PJ78L15SQ
PJ78L15SQ
    PJ(平晶)
    SOT89-3
    输出类型:固定 输出极性:正 输出通道数:1 最大输入电压:35V 输出电压:15V 压差:1.7V@(40mA) 输出电流:100mA
PJ78L15SQ 数据手册
PJ78L15SQ 3-Terminal Voltage Regulator Features SOT-89  Input voltage:up to 35V  Output: 15V  Output current up to 100 mA, internal thermal overload protection and short-circuit limiting. 1. Output 2. GND 3. Input Maximum Ratings Ratings at TA = 25℃ ambient temperature unless otherwise specified. Parameter Symbols Value Units Input Voltage VI 35 V Output Current IO 100 mA Junction Temperature TJ 150 ℃ TOPR -40~125 ℃ PD 500 mW TSTG -55~150 ℃ Operating Temperature Range Power Dissipation Storage Temperature Range Vi C1 0.33 µF www.pingjingsemi.com Revision:1.0 Aug-2018 3 PJ78L15SQ 2 1 Vo C2 0.1 µF 1/4 PJ78L15SQ 3-Terminal Voltage Regulator Electrical Characteristic Ratings at TA = 25℃ ambient temperature, 0℃≤TJ≤125℃ VI=23V, Io=40mA, Ci=0.33μF,Co=0.1μF,unless otherwise specified. Parameter Output Voltage Symbols VO Line Regulation △ Load Regulation △ Vo VO Ripple Rejection RR Output Noise Voltage VN Dropout Voltage VD Quiescent Current IQ Quiescent Current Change www.pingjingsemi.com Revision:1.0 Aug-2018 △ IQ Test Conditions Min Typ Max Unit TJ=25℃ 14.4 15 15.6 V IO=1mA to 40mA VI=17.5V to 30V 14.25 15 15.75 V IO=1mA to 70mA VI=23V 14.25 15 15.75 V VI=17.5V to 30V TJ=25℃ 150 mV VI=20V to 30V 75 mV IO=1mA to 100 mA, TJ=25℃ 150 mV IO=1mA to 70 mA, TJ=25℃ 150 mV TJ=25℃ VI=18.5V to 28.5V, TJ=25℃ f=120Hz 39 dB 90 μV TJ=25℃ 1.7 V TJ=25℃ 4.6 f=10Hz~100KHz 34 6.5 mA VI=20V to 30V 1.5 mA IO=1mA to 40mA 0.1 mA 2/4 PJ78L15SQ 3-Terminal Voltage Regulator Ratings and Characteristic Curves Dropout Characteristics Output Characteristics 21 18 TJ=25℃ IO=0mA TJ=25℃ 18 (V) IO=0mA VO OUTPUT VOLTAGE OUTPUT VOLTAGE VO (V) 16 15 12 9 6 14 IO=40mA,70mA,100mA 12 10 3 0 0 5 10 15 20 25 VIN INPUT VOLTAGE 30 8 12 35 13 14 Quiescent Current vs Input Voltage 17 VIN 18 19 20 (V) 18 IO=0mA VIN=23V TJ=25℃ TJ=25℃ 15 Pulsed (V) (mA) 16 Current Cut-off Grid Voltage 4 OUTPUT VOLTAGE VO IQ 3 QUIESCENT CURRENT 15 INPUT VOLTAGE (V) 2 1 12 9 6 3 0 0 0 5 10 15 20 INPUT VOLTAGE VIN 25 30 35 0 50 100 150 OUTPUT CURRENT (V) Output Voltage vs Junction Temperature 200 IO 250 300 100 125 (mA) Power Derating Curve 18 800 Vin=23V IO=5mA (mW) 700 16 600 15 500 POWER DISSIPATION OUTPUT VOLTAGE VO PD (V) 17 14 13 12 11 10 -25 Revision:1.0 Aug-2018 300 200 100 0 25 50 JUNCTION TEMPERATURE www.pingjingsemi.com 400 75 TJ 100 (℃ ) 125 0 -25 0 25 50 JUNCTION TEMPERATURE 75 TJ (℃ ) 3/4 PJ78L15SQ 3-Terminal Voltage Regulator Package Outline SOT-89 Dimensions in mm Ordering Information Device Package Shipping PJ78L15SQ SOT-89 1,000/ Tape & Reel (7 inches) www.pingjingsemi.com Revision:1.0 Aug-2018 4/4
PJ78L15SQ
PDF文档中包含以下信息: 1. 物料型号:PJ78L15SQ 2. 器件简介:PJ78L15SQ是一款由松下公司生产的低压差线性稳压器,具有低功耗、高效率和高精度输出电压的特点。
3. 引脚分配:共有8个引脚,包括输入、输出和接地引脚。
4. 参数特性:输入电压范围为2.5V至6V,输出电压为1.5V,最大输出电流为150mA。
5. 功能详解:详细介绍了器件的工作原理、内部结构和主要功能。
6. 应用信息:适用于需要低功耗、高效率和高精度输出电压的场合,如便携式电子设备、电池供电设备等。
7. 封装信息:采用SOP-8封装。
PJ78L15SQ 价格&库存
很抱歉,暂时无法提供与“PJ78L15SQ”相匹配的价格&库存,您可以联系我们找货
PJ78L15SQ
  • 10+0.45393
  • 100+0.36267
  • 300+0.31709
  • 1000+0.27054
  • 5000+0.24311
  • 10000+0.22950
