PCMF1HDMI14SZ
PCMF1HDMI14SZ
    NEXPERIA(安世)
    WLCSP5
    ESD保护 1通道 VRWM=5 V VBR(Min)=6.0 V VC=2.8 V IPP=7 A Ppp=Original WLCSP5
PCMF1HDMI14SZ 数据手册
PCMFXHDMI14S series Common-mode EMI filter for differential channels with integrated ESD protection Rev. 1 — 15 September 2016 Product data sheet 1. Product profile 1.1 General description Common-mode ElectroMagnetic Interference (EMI) filters with integrated ElectroStatic Discharge (ESD) protection for one, two and three differential channels. The devices are designed to provide low insertion loss for differential high-speed signals on each channel while unwanted common-mode signals are attenuated. Each differential channel incorporates two signal lines that are coupled by integrated coils. Diodes provide protection to downstream components from ESD voltages up to 15 kV on each signal line. Table 1. Product overview Type number Number of channels Package Name PCMF1HDMI14S 1 WLCSP5 PCMF2HDMI14S 2 WLCSP10 PCMF3HDMI14S 3 WLCSP15 1.2 Features and benefits  One, two and three differential channels common-mode EMI filters with integrated ESD protection  ESD protection up to 15 kV contact discharge according to IEC 61000-4-2  Superior common-mode suppression over a wide frequency range  Superior RF performance compared to other integrated filters or discrete filters with external ESD protection  Extremely high symmetry between line pairs  Industry-standard Wafer Level Chip Scale Packages: WLCSP5, 10 and 15 for smaller footprint 1.3 Applications     Smartphone, cellular and cordless phone Tablet PC and Mobile Internet Device (MID) HDMI 1.4 General-purpose EMI and Radio-Frequency Interference (RFI) filter and downstream ESD protection PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection 2. Pinning information Table 2. Pin Pinning Symbol Description Simplified outline Graphic symbol PCMF1HDMI14S (WLCSP5_2-1-2) A1 CH1_IN+ channel 1+, external A2 CH1_IN channel 1, external B1 GND_CH1 ground channel 1 C1 CH1_OUT+ channel 1+, internal C2 CH1_OUT channel 1, internal 2 A1 C1 A2 C2 B1 1 A B C Transparent top view WLCSP5_2-1-2 B1 aaa-019784 PCMF2HDMI14S (WLCSP10_4-2-4) A1 CH1_IN+ channel 1+, external A2 CH1_IN channel 1, external A3 CH2_IN+ channel 2+, external A4 CH2_IN channel 2, external B1 GND_CH1 ground channel 1 B2 GND_CH2 ground channel 2 C1 CH1_OUT+ channel 1+, internal C2 CH1_OUT channel 1, internal C3 CH2_OUT+ channel 2+, internal C4 CH2_OUT channel 2, internal 4 A1, 3 C1, 3 A2, 4 C2, 4 B2 3 2 B1 1 B1, B2 - no internal connection A B aaa-019785 C Transparent top view WLCSP10_4-2-4 PCMF3HDMI14S (WLCSP15_6-3-6) A1 CH1_IN+ channel 1+, external A2 CH1_IN channel 1, external A3 CH2_IN+ channel 2+, external A4 CH2_IN channel 2, external A5 CH3_IN+ channel 3+, external A6 CH3_IN channel 3, external B1 GND_CH1 ground channel 1 B2 GND_CH2 ground channel 2 B3 GND_CH3 ground channel 3 C1 CH1_OUT+ channel 1+, internal C2 CH1_OUT channel 1, internal C3 CH2_OUT+ channel 2+, internal C4 CH2_OUT channel 2, internal C5 CH3_OUT+ channel 3+, internal C6 CH3_OUT channel 3, internal PCMFXHDMI14S_SER Product data sheet 6 A1, 3, 5 C1, 3, 5 A2, 4, 6 C2, 4, 6 B3 5 4 B2 3 B1, B2, B3 - no internal connection aaa-019786 2 B1 1 A B C Transparent top view WLCSP15_6-3-6 All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 2 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection 3. Ordering information Table 3. Ordering information Type number Package Name Description Version PCMF1HDMI14S WLCSP5 wafer level chip-size package; 5 bumps (2-1-2) PCMF1HDMI14S PCMF2HDMI14S WLCSP10 wafer level chip-size package; 10 bumps (4-2-4) PCMF2HDMI14S PCMF3HDMI14S WLCSP15 wafer level chip-size package; 15 bumps (6-3-6) PCMF3HDMI14S 4. Marking