BUK7M8R5-40H
N-channel 40 V, 8.5 mΩ standard level MOSFET in LFPAK33
5 February 2019
Product data sheet
1. General description
Automotive qualified standard level N-channel MOSFET in an LFPAK33 package using Trench 9
TrenchMOS technology. This product has been designed and qualified to AEC-Q101 for use in high
performance automotive applications.
2. Features and benefits
Fully automotive qualified to AEC-Q101 at 175 °C
Trench 9 superjunction technology:
• Low power losses, high power density
LFPAK copper clip package technology:
• High robustness and reliability
• Gull wing leads for high manufacturability and AOI
Repetitive avalanche rated
3. Applications
12 V automotive systems
Powertrain, chassis, body and infotainment applications
Medium/Low power motor drive
DC-DC systems
LED lighting
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
25 °C ≤ Tj ≤ 175 °C
40
V
ID
drain current
VGS = 10 V; Tmb = 25 °C; Fig. 2
40
A
Ptot
total power dissipation
Tmb = 25 °C; Fig. 1
59
W
VGS = 10 V; ID = 15 A; Tj = 25 °C;
Fig. 11
5.2
7.4
8.5
mΩ
ID = 15 A; VDS = 32 V; VGS = 10 V;
Fig. 13; Fig. 14
2.6
5.2
nC
IS = 15 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 20 V
15
nC
[1]
Static characteristics
RDSon
drain-source on-state
resistance
Dynamic characteristics
QGD
gate-drain charge
Source-drain diode
Qr
recovered charge
BUK7M8R5-40H
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
S
softness factor
VDS = 20 V; Tj = 25 °C; Fig. 17
0.62
[1]
Unit
40A continuous current has been successfully demonstrated during application tests. Practically the current will be limited by PCB,
thermal design and operating temperature.
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
Simplified outline
Graphic symbol
1
S
source
2
S
source
3
S
source
G
4
G
gate
mbb076
mb
D
Mounting base; connected to
drain
D
1
2
3
S
4
LFPAK33 (SOT1210)
6. Ordering information
Table 3. Ordering information
Type number
Package
BUK7M8R5-40H
Name
Description
Version
LFPAK33
Plastic, single ended surface mounted package (LFPAK33); 8
leads; 0.65 mm pitch
SOT1210
7. Marking
Table 4. Marking codes
Type number
Marking code
BUK7M8R5-40H
78H040
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
25 °C ≤ Tj ≤ 175 °C
40
V
VGS
gate-source voltage
DC; Tj ≤ 175 °C
-10
V
Ptot
Tmb = 25 °C; Fig. 1
59
W
ID
drain current
40
A
VGS = 10 V; Tmb = 100 °C; Fig. 2
[1]
40
A
pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3
239
A
IDM
peak drain current
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
Source-drain diode
BUK7M8R5-40H
Product data sheet
All information provided in this document is subject to legal disclaimers.
5 February 2019
Nexperia B.V. 2019. All rights reserved
2 / 11
BUK7M8R5-40H
Nexperia
Symbol
Parameter
Conditions
Min
Max
Unit
IS
source current
Tmb = 25 °C
40
A
ISM
peak source current
239
A
24
mJ
Avalanche ruggedness
EDS(AL)S
[1]
[2]
[3]
non-repetitive drainID = 40 A; Vsup ≤ 40 V; RGS = 50 Ω;
source avalanche energy VGS = 10 V; Tj(init) = 25 °C; unclamped;
Fig. 4
[2] [3]
Single-pulse avalanche rating limited by maximum junction temperature of 175 °C.
Refer to application note AN10273 for further information.
03aa16
120
ID
(A)
Pder
aaa-029136
60
50
80
40
(1)
30
40
Fig. 1.
100
150
Tmb (°C)
25
50
75
100
125
150 175
Tmb (°C)
Normalized total power dissipation as a
function of mounting base temperature
Continuous drain current as a function of
aaa-028939
103
102
200
VGS ≥ 10 V
(1) 40A continuous current has been successfully
the current will be limited by PCB, thermal design
Fig. 2.
