TL431SQ
TL431SQ
    PJ(平晶)
    SOT-89-3
    37V
TL431SQ 数据手册
TL431SQ/TL431ASQ Programmable Precision Reference Features  Programmable output voltage to 36V.  Low dynamic output impedance.  Sink current capability of 1.0 to 100mA.  Low output noise voltage  SOT-89 1:Reference 2:Anode 3:Cathode Fast turn on response Marking: TL431SQ: TL431 TL431ASQ: TL431A Application  It provides very wide applications, including shunt regulator, series regulator, switching regulator, voltage reference and others. Absolute Maximum Ratings (Ta=25℃ unless otherwise specified) Symbol Parameter Rating Units 37 V VKA Cathode Voltage IKA Cathode Current Range(Continuous) -100 ~ +150 mA IREF Reference Input Current Range -0.05 ~ +10 mA PD Power Dissipation 770 mW TJ Operating Junction +150 °C TOPR Operating Ambient -40 ~ +85 °C TSTG Storage Temperature -65 ~ +150 °C Recommended Operating Conditions Symbol Parameter Min. Typ. Max. Units VKA Cathode Voltage VREF - 36 V IKA Cathode Current 1 - 100 mA www.pingjingsemi.com Revision:1.0 Jun-2018 1/4 TL431SQ/TL431ASQ Programmable Precision Reference Electrical Characteristics (Ta=25℃ unless otherwise specified) Symbol VREF ∆VREF ∆VREF ∆VKA IREF ∆IREF Parameter Reference Input Voltage Deviation of Reference Input Voltage Over Temperature Ratio of Change in Reference Input Voltage to the Change in Cathode Voltage 2.44 2.495 2.55 V TL431ASQ 2.48 2.495 2.51 V 4.5 17 mV VKA=10V~VREF -1.0 -2.7 mV/V VKA=36V~10V -0.5 -2.0 mV/V 1.5 4 µA 0.4 1.2 µA VKA=VREF 0.45 1 mA VKA=36V, VREF=0 0.05 1.0 µA VKA=VREF, IKA=1~ 100mA,f≤1.0kHz 0.15 0.5 Ω VKA=VREF,IKA=10mA, -40°C ≤TA≤+85°C IKA=10mA IKA=10mA, R1=10kΩ, R2=∞ Deviation of Reference Input Current Over Full IKA=10mA, R1=10kΩ, R2=∞, Temperature Range Minimum Cathode Current for Regulation IKA(OFF) Off-State Cathode Current Dynamic Impedance www.pingjingsemi.com Revision:1.0 Jun-2018 Min. Typ. Max. Unit TL431SQ VKA=VREF, IKA=10mA Reference Input Current IKA(MIN) ZKA Test Conditions -25°C ≤TA≤+85°C 2/4 TL431SQ/TL431ASQ Programmable Precision Reference Typical Characteristic Curves Cathode Current vs. Cathode Voltage Change In Reference Input Voltage (mV) Cathode Current (μA) TA=25°C 125 V =V KA REF 100 75 50 25 0 -25 -50 -75 -100 -2 0 -5 -1 2 0 1 Cathode Voltage (V) Change in Reference Input Voltage vs. Cathode Voltage IKA=10mA TA=25°C -25 -30 -35 15 20 25 30 Cathode Voltage (V) www.pingjingsemi.com Revision:1.0 Jun-2018 35 400 IKA(MIN ) 200 0 -1 0 1 2 Cathode Voltage (V) 3 Pulse Response -20 10 600 7 -15 5 TA=25°C VKA=VREF -200 -2 3 -10 -40 0 Cathode Current vs. Cathode Voltage 800 Input and Output Voltage (V) Cathode Current (mA) 150 40 6 TA=25°C 5 4 3 2 1 0 -1 -1 0 1 2 3 4 Time (µs) 5 6 3/4 TL431SQ/TL431ASQ Programmable Precision Reference Package Outline SOT-89 Dimensions in mm Ordering Information Device Package Shipping TL431SQ/TL431ASQ SOT-89 1000PCS/Reel&Tape www.pingjingsemi.com Revision:1.0 Jun-2018 4/4
TL431SQ
PDF文档中包含以下信息:
1. 物料型号:TL431SQ_PJ 2. 器件简介:TL431SQ_PJ 是一款可调式精密分流基准电压源,广泛应用于模拟电路中。
3. 引脚分配:该器件共有8个引脚,包括参考电压输出、误差放大器输入、误差放大器输出等。
4. 参数特性:包括最大工作温度、最小工作温度、工作电压范围等。
5. 功能详解:TL431SQ_PJ 通过内部电路实现稳定的2.5V基准电压输出,并通过外部电阻调整输出电压。
6. 应用信息:适用于电源管理、传感器、数据采集等领域。
7. 封装信息:采用SOP-8封装。
TL431SQ 价格&库存
很抱歉,暂时无法提供与“TL431SQ”相匹配的价格&库存,您可以联系我们找货