Table 4. Marking codes Type number Marking code PCMF1HDMI14S PF1S PCMF2HDMI14S PF2S PCMF3HDMI14S PF3S 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VI input voltage VESD electrostatic discharge voltage Conditions Min Max Unit 0.5 5 V contact discharge 15 15 kV air discharge 15 15 kV contact discharge 2 2 kV air discharge 2 2 kV 7 7 A IEC 61000-4-2, level 4; all input pins to ground IEC 61000-4-2, level 4; all output pins to ground PCMFXHDMI14S_SER Product data sheet tp = 8/20 s IPPM rated peak pulse current Tstg storage temperature 40 +125 C Tamb ambient temperature 40 +85 C All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 3 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection 6. Characteristics 6.1 Channel characteristics Table 6. Channel characteristics Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit - 3 -  - 0.25 - pF Rs(ch) channel series resistance single line; input to output Cd diode capacitance f = 1 MHz; VI = 2.5 V IRM reverse leakage current per line; VI = 5 V - - 100 nA VBR breakdown voltage IR = 1 mA 6 9 - V VF forward voltage IF = 10 mA - 0.8 - V VCL clamping voltage TLP IPP = 16 A - 3.7 - V IPP = 8 A - 2.5 - V IPP = 8 A - 2.8 - V IPP = 16 A - 4 - V - 0.16 -  - 0.16 -  positive transient - 0.22 -  negative transient - 0.22 -  Min Typ Max Unit f = 800 MHz - 12 - dB f = 1.7 GHz - 21.5 - dB f = 3 GHz - 31.5 - dB [1] - 0.3 - dB [1] - 6 - GHz Rdyn dynamic resistance TLP [1] [2] [2] positive transient negative transient surge [1] [3] This parameter is guaranteed by design. [2] 100 ns Transmission Line Pulse (TLP); 50 ; pulser at 70 ns to 90 ns. [3] According to IEC 61000-4-5 (8/20 s). 6.2 Frequency characteristics Table 7. Frequency characteristics Symbol Parameter Conditions Common mode: S21cc il [1] insertion loss Differential mode: S21dd il insertion loss f3dB cut-off frequency [1] PCMFXHDMI14S_SER Product data sheet f = 1 MHz Normalized to attenuation at 1 MHz. All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 4 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection aaa-019777 0 aaa-019778 0 Scc21 (dB) Sdd21 (dB) -10 -2 -20 S21dd pin 1 - 2 -4 S21cc pin 1 - 2 S21dd pin 5 - 6 S21cc pin 5 - 6 -30 -6 -40 -8 107 108 109 -50 107 1010 108 109 1010 f (Hz) Fig 1. f (Hz) Differential-mode insertion loss; typical values aaa-021982 0 Sdd21 (db) Fig 2. Common-mode insertion loss; typical values aaa-019779 115 Zdif (Ω) -20 Mag S21dd A3 - A4 > C1 - C2 -40 105 Mag S21dd A5 - A6 > C1 - C2 Z reference Z DUT 95 -60 -80 107 108 109 1010 85 40.4 1011 40.6 40.8 41.0 f (Hz) 41.2 t (ns) tr = 200 ps Fig 3. Differential crosstalk; typical values PCMFXHDMI14S_SER Product data sheet Fig 4. Differential Time Domain Reflectometer (TDR) plot; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 5 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection Pixel clock: 297 MHz Vertical scale: 200 mV/div Horizontal scale: 67 ps/div Offset: 33.4 mV Fig 5. HDMI1.4 eye diagram, test board with PCMF2HDMI14S; typical values Pixel clock: 297 MHz Vertical scale: 200 mV/div Horizontal scale: 67 ps/div Offset: 29.6 mV Fig 6. PCMFXHDMI14S_SER Product data sheet HDMI1.4 eye diagram, test board without device; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 6 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection aaa-019781 25 I (A) aaa-019782 0 I (A) 20 -5 15 -10 10 -15 5 -20 0 0 5 10 15 20 -25 -25 25 -20 -15 -10 -5 VCL (V) Fig 7. Transmission Line Pulse (TLP) = 100 ns; Transmission Line Pulse (TLP) = 100 ns; tr = 1 ns tr = 1 ns Dynamic resistance with positive clamping; typical values Fig 8. Dynamic resistance with negative clamping; typical values aaa-021984 25 I (A) aaa-021983 0 I (A) 20 -5 15 -10 10 -15 5 -20 0 0 5 10 15 20 25 -25 -25 -20 -15 -10 -5 VCL (V) Very-Fast Transmission Line Pulse (VF-TLP) = 5 ns; tr = 600 ps Fig 9. 