MMBZ16VTALR
MMBZ16VTALR
    NEXPERIA(安世)
    SOT-23
    ESD抑制器/TVS二极管 VRWM=13V VBR(Min)=15.68V VC=28V IPP=11A Ppp=300W SOT23
MMBZ16VTALR 数据手册
MMBZ16VTAL High surge current unidirectional double ESD protection diodes 6 November 2017 Product data sheet 1. General description Unidirectional double ElectroStatic Discharge (ESD) protection diodes in a common anode configuration, encapsulated in a SOT23 (TO-236AB) small Surface-Mounted Device (SMD) plastic package. The device is designed for ESD and transient overvoltage protection of up to two signal lines. 2. Features and benefits • • • • • • Unidirectional protection of two lines Reverse standoff voltage: VRWM = 13 V Average measured surge robustness: IPPM = 14 A (8/20 µs) / IPPM = 2.54 A (10/1000 µs) Typical reverse leakage current: IRM = 0.1 nA Tight breakdown voltage tolerance: ΔVBR +/- 2% AEC-Q101 qualified 3. Applications • • • Automotive in-vehicle networks protection Industrial application Power management 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tj = 25 °C - - 13 V IPPM rated peak pulse current tp = 10/1000 µs [1] [2] - - 1.9 A VCL clamping voltage IPP = 1.7 A; tp = 10/1000 µs; Tj = 25 °C [1] [2] - 19.5 23 V [1] [2] According to IEC 61643-321. Measured from pin 1 or 2 to pin 3. MMBZ16VTAL Nexperia High surge current unidirectional double ESD protection diodes 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K1 cathode 2 K2 cathode 3 A common anode Simplified outline Graphic symbol 3 1 3 2 TO-236AB (SOT23) 1 2 006aaa154 6. Ordering information Table 3. Ordering information Type number MMBZ16VTAL Package Name Description Version TO-236AB plastic, surface-mounted package; 3 terminals; 1.9 mm pitch; 2.9 SOT23 mm x 1.3 mm x 1 mm body 7. Marking Table 4. Marking codes Type number Marking code[1] MMBZ16VTAL %HH [1] % = placeholder for manufacturing site code MMBZ16VTAL Product data sheet All information provided in this document is subject to legal disclaimers. 6 November 2017 © Nexperia B.V. 2017. All rights reserved 2 / 12 MMBZ16VTAL Nexperia High surge current unidirectional double ESD protection diodes 8. Limiting values Table 5. Limiting values In accordance with the Aboluste Maximum Rating System (IEC 60134) Symbol Parameter Conditions PPPM rated peak pulse power tp = 8/20 µs IPPM rated peak pulse current Min Max Unit [1] [2] - 300 W tp = 10/1000 µs [3] [2] - 45 W tp = 8/20 µs [1] [2] - 11 A tp = 10/1000 µs [3] [2] - 1.9 A Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C ESD maximum ratings VESD [1] [2] [3] [4] electrostatic discharge voltage IEC 61000-4-2; contact discharge [4] [2] - 30 kV IEC 61000-4-2; air discharge [4] [2] - 30 kV According to IEC 61000-4-5. Measured from pin 1 or 2 to pin 3. According to IEC 61643-321. Device stressed with ten non-repetitive ESD pulses. 001aaa631 001aaa630 120 IPP 100 % 100 % IPP; 8 µs IPP (%) 80 90 % e-t 50 % IPP; 20 µs 40 10 % 0 0 10 20 30 t (µs) t tr = 0.6 ns to 1 ns 40 30 ns 60 ns Fig. 1. 8/20 µs pulse waveform according to IEC 61000-4-5 MMBZ16VTAL Product data sheet Fig. 2. ESD pulse waveform according to IEC 61000-4-2 All information provided in this document is subject to legal disclaimers. 6 November 2017 © Nexperia B.V. 2017. All rights reserved 3 / 12 MMBZ16VTAL Nexperia High surge current unidirectional double ESD protection diodes 006aab319 150 IPP (%) 100 % IPP; 10 µs 100 50 % IPP; 1000 µs 50 0 Fig. 3. 0 1.0 2.0 3.0 tp (ms) 4.0 10/1000 µs pulse waveform according to IEC 61643-321 9. