PJM138NSA
N- Enhancement Mode Field Effect Transistor
SOT-23
Features
Low gate charge and RDS(ON)
Rugged and relaible
Application
Direct logic-level interface: TTL/CMOS
Drivers: relays, solenoids, lamps, hammers,
1. Gate
2.Source 3.Drain
Marking: S3
Schematic diagram
Display, memories, transistors, etc.
Battery operated systems
Solid-state relays
3Drain
1
Gate
2 Source
Absolute Maximum Ratings (TA=25℃unless otherwise specified)
Parameter
Symbol
Limit
Unit
Drain-Source Voltage
VDS
50
V
Gate-Source Voltage
VGS
±20
V
Drain Current-Continuous
ID
0.22
A
Maximum Power Dissipation
PD
0.35
W
TJ,TSTG
-55 To 150
RθJA
357
℃/W
Operating Junction and Storage Temperature Range
Thermal Characteristics
Thermal Resistance,Junction-to-Ambient
www.pingjingsemi.com
Revision:1.1 Jan-2019
1/6
PJM138NSA
Electrical Characteristics (TA=25℃ unless otherwise specified)
Parameter
Symbol
Test Condition
Min.
Typ.
Max.
Units
Static Characteristics
Drain-source breakdown voltage
V(BR)DSS
Drain to Source Leakage Current
IDSS
Gate-body leakage current
IGSS
Gate threshold voltage Note1
VGS(th)
Drain-source on-resistance Note1
RDS(on)
Forward
tranconductance Note1
gFS
VGS = 0V, ID=250µA
50
V
VDS =50V, VGS= 0V
0.5
µA
VDS =30V, VGS= 0V
100
nA
VGS =±20V,VDS = 0V
±200
nA
1.6
2
V
VGS =10V, ID =0.22A
1
3.5
Ω
VGS =4.5V, ID =0.22A
1.1
6
Ω
VDS =10V, ID =0.22A
0.13
VDS =VGS, ID =250µA
1
S
Dynamic characteristics
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
26.5
VDS =25V,VGS =0V,f=1MHz
pF
12.9
5.9
Switching Characteristics
Turn-on delay time
Turn-on rise time
Turn-off delay time
Turn-off fall time
td(on)
5
tr
VGS=10V,VDD=30V,ID=0.29A
18
td(off)
,RGEN =6Ω,
36
tf
ns
14
Source-Drain Diode characteristics
Diode Forward voltage Note1
VSD
VGS =0V, IS=0.44A
1.4
V
Notes :
1. Pulse test : pulse width≤300μs, duty cycle≤2%.
2/6
PJM138NSA
Typical Characteristic Curves
Transfer Characteristics
Output Characteristics
500
V =10V
GS
V =4V
GS
VGS=3V
V =3V
DS
Plused
V =2V
320
GS
Drain Current(mA)
400
Drain Current I D(mA)
400
300
200
100
240
160
T =125℃
a
Ta=25℃
80
T =25℃
a
Pl sed
2
3
0.8
Drain to Source Voltage VDS (V)
1.5
1.2
1.6
2.0
2.4
Gate to Source Voltage V GS (V)
RDS(ON)——ID
R DS(ON)——VGS
5
T a =25℃
ID =500mA
Plused
Plused
On-Resistancer RDS(ON) (Ω)
4
VGS=4.5V
1.2
VGS=10V
0.9
0.6
0.2
0.4
1
0.6
3
Ta=125℃
2
1
Ta=25℃
1
2
3
4
Drain Current I D(A)
IS ——VSD
Threshold Voltage
5
Plused
Threshold Voltage V TH(V)
0.1
S
Source Current I (A)
1.2
Ta=125℃
Ta=25℃
0.01
1E-3
0.2
0.4
0.6
0.8
1.0
1.2
Source to Drain Voltage V SD (V)
1.4
ID =250uA
1.0
0.8
0.6
25
50
75
100
125
Juction Temperature T J(℃)
3/6
PJM138NSA
Package Outline
SOT-23
0.8
Max.
1.025
1.150
A1
0.000
0.050
0.100
b
c
D
0.300
0.080
2.800
0.400
0.115
2.900
0.500
0.150
3.000
E
1.200
1.300
1.400
HE
2.250
2.400
2.550
e
1.800
1.900
2.000
0.550REF
L1
L
0.300
0.500
θ
0o
8o
2.2
Typ.
0.900
A
0.8
1.0
Min.
1.0
Dimensions in millimeter
Symbol
1.9
SOT-23 (TO-236)
Recommended soldering pad
Ordering Information
Device
Package
Shipping
PJM138NSA
SOT-23
3000PCS/Reel&Tape
4/6
PJM138NSA
Conditions of Soldering and Storage
Recommended condition of reflow soldering
Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust
the following parameters:
Time length of peak temperature (longer)
Time length of soldering (longer)
Thickness of solder paste (thicker)
Conditions of hand soldering
Temperature: 370 OC
Time: 3s max.
Times: one time
Storage conditions
Temperature
5 to 40 OC
Humidity
30 to 80% RH
Recommended period
One year after manufacturing
5/6
PJM138NSA
Package Specifications
The method of packaging
Cover Tape
SOT-23 (TO-236)
3,000 pcs per reel
1
3
2
Carrier Tape
30,000 pcs per box
10 reels per box
220
195
21
43
5
120,000 pcs per carton
4 boxes per carton
210
Embossed tape and reel data
D
A
T2
T1
4.0
4.0
B
8.0
C
E
1Pin
G
N
Tape (8mm)
F
Reel (7'')
Symbol
A
B
C
E
F
D
T1
T2
N
G
Value (unit: mm)
Ø 177.8±1
2.7±0.2
Ø 13.5±0.2
Ø 54.5±0.2
12.3±0.3
9.6+2/-0.3
1.0±0.2
1.2±0.2
3.15±0.1
1.25±0.1
6/6
很抱歉,暂时无法提供与“PJM138NSA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.12600
- 500+0.11340
- 5000+0.10500
- 10000+0.10080
- 30000+0.09660
- 50000+0.09408
