PJ78L12SQ-L
PJ78L12SQ-L
    PJ(平晶)
    SOT89-3
    输出类型:固定 输出极性:正 输出通道数:1 最大输入电压:35V 输出电压:12V 压差:1.7V@(40mA) 输出电流:200mA
PJ78L12SQ-L 数据手册
PJ78L12SQ-L 3-Terminal Voltage Regulator Features SOT-89  Input voltage: up to 35V  Output Voltage: 12V  Output current up to 200 mA, internal thermal overload protection and short-circuit limiting. 1. OUT 2. GND 3. IN Maximum Ratings Ratings at TA = 25℃ ambient temperature unless otherwise specified. Parameter Symbols Value Units Input Voltage VI 35 V Output Current IO 200 mA Power Dissipation PD 500 mW TOPR -40~125 ℃ TJ 150 ℃ TSTG -55~150 ℃ Operating Temperature Range Junction Temperature Storage Temperature Range Vi C1 0.33 µF www.pingjingsemi.com Revision 1.0 Mar-2019 1 3 PJ78L12SQ-L 2 Vo C2 0.1 µF 1/4 PJ78L12SQ-L 3-Terminal Voltage Regulator Electrical Characteristics Ratings at TA = 25℃ ambient temperature, 0℃≤TJ≤125℃ , VI=19V, Io=40mA, Ci=0.33μF,Co=0.1μF,unless otherwise specified. Parameter Output Voltage Symbols VO Test Conditions Min Typ Max Unit 11.5 12 12.5 V IO=1mA to 40mA VI=14.5V to 27V 11.4 12 12.6 V IO=1mA to 70mA VI=19V 11.4 12 12.6 V VI=14.5V to 27V TJ=25℃ 250 mV VI=16V to 27V TJ=25℃ 200 mV IO=1mA to 100 mA, TJ=25℃ 100 mV IO=1mA to 40 mA, TJ=25℃ 50 mV Line Regulation △ Load Regulation △ Ripple Rejection RR VI=15V to 25V, TJ=25℃ f=120Hz Output Noise Voltage VN =f 10Hz~100KHz TJ=25℃ Dropout Voltage VD TJ=25℃ Quiescent Current IQ TJ=25℃ Quiescent Current Change www.pingjingsemi.com Revision 1.0 Mar-2019 Vo VO △ IQ 37 dB 70 μV 1.7 V 6 mA VI=16V to 27V 1.5 mA IO=1mA to 40mA 0.1 mA 2/4 PJ78L12SQ-L 3-Terminal Voltage Regulator Ratings and Characteristic Curves Current Cut-off Grid Voltage Output Characteristics 18 16 VIN=19V IO=0mA TJ=25℃ TJ=25℃ 15 Pulsed VO (V) 12 10 OUTPUT VOLTAGE OUTPUT VOLTAGE VO (V) 14 8 6 4 12 9 6 3 2 0 0 0 5 10 15 20 INPUT VOLTAGE 25 VIN 30 0 35 40 80 120 OUTPUT CURRENT (V) 160 IO 200 240 100 125 (mA) Power Derating Curve Quiescent Current 800 5 IO=0mA (mW) 700 4 PD 600 500 3 POWER DISSIPATION QUIESCENT CURRENT IQ (mA) TJ=25℃ 2 1 400 300 200 100 0 0 10 5 15 INPUT VOLTAGE 20 VIN 25 30 0 -25 0 25 50 JUNCTION TEMPERATURE (V) 75 TJ (℃ ) Output Voltage vs Junction Temperature 14 Vin=19V OUTPUT VOLTAGE VO (V) IO=5mA 13 12 11 10 -25 25 0 50 JUNCTION TEMPERATURE www.pingjingsemi.com Revision 1.0 Mar-2019 75 100 125 TJ (℃ ) 3/4 PJ78L12SQ-L 3-Terminal Voltage Regulator Package Outline SOT-89 Dimensions in mm ORDERING INFORMATION Device Package Shipping PJ78L12SQ-L SOT-89 1,000/ Tape & Reel (7 inches) www.pingjingsemi.com Revision 1.0 Mar-2019 4/4
PJ78L12SQ-L 价格&库存
很抱歉,暂时无法提供与“PJ78L12SQ-L”相匹配的价格&库存,您可以联系我们找货
