6 1Q7 12 37 1D7 16373A 2Q0 13 36 2D0 2Q1 14 35 2D1 GND 15 34 GND 2Q2 16 33 2D2 2Q3 17 32 2D3 VCC 18 31 VCC 2Q4 19 30 2D4 2Q5 20 29 2D5 GND 21 28 GND 2Q6 22 27 2D6 2Q7 23 26 2D7 2OE 24 25 2LE 001aad112 Fig. 5. Pin configuration SOT370-1 (SSOP48), SOT362-1 (TSSOP48) and SOT480-1 (TSSOP48) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE 1, 24 output enable input (active LOW) 1LE, 2LE 48, 25 latch enable input (active HIGH) GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) VCC 7, 18, 31, 42 supply voltage 1Q0 to 1Q7 2, 3, 5, 6, 8, 9, 11, 12 data output 2Q0 to 2Q7 13, 14, 16, 17, 19, 20, 22, 23 data output 1D0 to 1D7 47, 46, 44, 43, 41, 40, 38, 37 data input 2D0 to 2D7 36, 35, 33, 32, 30, 29, 27, 26 data input 74LVC_LVCH16373A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 4 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state 6. Functional description Table 3. Function table Per section of eight bits. H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the HIGH to LOW LE transition L = LOW voltage level; l = LOW voltage level one set-up time prior to the HIGH to LOW LE transition Z = high-impedance OFF-state Operating modes Input Internal latch Output nQ0 to nQ7 nOE nLE nDn Enable and read register (transparent mode) L H L L L L H H H H Latch and read register L L l L L L L h H H Latch register and disable outputs H L l L Z H L h H Z 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO > VCC or VO < 0 VO output voltage output HIGH or LOW state output 3-state Min Max Unit -0.5 +6.5 V -50 - -0.5 +6.5 V - ±50 mA [2] -0.5 VCC + 0.5 V [2] -0.5 +6.5 V - ±50 mA VI < 0 [1] IO output current ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] [3] VO = 0 V to VCC mA Tamb = -40 °C to +125 °C [3] The minimum input voltage ratings may be exceeded if the input current ratings are observed. The output voltage ratings may be exceeded if the output current ratings are observed. Above 60 °C, the value of Ptot derates linearly with 5.5 mW/K. 74LVC_LVCH16373A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 5 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC 1.65 - 3.6 V 1.2 - 3.6 V 0 - 5.5 V output HIGH or LOW state 0 - VCC V output 3-state 0 - 5.5 V -40 - +125 °C supply voltage functional VI input voltage VO output voltage Tamb ambient temperature in free air Δt/ΔV input transition rise and fall rate VCC = 1.2 V to 2.7 V 0 - 20 ns/V VCC = 2.7 V to 3.6 V 0 - 10 ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage Conditions -40 °C to +85 °C VCC = 1.2 V Typ [1] Max Min Max 1.08 - - 1.08 - V - - 0.65VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 1.2 V - - 0.12 - 0.12 V VCC = 1.65 V to 1.95 V - - 0.35VCC - VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC - 0.2 - - VCC - 0.3 - V IO = -4 mA; VCC = 1.65 V 1.2 - - 1.05 - V IO = -8 mA; VCC = 2.3 V 1.8 - - 1.65 - V IO = -12 mA; VCC = 2.7 V 2.2 - - 2.05 - V IO = -18 mA; VCC = 3.0 V 2.4 - - 2.25 - V IO = -24 mA; VCC = 3.0 V 2.2 - - 2.0 - V - - 0.2 - 0.3 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.65 V IO = 8 mA; VCC = 2.3 V - - 0.6 - 0.8 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V VI = VIH or VIL LOW-level output voltage IO = 100 μA; VCC = 1.65 V to 3.6 V Product data sheet Min Unit 0.65VCC VCC = 1.65 V to 1.95 V VI = VIH or VIL HIGH-level output voltage IO = -100 μA; VCC = 1.65 V to 3.6 V 74LVC_LVCH16373A -40 °C to +125 °C All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © 0.35VCC V Nexperia B.V. 2019. All rights reserved 6 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Min Typ [1] Max Min Max Unit II input leakage VCC = 