BC807-40LWF
BC807-40LWF
    NEXPERIA(安世)
    SOT-323
    晶体管类型:PNP 集射极击穿电压(Vceo):45V 集电极电流(Ic):500mA 功率(Pd):200mW
BC807-40LWF 数据手册
BC807L; BC807LW 45 V, 500 mA PNP general-purpose transistors Rev. 1 — 5 January 2018 1 Product data sheet Product profile 1.1 General description PNP general-purpose transistors in a small SOT23 (TO-236AB) or SOT323 (SC-70) Surface-Mounted Device (SMD) plastic package. Table 1. Product overview Type number Package BC807-16L Nexperia JEITA JEDEC SOT23 - TO-236AB SOT323 SC70 - BC807-25L BC807-40L BC807-16LW BC807-25LW BC807-40LW 1.2 Features and benefits • High current • Three current gain selections • AEC-Q101 qualified 1.3 Applications • General-purpose switching and amplification 1.4 Quick reference data Table 2. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - -45 V IC collector current - - -500 mA ICM peak collector current - - -1 A single pulse; tp ≤ 1 ms BC807L; BC807LW Nexperia 45 V, 500 mA PNP general-purpose transistors Symbol Parameter Conditions hFE DC current gain VCE = -1 V; IC = -100 mA Min Typ Max Unit BC807-16L; BC807-16LW [1] 100 - 250 - BC807-25L; BC807-25LW [1] 160 - 400 - BC807-40L; BC807-40LW [1] 250 - 600 - [1] pulsed; tp ≤ 300 μs; δ ≤ 0.02 2 Pinning information Table 3. Pinning Pin Symbol Description 1 B base 2 E emitter 3 C collector Simplified outline Graphic symbol SOT23 3 C B E sym132 1 2 SOT323 1 B base 2 E emitter 3 C collector 3 C B E sym132 1 BC807L_BC807LW Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 January 2018 2 © Nexperia B.V. 2018. All rights reserved. 2 / 16 BC807L; BC807LW Nexperia 45 V, 500 mA PNP general-purpose transistors 3 Ordering information Table 4. Ordering information Type number Package BC807-16L Name Description Version TO-236AB Plastic surface-mounted package; 3 leads SOT23 BC807-25L BC807-40L SC70 BC807-16LW SOT323 BC807-25LW BC807-40LW 4 Marking Table 5. Marking Type number Marking code BC807-16L [1] HL% BC807-25L [1] HM% BC807-40L [1] HN% BC807-16LW [1] C3% BC807-25LW [1] C4% BC807-40LW [1] C5% [1] % = placeholder for manufacturing site code 5 Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - -50 V VCEO collector-emitter voltage open base - -45 V VEBO emitter-base voltage open collector - -7 V IC collector current - -500 mA ICM peak collector current single pulse; tp ≤ 1 ms - -1 A IBM peak base current single pulse; tp ≤ 1 ms Ptot total power dissipation BC807L (SOT23) Tamb ≤ 25 °C total power dissipation BC807LW (SOT323) BC807L_BC807LW Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 January 2018 - -200 mA [1] - 250 mW [1] - 200 mW © Nexperia B.V. 2018. All rights reserved. 3 / 16 BC807L; BC807LW Nexperia 45 V, 500 mA PNP general-purpose transistors Symbol Parameter Tj Conditions Min Max Unit junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C [1] Device mounted on an FR4 Printed-Circuit-Board (PCB); single-sided copper; tin-plated and standard footprint. 6 Thermal characteristics Table 7. Thermal characteristics Symbol Rth(j-a) Parameter Conditions thermal resistance from junction to ambient SOT23 in free air thermal resistance from junction to ambient SOT323 Min Typ Max Unit [1] - - 500 K/W [1] - - 625 K/W [1] Device mounted on an FR4 PCB; single-sided copper; tin-plated and standard footprint. 7 Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit V(BR)CBO collector-base breakdown voltage IC = -100 µA; IE = 0 A -50 - - V V(BR)CEO collector-emitter breakdown voltage IC = -10 mA; IB = 0 A -45 - - V V(BR)EBO emitter-base breakdown voltage IE = -100 µA; IC = 0 A -7 - - V ICBO collector-base cut-off current VCB = -40 V; IE = 0 A - - -100 nA VCB = -40 V; IE = 0 A; Tj = 150 °C - - -5 μA IEBO emitter-base cut-off current VEB = -5 V; IC = 0 A - - -100 nA hFE DC current gain [1] 100 - 250 BC807-25L, BC807-25LW [1] 160 - 400 BC807-40L, BC807-40LW [1] 250 - 600 VCE = -1 V; IC = -500 mA [1] 40 - - - - -700 mV - - -1.2 V BC807-16L, BC807-16LW DC current gain VCE = -1 V; IC = -100 mA VCEsat collector-emitter saturation voltage IC = -500 mA; IB = -50 mA [1] VBE base-emitter voltage VCE = -1 V; IC = -500 mA [1] BC807L_BC807LW Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 January 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 16 BC807L; BC807LW Nexperia 45 V, 500 mA PNP general-purpose transistors Symbol Parameter Conditions Min Typ Max Unit fT transition frequency VCE = -5 V; IC = -10 mA; f = 100 MHz 80 - - MHz Cc collector capacitance VCB = -10 V; IE = ie = 0 A; f = 1 MHz - 5.5 - pF [1] pulsed; tp ≤ 300 μs; δ ≤ 0.02 aaa-027822 400 hFE aaa-027824 -1.2 VBEsat (V) 