BUK7J1R0-40H
N-channel 40 V, 1.0 mΩ standard level MOSFET in LFPAK56E
31 May 2018
Product data sheet
1. General description
Automotive qualified N-channel MOSFET using the latest Trench 9 low ohmic superjunction
technology, housed in an enhanced LFPAK56E package. This product has been fully designed and
qualified to meet AEC-Q101 requirements delivering high performance and endurance.
2. Features and benefits
Fully automotive qualified to AEC-Q101:
• 175 °C rating suitable for thermally demanding environments
Trench 9 Superjunction technology:
Reduced cell pitch enables enhanced power density and efficiency with lower RDSon in
same footprint
• Improved SOA and avalanche capability compared to standard TrenchMOS
• Tight VGS(th) limits enable easy paralleling of MOSFETs
LFPAK Gull Wing leads:
High Board Level Reliability absorbing mechanical stress during thermal cycling, unlike
traditional QFN packages
• Visual (AOI) soldering inspection, no need for expensive x-ray equipment
• Easy solder wetting for good mechanical solder joint
LFPAK copper clip technology:
Improved reliability, with reduced Rth and RDSon
Increases maximum current capability and improved current spreading
3. Applications
12 V automotive systems
Motors, lamps and solenoid control
Start-Stop micro-hybrid applications
Transmission control
Ultra high performance power switching
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
25 °C ≤ Tj ≤ 175 °C
40
V
ID
drain current
VGS = 10 V; Tmb = 25 °C; Fig. 2
220
A
Ptot
total power dissipation
Tmb = 25 °C; Fig. 1
500
W
[1]
BUK7J1R0-40H
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VGS = 10 V; ID = 25 A; Tj = 25 °C;
Fig. 11
0.6
0.85
1
mΩ
ID = 25 A; VDS = 32 V; VGS = 10 V;
Fig. 13; Fig. 14
17.7
35.5
nC
nC
Static characteristics
RDSon
drain-source on-state
resistance
Dynamic characteristics
QGD
gate-drain charge
Source-drain diode
Qr
recovered charge
IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 20 V
53.2
S
softness factor
VDS = 20 V; Tj = 25 °C; Fig. 17
0.77
[1]
220A continuous current has been successfully demonstrated during application tests. Practically the current will be limited by PCB,
thermal design and operating temperature.
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
Simplified outline
1
S
source
2
S
source
3
S
source
4
G
gate
mb
D
mounting base; connected to
drain
Graphic symbol
D
G
mbb076
1
2
3
S
4
LFPAK56E; PowerSO8 (SOT1023)
6. Ordering information
Table 3. Ordering information
Type number
BUK7J1R0-40H
Package
Name
Description
Version
LFPAK56E;
Power-SO8
plastic, single-ended surface-mounted package (LFPAK56); 4
leads; 1.27 mm pitch
SOT1023
7. Marking
Table 4. Marking codes
Type number
Marking code
BUK7J1R0-40H
71H040E
BUK7J1R0-40H
Product data sheet
All information provided in this document is subject to legal disclaimers.
31 May 2018
Nexperia B.V. 2018. All rights reserved
2 / 12
BUK7J1R0-40H
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
25 °C ≤ Tj ≤ 175 °C
40
V
VGS
gate-source voltage
DC; Tj ≤ 175 °C
-10
V
Ptot
Tmb = 25 °C; Fig. 1
500
W
ID
drain current
[1]
220
A
VGS = 10 V; Tmb = 100 °C; Fig. 2
[1]
220
A
600
A
IDM
peak drain current
pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
165
A
600
A
242
mJ
Source-drain diode
IS
source current
Tmb = 25 °C
ISM
peak source current
[2]
Avalanche ruggedness
EDS(AL)S
[1]
[2]
[3]
[4]
non-repetitive drainsource avalanche
energy
ID = 190 A; Vsup ≤ 40 V; RGS = 50 Ω;
VGS = 10 V; Tj(init) = 25 °C; unclamped;
Fig. 4
[3] [4]
165A continuous current has been successfully demonstrated during application tests. Practically the current will be limited by PCB,
Single-pulse avalanche rating limited by maximum junction temperature of 175 °C.
Refer to application note AN10273 for further information.
BUK7J1R0-40H
Product data sheet
31 May 2018
3 / 12
BUK7J1R0-40H
Nexperia
03na19
120
aaa-028015
500
ID
(A)
Pder
400
80
300
200
(1)
40
100
Fig. 1.
