BCX53SQ-16
BCX53SQ-16
    PJ(平晶)
    SOT89-3
    三极管 PNP Ic=1A Vceo=80V hfe=25~250 P=0.5W SOT89-3
BCX53SQ-16 数据手册
BCX53SQ PNP Silicon Epitaxial Planar Transistor Features    SOT-89 For AF driver and output stages High collector current Low collector-emitter saturation voltage Absolute Maximum Ratings (Ta=25℃unless otherwise specified) Parameter Symbol Value Units Collector Base Voltage VCBO -100 V Collector Emitter Voltage VCEO -80 V Emitter Base Voltage VEBO -5 V Collector Current IC -1 A Peak Collector Current ICM A Total Power Dissipation Ptot -1.5 0.5(1) 1.3(2) Junction Temperature TJ 150 ℃ Storage Temperature Range Tstg - 65 to + 150 ℃ W Note :1.Device mounted on an FR4 Printed-Circuit Board(PCB), single-sided copper, tin-plated and standard footprint. 2. Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2 Electrical Characteristics (Ta=25℃ unless otherwise specified) Parameter Symbol Min. Typ. Max. Units hFE 40 - - - BCX53SQ-10 hFE 63 - 160 - BCX53SQ-16 hFE 100 - 250 - hFE 25 - - - Collector Base Cutoff Current at VCB = -30 V -ICBO - - 100 nA Emitter Base Cutoff Current at VEB = -5 V -IEBO - - 100 nA Collector Base Breakdown Voltage at IC = -100 µA -V(BR)CBO 100 - - V Collector Emitter Breakdown Voltage at IC = -1 mA -V(BR)CEO 80 - - V Emitter Base Breakdown Voltage at IE = -100 µA -V(BR)EBO 5 - - V Collector Emitter Saturation Voltage at IC = -500 mA, IB = -50 mA -VCE(sat) - - 0.5 V -VBE - - 1 V Transition Frequency at VCE =- 5 V, IC = -50 mA, f = 100 MHz fT - 145 - MHz Collector Capacitance at VCB =-15 V, f = 1 MHz Cc - 15 - pF DC Current Gain at VCE = -2 V, IC = -5 mA at VCE = -2 V, IC = -150 mA at VCE =- 2 V, IC = -500m A Base Emitter Voltage at VCE = -2 V, IC = -500 mA www.pingjingsemi.com Revision:1.0 Jun-2018 1/3 BCX53SQ PNP Silicon Epitaxial Planar Transistor Typical Characteristic Curves Power derating curves www.pingjingsemi.com Revision:1.0 Jun-2018 2/3 BCX53SQ PNP Silicon Epitaxial Planar Transistor Package Outline SOT-89 Dimensions in mm Ordering information Device Package Shipping BCX53SQ SOT-89 1000PCS/Reel&Tape www.pingjingsemi.com Revision:1.0 Jun-2018 3/3
BCX53SQ-16 价格&库存
很抱歉,暂时无法提供与“BCX53SQ-16”相匹配的价格&库存,您可以联系我们找货
BCX53SQ-16
  • 10+0.47391
  • 100+0.39626
  • 300+0.35738
  • 3000+0.29355
  • 6000+0.27022
  • 9000+0.25856
库存:304
BCX53SQ-16
  • 5+0.24310
  • 20+0.22165
  • 100+0.20020
  • 500+0.17875
  • 1000+0.16874
  • 2000+0.16159
库存:642