300 (1) -0.8 (1) (2) 200 (2) (3) -0.4 100 0 -10-1 VCE = -1 V (1) Tamb = 150 °C (2) Tamb = 85 °C (3) Tamb = 25 °C (4) Tamb = -40 °C (4) (4) -1 (3) -10 -102 IC (mA) -103 0 -10-1 -1 -10 -102 IC (mA) -103 IC/IB = 10 (1) Tamb = -40 °C (2) Tamb = 25 °C (3) Tamb = 85 °C (4) Tamb = 150 °C Figure 1. BC807-16L, BC807-16LW: DC current gain as a Figure 2. BC807-16L, BC807-16LW: Base-emitter function of collector current; typical values saturation voltage as a function of collector current; typical values BC807L_BC807LW Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 January 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 16 BC807L; BC807LW Nexperia 45 V, 500 mA PNP general-purpose transistors aaa-027825 -1 aaa-027835 103 RCEsat (Ω) VCEsat (V) 102 (1) -10-1 (2) 10 (3) (1) (2) (3) -10-2 -10-1 -1 1 -102 -10 IC (mA) -103 10-1 -10-1 -1 -10 -102 IC (mA) -103 IC/IB = 10 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -40 °C IC/IB = 10 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -40 °C Figure 3. BC807-16L, BC807-16LW: Collector-emitter saturation voltage as a function of collector current; typical values Figure 4. BC807-16L, BC807-16LW: Collector-emitter saturation resistance as a function of collector current; typical values aaa-027823 -1.0 IB (µA) = -17.0 IC (A) -15.3 -13.6 -0.8 -10.2 -0.6 hFE -11.9 (1) -8.5 400 (2) -6.8 -5.1 -0.4 (3) -3.4 200 (4) -1.7 -0.2 0 0 -1 -2 -3 aaa-027826 600 -4 VCE (V) -5 0 -10-1 -1 -10 -102 IC (mA) -103 Tamb = 25 °C VCE = -1 V Figure 5. BC807-16L, BC807-16LW: Collector current as (1) Tamb = 150 °C (2) Tamb = 85 °C a function of collector-emitter voltage; typical values (3) Tamb = 25 °C (4) Tamb = -40 °C Figure 6. BC807-25L, BC807-25LW: DC current gain as a function of collector current; typical values BC807L_BC807LW Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 January 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 16 BC807L; BC807LW Nexperia 45 V, 500 mA PNP general-purpose transistors aaa-027828 -1.2 VBEsat (V) -0.8 aaa-027829 -10 VCEsat (V) (1) (2) -10-1 (3) -0.4 (1) (2) (4) (3) -0 -10-1 -1 -10 -102 IC (mA) -103 IC/IB = 10 (1) Tamb = -40 °C (2) Tamb = 25 °C (3) Tamb = 85 °C (4) Tamb = 150 °C -10-2 -10-1 -1 -102 -10 -103 IC/IB = 10 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -40 °C Figure 7. BC807-25L, BC807-25LW: Base-emitter saturation voltage as a function of collector current; typical values aaa-027836 103 Figure 8. BC807-25L, BC807-25LW: Collector-emitter saturation voltage as a function of collector current; typical values aaa-027827 -1.0 IB (mA) = -13.0 IC (A) RCEsat (Ω) -10.4 -0.8 102 (1) -7.8 -11.7 -9.1 -6.5 -5.2 -0.6 (2) 10 -3.9 (3) -0.4 1 10-1 -10-1 IC (mA) -2.6 -1.3 -0.2 -1 -10 -102 IC (mA) -103 IC/IB = 10 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -40 °C 0 0 -1 -2 -3 -4 VCE (V) -5 Tamb = 25 °C Figure 10. BC807-25L, BC807-25LW: Collector current as a function of collector-emitter voltage; typical values Figure 9. BC807-25L, BC807-25LW: Collector-emitter saturation resistance as a function of collector current; typical values BC807L_BC807LW Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 January 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 16 BC807L; BC807LW Nexperia 45 V, 500 mA PNP general-purpose transistors aaa-027830 800 (1) hFE 600 400 aaa-027832 -1.2 VBEsat (V) (2) -0.8 (3) (1) (2) (3) -0.4 (4) (4) 200 0 -10-1 -1 -10 -102 IC (mA) -103 VCE = -1 V (1) Tamb = 150 °C (2) Tamb = 85 °C (3) Tamb = 25 °C (4) Tamb = -40 °C -0 -10-1 -1 -10 -102 IC (mA) -103 IC/IB = 10 (1) Tamb = -40 °C (2) Tamb = 25 °C (3) Tamb = 85 °C (4) Tamb = 150 °C Figure 11. BC807-40L, BC807-40LW: DC current gain as Figure 12. BC807-40L, BC807-40LW: Base-emitter as a function of collector current; typical values saturation voltage as a function of collector current; typical values aaa-027833 -10 aaa-027836 103 RCEsat (Ω) VCEsat (V) 102 (1) -10-1 (2) 10 (3) (1) (2) 1 (3) -10-2 -10-1 -1 -10 -102 IC (mA) -103 10-1 -10-1 -1 -10 -102 IC (mA) -103 IC/IB = 10 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -40 °C IC/IB = 10 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -40 °C Figure 13. BC807-40L, BC807-40LW: Collector-emitter saturation voltage as a function of collector current; typical values Figure 14. BC807-40L, BC807-40LW: Collector-emitter saturation resistance as a function of collector current; typical values BC807L_BC807LW Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 January 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 16 BC807L; BC807LW Nexperia 45 V, 500 mA PNP general-purpose transistors aaa-027831 -1.0 IB (mA) = -14.0 IC (A) -12.6 -11.2 -8.4 -0.8 -7.0 -5.6 -4.2 -0.6 -2.8 -0.4 -1.4 -0.2 0 0 -1 -2 -3 -4 VCE (V) -5 Tamb = 25 °C Figure 15. BC807-40L, BC807-40LW: Collector current as a function of collector-emitter voltage; typical values 8 Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. BC807L_BC807LW Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 January 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 16 BC807L; BC807LW Nexperia 45 V, 500 mA PNP general-purpose transistors 9 Package outline Table 9. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 0.48 0.38 1.9 0.15 0.09 Dimensions in mm 04-11-04 Figure 16. Package outline SOT23 (TO-236) 2.2 1.8 1.1 0.8 0.45 0.15 3 2.2 1.35 2.0 1.15 1 2 1.3 0.4 0.3 0.25 0.10 Dimensions in mm 04-11-04 Figure 17. Package outline SOT323 (SC-70) BC807L_BC807LW Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 January 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 16 BC807L; BC807LW Nexperia 45 V, 500 mA PNP general-purpose transistors 10 Soldering Table 10. Soldering 3.3 2.9 1.9 solder lands 3 solder resist 2 1.7 solder paste occupied area 0.6 (3×) 0.7 (3×) Dimensions in mm 0.5 (3×) 0.6 (3×) 1 sot023_fr Figure 18. Reflow soldering footprint for SOT23 (TO-236AB) 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 sot023_fw Figure 19. Wave soldering footprint for SOT23 (TO-236AB) BC807L_BC807LW Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 January 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 16 BC807L; BC807LW Nexperia 45 V, 500 mA PNP general-purpose transistors 2.65 1.85 1.325 solder lands solder resist 2 2.35 0.6 (3×) 3 solder paste 1.3 1 occupied area 0.5 (3×) Dimensions in mm 0.55 (3×) sot323_fr Figure 20. Reflow soldering footprint for SOT323 (SC-70) 4.6 2.575 1.425 (3×) solder lands solder resist occupied area 1.8 3.65 2.1 09 (2×) Dimensions in mm preferred transport direction during soldering sot323_fw Figure 21. Wave soldering footprint for SOT323 (SC-70) BC807L_BC807LW Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 January 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 16 BC807L; BC807LW Nexperia 45 V, 500 mA PNP general-purpose transistors 11 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BC807L_BC807LW v.1 20180105 Product data sheet - - BC807L_BC807LW Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 January 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 16 BC807L; BC807LW Nexperia 45 V, 500 mA PNP general-purpose transistors 12 Legal information 12.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation BC807L_BC807LW Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 January 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 16 BC807L; BC807LW Nexperia 45 V, 500 mA PNP general-purpose transistors Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BC807L_BC807LW Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 5 January 2018 © Nexperia B.V. 2018. All rights reserved. 15 / 16 Nexperia BC807L; BC807LW 45 V, 500 mA PNP general-purpose transistors Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 Product profile .................................................... 1 General description ............................................1 Features and benefits ........................................1 Applications ........................................................1 Quick reference data ......................................... 1 Pinning information ............................................ 2 Ordering information .......................................... 3 Marking .................................................................3 Limiting values .................................................... 3 Thermal characteristics ......................................4 Characteristics .................................................... 4 Test information .................................................. 9 Quality information .............................................9 Package outline .................................................10 Soldering ............................................................11 Revision history ................................................ 13 Legal information .............................................. 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 5 January 2018 Document identifier: BC807L_BC807LW
BC807-40LWF 价格&库存
很抱歉,暂时无法提供与“BC807-40LWF”相匹配的价格&库存,您可以联系我们找货
BC807-40LWF
    • 1+0.07355
    • 10+0.05757
    • 30+0.04871
    • 100+0.04342
    • 500+0.03878
    • 1000+0.03629
