PJ78L06SQ
PJ78L06SQ
    PJ(平晶)
    SOT89-3
    正电压 30V 6V 100mA 5.5mA
PJ78L06SQ 数据手册
PJ78L06SQ 3-Terminal Voltage Regulator Features SOT-89  Input voltage:up to 30V  Output:6V  Output current up to 100 mA, internal thermal overload protection and short-circuit limiting. 1. OUT 2. GND 3. IN Maximum Ratings Ratings at TA = 25℃ ambient temperature unless otherwise specified. Parameter Symbols Value Units Input Voltage VI 30 V Output Current IO 100 mA Junction Temperature TJ 150 ℃ TOPR -40~125 ℃ Power Dissipation PD 500 mW Storage Temperature Range TSTG -55~150 ℃ Operating Temperature Range Vi C1 0.33 µF www.pingjingsemi.com Revision:1.0 Sep-2018 1 3 PJ78L06SQ 2 Vo C2 0.1 µF 1/4 PJ78L06SQ 3-Terminal Voltage Regulator Electrical Characteristics Ratings at TA = 25℃ ambient temperature, 0℃≤ TJ≤125℃ VI=11V, Io=40mA, Ci=0.33μF,Co=0.1μF,unless otherwise specified. Parameter Output Voltage Symbols VO Test Conditions Min Typ Max Unit TJ=25℃ 5.76 6 6.24 V 5.7 6 6.3 V 5.7 6 6.3 V VI=8.5V to 21V TJ=25℃ 155 mV VI=9V to 21V TJ=25℃ 105 mV IO=1mA to 100 mA, TJ=25℃ 65 mV IO=1mA to 40 mA, TJ=25℃ 35 mV IO=1mA to 40mA VI=8.5V to 21V IO=1mA to 70mA VI=11V Line Regulation △ Load Regulation △ Ripple Rejection RR Output Noise Voltage VN Dropout Voltage VD TJ=25℃ Quiescent Current IQ TJ=25℃ Quiescent Current Change www.pingjingsemi.com Revision1.0 Sep-2018 Vo VO △ IQ VI=9V to 19V, TJ=25℃ f=120Hz =f 10Hz~100KHz TJ=25℃ 40 dB 49 μV 1.7 V 5.5 mA VI=9V to 21V, IO=40mA 1.5 mA VI=11V, IO=1mA to 40mA 0.1 mA 2/4 PJ78L06SQ 3-Terminal Voltage Regulator Ratings and Characteristic Curves Output Characteristics Current Cut-off Grid Voltage (V) 8 7 IO=0mA VIN=11V TJ=25℃ TJ=25℃ 6 Pulsed (V) OUTPUT VOLTAGE VO OUTPUT VOLTAGE VO 6 4 2 5 4 3 2 0 0 5 25 1 0.00 30 0.05 0.10 0.15 OUTPUT CURRENT Quiescent Current 5 0.20 IO 0.25 0.30 100 125 (A) Power Derating Curve 800 IO=0mA (mW) 700 4 PD 600 500 3 POWER DISSIPATION QUIESCENT CURRENT IQ (mA) TJ=25℃ 2 1 400 300 200 100 0 0 5 10 15 INPUT VOLTAGE 25 20 VIN 30 0 -25 0 25 50 JUNCTION TEMPERATURE (V) 75 TJ (℃ ) Output Voltage vs Junction Temperature 6.50 Vin=11V IO=5mA OUTPUT VOLTAGE VO (V) 6.25 6.00 5.75 5.50 5.25 5.00 -25 25 0 50 JUNCTION TEMPERATURE www.pingjingsemi.com Revision:1.0 Sep-2018 75 TJ 100 125 (℃ ) 3/4 PJ78L06SQ 3-Terminal Voltage Regulator Package Outline SOT-89 Dimensions in mm Ordering Information Device Package Shipping PJ78L06SQ SOT-89 1,000/ Tape & Reel (7 inches) www.pingjingsemi.com Revision:1.0 Sep-2018 4/4
PJ78L06SQ 价格&库存
很抱歉,暂时无法提供与“PJ78L06SQ”相匹配的价格&库存,您可以联系我们找货
PJ78L06SQ
  • 10+0.43438
  • 100+0.35198
  • 300+0.31072
  • 1000+0.23890
  • 5000+0.21417
  • 10000+0.20186
库存:920