ID
(A)
Limit RDSon = VDS / ID
tp = 10 µs
DC
100 µs
10
1 ms
1
10 ms
100 ms
10-1
10-1
1
10
VDS (V)
102
Tmb = 25 °C; IDM is a single pulse
Fig. 3.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
BUK7M8R5-40H
Product data sheet
5 February 2019
3 / 11
BUK7M8R5-40H
Nexperia
IAL
(A)
aaa-028940
102
(1)
10
(2)
1
(3)
10-1
10-2
10-3
10-2
10-1
1
tAL (ms)
10
(1) Tj (init) = 25 °C; (2) Tj (init) = 150 °C; (3) Repetitive Avalanche
Fig. 4.
Avalanche rating; avalanche current as a function of avalanche time
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Rth(j-mb)
Conditions
thermal resistance from Fig. 5
junction to mounting
base
Min
Typ
Max
Unit
2.33
2.56
K/W
aaa-028941
10
Zth(j-mb)
(K/W)
1
δ = 0.5
0.2
0.1
10-1
0.05
P
0.02
δ=
single shot
Fig. 5.
10-5
10-4
10-3
10-2
T
t
tp
10-2
10-6
tp
T
10-1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ID = 250 µA; VGS = 0 V; Tj = 25 °C
40
43
V
ID = 250 µA; VGS = 0 V; Tj = -40 °C
40.5
V
V(BR)DSS
drain-source
breakdown voltage
BUK7M8R5-40H
Product data sheet
5 February 2019
4 / 11
BUK7M8R5-40H
Nexperia
Symbol
VGS(th)
IDSS
IGSS
RDSon
RG
Parameter
gate-source threshold
voltage
drain leakage current
gate leakage current
resistance
gate resistance
Conditions
Min
Typ
Max
Unit
ID = 250 µA; VGS = 0 V; Tj = -55 °C
36
40
V
ID = 1 mA; VDS=VGS; Tj = 25 °C; Fig. 9;
Fig. 10
2.4
3
3.6
V
ID = 1 mA; VDS=VGS; Tj = -55 °C; Fig. 10
4.3
V
ID = 1 mA; VDS=VGS; Tj = 175 °C;
Fig. 10
1
V
VDS = 40 V; VGS = 0 V; Tj = 25 °C
0.05
1
µA
VDS = 16 V; VGS = 0 V; Tj = 125 °C
0.42
10
µA
VDS = 40 V; VGS = 0 V; Tj = 175 °C
36
500
µA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -10 V; VDS = 0 V; Tj = 25 °C
2
100
nA
Fig. 11
5.2
7.4
8.5
mΩ
VGS = 10 V; ID = 15 A; Tj = 105 °C;
Fig. 12
7.1
10.7
12.8
mΩ
VGS = 10 V; ID = 15 A; Tj = 125 °C;
Fig. 12
7.8
11.6
13.7
mΩ
VGS = 10 V; ID = 15 A; Tj = 175 °C;
Fig. 12
9.5
13.9
16.5
mΩ
f = 1 MHz; Tj = 25 °C
0.3
0.8
2
Ω
Fig. 13; Fig. 14
14
nC
4.5
6.8
nC
2.6
5.2
nC
935
1309
pF
374
524
pF
43
95
pF
5
ns
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
3.2
ns
td(off)
turn-off delay time
9.2
ns
tf
fall time
3.7
ns
VDS = 25 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; Fig. 15
VDS = 30 V; RL = 2 Ω; VGS = 10 V;
RG(ext) = 5 Ω
Source-drain diode
VSD
source-drain voltage
IS = 15 A; VGS = 0 V; Tj = 25 °C; Fig. 16
0.85
1.2
V
trr
reverse recovery time
VDS = 20 V; Fig. 17
22
ns
Qr
recovered charge
VDS = 20 V
15
nC
S
softness factor
0.62
IS = 15 A; dIS/dt = -500 A/µs; VGS = 0 V;
0.42
BUK7M8R5-40H
Product data sheet
5 February 2019
5 / 11
BUK7M8R5-40H
Nexperia
ID
(A)
aaa-028947
80
10 V
6V
aaa-028948
40
RDSon
(mΩ)
5.5 V
60
30
VGS = 5 V
40
4.5 V
4V
Fig. 6.