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tj = 25 °C - - 13 V VBR breakdown voltage IR = 1 mA; Tj = 25 °C [1] 15.68 16 16.32 V IRM reverse leakage current VRWM = 13 V; Tj = 25 °C [1] - 0.1 5 nA Cd diode capacitance f = 1 MHz; VR = 0 V; Tj = 25 °C [1] - 76 95 pF VCL clamping voltage IPP = 11 A; tp = 8/20 µs; Tj = 25 °C [2] [1] - 23 28 V IPP = 1.7 A; tp = 10/1000 µs; Tj = 25 °C [3] [1] - 19.5 23 V [1] [2] [3] Measured from pin 1 or 2 to pin 3. According to IEC 61000-4-5. According to IEC 61643-321. MMBZ16VTAL Product data sheet All information provided in this document is subject to legal disclaimers. 6 November 2017 © Nexperia B.V. 2017. All rights reserved 4 / 12 MMBZ16VTAL Nexperia High surge current unidirectional double ESD protection diodes I 006aab321 1.2 PPPM PPPM(25°C) 0.8 - VCL - VBR - VRWM V - IRM - IR - 0.4 + P-N 0 - IPP - IPPM Fig. 4. 006aab324 V-I characteristics for a unidirectional TVS protection diode aaa-027130 Cd 90 (pF) 80 Fig. 5. 100 150 Tj (°C) 200 Relative variation of rated peak pulse power as a function of junction temperature; typical values aaa-027131 80 60 50 60 40 40 30 20 20 10 Fig. 6. 50 120 PPPM (W) 100 70 0 0 0 4 8 12 VR (V) 0 102 16 Diode capacitance as a function of reverse voltage; typical values MMBZ16VTAL Product data sheet Fig. 7. tp 104 Rated peak pulse power as a function of a pulse duration; typical values All information provided in this document is subject to legal disclaimers. 6 November 2017 103 © Nexperia B.V. 2017. All rights reserved 5 / 12 MMBZ16VTAL Nexperia High surge current unidirectional double ESD protection diodes aaa-027132 30 VCL (V) VCL (V) aaa-027133 0 -2 -4 20 -6 -8 -10 10 -12 -14 0 0 5 10 IPP (A) -16 -100 15 Positive clamping voltage (8/20 μs pulse); typical values Fig. 9. -25 IPP (A) 0 Negative clamping voltage (8/20 μs pulse); typical values aaa-027134 21 -50 tp = 8/20 μs; according to IEC 61000-4-5 tp = 8/20 μs; according to IEC 61000-4-5 Fig. 8. -75 aaa-027135 0 VCL (V) VCL (V) -0.5 20 -1 -1.5 19 -2 18 0 1 2 IPP (A) -2.5 3 MMBZ16VTAL Product data sheet -5 -4 -3 -2 -1 0 IPP (A) tp = 10/1000 μs; according to IEC 61643-321 tp = 10/1000 μs; according to IEC 61643-321 Fig. 10. Positive clamping voltage (10/1000 μs pulse); typical values -6 Fig. 11. Negative clamping voltage (10/1000 μs pulse); typical values All information provided in this document is subject to legal disclaimers. 6 November 2017 © Nexperia B.V. 2017. All rights reserved 6 / 12 MMBZ16VTAL Nexperia High surge current unidirectional double ESD protection diodes ESD TESTER 4 GHz DIGITAL OSCILLOSCOPE RG 223/U 50 Ω coax Rd 40 dB ATTENUATOR Cs 50 Ω DUT (DEVICE UNDER TEST) IEC 61000-4-2 ed.2 Cs = 150 pF; Rd = 330 Ω 10 2 V (kV) 8 V (kV) 0 6 -2 4 -4 2 -6 0 -8 -2 -10 0 10 20 30 40 50 t (ns) 60 70 -10 -10 unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) 0 10 20 30 40 50 t (ns) 60 70 unclamped -8 kV ESD pulse waveform (IEC 61000-4-2 network) aaa-003952 Fig. 12. ESD clamping test setup and waveforms aaa-027136 120 VCL (V) 100 VCL (V) 80 40 20 60 0 VCL_ESD at 30 ns = 17 V 40 -20 20 VCL_ESD at 30 ns = -2 V -40 0 -60 -20 -80 -40 -60 -10 aaa-027137 60 0 10 20 30 40 50 -100 -10 60 70 t (ns) Fig. 13. Clamped +8 kV pulse waveform (IEC61000-4-2 network) MMBZ16VTAL Product data sheet 0 10 20 30 40 50 60 70 t (ns) Fig. 14. Clamped -8 kV pulse waveform (IEC61000-4-2 network) All information provided in this document is subject to legal disclaimers. 