2SD882SQ-P
2SD882SQ-P
    PJ(平晶)
    SOT89-3
    三极管 NPN Ic=3A Vceo=30V hfe=30~400 P=1W SOT89-3
2SD882SQ-P 数据手册
2SD882SQ Silicon NPN Power Transistor Features.    High current output up to 3A Low saturation voltage Complement to 2SB772SQ Applications PIN1:Base PIN 2:Collector PIN 3:Emitter These devices are intended for use in audio frequency power amplifier and low speed switching applications 2C 1B 3E Absolute Maximum Ratings (Ta=25℃unless otherwise specified) Parameter Symbol Rating Unit Collector to Base Voltage VCBO 40 V Collector to Emitter Voltage VCEO 30 V Emitter to Base Voltage VEBO 5 V Collector Current-Continuous IC 3 A Peak Collector Current ICP 7 A Total Power Dissipation PD 1 W Total Power Dissipation PD (Tc=25℃) 10 W TJ 150 ℃ TSTG -55~150 ℃ Junction Temperature Storage Temperature Range www.pingjingsemi.com Revision:1.0 May-2018 1/3 2SD882SQ Silicon NPN Power Transistor Electrical Characteristics (Ta=25℃ unless otherwise specified) Parameter Symbol Min. Typ. Max. Unit hFE 30 R hFE 60 Q hFE 100 P hFE 160 E hFE 200 - 120 200 320 400 - DC Current Gain at VCE = 2 V, IC = 20 mA at VCE = 2 V, IC = 1 A Current Gain Group Collector Base Cutoff Current at VCB = 30 V ICBO - - 1 µA Emitter Base Cutoff Current at VEB = 3 V IEBO - - 1 µA Collector Emitter Saturation Voltage at IC = 2 A, IB = 0.2 A VCE(sat) - - 0.5 V Base Emitter Saturation Voltage at IC = 2 A, IB = 0.2 A VBE(sat) - - 2 V Gain Bandwidth Product at VCE = 5 V, IC = 0.1 A fT - 90 - MHz Output Capacitance at VCB = 10 V, f = 1 MHz Cob - 45 - pF Typical Characteristic Curves 1000 2.0 300 h FE -DC Current Gain 10 9 8 1.6 I C-Collector Current-A VCE=2.0V Pulse Test Pulse Test 7 1.2 6 5 0.8 4 3 0.4 2 h FE 100 60 30 10 6 3 1 0.6 VBE VBE -Base Emitter Voltage-V DC CURRENT GAIN, BASE TO EMITTER VOLTAGE vs. COLLECTOR CURRENT COLLECTOR CURRENT vs. COLLECTOR TO EMITTER VOLTAGE 0.3 3 I B =1mA 1 0.001 0.003 0.01 0.03 0.1 0.3 0 4 8 12 1 3 10 0.1 20 16 I C-Collector Current-A o Voltage-V VCE-Collector to Emitter BASE AND COLLECTOR SATURATION VOLTAGE vs. COLLECTOR CURRENT VBE(sat) -Base Saturation Voltage-v VCE(sat)-Collector Saturation Voltage-V 10 I C=10.I B Pulse Test 3 1 0.6 0.3 VBE(sat) 0.1 0.06 0.03 VCE(sat) 0.01 0.006 0.003 0.001 0.003 0.01 0.03 0.1 0.3 1 3 10 I C-Collector Current-A www.pingjingsemi.com Revision:1.0 May-2018 2/3 2SD882SQ Silicon NPN Power Transistor Package Outline SOT-89 Ordering information Device 2SD882SQ www.pingjingsemi.com Revision:1.0 May-2018 Package SOT-89 Shipping 1000PCS 3/3
2SD882SQ-P 价格&库存
很抱歉,暂时无法提供与“2SD882SQ-P”相匹配的价格&库存,您可以联系我们找货
2SD882SQ-P
  • 5+0.23322
  • 20+0.21252
  • 100+0.19182
  • 500+0.17112
  • 1000+0.16146
  • 2000+0.15456
库存:575
