PBSS5350THR
PBSS5350THR
    NEXPERIA(安世)
    SOT-23
    50伏,3安PNP低VCEsat(BISS)晶体管
PBSS5350THR 数据手册
PBSS5350TH 50 V, 3 A PNP low VCEsat (BISS) transistor 21 June 2017 Product data sheet 1. General description PNP low VCEsat Breakthrough In Small Signal (BISS) transistor in a small SOT23 (TO-236AB) Surface-Mounted Device (SMD) plastic package. 2. Features and benefits • • • • • • Low collector-emitter saturation voltage VCEsat High collector current capability: IC and ICM High collector current gain (hFE) at high IC Higher efficiency leading to less heat genereation High temperature applications up to 175 °C AEC-Q101 qualified 3. Applications • • • • • • • Power management DC-to-DC conversion Supply line switches Battery charger switches Peripheral drivers Driver in low supply voltage applications (e.g. lamps and LEDs) Inductive load driver 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - -50 V IC collector current - - -2 A ICM peak collector current - - -3 A - - -5 A - - 135 mΩ pulsed [1] single pulse; tp < 1 ms RCEsat [1] [2] collector-emitter saturation resistance IC = -2 A; IB = -200 mA; Tamb = 25 °C Pulse conditions: pulse width tp ≤ 100 ms; duty cycle δ ≤ 0.25 Pulse test: tp ≤ 300 µs; δ ≤ 0.02 [2] PBSS5350TH Nexperia 50 V, 3 A PNP low VCEsat (BISS) transistor 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 B base 2 E emitter 3 C collector Simplified outline Graphic symbol 3 C B E 1 2 sym132 TO-236AB (SOT23) 6. Ordering information Table 3. Ordering information Type number PBSS5350TH Package Name Description Version TO-236AB plastic surface-mounted package; 3 leads SOT23 7. Marking Table 4. Marking codes Type number Marking code[1] PBSS5350TH FJ% [1] % = placeholder for manufacturing site code PBSS5350TH Product data sheet All information provided in this document is subject to legal disclaimers. 21 June 2017 © Nexperia B.V. 2017. All rights reserved 2 / 14 PBSS5350TH Nexperia 50 V, 3 A PNP low VCEsat (BISS) transistor 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - -50 V VCEO collector-emitter voltage open base - -50 V VEBO emitter-base voltage open collector - -7 V IC collector current - -2 A ICM peak collector current - -3 A - -5 A - -500 mA [2] - 360 mW [3] - 575 mW [4] - 600 mW [5] - 700 mW [1] [2] - 1.44 W pulsed [1] single pulse; tp < 1 ms IB base current Ptot total power dissipation Tamb ≤ 25 °C Tj junction temperature - 175 °C Tamb ambient temperature -55 175 °C Tstg storage temperature -65 175 °C [1] [2] [3] [4] [5] Pulse conditions: pulse width tp ≤ 100 ms; duty cycle δ ≤ 0.25 Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm . Device mounted on an FR4 PCB, 4-layer copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, 4-layer copper, tin-plated, mounting pad for collector 1 cm . aaa-026656 800 (1) Ptot (mw) (2) 600 (3) 400 (4) 200 0 -75 25 125 2 Tamb (°C) 225 (1) FR4 PCB, 4-layer copper, 1 cm (2) FR4 PCB, 4-layer copper, standard footprint 2 (3) FR4 PCB, single sided copper, 1 cm (4) FR4 PCB, single sided copper, standard footprint Fig. 1. Power derating curves for SOT23 PBSS5350TH Product data sheet All information provided in this document is subject to legal disclaimers. 