OY19200004
OY19200004
    TXC(台晶)
    SMD2016_4P
    无源晶振 100Ω 19.2MHz ±10ppm -30℃~+85℃ 8,10,12pF SMD2016_4P
OY19200004 数据手册
SMD Seam Temperature Sensing Crystals 2.0 x 1.6 x 0.8 mm OY Series come visit our site http://www.txccorp.com Features Quartz Crystals Series Think of Frequency Think of 92 T1 X X X X .High precision and high frequency stability. .Excellent thermal coupling between thermistor and crystal. .Application in mobile communications. .RoHS Compliant / Pb Free. Item / Type OY Frequency Range 19.2 ~ 54 MHz Frequency Tolerance (at 25℃) ± 10 ppm , or specify Frequency Stability Over Operating Temperature Range ± 10 ppm , or specify Operating Temperature Range -30 ~ 85 ℃ or specify Shunt Capacitance (C0) 3 pF Max. Drive Level 1 ~ 200μW ( 50μW typical ) Load Capacitance 8 pF , 10 pF , 12 pF , or specify Aging (at 25℃) ± 3 ppm / year Max. Storage Temperature Range -40 ~ +85 ℃ Thermistor Resistance (25℃) 100 kΩ , or specify Thermistor B-constant (25~50℃) 4250, or specify Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Electrical Specifications Equivalent Series Resistance(ESR) Fundamental 19.2 ~ 30 MHz 100 Ω Max. 30 ~ 54 MHz 80 Ω Max. Dimensions Units: mm 11
OY19200004 价格&库存
很抱歉,暂时无法提供与“OY19200004”相匹配的价格&库存,您可以联系我们找货
OY19200004
  • 1+1.44950
  • 10+1.33800
  • 30+1.31570
库存:25
