come visit our site http://www.txccorp.com
SMD TCXO
2.0 x 1.6 x 0.75 mm
7Z Series
Oscillators
Series
Think of Frequency Think of
Features
.Temperature Stability: ± 0.5 ppm ~ ± 2.0 ppm.
.Operating Temperature Range: - 30 ℃ ~ 85 ℃.
BC
9
TA
A0
26
.Supply Voltage: 1.8 V ~ 3.3 V.
.Voltage Control Function Available.
.World's Thinnest Package.
.Frequencies: 26 MHz, 33.6 MHz, 38.4 MHz, 40 MHz, 52 MHz.
.Applications: GPS, WiMAX, Cellular and Wireless Communications.
.RoHS Compliant / Pb Free.
Electrical Specifications
7Z
Clipped Sinewave
Output Load
10KΩ // 10 pF
Oscillation Mode
Fundamental
Supply Voltage
1.8 ~ 3.3 V
Frequency Range
26 ~ 52 MHz
Clipped Sinewave Output Voltage
Vs. Temperature ( - 30 ~ + 85 ℃ )
Frequency Stability
0.8 Vp-p typical
± 0.5 / ± 2.0 ppm
Vs. Load ( Load varies ± 10 % )
± 0.2 ppm Max.
Vs. Supply Voltage ( Vcc = Typical ± 0.1 V )
± 0.2 ppm Max.
Frequency Tolerance at 25 ℃ after 2 Reflows with Typical
Applied to Auto Frequency Control Pin
Slope of Frequency Drift
Storage Temperature Range
Auto Frequency Control ( AFC ) Range *
Supply Current
Start-up Time
± 2.5 ppm Max.
± 0.1 ppm / ℃ Typical ; ± 0.5 ppm / ℃ Max.
- 40 ~ + 85 ℃
± 7 ~ ± 16 ppm (1.4±1V)
2.0 mA Max.
5 ms Max.
Harmonics
- 5 dBc Max.
Phase Noise at 1 kHz offset
- 130 dBc / Hz
Aging ( at 25 ℃ )
Dimensions
± 1 ppm / year Max.
* AFC Range is selective and disable is acceptable.
Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com
Item / Type
Output Type
Units: mm
89
很抱歉,暂时无法提供与“7Z19200010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.55680
- 10+3.28320
- 30+3.22848