ID
(A)
2
3
VDS (V)
8
12
16
VGS (V)
Tj = 25 °C
Tj = 25 °C; ID = 15 A
Output characteristics; drain current as a
Fig. 7.
function of drain-source voltage; typical values
Drain-source on-state resistance as a function
of gate-source voltage; typical values
aaa-028949
80
aaa-018138
10-1
ID
(A)
10-2
60
Min
10-3
Typ
Max
40
10-4
175°C
10-5
Tj = -55°C
25°C
2
3
4
5
6
VGS (V)
10-6
7
VDS = 8 V
Fig. 8.
Product data sheet
1
2
3
4
VGS (V)
5
Tj = 25 °C; VDS = 5 V
Transfer characteristics; drain current as a
function of gate-source voltage; typical values
BUK7M8R5-40H
Fig. 9.
Sub-threshold drain current as a function of
gate-source voltage
5 February 2019
6 / 11
BUK7M8R5-40H
Nexperia
VGS(th)
(V)
aaa-018139
5
4
4.5 V
5V
5.5 V
30
Max
3
aaa-028950
40
RDSon
(mΩ)
Typ
6V
2
Min
8V
10
1
VGS = 10 V
-30
60
90
120 150
Tj (°C)
ID = 1 mA ; VDS = VGS
60
ID (A)
80
Tj = 25 °C
Fig. 10. Gate-source threshold voltage as a function of
a
Fig. 11. Drain-source on-state resistance as a function
of drain current; typical values
aaa-029494
2
VGS
(V)
aaa-028951
10
1.6
8
1.2
6
0.8
4
0.4
2
32 V
VDS = 14 V
-30
60
90
120 150
Tj (°C)
5
7.5
10
12.5
QG (nC)
15
Fig. 12. Normalized drain-source on-state resistance
factor as a function of junction temperature
BUK7M8R5-40H
Product data sheet
Fig. 13. Gate-source voltage as a function of gate
charge; typical values
5 February 2019
7 / 11
BUK7M8R5-40H
Nexperia
aaa-028952
104
C
(pF)
VDS
ID
103
VGS(pl)
Ciss
Coss
VGS(th)
VGS
QGS2
QGS1
QGS
102
QGD
QG(tot)
Crss
003aaa508
10
10-1
Fig. 14. Gate charge waveform definitions
1
10
VDS (V)
102
Fig. 15. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
IS
(A)
003aaf444
aaa-028953
80
ID
(A)
60
trr
ta
40
tb
0.25 IRM
175°C
0.4
0.6
Tj = 25°C
0.8
1
VSD (V)
tb
S= t
a
1.2
VGS = 0 V
Fig. 16. Source-drain (diode forward) current as a
function of source-drain (diode forward)
BUK7M8R5-40H
Product data sheet
IRM
t (s)
Fig. 17. Reverse recovery timing definition
5 February 2019
8 / 11
BUK7M8R5-40H
Nexperia
11. Package outline
Plastic single ended surface mounted package (LFPAK33); 8 leads
E
A
e1
A
c1
b1
L1
SOT1210
D2
mounting
base
D1
(D)
H
E1
L
1
4
b
e
w
A
A1
C
X
c
Lp
y C
detail X
5 mm
scale
Dimensions
Unit(1)
A
A1
b(1)
max 0.90 0.10 0.35
nom
min 0.80 0.00 0.25
mm
b1(1)
c
c1
2.4
0.20 0.30
2.2
0.10 0.20
D ref
2.60
D1
2.35
1.90
D2
0.50
E(1)
E1
3.40 2.45
3.20 2.00
e
e1
0.65 0.65
H
L
L1
Lp
3.40
0.65 0.25 0.50
3.20
0.45 0.13 0.30
w
0.20 0.10
Note
1. Plastic or metal protrusions of 0.15 mm per side are not included.
Outline
version
sot1210_po
References
IEC
JEDEC
y
JEITA
European
projection
Issue date
14-04-25
16-08-09
SOT1210
Fig. 18. Package outline LFPAK33 (SOT1210)
BUK7M8R5-40H
Product data sheet
5 February 2019
9 / 11
BUK7M8R5-40H
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
12. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
BUK7M8R5-40H
Product data sheet
5 February 2019
10 / 11
BUK7M8R5-40H
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 2
9. Thermal characteristics............................................... 4
10. Characteristics............................................................ 4
11. Package outline.......................................................... 9
12. Legal information......................................................10
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 5 February 2019
BUK7M8R5-40H
Product data sheet
5 February 2019
11 / 11