0 VCL (V) Dynamic resistance with positive clamping; typical values 0 VCL (V) Very-Fast Transmission Line Pulse (VF-TLP) = 5 ns; tr = 600 ps Fig 10. Dynamic resistance with negative clamping; typical values The device uses an advanced clamping structure showing a negative dynamic resistance. This snapback behavior strongly reduces the clamping voltage to the system behind the ESD protection during an ESD event. Do not connect unlimited DC current sources to the data lines to avoid keeping the ESD protection device in snapback state after exceeding breakdown voltage (due to an ESD pulse for instance). PCMFXHDMI14S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 7 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection aaa-022150 10 I (A) aaa-022151 0 I (A) 8 -2 6 -4 4 -6 2 -8 0 0 2 4 6 8 10 -10 -10 -8 -6 -4 -2 VCL (V) According to IEC 61000-4-5 (8/20 s) 0 VCL (V) According to IEC 61000-4-5 (8/20 s) Fig 11. Dynamic resistance with positive clamping; typical values Fig 12. Dynamic resistance with negative clamping; typical values 7. Application information The device is designed to provide high-level ESD protection and common-mode filtering for differential high-speed data line pairs such as: • • • • • HDMI 1.4 Transition-Minimized Differential Signaling (TMDS) DisplayPort external Serial Advanced Technology Attachment (eSATA) Low Voltage Differential Signaling (LVDS) When designing the PCB, give careful consideration to impedance matching and signal coupling. Do not connect the protected signal lines to unlimited current sources like, for example, a battery. PCMFXHDMI14S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 8 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection 8. Package outline WLCSP5: wafer level chip-size package; 5 bumps (2-1-2) PCMF1HDMI14S D bump A1 index area A1 E A detail X e 1/2 e b C e1 B1 B e2 A bump A1 index area 1 2 X 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 b D E e e1 e2 max 0.60 0.38 0.31 0.82 1.22 nom 0.57 0.37 0.26 0.77 1.17 0.40 0.40 0.80 min 0.54 0.36 0.21 0.72 1.12 pcmf1hdmi14s_po Outline version References IEC JEDEC JEITA European projection Issue date 15-10-22 16-07-18 PCMF1HDMI14S Fig 13. Package outline WLCSP5 (PCMF1HDMI14S) PCMFXHDMI14S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 9 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection WLCSP10: wafer level chip-size package; 10 bumps (4-2-4) PCMF2HDMI14S D bump A1 index area A1 E A detail X e b C e1 B1 B B2 e2 A bump A1 index area 1 2 3 4 e3 X 1/2 e 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 b D E e e1 e2 max 0.60 0.38 0.31 1.62 1.22 nom 0.57 0.37 0.26 1.57 1.17 0.40 0.40 0.80 min 0.54 0.36 0.21 1.52 1.12 e3 0.80 pcmf2hdmi14s_po Outline version References IEC JEDEC JEITA European projection Issue date 15-10-22 16-07-18 PCMF2HDMI14S Fig 14. Package outline WLCSP10 (PCMF2HDMI14S) PCMFXHDMI14S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 10 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection WLCSP15: wafer level chip-size package; 15 bumps (6-3-6) PCMF3HDMI14S D bump A1 index area A1 E A detail X e 1/2 e b C e1 B2 B1 B B3 e2 A 1 bump A1 index area 2 3 4 5 6 e3 X 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A A1 b D E e e1 e2 e3 max 0.60 0.38 0.31 2.42 1.22 nom 0.57 0.37 0.26 2.37 1.17 0.40 0.40 0.80 0.80 min 0.54 0.36 0.21 2.32 1.12 pcmf3hdmi14s_po Outline version References IEC JEDEC JEITA European projection Issue date 15-10-22 16-07-18 PCMF3HDMI14S Fig 15. Package outline WLCSP15 (PCMF3HDMI14S) PCMFXHDMI14S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 11 