6 November 2017 © Nexperia B.V. 2017. All rights reserved 7 / 12 MMBZ16VTAL Nexperia High surge current unidirectional double ESD protection diodes 10. Application information The device is designed for the protection of one bidirectional or up to two unidirectional data or signal lines from the damage caused by ESD and surge pulses. The devices may be used on lines where the signal polarities are either positive or negative with respect to ground for the unidirectional configuration or both positive and negative for the bidirectional configuration. line 1 to be protected line 1 to be protected line 2 to be protected MMBZxAL MMBZxAL GND GND unidirectional protection of two lines bidirectional protection of one line 006aab842 Fig. 15. Application diagram 11. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 1.9 0.48 0.38 Dimensions in mm 0.15 0.09 04-11-04 Fig. 16. Package outline TO-236AB (SOT23) MMBZ16VTAL Product data sheet All information provided in this document is subject to legal disclaimers. 6 November 2017 © Nexperia B.V. 2017. All rights reserved 8 / 12 MMBZ16VTAL Nexperia High surge current unidirectional double ESD protection diodes 12. Soldering 3.3 2.9 1.9 solder lands 3 solder resist 2 1.7 solder paste occupied area 0.6 (3×) 0.7 (3×) Dimensions in mm 0.5 (3×) 0.6 (3×) 1 sot023_fr Fig. 17. Reflow soldering footprint for TO-236AB (SOT23) 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 sot023_fw Fig. 18. Wave soldering footprint for TO-236AB (SOT23) MMBZ16VTAL Product data sheet All information provided in this document is subject to legal disclaimers. 6 November 2017 © Nexperia B.V. 2017. All rights reserved 9 / 12 MMBZ16VTAL Nexperia High surge current unidirectional double ESD protection diodes 13. Revision history Table 7. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes MMBZ16VTAL v.1 20171106 Product data sheet - - MMBZ16VTAL Product data sheet All information provided in this document is subject to legal disclaimers. 6 November 2017 © Nexperia B.V. 2017. All rights reserved 10 / 12 MMBZ16VTAL Nexperia High surge current unidirectional double ESD protection diodes for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 14. Legal information Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’ aggregate and cumulative liability towards customer Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. MMBZ16VTAL Product data sheet Trademarks All information provided in this document is subject to legal disclaimers. 6 November 2017 © Nexperia B.V. 2017. All rights reserved 11 / 12 MMBZ16VTAL Nexperia High surge current unidirectional double ESD protection diodes 15. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Characteristics..............................................................4 10. Application information............................................. 8 11. Package outline.......................................................... 8 12. Soldering..................................................................... 9 13. Revision history........................................................10 14. Legal information..................................................... 11 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 6 November 2017 MMBZ16VTAL Product data sheet All information provided in this document is subject to legal disclaimers. 6 November 2017 © Nexperia B.V. 2017. All rights reserved 12 / 12 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: MMBZ16VTALR MMBZ16VTALVL
MMBZ16VTALR 价格&库存
很抱歉,暂时无法提供与“MMBZ16VTALR”相匹配的价格&库存,您可以联系我们找货
MMBZ16VTALR
  • 1+2.302551+0.29665
  • 10+1.4083110+0.18144
  • 100+0.87497100+0.11273
  • 500+0.64262500+0.08279
  • 1000+0.567431000+0.07311
库存:2800
MMBZ16VTALR
  • 3000+0.471493000+0.06075
  • 6000+0.423066000+0.05451
  • 9000+0.398339000+0.05132
  • 15000+0.3705415000+0.04774
  • 21000+0.3540721000+0.04562
  • 30000+0.3380530000+0.04356
库存:2800
