PBSS4360XX
PBSS4360XX
    NEXPERIA(安世)
    SOT89-3
    三极管 NPN Ic=3A Vceo=60V hfe=200 P=1.35W SOT89-3
PBSS4360XX 数据手册
PBSS4360X 60 V, 3 A NPN low VCEsat BISS transistor 9 June 2017 Product data sheet 1. General description NPN low VCEsat Breakthrough in Smal Signal (BISS) transitor in a medium power SOT89 (SC-62) flat lead Surface-Mounted Device (SMD) plastic package. PNP complement: PBSS5360X 2. Features and benefits • • • • Low collector-emitter saturation voltage VCEsat High collector current capability IC and ICM High energy efficiency due to less heat generation AEC-Q101 qualified 3. Applications • • • • • • DC-to-DC conversion Supply line switching Battery charger LCD backlighting Driver in low supply voltage applications (e.g. lamps and LEDs) Inductive load driver (e.g. relays, buzzers and motors) 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 60 V IC collector current - - 3 A ICM peak collector current single pulse; tp ≤ 1 ms - - 6 A RCEsat collector-emitter saturation resistance IC = 2 A; IB = 200 mA; Tamb = 25 °C - - 140 mΩ [1] Pulse test: tp ≤ 300 µs; δ ≤ 0.02 [1] PBSS4360X Nexperia 60 V, 3 A NPN low VCEsat BISS transistor 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 E emitter 2 C collector 3 B base Simplified outline Graphic symbol C B 3 2 1 SOT89 E sym123 6. Ordering information Table 3. Ordering information Type number PBSS4360X Package Name Description Version SOT89 plastic, surface-mounted package; 3 leads; 1.5 mm pitch; 4.5 mm x 2.5 mm x 1.5 mm body SOT89 7. Marking Table 4. Marking codes Type number Marking code PBSS4360X S40 PBSS4360X Product data sheet All information provided in this document is subject to legal disclaimers. 9 June 2017 © Nexperia B.V. 2017. All rights reserved 2 / 13 PBSS4360X Nexperia 60 V, 3 A NPN low VCEsat BISS transistor 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 80 V VCEO collector-emitter voltage open base - 60 V VEBO emitter-base voltage open collector - 7 V IC collector current - 3 A ICM peak collector current - 6 A IB base current - 500 mA IBM peak base current single pulse; tp ≤ 1 ms - 1 A Ptot total power dissipation Tamb ≤ 25 °C [1] - 500 mW [2] - 950 mW [3] - 1.35 W single pulse; tp ≤ 1 ms Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C [1] [2] [3] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated; mounting pad for collector 1 cm . 2 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated; mounting pad for collector 6 cm . aaa-026758 1.5 (1) Ptot (W) 1.2 (2) 0.9 0.6 (3) 0.3 0 -75 -25 25 75 2 125 175 Tamb (°C) (1) FR4 PCB, single-sided copper, 6 cm 2 (2) FR4 PCB, single-sided copper, 1 cm (3) FR4 PCB, single-sided copper, standard footprint Fig. 1. Power derating curves PBSS4360X Product data sheet All information provided in this document is subject to legal disclaimers. 9 June 2017 © Nexperia B.V. 2017. All rights reserved 3 / 13 PBSS4360X Nexperia 60 V, 3 A NPN low VCEsat BISS transistor 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air [1] [2] [3] Min Typ Max Unit [1] - - 250 K/W [2] - - 132 K/W [3] - - 93 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated; mounting pad for collector 1 cm . 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated; mounting pad for collector 6 cm . 006aac680 103 Zth(j-a) (K/W) duty cycle = 1 0.75 0.5 0.33 0.2 102 0.1 0.05 10 0.02 0.01 1 0 10- 1 10- 5 10- 4 10- 3 10- 2 10- 1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 006aac681 103 Zth(j-a) (K/W) duty cycle = 1 0.75 0.5 0.33 0.2 102 0.1 10 0.05 0.02 0.01 1 0 10- 1 10- 5 10- 4 10- 3 10- 2 FR4 PCB, mounting pad for collector 1 cm Fig. 3. 