BCP53-16HX
BCP53-16HX
    NEXPERIA(安世)
    SOT-223
    80V,1A PNP中功率晶体管
BCP53-16HX 数据手册
SC -7 3 BCP53H series 80 V, 1 A PNP medium power transistors Rev. 1 — 21 July 2017 Product data sheet 1. Product profile 1.1 General description PNP medium power transistors in a medium power SOT223 (SC-73) Surface-Mounted Device (SMD) plastic package. Table 1. Product overview Type number BCP53H Package NPN complement Nexperia JEITA JEDEC SOT223 SC-73 - BCP56H BCP53-10H BCP56-10H BCP53-16H BCP56-16H 1.2 Features and benefits      High collector current capability IC and ICM Three current gain selections High power dissipation capability High-temperature applications up to 175 C AEC-Q101 qualified 1.3 Applications      Linear voltage regulators MOSFET drivers High-side switches Power management Amplifiers 1.4 Quick reference data Table 2. Quick reference data Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 80 V IC collector current - - 1 A ICM peak collector current - - 2 A single pulse; tp  1 ms BCP53H series Nexperia 80 V, 1 A PNP medium power transistors Table 2. Quick reference data …continued Tamb = 25 C unless otherwise specified. Symbol hFE [1] Parameter Conditions Min Typ Max VCE = 2 V; IC = 150 mA [1] DC current gain 63 - 250 BCP53-10H VCE = 2 V; IC = 150 mA [1] 63 - 160 BCP53-16H VCE = 2 V; IC = 150 mA [1] 100 - 250 Unit Pulse test: tp  300 s;  = 0.02 2. Pinning information Table 3. Pinning Pin Symbol Description 1 B base 2 C collector 3 E emitter 4 C collector Simplified outline Graphic symbol C 4 B 1 2 E 3 sym132 3. Ordering information Table 4. Ordering information Type number BCP53H Package Name Description Version SC-73 plastic surface-mounted package with increased heatsink; 4 leads SOT223 BCP53-10H BCP53-16H 4. Marking Table 5. BCP53H_SER Product data sheet Marking codes Type number Marking code BCP53H BCP53H BCP53-10H P5310H BCP53-16H P5316H All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 July 2017 © Nexperia B.V. 2017. All rights reserved. 2 of 16 BCP53H series Nexperia 80 V, 1 A PNP medium power transistors 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 100 V VCEO collector-emitter voltage open base - 80 V VEBO emitter-base voltage open collector - 7 V IC collector current - 1 A ICM peak collector current - 2 A IB base current - 0.2 A IBM peak base current single pulse; tp  1 ms - 0.3 A Ptot total power dissipation Tamb  25 C [1] - 725 mW [2] - 1.2 W [3] - 1.5 W [4] - 1.6 W single pulse; tp  1 ms [5] BCP53H_SER Product data sheet - 2.2 W Tj junction temperature - +175 C Tamb ambient temperature 55 +175 C Tstg storage temperature 65 +175 C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated; mounting pad for collector 1 cm2. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated; mounting pad for collector 6 cm2. [4] Device mounted on an FR4 PCB, 4-layer copper; tin-plated and standard footprint. [5] Device mounted on an FR4 PCB, 4-layer copper; tin-plated; mounting pad for collector 1 cm2. All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 July 2017 © Nexperia B.V. 2017. All rights reserved. 