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection 9. Soldering WLCSP5: Solder footprint and stencil aperture PCMF1HDMI14S Hx P see detail X P solder land (SL) Hy solder paste deposit (SP) solder land plus solder paste SL = SP solder resist opening (SR) SR occupied area detail X Dimensions in mm recommend stencil thickness: 0.1 mm P SL SP SR Hx Hy 15-10-22 16-07-18 0.40 0.25 0.25 0.325 1.00 1.40 pcmf1hdmi14s_fr Fig 16. Soldering footprint WLCSP5 (PCMF1HDMI14S) PCMFXHDMI14S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 12 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection WLCSP10: Solder footprint and stencil aperture PCMF2HDMI14S Hx P see detail X P solder land (SL) Hy solder paste deposit (SP) solder land plus solder paste SL = SP solder resist opening (SR) SR occupied area P1 detail X Dimensions in mm recommend stencil thickness: 0.1 mm P P1 SL SP SR Hx Hy 15-10-22 16-07-18 0.40 0.80 0.25 0.25 0.325 1.80 1.40 pcmf2hdmi14s_fr Fig 17. Soldering footprint WLCSP10 (PCMF2HDMI14S) WLCSP15: Solder footprint and stencil aperture PCMF3HDMI14S Hx P see detail X P solder land (SL) Hy solder paste deposit (SP) solder land plus solder paste SL = SP solder resist opening (SR) SR occupied area P1 detail X Dimensions in mm recommend stencil thickness: 0.1 mm P P1 SL SP SR Hx Hy 15-10-22 16-07-18 0.40 0.80 0.25 0.25 0.325 2.60 1.40 pcmf3hdmi14s_fr Fig 18. Soldering footprint WLCSP15 (PCMF3HDMI14S) PCMFXHDMI14S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 13 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection 10. Revision history Table 8. Revision history Document ID Release date PCMFXHDMI14S_SER v.2 20160915 Modifications: • • Product data sheet Change notice Supersedes Product data sheet - PCMFXHDMI14S_SER v.1 - - Fig 4 and Fig 5: eye diagrams added Product status changed PCMFXHDMI14S_SER v.1 20160721 PCMFXHDMI14S_SER Data sheet status Preliminary data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 14 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection 11. Legal information 11.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 11.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 11.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. PCMFXHDMI14S_SER Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 15 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 11.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 12. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PCMFXHDMI14S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 September 2016 © Nexperia B.V. 2017. All rights reserved 16 of 17 PCMFXHDMI14S series Nexperia Common-mode EMI filter for differential channels with ESD protection 13. Contents 1 1.1 1.2 1.3 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 11.2 11.3 11.4 12 13 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 3 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Channel characteristics . . . . . . . . . . . . . . . . . . 4 Frequency characteristics. . . . . . . . . . . . . . . . . 4 Application information. . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15 Legal information. . . . . . . . . . . . . . . . . . . . . . . 16 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Contact information. . . . . . . . . . . . . . . . . . . . . 17 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 September 2016
PCMF1HDMI14SZ 价格&库存
很抱歉,暂时无法提供与“PCMF1HDMI14SZ”相匹配的价格&库存,您可以联系我们找货
PCMF1HDMI14SZ
  • 1238+2.574951238+0.33330
  • 10000+2.2970610000+0.29733
  • 100000+1.92399100000+0.24904
库存:26247
PCMF1HDMI14SZ
库存:4250
PCMF1HDMI14SZ
库存:18000
PCMF1HDMI14SZ
  • 22+1.5737322+0.20371
库存:4250
PCMF1HDMI14SZ
    • 1+3.33720
    • 200+1.29600
    • 500+1.25280
    • 1000+1.23120
    PCMF1HDMI14SZ
