Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
DISCRETE SEMICONDUCTORS
DATA SHEET
M3D319
BAS716
Low-leakage diode
Product data sheet
2003 Nov 07
NXP Semiconductors
Product data sheet
Low-leakage diode
BAS716
FEATURES
PINNING
• Plastic SMD package
PIN
• Low leakage current: typ. 0.2 nA
• Switching time: typ. 0.6 µs
• Continuous reverse voltage: max. 75 V
• Repetitive peak reverse voltage: max. 85 V
• Repetitive peak forward current: max. 500 mA.
1
cathode
2
anode
handbook, halfpage1
APPLICATION
• Low leakage current applications in surface mounted
circuits.
DESCRIPTION
2
Top view
MAM408
Marking code: S1.
The marking bar indicates the cathode.
DESCRIPTION
Epitaxial medium-speed switching diode with a low
leakage current in an ultra small SOD523 (SC-79) SMD
plastic package.
Fig.1
Simplified outline (SOD523; SC-79) and
symbol.
ORDERING INFORMATION
PACKAGE
TYPE NUMBER
NAME
BAS716
DESCRIPTION
VERSION
plastic surface mounted package; 2 leads
SOD523
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC 60134).
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
UNIT
85
V
75
V
200
mA
500
mA
tp = 1 µs
4
A
tp = 1 ms
1
A
tp = 1 s
0.5
A
250
mW
VRRM
repetitive peak reverse voltage
VR
continuous reverse voltage
IF
continuous forward current
IFRM
repetitive peak forward current
IFSM
non-repetitive peak forward current square wave; Tj = 25 °C prior to surge;
see Fig.4
see Fig.2; note 1
Tamb = 25 °C; note 1
Ptot
total power dissipation
Tstg
storage temperature
−65
+150
°C
Tj
junction temperature
150
°C
Note
1. Device mounted on a FR4 printed-circuit board.
2003 Nov 07
2
NXP Semiconductors
Product data sheet
Low-leakage diode
BAS716
ELECTRICAL CHARACTERISTICS
Tj = 25 °C unless otherwise specified.
SYMBOL
VF
IR
PARAMETER
forward voltage
reverse current
CONDITIONS
TYP.
MAX.
UNIT
IF = 1 mA
0.77
0.9
V
IF = 10 mA
0.85
1
V
IF = 50 mA
0.92
1.1
V
IF = 150 mA
1.02
1 .25
V
VR = 75 V
0.2
5
nA
VR = 75 V; Tj = 150 °C
3
80
nA
VR = 100 V
0.3
nA
Cd
diode capacitance
VR = 0 V; f = 1 MHz; see Fig.6
2
pF
trr
reverse recovery time
when switched from IF = 10 mA to
IR = 10 mA; RL = 100 Ω; measured at
IR = 1 mA
0.6
3
µs
THERMAL CHARACTERISTICS
SYMBOL
PARAMETER
CONDITIONS
VALUE
UNIT
Rth j-a
thermal resistance from junction to ambient
note 1
450
K/W
Rth j-s
thermal resistance from junction to soldering point
note 2
120
K/W
Notes
1. Device mounted on a FR4 printed-circuit board. Refer to SOD523 (SC-79) standard mounting conditions.
2. Soldering point of the cathode tab.
2003 Nov 07
3
NXP Semiconductors
Product data sheet
Low-leakage diode
BAS716
GRAPHICAL DATA
MHC323
300
MLB752 - 1
300
handbook, halfpage
handbook, halfpage
IF
(mA)
IF
(mA)
200
200
100
100
(1)
(2)
(3)
Tamb (°C)
0.8
1.2
V F (V)
1.6
(1) Tj = 150 °C; typical values.
(2) Tj = 25 °C; typical values.
(3) Tj = 25 °C; maximum values.
Fig.2
0.4
Maximum permissible continuous forward
current as a function of ambient
temperature.
Fig.3
Forward current as a function of forward
voltage.
MBG704
102
handbook, full pagewidth
IFSM
(A)
10
1
10−1
1
10
102
103
tp (µs)
Based on square wave currents; Tj = 25 °C prior to surge.
Fig.4 Maximum permissible non-repetitive peak forward current as a function of pulse duration.
2003 Nov 07
4
104
NXP Semiconductors
Product data sheet
Low-leakage diode
BAS716
MDB826
102
handbook, halfpage
MDB827
2.0
handbook, halfpage
Cd
(pF)
IR
(nA)
(1)
1.5
10
1.0
(2)
1
0.5
10−1
100
150
Tj (°C)
VR = 75 V.
(1) Maximum values.
(2) Typical values.
Fig.5
5
10
15 V (V) 20
R
f = 1 MHz; Tj = 25 °C.
Reverse current as a function of junction
temperature.
Fig.6
tr
Diode capacitance as a function of reverse
voltage; typical values.
tp
t
D.U.T.
RS = 50 Ω
V = VR I F x R S
IF
10%
IF
SAMPLING
OSCILLOSCOPE
t
R i = 50 Ω
MGA881
(1)
90%
VR
input signal
(1) IR = 1 mA.