100
150
Tmb (°C)
25
50
75
100
125
150 175
Tmb (°C)
200
VGS ≥ 10 V
(1) 220A continuous current has been successfully
the current will be limited by PCB, thermal design
Normalized total power dissipation as a
function of mounting base temperature
Fig. 2.
ID
(A)
Continuous drain current as a function of
aaa-028017
103
tp = 10 µs
Limit RDSon = VDS / ID
100 µs
102
DC
10
1 ms
10 ms
100 ms
1
10-1
1
10
VDS (V)
102
Tmb = 25 °C; IDM is a single pulse
Fig. 3.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
BUK7J1R0-40H
Product data sheet
31 May 2018
4 / 12
BUK7J1R0-40H
Nexperia
IAL
(A)
aaa-028014
103
102
(1)
(2)
10
(3)
1
10-1
10-3
10-2
10-1
1
tAL (ms)
10
(1) Tj (init) = 25 °C; (2) Tj (init) = 150 °C; (3) Repetitive Avalanche
Fig. 4.
Avalanche rating; avalanche current as a function of avalanche time
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance
from junction to
mounting base
Fig. 5
0.21
0.3
K/W
aaa-028016
1
Zth(j-mb)
(K/W)
10-1
δ = 0.5
0.2
0.1
0.05
10-2
0.02
P
δ=
Fig. 5.
T
single shot
t
tp
10-3
10-6
tp
10-5
10-4
10-3
10-2
T
10-1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration
BUK7J1R0-40H
Product data sheet
31 May 2018
5 / 12
BUK7J1R0-40H
Nexperia
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ID = 250 µA; VGS = 0 V; Tj = 25 °C
40
43
V
ID = 250 µA; VGS = 0 V; Tj = -40 °C
40.5
V
ID = 250 µA; VGS = 0 V; Tj = -55 °C
36
40
V
ID = 1 mA; VDS=VGS; Tj = 25 °C; Fig. 9;
Fig. 10
2.4
3
3.6
V
ID = 1 mA; VDS=VGS; Tj = -55 °C; Fig. 9
4.3
V
ID = 1 mA; VDS=VGS; Tj = 175 °C; Fig. 9
1
V
VDS = 40 V; VGS = 0 V; Tj = 25 °C
0.07
1.5
µA
VDS = 16 V; VGS = 0 V; Tj = 125 °C
3.2
25
µA
VDS = 40 V; VGS = 0 V; Tj = 175 °C
0.34
1
mA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -10 V; VDS = 0 V; Tj = 25 °C
2
100
nA
Fig. 11
0.6
0.85
1
mΩ
VGS = 10 V; ID = 25 A; Tj = 105 °C;
Fig. 12
0.84
1.27
1.6
mΩ
VGS = 10 V; ID = 25 A; Tj = 125 °C;
Fig. 12
0.93
1.41
1.75
mΩ
VGS = 10 V; ID = 25 A; Tj = 175 °C;
Fig. 12
1.17
1.76
2.18
mΩ
f = 1 MHz; Tj = 25 °C
0.47
1.17
2.9
Ω
Fig. 13; Fig. 14
90.7
131
nC
25.8
40
nC
17.7
35.5
nC
6666
9340
pF
1644
2300
pF
309
679
pF
22.2
ns
18.9
ns
V(BR)DSS
VGS(th)
IDSS
IGSS
RDSon
RG
drain-source
breakdown voltage
gate-source threshold
voltage
drain leakage current
gate leakage current
resistance
gate resistance
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
turn-off delay time
51.7
ns
tf
fall time
23.8
ns
0.77
1.2
V
VDS = 25 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; Fig. 15
VDS = 30 V; RL = 1.2 Ω; VGS = 10 V;
RG(ext) = 5 Ω
Source-drain diode
VSD
source-drain voltage
BUK7J1R0-40H
Product data sheet
IS = 25 A; VGS = 0 V; Tj = 25 °C; Fig. 16
31 May 2018
6 / 12
BUK7J1R0-40H
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
trr
reverse recovery time
44.9
ns
Qr
recovered charge
VDS = 20 V
53.2
nC
S
softness factor
0.77
IS = 25 A; dIS/dt = -500 A/µs; VGS = 0 V;
0.68
aaa-028018
400
10 V
ID
(A)
7V
RDSon
(mΩ)
VGS = 5.5 V
aaa-028019
4
6V
300
3
5V
200
2
100
1
4.5 V
Fig. 6.
