PJ71K30SQ
PJ71K30SQ
    PJ(平晶)
    SOT89-3
    输出类型:固定 输出极性:正 输出通道数:1 最大输入电压:24V 输出电压:3V 压差:100mV@(1mA) 输出电流:30mA
PJ71K30SQ 数据手册
PJ71KXXSQ Series High Voltage Regulator Features SOT-89  Low power consumption  Low voltage drop  Low temperature coefficient  High input voltage (up to 24V) Applications  Battery-powered equipment  Communication equipment  Audio/Video equipment 1.GND 2.VIN 3.VOUT Block Diagram VIN General Description The PJ71KXXSQ series is a set of three-terminal low power high voltage regulators implemented in CMOS technology. They allow input voltages as high as 24V. They are available with several fixed output voltages ranging from 3.0V to 5.0V. CMOS technology ensures low voltage drop and low quiescent current. VOUT Vref GND Although designed primarily as fixed voltage regulators, these devices can be used with external components to obtain variable voltages and currents. Selection Table www.pingjingsemi.com Revision:1.0 Jun-2018 Part No. Output Voltage Tolerance PJ71K30SQ 3.0V ± 5% PJ71K33SQ 3.3V ± 5% PJ71K36SQ 3.6V ± 5% PJ71K44SQ 4.4V ± 5% PJ71K50SQ 5.0V ± 5% 1/7 PJ71KXXSQ Series High Voltage Regulator Absolute Maximum Ratings (Ta=25℃ unless otherwise specified) Symbol Parameter VIN Supply Voltage PD Power Dissipation Units Rating -0.3V to 28V V 200 mW TOPR Operating Ambient (2) 0 ~ +70 °C TSTG Storage Temperature -65 ~ +125 °C Note: These are stress ratings only. Stresses exceeding the range specified under Absolute Maximum Ratings may cause substantial damage to the device. Functional operation of this device at other conditions beyond those listed in the specification is not implied and prolonged exposure to extreme conditions may affect device reliability. Electrical Characteristics PJ71K30SQ (Ta=25℃) Symbol Parameter VOUT IOUT Test Conditions VIN Conditions Output Voltage 5V IOUT=10mA Output Current 5V △VOUT Load Regulation 5V VD Voltage Drop ISS Current Consumption △VOUT △VIN×VOUT 5V Input Voltage △VOUT △Ta Temperature Coefficient Typ. Max. Units 2.85 3.0 3.15 V 20 30 1mA≤IOUT≤20mA 60 IOUT=1mA 100 No load 4 4V≤VIN≤24V Line Regulation VIN Min. mA 100 mV 6.0 24 5V IOUT=10mA V mV/℃ ±0.45 0℃