3.6 V; current VI = 5.5 V or GND [2] - ±0.1 ±5 - ±20 μA IOZ OFF-state VI = VIH or VIL; VCC = 3.6 V; output current VO = 5.5 V or GND [2] - ±0.1 ±5 - ±20 μA IOFF power-off leakage current - ±0.1 ±10 - ±20 μA ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - 0.1 20 - 80 μA ΔICC additional per input pin; supply current VCC = 2.7 V to 3.6 V; VI = VCC - 0.6 V; IO = 0 A - 5 500 - 5000 μA CI input capacitance - 5.0 - - - pF IBHL bus hold LOW VCC = 1.65; VI = 0.58 V current VCC = 2.3; VI = 0.7 V 10 - - 10 - μA 30 - - 25 - μA 75 - - 60 - μA -10 - - -10 - μA -30 - - -25 - μA -75 - - -60 - μA 200 - - 200 - μA 300 - - 300 - μA VCC = 0 V; VI or VO = 5.5 V VCC = 0 V to 3.6 V; VI = GND to VCC [3] [4] VCC = 3.0; VI = 0.8 V IBHH VCC = 1.65; VI = 1.07 V bus hold HIGH current V = 2.3; V = 1.7 V CC I [3] [4] VCC = 3.0; VI = 2.0 V IBHLO IBHHO [1] [2] [3] [4] [5] bus hold LOW VCC = 1.95 V overdrive VCC = 2.7 V current VCC = 3.6 V [3] [5] VCC = 1.95 V [3] [5] bus hold HIGH overdrive current 500 - - 500 - μA -200 - - -200 - μA VCC = 2.7 V -300 - - -300 - μA VCC = 3.6 V -500 - - -500 - μA All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C. The bus hold circuit is switched off when VI > VCC allowing 5.5 V on the input pin. Valid for data inputs (74LVCH16373A) only; control inputs do not have a bus hold circuit. The specified sustaining current at the data inputs holds the input below the specified VI level. The specified overdrive current at the data input forces the data input to the opposite logic input state. 74LVC_LVCH16373A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 7 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 10. Symbol Parameter Conditions -40 °C to +85 °C Min tpd propagation delay Dn to Qn; see Fig. 6 Typ [1] -40 °C to +125 °C Unit Max Min Max [2] VCC = 1.2 V - 12 - - - ns VCC = 1.65 V to 1.95 V 1.5 5.4 11.4 1.5 13.2 ns VCC = 2.3 V to 2.7 V 1.0 2.9 5.7 1.0 6.6 ns VCC = 2.7 V 1.5 2.9 4.9 1.5 6.5 ns VCC = 3.0 V to 3.6 V 1.0 2.4 4.4 1.0 5.5 ns - 14 - - - ns VCC = 1.65 V to 1.95 V 2.0 6.4 12.4 2.0 14.4 ns VCC = 2.3 V to 2.7 V 1.5 3.4 6.1 1.5 7.1 ns VCC = 2.7 V 1.5 3.0 5.3 1.5 7.0 ns 1.5 2.9 4.8 1.5 6.0 ns - 18 - - - ns VCC = 1.65 V to 1.95 V 1.5 5.5 12.4 1.5 14.3 ns VCC = 2.3 V to 2.7 V 1.0 3.1 6.6 1.0 7.6 ns VCC = 2.7 V 1.5 3.3 5.7 1.5 7.5 ns VCC = 3.0 V to 3.6 V 1.0 2.5 4.9 1.0 6.5 ns - 11 - - - ns VCC = 1.65 V to 1.95 V 2.8 4.5 9.1 2.8 10.5 ns VCC = 2.3 V to 2.7 V 1.0 2.5 5.1 1.0 6.0 ns VCC = 2.7 V 1.5 3.3 6.3 1.5 8.0 ns VCC = 3.0 V to 3.6 V 1.5 3.1 5.4 1.5 7.0 ns VCC = 1.65 V to 1.95 V 5.0 - - 5.0 - ns VCC = 2.3 V to 2.7 V 4.0 - - 4.0 - ns VCC = 2.7 V 3.0 - - 3.0 - ns VCC = 3.0 V to 3.6 V 3.0 2.0 - 3.0 - ns VCC = 1.65 V to 1.95 V 3.0 - - 3.0 - ns VCC = 2.3 V to 2.7 V 2.5 - - 2.5 - ns VCC = 2.7 V 2.0 - - 2.0 - ns VCC = 3.0 V to 3.6 V 2.0 1.0 - 2.0 - ns VCC = 1.65 V to 1.95 V 2.5 - - 2.5 - ns VCC = 2.3 V to 2.7 V 2.0 - - 2.0 - ns VCC = 2.7 V 0.9 - - 0.9 - ns VCC = 3.0 V to 3.6 V +0.9 -1.0 - +0.9 - ns LE to Qn; see Fig. 7 VCC = 1.2 V VCC = 3.0 V to 3.6 V ten enable time OE to Qn; see Fig. 8 [2] VCC = 1.2 V tdis disable time OE to Qn; see Fig. 8 VCC = 1.2 V tW tsu th pulse width set-up time hold time 74LVC_LVCH16373A Product data sheet [2] LE HIGH; see Fig. 7 Dn to LE; see Fig. 9 Dn to LE; see Fig. 9 All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 8 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state Symbol Parameter Conditions -40 °C to +85 °C Min Typ [1] Max Min Max - - 1.0 - 1.5 ns VCC = 1.65 V to 1.95 V - 10.8 - - - pF VCC = 2.3 V to 2.7 V - 13.0 - - - pF VCC = 3.0 V to 3.6 V - 15.0 - - - pF tsk(o) output