4V
2
3
VDS (V)
8
12
16
VGS (V)
Tj = 25 °C
Tj = 25 °C; ID = 25 A
Output characteristics; drain current as a
Fig. 7.
function of drain-source voltage; typical values
Drain-source on-state resistance as a function
of gate-source voltage; typical values
aaa-028020
400
ID
(A)
VGS(th)
(V)
aaa-018139
5
4
300
Max
3
Typ
200
2
Min
100
Tj = -55°C
175°C
1
25°C
2
3
4
5
6
7
VGS (V)
8
VDS = 8 V
Fig. 8.
Product data sheet
60
90
120 150
Tj (°C)
180
ID = 1 mA ; VDS = VGS
Transfer characteristics; drain current as a
function of gate-source voltage; typical values
BUK7J1R0-40H
-30
Fig. 9.
Gate-source threshold voltage as a function of
31 May 2018
7 / 12
BUK7J1R0-40H
Nexperia
aaa-018138
10-1
ID
(A)
RDSon
(mΩ)
10-2
aaa-028021
8
4.5 V
5V
5.5 V
6
Min
10-3
Typ
Max
4
10-4
6V
2
10-5
10-6
2
3
4
VGS (V)
Tj = 25 °C; VDS = 5V
VGS = 10 V
100
150
200
250
300 350
ID (A)
400
Tj = 25 °C
Fig. 10. Sub-threshold drain current as a function of
gate-source voltage
a
7V
Fig. 11. Drain-source on-state resistance as a function
of drain current; typical values
aaa-026897
2.4
VGS
(V)
2
aaa-028022
10
8
1.6
VDS = 14 V
6
32 V
1.2
4
0.8
2
0.4
-30
60
90
120 150
Tj (°C)
60
80
QG (nC)
100
Fig. 12. Normalized drain-source on-state resistance
factor as a function of junction temperature
BUK7J1R0-40H
Product data sheet
Fig. 13. Gate-source voltage as a function of gate
charge; typical values
31 May 2018
8 / 12
BUK7J1R0-40H
Nexperia
aaa-028023
104
C
(pF)
VDS
ID
Ciss
Coss
103
VGS(pl)
Crss
VGS(th)
VGS
QGS2
QGS1
QGS
102
QGD
QG(tot)
003aaa508
10
10-1
Fig. 14. Gate charge waveform definitions
1
10
VDS (V)
102
Fig. 15. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
003aaf444
aaa-028024
400
IS
(A)
ID
(A)
300
trr
ta
200
tb
0.25 IRM
100
175°C
0.4
0.6
Tj = 25°C
0.8
1
VSD (V)
tb
S= t
a
IRM
1.2
t (s)
VGS = 0 V
Fig. 16. Source-drain (diode forward) current as a
function of source-drain (diode forward)
BUK7J1R0-40H
Product data sheet
Fig. 17. Reverse recovery waveform definitions
31 May 2018
9 / 12
BUK7J1R0-40H
Nexperia
11. Package outline
Plastic single-ended surface-mounted package (LFPAK56E); 4 leads
A
E
SOT1023
E1
A
b1
b2
(3x)
c1
mounting
base
H
D1
D
L
1
2
3
4
b
e
A1
w
A
X
c
C
θ
Lp
detail X
A
A1
b
b1
b2
c
c1
D(1) D1(1) E(1) E1(1)
max 1.10 0.15 0.50 4.41
0.25 0.30 4.70 4.45 5.30
nom
0.85
min 0.95 0.00 0.35 3.62
0.19 0.24 4.45
4.95
mm
5 mm
scale
Dimensions
Unit
y C
3.7
3.5
e
1.27
H
L
Lp
6.2
1.3
0.85
5.9
0.8
0.40
w
y
0.25
0.1
θ
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm per side are not included.
Outline
version
sot1023_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
13-03-05
17-07-31
SOT1023
Fig. 18. Package outline LFPAK56E; Power-SO8 (SOT1023)
BUK7J1R0-40H
Product data sheet
31 May 2018
10 / 12
BUK7J1R0-40H
Nexperia
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
12. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
BUK7J1R0-40H
Product data sheet
31 May 2018
11 / 12
BUK7J1R0-40H
Nexperia
Contents
1. General description......................................................1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 5
10. Characteristics............................................................ 6
11. Package outline........................................................ 10
12. Legal information.......................................................11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 31 May 2018
BUK7J1R0-40H
Product data sheet
31 May 2018
12 / 12