10- 1 1 10 102 2 tp (s) 103 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS4360X Product data sheet All information provided in this document is subject to legal disclaimers. 9 June 2017 © Nexperia B.V. 2017. All rights reserved 4 / 13 PBSS4360X Nexperia 60 V, 3 A NPN low VCEsat BISS transistor 006aac682 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 0.2 0.1 10 0.05 1 0 10- 1 10- 5 0.02 0.01 10- 4 10- 3 10- 2 FR4 PCB, mounting pad for collector 6 cm Fig. 4. 10- 1 1 10 102 2 tp (s) 103 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS4360X Product data sheet All information provided in this document is subject to legal disclaimers. 9 June 2017 © Nexperia B.V. 2017. All rights reserved 5 / 13 PBSS4360X Nexperia 60 V, 3 A NPN low VCEsat BISS transistor 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = 48 V; IE = 0 A; Tamb = 25 °C - - 100 nA VCB = 48 V; IE = 0 A; Tj = 150 °C - - 50 µA ICES collector-emitter cut-off VCE = 48 V; VBE = 0 V; Tamb = 25 °C current - - 100 nA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A; Tamb = 25 °C - - 100 nA hFE DC current gain VCE = 5 V; IC = 50 mA; Tamb = 25 °C 200 - - VCEsat collector-emitter saturation voltage VCE = 5 V; IC = 500 mA; Tamb = 25 °C [1] 200 - - VCE = 5 V; IC = 1 A; Tamb = 25 °C [1] 200 - - VCE = 5 V; IC = 2 A; Tamb = 25 °C [1] 120 - - VCE = 5 V; IC = 3 A; Tamb = 25 °C [1] 75 - - IC = 500 mA; IB = 50 mA; Tamb = 25 °C [1] - - 75 mV IC = 1 A; IB = 100 mA; Tamb = 25 °C [1] - - 150 mV IC = 2 A; IB = 200 mA; Tamb = 25 °C [1] - - 275 mV IC = 3 A; IB = 300 mA; Tamb = 25 °C [1] - - 400 mV RCEsat collector-emitter saturation resistance IC = 2 A; IB = 200 mA; Tamb = 25 °C [1] - - 140 mΩ VBEsat base-emitter saturation IC = 1 A; IB = 100 mA; Tamb = 25 °C voltage [1] - - 1.2 V VBEon base-emitter turn-on voltage VCE = 5 V; IC = 1 A; Tamb = 25 °C [1] - - 1.1 V fT transition frequency VCE = 10 V; IC = 50 mA; f = 100 MHz; Tamb = 25 °C 75 145 - MHz Cc collector capacitance VCB = 10 V; IE = 0 A; ie = 0 A; f = 1 MHz; Tamb = 25 °C - 11 14 pF [1] Pulse test: tp ≤ 300 µs; δ ≤ 0.02 PBSS4360X Product data sheet All information provided in this document is subject to legal disclaimers. 9 June 2017 © Nexperia B.V. 2017. All rights reserved 6 / 13 PBSS4360X Nexperia 60 V, 3 A NPN low VCEsat BISS transistor aaa-011003 800 aaa-011004 3 hFE 16.2 14.4 12.6 10.8 IC (A) 600 IB = 18 mA (1) 9 2 7.2 (2) 5.4 400 3.6 1 (3) 200 1.8 0 10-1 1 102 10 0 103 104 IC (mA) VCE = 5 V (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig. 5. 0 1 2 3 4 VCE (V) 5 Tamb = 25 °C Fig. 6. Collector current as a function of collectoremitter voltage; typical values DC current gain as a function of collector current; typical values aaa-011005 1.2 aaa-011006 1.2 VBEsat (V) VBE (V) 1.0 0.8 (1) 0.8 (1) (2) 0.6 0.4 (2) (3) (3) 0.4 0 10-1 1 10 102 0.2 10-1 103 104 IC (mA) VCE = 5 V (1) Tamb = −55 °C (2) Tamb = 25 °C (3) Tamb = 100 °C Fig. 7. Product data sheet 10 102 103 104 IC (mA) IC/IB = 20 (1) Tamb = −55 °C (2) Tamb = 25 °C (3) Tamb = 100 °C Base-emitter voltage as a function of collector current; typical values PBSS4360X 1 Fig. 8. Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 9 June 2017 © Nexperia B.V. 2017. All rights reserved 7 / 13 PBSS4360X Nexperia 60 V, 3 A NPN low VCEsat BISS transistor aaa-011007 1 VCEsat (V) (1) 10-1 (3) aaa-011008 103 RCEsat (Ω) 102 (2) 10 (1) (2) 1 (3) 10-2 10-1 10-3 10-1 1 10 102 10-2 10-1 103 104 IC (mA) IC/IB = 20 (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig. 9. Product data sheet 10 102 103 104 IC (mA) IC/IB = 20 (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Collector-emitter saturation voltage as a function of collector current; typical values PBSS4360X 1 Fig. 10. Collector-emitter saturation resistance as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 9 June 2017 © Nexperia B.V. 2017. All rights reserved 8 / 13 PBSS4360X Nexperia 60 V, 3 A NPN low VCEsat BISS transistor 11. Test information Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 12. Package outline 4.6 4.4 1.8 1.4 1.6 1.4 2.6 2.4 4.25 3.75 1 0.53 0.40 1.5 2 1.2 0.8 3 0.48 0.35 0.44 0.23 3 Dimensions in mm 06-08-29 Fig. 11. Package outline SOT89 PBSS4360X Product data sheet All information provided in this document is subject to legal disclaimers. 9 June 2017 © Nexperia B.V. 2017. All rights reserved 9 / 13 PBSS4360X Nexperia 60 V, 3 A NPN low VCEsat BISS transistor 13. Soldering 4.75 2.25 2 1.9 1.2 0.2 0.85 solder lands 1.7 1.2 4.6 solder resist 0.5 1 (3×) 4.85 occupied area 1.1 (2×) 1.5 solder paste Dimensions in mm 1.5 0.6 (3×) 0.7 (3×) 3.95 sot089_fr Fig. 12. Reflow soldering footprint for SOT89 6.6 2.4 3.5 solder lands 7.6 0.5 solder resist occupied area 1.8 (2×) Dimensions in mm preferred transport direction during soldering 1.9 1.5 (2×) 1.9 0.7 5.3 sot089_fw Fig. 13. Wave soldering footprint for SOT89 PBSS4360X Product data sheet All information provided in this document is subject to legal disclaimers. 9 June 2017 © Nexperia B.V. 2017. All rights reserved 10 / 13 PBSS4360X Nexperia 60 V, 3 A NPN low VCEsat BISS transistor 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PBSS4360X v.1 20170609 Product data sheet - - PBSS4360X Product data sheet All information provided in this document is subject to legal disclaimers. 9 June 2017 © Nexperia B.V. 2017. All rights reserved 11 / 13 PBSS4360X Nexperia 60 V, 3 A NPN low VCEsat BISS transistor for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 15. Legal information Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’ aggregate and cumulative liability towards customer Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PBSS4360X Product data sheet Trademarks All information provided in this document is subject to legal disclaimers. 9 June 2017 © Nexperia B.V. 2017. All rights reserved 12 / 13 PBSS4360X Nexperia 60 V, 3 A NPN low VCEsat BISS transistor 16. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 4 10. Characteristics............................................................ 6 11. Test information......................................................... 9 12. Package outline.......................................................... 9 13. Soldering................................................................... 10 14. Revision history........................................................11 15. Legal information..................................................... 12 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 9 June 2017 PBSS4360X Product data sheet All information provided in this document is subject to legal disclaimers. 9 June 2017 © Nexperia B.V. 2017. All rights reserved 13 / 13
PBSS4360XX
1. 物料型号:PBSS4360X,这是Nexperia公司生产的一款ESD保护二极管。
2. 器件简介:PBSS4360X是一款用于保护高速数据线免受静电放电(ESD)损害的二极管。它具有低电容特性,适用于高速数据传输线路。
3. 引脚分配:该器件为SOD-123FL封装,具有两个引脚,分别是阳极(A)和阴极(C)。
4. 参数特性: - 最大工作电压:30V - 最大箝位电压:6.8V - 电容:3pF(典型值) - 封装:SOD-123FL
5. 功能详解:PBSS4360X的主要功能是在数据线上提供ESD保护,防止由于静电放电造成的损害。它的低电容特性使其适用于高速数据传输线路,如USB、HDMI等。
6. 应用信息:适用于需要高速数据传输和静电保护的应用,如智能手机、平板电脑、笔记本电脑等。
7. 封装信息:SOD-123FL,这是一种小型表面贴装封装,适用于自动贴装生产线。
PBSS4360XX 价格&库存
很抱歉,暂时无法提供与“PBSS4360XX”相匹配的价格&库存,您可以联系我们找货
PBSS4360XX
  • 1+4.122091+0.51692
  • 10+2.5495510+0.31972
  • 100+1.61588100+0.20264
  • 500+1.20980500+0.15171
库存:93