skew time VCC = 3.0 V to 3.6 V [3] CPD power dissipation capacitance per input; VI = GND to VCC [4] [1] [2] [3] [4] -40 °C to +125 °C Unit Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V and 3.3 V respectively. tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching 2 Σ(CL × VCC × fo) = sum of the outputs 10.1. Waveforms and test circuit VI LE input VM t PHL t PHL t PLH Qn output Product data sheet VM mgu773 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. mgu772 Input (Dn) to output (Qn) propagation delays 74LVC_LVCH16373A VM VOL VM Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. t PLH VOH VOH VOL VM tW VM GND Qn output VM GND VI Dn input VM Fig. 7. Latch enable input (LE) pulse width, and the latch enable input to output (Qn) propagation delays All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 9 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state VI OE input VM VM GND t PLZ t PZL VCC Qn output LOW-to-OFF OFF-to-LOW VM VX VOL t PZH t PHZ VOH Qn output HIGH-to-OFF OFF-to-HIGH VY VM GND outputs enabled outputs enabled outputs disabled mgu775 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 8. 3-state enable and disable times VI VM Dn input GND t su th t su th VI VM LE input GND mgu774 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. The shaded areas indicate when the input is permitted to change for predictable output performance. Fig. 9. Data set-up and hold times for the Dn input to the LE input Table 8. Measurement points Supply voltage Input Output VCC VI VM VM VX VY 1.2 V VCC 0.5 × VCC 0.5 × VCC VOL + 0.15 V VOH - 0.15 V 1.65 V to 1.95 V VCC 0.5 × VCC 0.5 × VCC VOL + 0.15 V VOH - 0.15 V 2.3 V to 2.7 V VCC 0.5 × VCC 0.5 × VCC VOL + 0.15 V VOH - 0.15 V 2.7 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 3.0 V to 3.6 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74LVC_LVCH16373A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 10 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state tW VI 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 10. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.2 V VCC ≤ 2 ns 30 pF 1 kΩ open 2 × VCC GND 1.65 V to 1.95 V VCC ≤ 2 ns 30 pF 1 kΩ open 2 × VCC GND 2.3 V to 2.7 V VCC ≤ 2 ns 30 pF 500 Ω open 2 × VCC GND 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 2 × VCC GND 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 2 × VCC GND 74LVC_LVCH16373A Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 11 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state 11. Package outline SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 D E A X c y HE v M A Z 25 48 Q A2 A1 A (A 3 ) θ pin 1 index Lp L 24 1 detail X w M bp e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2.8 0.4 0.2 2.35 2.20 0.25 0.3 0.2 0.22 0.13 16.00 15.75 7.6 7.4 0.635 10.4 10.1 1.4 1.0 0.6 1.2 1.0 0.25 0.18 0.1 0.85 0.40 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT370-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-118 Fig. 11. Package outline SOT370-1 (SSOP48) 74LVC_LVCH16373A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 12 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 D E A X c v HE y A Z 48 25 Q A2 A1 (A3) pin 1 index A θ Lp 1 L 24 bp e detail X w 0 5 mm 2.5 scale Dimensions (mm are the original dimensions) Unit mm max nom min A 1.2 A1 A2 0.15 1.05 0.05 0.85 A3 0.25 bp c D(1) E(2) 0.28 0.2 12.6 6.2 0.17 0.1 12.4 6.0 e HE 0.5 8.3 7.9 L 1 Lp Q 0.8 0.50 0.4 0.35 v w 0.25 0.08 y 0.1 Z θ 0.8 8° 0.4 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. Outline version SOT362-1 References IEC JEDEC JEITA sot362-1_po