2SD965ASQ
NPN Transistor
Features
SOT-89
Low saturation voltage
Large Collector Power Dissipation and Current
1. Base 2. Collector 3.Emitter
Marking: Q: AQ
R:AR
S:AS
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Symbol
Value
Unit
Collector Base Voltage
VCBO
40
V
Collector Emitter Voltage
VCEO
30
V
Emitter Base Voltage
DC
Current
Gain
Collector
Current
VEBO
7
Unit
V
IC
5
A
PD
750
mW
RθJA
167
°C/W
TJ
150
°C
TSTG
-55 to 150
°C
Power Dissipation
Maximum Junction-to-Ambient
Junction Temperature
Storage Temperature Range
40
www.pingjingsemi.com
Revision:1.0 Feb-2019
40
40
1/4
2SD965ASQ
NPN Transistor
Electrical Characteristics
Parameter
Min.
Typ.
Max.
at VCE = 2 V, IC = 1 mA
230
340
560
at VCE = 2 V, IC = 2 A
150
200
380
600
800
DC Current Gain
at VCE = 2 V, IC = 500 mA
Current Gain Group Q
R
S
Symbol
HFE
Collector Base Cutoff Current
at VCB = 10 V
ICBO
0.1
μA
Emitter Base Cutoff Current
at VEB = 7 V
IEBO
0.1
μA
Collector Base Breakdown Voltage
at IC = 100 μA
V(BR)CBO
40
V
Collector Emitter Breakdown Voltage
at IC = 1 mA
V(BR)CEO
30
V
Emitter Base Breakdown Voltage
at IE = 10 μA
V(BR)EBO
7
V
Collector Emitter Saturation Voltage
at IC = 3 A, IB = 0.1 A
VCE(sat)
1
V
fT
150
MHz
Cob
50
pF
Transition Frequency
at VCE = 6 V, IC = 50 mA
Collector Output Capacitance
at VCB = 20 V, IE = 0, f = 1MHz
2/4
2SD965ASQ
NPN Transistor
Static Characteristic
900
700
IC
o
Ta=100 C
1.4mA
1.2mA
600
500
1mA
400
0.8mA
300
0.6mA
200
o
Ta=25 C
0.4mA
100
IB=0.2mA
VCE=2V
4
6
8
10
12
14
COLLECTOR-EMITTER VOLTAGE
16
VCE
18
100
1
10
100
1000
COLLECTOR CURRENT
(V)
IC
VCEsat
1
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (V)
VBEsat
2000
BASE-EMITTER SATURATION
VOLTAGE VBEsat (mV)
hFE
1.6mA
DC CURRENT GAIN
(mA)
IC
COLLECTOR CURRENT
COMMON
EMITTER
Ta=25℃
1.8mA
800
hFE
1000
1000
Ta=25℃
Ta=100℃
IC
5000
(mA)
IC
0.1
Ta=100℃
Ta=25℃
β=30
100
0.3
1
10
100
COLLECTOR CURRENT
VBE
5000
1000
IC
100
Cob/ Cib
1000
IC
5000
(mA)
VCB/ VEB
500
f=1MHz
IE=0/ IC=0
o
(pF)
Ta=25 C
Cib
C
100
o
Ta=100 C
100
Ta=25℃
CAPACITANCE
COLLCETOR CURRENT
10
COLLECTOR CURRENT
IC
1
1000
10
Cob
1
0.1
100
VCE=2V
200
300
400
500
600
700
800
BASE-EMMITER VOLTAGE
fT
500
VBE
900
1000
1100
10
0.1
1200
1
10
REVERSE VOLTAGE
(mV)
Pc
IC
V
(V)
Ta
0.9
COLLECTOR POWER DISSIPATION
Pc (W)
(MHz)
0.8
fT
TRANSITION FREQUENCY
0.3
5000
(mA)
IC
(mA)
β=30
0.01
100
VCE=6V
0.7
0.6
0.5
0.4
0.3
0.2
0.1
o
Ta=25 C
10
2
10
COLLECTOR CURRENT
100
IC
(mA)
0.0
50
75
AMBIENT TEMPERATURE
100
Ta
125
150
3/4
2SD965ASQ
NPN Transistor
Package Outline
SOT-89
Dimensions in mm
Ordering information
Device
2SD965ASQ
Package
SOT-89
Shipping
1000/Tape&Reel(7inches)
4/4
很抱歉,暂时无法提供与“2SD965ASQ-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.45533
- 100+0.35997
- 300+0.31223
- 国内价格
- 5+0.34000
- 20+0.31000
- 100+0.28000
- 500+0.25000
- 1000+0.23600
- 2000+0.22600