Input signal: reverse pulse rise time tr = 0.6 ns; reverse voltage pulse duration tp = 100 ns; duty factor δ = 0.05;
Oscilloscope: rise time tr = 0.35 ns.
Fig.7 Reverse recovery voltage test circuit and waveforms.
2003 Nov 07
t rr
5
output signal
NXP Semiconductors
Product data sheet
Low-leakage diode
BAS716
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD523
A
c
v M A
HE
A
D
1
E
1 mm
scale
2
DIMENSIONS (mm are the original dimensions)
bp
(1)
UNIT
A
bp
c
D
E
HE
v
mm
0.65
0.58
0.34
0.26
0.17
0.11
1.25
1.15
0.85
0.75
1.65
1.55
0.1
Note
1. The marking bar indicates the cathode.
OUTLINE
VERSION
SOD523
2003 Nov 07
REFERENCES
IEC
JEDEC
JEITA
SC-79
6
EUROPEAN
PROJECTION
ISSUE DATE
98-11-25
02-12-13
NXP Semiconductors
Product data sheet
Low-leakage diode
BAS716
DATA SHEET STATUS
DOCUMENT
STATUS(1)
PRODUCT
STATUS(2)
DEFINITION
Objective data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary data sheet
Qualification
This document contains data from the preliminary specification.
Product data sheet
Production
This document contains the product specification.
Notes
1. Please consult the most recently issued document before initiating or completing a design.
2. The product status of device(s) described in this document may have changed since this document was published
and may differ in case of multiple devices. The latest product status information is available on the Internet at
URL http://www.nxp.com.
Limiting values ⎯ Stress above one or more limiting
values (as defined in the Absolute Maximum Ratings
System of IEC 60134) may cause permanent damage to
the device. Limiting values are stress ratings only and
operation of the device at these or any other conditions
above those given in the Characteristics sections of this
document is not implied. Exposure to limiting values for
extended periods may affect device reliability.
DISCLAIMERS
General ⎯ Information in this document is believed to be
accurate and reliable. However, NXP Semiconductors
does not give any representations or warranties,
expressed or implied, as to the accuracy or completeness
of such information and shall have no liability for the
consequences of use of such information.
Right to make changes ⎯ NXP Semiconductors
reserves the right to make changes to information
published in this document, including without limitation
specifications and product descriptions, at any time and
without notice. This document supersedes and replaces all
information supplied prior to the publication hereof.
Terms and conditions of sale ⎯ NXP Semiconductors
products are sold subject to the general terms and
conditions of commercial sale, as published at
http://www.nxp.com/profile/terms, including those
pertaining to warranty, intellectual property rights
infringement and limitation of liability, unless explicitly
otherwise agreed to in writing by NXP Semiconductors. In
case of any inconsistency or conflict between information
in this document and such terms and conditions, the latter
will prevail.
Suitability for use ⎯ NXP Semiconductors products are
not designed, authorized or warranted to be suitable for
use in medical, military, aircraft, space or life support
equipment, nor in applications where failure or malfunction
of an NXP Semiconductors product can reasonably be
expected to result in personal injury, death or severe
property or environmental damage. NXP Semiconductors
accepts no liability for inclusion and/or use of NXP
Semiconductors products in such equipment or
applications and therefore such inclusion and/or use is at
the customer’s own risk.
No offer to sell or license ⎯ Nothing in this document
may be interpreted or construed as an offer to sell products
that is open for acceptance or the grant, conveyance or
implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control ⎯ This document as well as the item(s)
described herein may be subject to export control
regulations. Export might require a prior authorization from
national authorities.
Applications ⎯ Applications that are described herein for
any of these products are for illustrative purposes only.
NXP Semiconductors makes no representation or
warranty that such applications will be suitable for the
specified use without further testing or modification.
2003 Nov 07
Quick reference data ⎯ The Quick reference data is an
extract of the product data given in the Limiting values and
Characteristics sections of this document, and as such is
not complete, exhaustive or legally binding.
7
NXP Semiconductors
Customer notification
This data sheet was changed to reflect the new company name NXP Semiconductors. No changes were
made to the content, except for the legal definitions and disclaimers.
Contact information
For additional information please visit: http://www.nxp.com
For sales offices addresses send e-mail to: salesaddresses@nxp.com
© NXP B.V. 2009
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner.
The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed
without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license
under patent- or other industrial or intellectual property rights.
Printed in The Netherlands
R76/01/pp8
Date of release: 2003 Nov 07
Document order number: 9397 750 11999
很抱歉,暂时无法提供与“BAS716F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.53568
- 50+0.41904
- 150+0.36072
- 500+0.31698
- 2500+0.28199
- 5000+0.26439
- 国内价格 香港价格
- 1+2.294751+0.29689
- 10+1.4206110+0.18380
- 100+0.88087100+0.11397
- 500+0.64610500+0.08359
- 1000+0.569931000+0.07374
- 2000+0.505592000+0.06541
- 5000+0.435755000+0.05638
- 国内价格 香港价格
- 10000+0.3634410000+0.04702
- 20000+0.3297120000+0.04266
- 30000+0.3125330000+0.04044
- 50000+0.3004050000+0.03887