European projection Issue date 03-02-19 13-08-05 MO-153 Fig. 12. Package outline SOT362-1 (TSSOP48) 74LVC_LVCH16373A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 13 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state TSSOP48: plastic thin shrink small outline package; 48 leads; body width 4.4 mm; lead pitch 0.4 mm SOT480-1 E D A X c y HE v M A Z 25 48 Q A2 (A 3) A1 pin 1 index A θ Lp L detail X 1 24 w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.85 0.25 0.23 0.13 0.20 0.09 9.8 9.6 4.5 4.3 0.4 6.6 6.2 1 0.7 0.5 0.4 0.3 0.2 0.07 0.08 0.4 0.1 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT480-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 13. Package outline SOT480-1 (TSSOP48) 74LVC_LVCH16373A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 14 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC_LVCH16373A v.9 20190215 Product data sheet - 74LVC_LVCH16373A v.8 Modifications: • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74LVCH16373ADL (SOT370-1) removed. Type numbers 74LVC16373ADGV and 74LVCH16373ADGV (SOT480-1) added. 74LVC_LVCH16373A v.8 20140106 Modifications: • 74LVC_LVCH16373A v.7 20130118 Modifications: • • • Product data sheet - 74LVC_LVCH16373A v.7 - 74LVC_LVCH16373A v.6 General description corrected (errata). Product data sheet The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Table 5, Table 6, Table 7, Table 8 and Table 9: values added for lower voltage ranges. 74LVC_LVCH16373A v.6 20031208 Product specification - 74LVC_LVCH16373A v.5 74LVC_LVCH16373A v.5 20021002 Product specification - 74LVC_H16373A v.4 74LVC_H16373A v.4 19980317 Product specification - 74LVC16373A_ 74LVCH16373A v.3 74LVC16373A_ 74LVCH16373A v.3 19980317 Product specification - 74LVC16373A v.2 74LVC16373A v.2 19970822 Product specification - 74LVC16373A v.1 74LVC16373A v.1 19960108 - - - 74LVC_LVCH16373A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 15 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVC_LVCH16373A Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 16 / 17 74LVC16373A; 74LVCH16373A Nexperia 16-bit D-type transparent latch with 5 V tolerant inputs/outputs; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................2 4. Functional diagram.......................................................2 5. Pinning information......................................................4 5.1. Pinning.........................................................................4 5.2. Pin description............................................................. 4 6. Functional description................................................. 5 7. Limiting values............................................................. 5 8. Recommended operating conditions..........................6 9. Static characteristics....................................................6 10. Dynamic characteristics............................................ 8 10.1. Waveforms and test circuit........................................ 9 11. Package outline........................................................ 12 12. Abbreviations............................................................ 15 13. Revision history........................................................15 14. Legal information......................................................16 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 February 2019 74LVC_LVCH16373A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 15 February 2019 © Nexperia B.V. 2019. All rights reserved 17 / 17
74LVCH16373ADGVJ 价格&库存
很抱歉,暂时无法提供与“74LVCH16373ADGVJ”相匹配的价格&库存,您可以联系我们找货