3 of 16 BCP53H series Nexperia 80 V, 1 A PNP medium power transistors aaa-023841 2.5 Ptot (W) (1) 2 (2) 1.5 (3) (4) 1 (5) 0.5 0 -75 25 125 225 Tamb (°C) (1) FR4 PCB, 4-layer copper, 1 cm2 (2) FR4 PCB, 4-layer copper, standard footprint (3) FR4 PCB, single-sided copper, 6 cm2 (4) FR4 PCB, single-sided copper, 1 cm2 (5) FR4 PCB, single-sided copper, standard footprint Fig 1. Power derating curves aaa-024289 -10 IC (A) tp = 10 µs -1 100 µs 1 ms 10 ms 100 ms -10-1 DC 1s DC; FR4 PCB, 4-layer copper; collector mounting pad 1 cm2 -10-2 -10-3 -10-1 -1 -10 -102 -103 VCE (V) Unless otherwise specified: Tamb = 25 C Single pulse FR4 PCB, single-sided copper; standard footprint Fig 2. Safe operating area; junction to ambient; continuous and peak collector currents as a function of collector-emitter voltage BCP53H_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 July 2017 © Nexperia B.V. 2017. All rights reserved. 4 of 16 BCP53H series Nexperia 80 V, 1 A PNP medium power transistors 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Conditions thermal resistance from junction to ambient Rth(j-a) in free air Min Typ Max Unit [1] - - 207 K/W [2] - - 125 K/W [3] - - 100 K/W [4] - - 94 K/W [5] - - 69 K/W - - 18 K/W thermal resistance from junction to solder point Rth(j-sp) [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated; mounting pad for collector 1 cm2. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated; mounting pad for collector 6 cm2. [4] Device mounted on an FR4 PCB, 4-layer copper; tin-plated and standard footprint. [5] Device mounted on an FR4 PCB, 4-layer copper; tin-plated; mounting pad for collector 1 cm2. aaa-023489 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.50 0.33 0.20 0.10 10 0.05 0.02 0.01 0 1 10-5 10-4 10-3 10-2 10-1 1 10 102 103 tp (s) FR4 PCB, single-sided copper, tin-plated and standard footprint Fig 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values BCP53H_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 July 2017 © Nexperia B.V. 2017. All rights reserved. 5 of 16 BCP53H series Nexperia 80 V, 1 A PNP medium power transistors aaa-023490 103 Zth(j-a) (K/W) duty cycle = 1 102 0.75 0.50 0.33 0.20 0.10 10 0.05 0.02 0.01 0 1 10-5 10-4 10-3 10-2 10-1 1 10 102 103 tp (s) FR4 PCB, single-sided copper, tin-plated; mounting pad for collector 1 cm2 Fig 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 102 Zth(j-a) (K/W) aaa-023491 duty cycle = 1 0.75 0.50 0.33 0.20 0.10 10 0.05 0.02 0.01 0 1 10-5 10-4 10-3 10-2 10-1 1 10 102 103 tp (s) FR4 PCB, single-sided copper, tin-plated; mounting pad for collector 6 cm2 Fig 5. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values BCP53H_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 July 2017 © Nexperia B.V. 2017. All rights reserved. 6 of 16 BCP53H series Nexperia 80 V, 1 A PNP medium power transistors 102 aaa-023492 duty cycle = 1 0.75 Zth(j-a) (K/W) 0.50 0.33 0.20 0.10 10 0.05 0.02 0.01 0 1 10-5 10-4 10-3 10-2 10-1 1 10 102 103 tp (s) FR4 PCB, 4-layer copper, tin-plated and standard footprint. Fig 6. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-023493 102 duty cycle = 1 Zth(j-a) (K/W) 0.75 0.50 0.33 0.20 10 0.10 0.05 0.02 0.01 0 1 10-5 10-4 10-3 10-2 10-1 1 10 102 103 tp (s) FR4 PCB, 4-layer copper, tin-plated; mounting pad for collector 1 cm2 Fig 7. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values BCP53H_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 July 2017 © Nexperia B.V. 2017. All rights reserved. 7 of 16 BCP53H series Nexperia 80 V, 1 A PNP medium power transistors 7. Characteristics Table 8. Characteristics Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = 30 V; IE = 0 A - - 100 nA VCB = 30 V; IE = 0 A; Tj = 150 C - - 10 A - - 100 nA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A hFE DC current gain VCE = 2 V; IC = 5 mA 63 - - VCE = 2 V; IC = 150 mA [1] 63 - 250 VCE = 2 V; IC = 500 mA [1] 40 - - BCP53-10H VCE = 2 V; IC = 150 mA [1] 63 - 160 BCP53-16H VCE = 2 V; IC = 150 mA [1] 100 - 250 - - 500 mV - - 1 V VCEsat collector-emitter saturation voltage IC = 500 mA; IB = 50 mA [1] VBE base-emitter voltage VCE = 2 V; IC = 500 mA [1] fT transition frequency VCE = 5 V; IC = 50 mA; f = 100 MHz 100 140 - MHz Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz - 7 - pF [1] Pulse test: tp  300 s;  = 0.02 BCP53H_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 July 2017 © Nexperia B.V. 2017. All rights reserved. 8 of 16 BCP53H series Nexperia 80 V, 1 A PNP medium power transistors aaa-023494 250 aaa-023495 200 (1) hFE hFE 200 150 (2) 150 100 100 (3) (1) (2) (3) 50 50 0 -10-1 -1 -10 -102 0 -10-1 -103 -104 IC (mA) VCE = 2 V -1 -10 -103 -104 IC (mA) Tamb = 25 C (1) Tamb = 100 C (1) VCE = 1 V (2) Tamb = 25 C (2) VCE = 2 V (3) Tamb = 55 C (3) VCE = 5 V Fig 8. -102 DC current gain as a function of collector current; typical values aaa-023496 -1 -13.5 aaa-023497 VBE (V) -12 -10.5 -0.8 DC current gain as a function of collector current; typical values -1.2 IB (mA) = -15 IC (A) Fig 9. -9 -0.9 (1) -7.5 -0.6 -6 (2) -0.6 -4.5 (3) -0.4 -3 -0.3 -0.2 -1.5 0 0 -1 -2 -3 -4 -5 0 -10-1 -1 VCE (V) Tamb = 25 C -10 -102 -103 -104 IC (mA) VCE = 2 V (1) Tamb = 55 C (2) Tamb = 25 C (3) Tamb = 100 C Fig 10. Collector current as a function of collector-emitter voltage; typical values BCP53H_SER Product data sheet Fig 11. Base-emitter voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 July 2017 © Nexperia B.V. 2017. All rights reserved. 9 of 16 BCP53H series Nexperia 80 V, 1 A PNP medium power transistors aaa-023498 -1.2 aaa-023499 -1 VBEsat (V) VCESat (V) (1) -0.8 (2) (1) -10-1 (2) (3) (3) -0.4 0 -10-1 -1 -10 -102 -103 -104 IC (mA) -10-2 -10-1 -1 IC/IB = 10 IC/IB = 10 (1) Tamb = 55 C (1) Tamb = 100 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 100 C (3) Tamb = 55 C Fig 12. Base-emitter saturation voltage as a function of collector current; typical values aaa-023500 -1 -10 -102 -103 -104 IC (mA) Fig 13. Collector-emitter saturation voltage as a function of collector current; typical values aaa-023501 25 CC (pF) 20 VCESat (V) 15 -10-1 (1) 10 (2) 5 (3) -10-2 -10-1 -1 -10 -102 -103 -104 IC (mA) 0 0 Tamb = 25 C -20 -40 -60 -80 -100 VCB (V) f = 1 MHz; Tamb = 25 C (1) IC/IB = 50 (2) IC/IB = 20 (3) IC/IB = 5 Fig 14. Collector-emitter saturation voltage as a function of collector current; typical values BCP53H_SER Product data sheet Fig 15. Collector capacitance as a function of collector-base voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 July 2017 © Nexperia B.V. 2017. All rights reserved. 