21 June 2017 © Nexperia B.V. 2017. All rights reserved 3 / 14 PBSS5350TH Nexperia 50 V, 3 A PNP low VCEsat (BISS) transistor aaa-026790 -10 IC (A) tp = 10 µs -1 tp = 100 µs tp = 1 ms tp = 10 ms -10-1 tp = 100 ms DC; FR4 PCB, 4-layer copper, collector mounting pad 1 cm2 tp = 1 s -10-2 DC -10-3 -10-1 -1 -10 -102 -103 VCE (V) Unless otherwise specified: Tamb = 25 °C; single pulse; FR4 PCB, single-sided copper, standard footprint Fig. 2. Safe operating area; junction to ambient; continuous and peak drain currents as a function of collectoremitter voltage 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) [1] [2] [3] [4] [5] thermal resistance from junction to solder point Min Typ Max Unit [1] - - 417 K/W [2] - - 261 K/W [3] - - 250 K/W [4] - - 215 K/W [1] [5] - - 104 K/W - 75 - K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm . Device mounted on an FR4 PCB, 4-layer copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, 4-layer copper, tin-plated, mounting pad for collector 1 cm . Operated under pulse conditions: pulse width tp ≤ 100 ms; duty cycle δ ≤ 0.25 PBSS5350TH Product data sheet All information provided in this document is subject to legal disclaimers. 21 June 2017 © Nexperia B.V. 2017. All rights reserved 4 / 14 PBSS5350TH Nexperia 50 V, 3 A PNP low VCEsat (BISS) transistor aaa-026658 103 Zth(j-a) (K/W) duty cycle = 1 0.75 102 0.33 0.50 0.20 0.10 0.05 10 0.02 0.01 1 0 10-1 10-5 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, single sided copper, standard footprint Fig. 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-026659 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.33 0.50 0.20 0.10 0.05 10 0.02 0.01 1 0 10-1 10-5 10-4 10-3 10-2 10-1 1 10 102 2 tp (s) 103 FR4 PCB, single sided copper, mounting pad for drain 1 cm Fig. 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS5350TH Product data sheet All information provided in this document is subject to legal disclaimers. 21 June 2017 © Nexperia B.V. 2017. All rights reserved 5 / 14 PBSS5350TH Nexperia 50 V, 3 A PNP low VCEsat (BISS) transistor aaa-026660 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.33 0.50 0.20 0.10 0.05 10 0.02 1 0.01 0 10-1 10-5 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, 4-layer copper, standard footprint Fig. 5. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-026661 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.33 0.50 0.20 0.10 0.05 10 0.02 1 0.01 0 10-1 10-5 10-4 10-3 10-2 10-1 FR4 PCB, 4-layer copper, mounting pad for collector 1 cm Fig. 6. 1 10 102 2 tp (s) 103 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS5350TH Product data sheet All information provided in this document is subject to legal disclaimers. 21 June 2017 © Nexperia B.V. 2017. All rights reserved 6 / 14 PBSS5350TH Nexperia 50 V, 3 A PNP low VCEsat (BISS) transistor 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit V(BR)CBO collector-base breakdown voltage IC = -100 µA; IE = 0 A; Tamb = 25 °C -50 - - V V(BR)CEO collector-emitter breakdown voltage IC = -10 mA; IB = 0 A; Tamb = 25 °C -50 - - V V(BR)EBO emitter-base breakdown voltage (collector open) IC = 0 A; IE = -100 µA; Tamb = 25 °C -7 - - V ICBO collector-base cut-off current VCB = -50 V; IE = 0 A; Tamb = 25 °C - - -100 nA VCB = -50 V; IE = 0 A; Tj = 150 °C - - -5 µA IEBO emitter-base cut-off current VEB = -5 V; IC = 0 A; Tamb = 25 °C - - -100 nA hFE DC current gain VCE = -2 V; IC = -100 mA; Tamb = 25 °C [1] 200 - - VCE = -2 V; IC = -500 mA; Tamb = 25 °C [1] 200 - - VCE = -2 V; IC = -1 A; Tamb = 25 °C [1] 200 - - VCE = -2 V; IC = -2 A; Tamb = 25 °C [1] 130 - - VCE = -2 V; IC = -3 A; Tamb = 25 °C [1] 80 - - IC = -500 mA; IB = -50 mA; Tamb = 25 °C [1] - - -90 mV IC = -1 A; IB = -50 mA; Tamb = 25 °C [1] - - -180 mV IC = -2 A; IB = -100 mA; Tamb = 25 °C [1] - - -320 mV IC = -2 A; IB = -200 mA; Tamb = 25 °C [1] - - -270 mV IC = -3 A; IB = -300 mA; Tamb = 25 °C [1] - - -390 mV VCEsat collector-emitter saturation voltage RCEsat collector-emitter saturation resistance IC = -2 A; IB = -200 mA; Tamb = 25 °C [1] - - 135 mΩ VBEsat base-emitter saturation IC = -2 A; IB = -100 mA; Tamb = 25 °C voltage IC = -3 A; IB = -300 mA; Tamb = 25 °C [1] - - -1.1 V [1] - - -1.2 V VBE base-emitter voltage VCE = -2 V; IC = -1 A; Tamb = 25 °C [1] - - -1.2 V fT transition frequency VCE = -5 V; IC = -100 mA; f = 100 MHz; Tamb = 25 °C 100 - - MHz Cc collector capacitance VCB = -10 V; IE = 0 A; ie = 0 A; f = 1 MHz; Tamb = 25 °C - - 35 pF [1] Pulse test: tp ≤ 300 µs; δ ≤ 0.02 PBSS5350TH Product data sheet All information provided in this document is subject to legal disclaimers. 21 June 2017 © Nexperia B.V. 2017. All rights reserved 7 / 14 PBSS5350TH Nexperia 50 V, 3 A PNP low VCEsat (BISS) transistor aaa-026662 800 hFE VBE (mV) (1) (2) 600 (3) (4) (1) - 800 (5) 400 mld886 - 1200 (2) (6) (3) - 400 (7) 200 (8) 0 -10-1 -1 -10 -102 -1 - 10 Fig. 8. - 103 - 104 IC (mA) Base-emitter voltage as a function of collector current; typical values DC current gain as a function of collector current; typical values mld887 - 1300 VBEsat (mV) mld888 - 1300 VBEsat (mV) (1) - 900 (1) - 900 (2) (2) (3) (3) - 500 - 100 - 10- 1 - 500 -1 - 10 - 102 - 103 - 104 IC (mA) - 100 - 10- 1 IC/IB = 10 (1) Tamb = −55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C Fig. 9. - 102 VCE = −2 V (1) Tamb = −55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C VCE = - 2 V (1) Tamb = 175 °C (2) Tamb = 150 °C (3) Tamb = 125 °C (4) Tamb = 100 °C (5) Tamb = 85 °C (6) Tamb = 25 °C (7) Tamb = -40 °C (8) Tamb = -55 °C Fig. 7. 0 - 10- 1 -103 -104 IC (mA) -1 - 10 - 102 - 103 - 104 IC (mA) IC/IB = 20 (1) Tamb = −55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C Base-emitter saturation voltage as a function of Fig. 10. Base-emitter saturation voltage as a function of collector current; typical values collector current; typical values PBSS5350TH Product data sheet All information provided in this document is subject to legal disclaimers. 21 June 2017 © Nexperia B.V. 2017. All rights reserved 8 / 14 PBSS5350TH Nexperia 50 V, 3 A PNP low VCEsat (BISS) transistor mld889 - 103 mld890 - 103 VCEsat (mV) VCEsat (mV) - 102 - 102 (1) (2) (1) - 10 (3) (2) - 10 (3) -1 - 10- 1 -1 - 10 - 102 -1 - 10- 1 - 103 - 104 IC (mA) IC/IB = 10 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = −55 °C -1 - 10 - 102 - 103 - 104 IC (mA) IC/IB = 20 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig. 11. Collector-emitter saturation voltage as a function of collector current; typical values Fig. 12. Collector-emitter saturation voltage as a function of collector current; typical values mld891 - 104 mld892 - 104 VCEsat (mV) VCEsat (mV) - 103 - 103 - 102 (1) (2) - 102 (3) (1) - 10 -1 - 10- 1 (3) (2) -1 - 10 - 102 - 10 - 10- 1 - 103 - 104 IC (mA) Fig. 13. Collector-emitter saturation voltage as a function of collector current; typical values Product data sheet - 10 - 102 - 103 - 104 IC (mA) IC/IB = 100 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = −55 °C IC/IB = 50 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = −55 °C PBSS5350TH -1 Fig. 14. Collector-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 21 June 2017 © Nexperia B.V. 2017. All rights reserved 9 / 14 PBSS5350TH Nexperia 50 V, 3 A PNP low VCEsat (BISS) transistor aaa-026691 103 RCEsat (Ω) 102 10 1 (1) 10-1 (2) 10-2 -10-1 -1 (3) -102 -10 -103 -104 IC (mA) IC/IB = 20 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig. 15. Collector-emitter saturation resistance as a function of collector current; typical values 11. Test information Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 12. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 1.9 0.48 0.38 Dimensions in mm 0.15 0.09 04-11-04 Fig. 16. Package outline TO-236AB (SOT23) PBSS5350TH Product data sheet All information provided in this document is subject to legal disclaimers. 21 June 2017 © Nexperia B.V. 2017. All rights reserved 10 / 14 PBSS5350TH Nexperia 50 V, 3 A PNP low VCEsat (BISS) transistor 13. Soldering 3.3 2.9 1.9 solder lands 3 solder resist 2 1.7 solder paste occupied area 0.6 (3×) 0.7 (3×) Dimensions in mm 0.5 (3×) 0.6 (3×) 1 sot023_fr Fig. 17. Reflow soldering footprint for TO-236AB (SOT23) 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 sot023_fw Fig. 18. Wave soldering footprint for TO-236AB (SOT23) PBSS5350TH Product data sheet All information provided in this document is subject to legal disclaimers. 21 June 2017 © Nexperia B.V. 2017. All rights reserved 11 / 14 PBSS5350TH Nexperia 50 V, 3 A PNP low VCEsat (BISS) transistor 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PBSS5350TH v.1 20170621 Product data sheet - - PBSS5350TH Product data sheet All information provided in this document is subject to legal disclaimers. 21 June 2017 © Nexperia B.V. 2017. All rights reserved 12 / 14 PBSS5350TH Nexperia 50 V, 3 A PNP low VCEsat (BISS) transistor for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 15. Legal information Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’ aggregate and cumulative liability towards customer Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PBSS5350TH Product data sheet Trademarks All information provided in this document is subject to legal disclaimers. 21 June 2017 © Nexperia B.V. 2017. All rights reserved 13 / 14 PBSS5350TH Nexperia 50 V, 3 A PNP low VCEsat (BISS) transistor 16. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 4 10. Characteristics............................................................ 7 11. Test information....................................................... 10 12. Package outline........................................................ 10 13. Soldering................................................................... 11 14. Revision history........................................................12 15. Legal information..................................................... 13 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 June 2017 PBSS5350TH Product data sheet All information provided in this document is subject to legal disclaimers. 21 June 2017 © Nexperia B.V. 2017. All rights reserved 14 / 14
PBSS5350THR 价格&库存
很抱歉,暂时无法提供与“PBSS5350THR”相匹配的价格&库存,您可以联系我们找货
PBSS5350THR
  • 1+7.312881+0.95033
  • 10+4.5049910+0.58544
  • 100+2.86940100+0.37289
  • 500+2.16084500+0.28081
  • 1000+1.932001000+0.25107
PBSS5350THR
  • 3000+1.640883000+0.21324
  • 6000+1.494156000+0.19417
  • 9000+1.419359000+0.18445
  • 15000+1.3352815000+0.17353
  • 21000+1.2854921000+0.16706
  • 30000+1.2371130000+0.16077
PBSS5350THR
    • 5+3.66120
    • 50+3.11040
    • 150+2.88360
    • 500+2.59200
    库存:2757
