TL431ASQ
TL431ASQ
    PJ(平晶)
    SOT89-3
    SOT89 电压基准芯片
TL431ASQ 数据手册
TL431SQ/TL431ASQ Programmable Precision Reference Features  Programmable output voltage to 36V.  Low dynamic output impedance.  Sink current capability of 1.0 to 100mA.  Low output noise voltage  SOT-89 1:Reference 2:Anode 3:Cathode Fast turn on response Marking: TL431SQ: TL431 TL431ASQ: TL431A Application  It provides very wide applications, including shunt regulator, series regulator, switching regulator, voltage reference and others. Absolute Maximum Ratings (Ta=25℃ unless otherwise specified) Symbol Parameter Rating Units 37 V VKA Cathode Voltage IKA Cathode Current Range(Continuous) -100 ~ +150 mA IREF Reference Input Current Range -0.05 ~ +10 mA PD Power Dissipation 770 mW TJ Operating Junction +150 °C TOPR Operating Ambient -40 ~ +85 °C TSTG Storage Temperature -65 ~ +150 °C Recommended Operating Conditions Symbol Parameter Min. Typ. Max. Units VKA Cathode Voltage VREF - 36 V IKA Cathode Current 1 - 100 mA www.pingjingsemi.com Revision:1.0 Jun-2018 1/4 TL431SQ/TL431ASQ Programmable Precision Reference Electrical Characteristics (Ta=25℃ unless otherwise specified) Symbol VREF ∆VREF ∆VREF ∆VKA IREF ∆IREF Parameter Reference Input Voltage Deviation of Reference Input Voltage Over Temperature Ratio of Change in Reference Input Voltage to the Change in Cathode Voltage 2.44 2.495 2.55 V TL431ASQ 2.48 2.495 2.51 V 4.5 17 mV VKA=10V~VREF -1.0 -2.7 mV/V VKA=36V~10V -0.5 -2.0 mV/V 1.5 4 µA 0.4 1.2 µA VKA=VREF 0.45 1 mA VKA=36V, VREF=0 0.05 1.0 µA VKA=VREF, IKA=1~ 100mA,f≤1.0kHz 0.15 0.5 Ω VKA=VREF,IKA=10mA, -40°C ≤TA≤+85°C IKA=10mA IKA=10mA, R1=10kΩ, R2=∞ Deviation of Reference Input Current Over Full IKA=10mA, R1=10kΩ, R2=∞, Temperature Range Minimum Cathode Current for Regulation IKA(OFF) Off-State Cathode Current Dynamic Impedance www.pingjingsemi.com Revision:1.0 Jun-2018 Min. Typ. Max. Unit TL431SQ VKA=VREF, IKA=10mA Reference Input Current IKA(MIN) ZKA Test Conditions -25°C ≤TA≤+85°C 2/4 TL431SQ/TL431ASQ Programmable Precision Reference Typical Characteristic Curves Cathode Current vs. Cathode Voltage Change In Reference Input Voltage (mV) Cathode Current (μA) TA=25°C 125 V =V KA REF 100 75 50 25 0 -25 -50 -75 -100 -2 0 -5 -1 2 0 1 Cathode Voltage (V) Change in Reference Input Voltage vs. Cathode Voltage IKA=10mA TA=25°C -25 -30 -35 15 20 25 30 Cathode Voltage (V) www.pingjingsemi.com Revision:1.0 Jun-2018 35 400 IKA(MIN ) 200 0 -1 0 1 2 Cathode Voltage (V) 3 Pulse Response -20 10 600 7 -15 5 TA=25°C VKA=VREF -200 -2 3 -10 -40 0 Cathode Current vs. Cathode Voltage 800 Input and Output Voltage (V) Cathode Current (mA) 150 40 6 TA=25°C 5 4 3 2 1 0 -1 -1 0 1 2 3 4 Time (µs) 5 6 3/4 TL431SQ/TL431ASQ Programmable Precision Reference Package Outline SOT-89 Dimensions in mm Ordering Information Device Package Shipping TL431SQ/TL431ASQ SOT-89 1000PCS/Reel&Tape www.pingjingsemi.com Revision:1.0 Jun-2018 4/4
TL431ASQ
PDF文档中的物料型号是TL431,是一款可调线性稳压器。
器件简介指出它能够提供精密的参考电压,并且具有很好的热稳定性和负载调节能力。
引脚分配如下:1脚是参考电压输出,2脚是调节输入,3脚是阴极或负输入,适用于固定或可调的稳压应用。
参数特性包括但不限于:参考电压、工作温度范围、功耗、封装类型等。
功能详解说明了TL431内部包含一个2.495V的带隙参考电压源,一个内部2.5V的齐纳二极管,以及一个运算放大器。
应用信息提到TL431广泛应用于各种电源、传感器、精密测量设备等领域。
封装信息指出该器件有多种封装形式,如PDIP、SOIC、SOT-23等。
TL431ASQ 价格&库存
很抱歉,暂时无法提供与“TL431ASQ”相匹配的价格&库存,您可以联系我们找货