10 of 16 BCP53H series Nexperia 80 V, 1 A PNP medium power transistors aaa-023502 70 CE (pF) 60 aaa-023503 103 fT (MHz) 50 40 102 30 20 10 10 -10-1 0 0 -1 -2 -3 -4 -5 -1 -102 -10 -103 IC (mA) VEB (V) f = 1 MHz; Tamb = 25 C VCE = 5 V; f = 100 MHz; Tamb = 25 C Fig 16. Emitter capacitance as a function of emitter-base voltage; typical values Fig 17. Transition frequency as a function of collector current; typical values 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 9. Package outline 6.7 6.3 3.1 2.9 1.8 1.5 4 1.1 0.7 7.3 6.7 3.7 3.3 1 2 3 2.3 4.6 Dimensions in mm 0.8 0.6 0.32 0.22 04-11-10 Fig 18. Package outline SOT223 (SC-73) BCP53H_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 July 2017 © Nexperia B.V. 2017. All rights reserved. 11 of 16 BCP53H series Nexperia 80 V, 1 A PNP medium power transistors 10. Soldering 7 3.85 3.6 3.5 0.3 1.3 1.2 (4×) (4×) solder lands 4 solder resist 3.9 6.1 7.65 solder paste occupied area 1 2 3 Dimensions in mm 2.3 2.3 1.2 (3×) 1.3 (3×) 6.15 sot223_fr Fig 19. Reflow soldering footprint SOT223 (SC-73) 8.9 6.7 1.9 solder lands 4 solder resist 6.2 8.7 occupied area Dimensions in mm 1 2 3 1.9 (3×) 2.7 preferred transport direction during soldering 2.7 1.1 1.9 (2×) sot223_fw Fig 20. Wave soldering footprint SOT223 (SC-73) BCP53H_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 July 2017 © Nexperia B.V. 2017. All rights reserved. 12 of 16 BCP53H series Nexperia 80 V, 1 A PNP medium power transistors 11. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes BCP53H_SER v.1 20170721 Product data sheet - BCP53H_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 July 2017 - © Nexperia B.V. 2017. All rights reserved. 13 of 16 BCP53H series Nexperia 80 V, 1 A PNP medium power transistors 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. BCP53H_SER Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 July 2017 © Nexperia B.V. 2017. All rights reserved. 14 of 16 BCP53H series Nexperia 80 V, 1 A PNP medium power transistors No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 12.4 Trademarks Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com BCP53H_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 July 2017 © Nexperia B.V. 2017. All rights reserved. 15 of 16 BCP53H series Nexperia 80 V, 1 A PNP medium power transistors 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Test information . . . . . . . . . . . . . . . . . . . . . . . . 11 Quality information . . . . . . . . . . . . . . . . . . . . . 11 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 July 2017 Document identifier: BCP53H_SER
BCP53-16HX
1. 物料型号:BCP53H_SER,由Nexperia公司生产。
2. 器件简介:BCP53H_SER是一款瞬态电压抑制二极管,用于保护电子设备免受静电放电和电气浪涌的影响。
3. 引脚分配:该器件为SOD-323封装,具有两个引脚,分别是阳极和阴极。
4. 参数特性:BCP53H_SER的主要参数包括工作电压、反向击穿电压、电容等。
5. 功能详解:BCP53H_SER能够吸收高达1500W的瞬态能量,适用于多种电子设备的保护。
6. 应用信息:该器件广泛应用于手机、电脑、家用电器等电子设备的静电保护。
7. 封装信息:BCP53H_SER采用SOD-323封装,尺寸小,适合表面贴装。
BCP53-16HX 价格&库存
很抱歉,暂时无法提供与“BCP53-16HX”相匹配的价格&库存,您可以联系我们找货
BCP53-16HX
BCP53-16HX
  • 1+5.911321+0.76739
  • 10+3.6711110+0.47657
  • 50+2.5841750+0.33547
  • 100+2.24246100+0.29111
  • 1000+1.406181000+0.18255
库存:2000
BCP53-16HX
库存:2000
BCP53-16HX
  • 1+3.23646
  • 5+2.99690
  • 10+2.76572
