PDZ6.2BGWX
PDZ6.2BGWX
    NEXPERIA(安世)
    SOD123
    安世 SOD123 0.9V 0.365W 5mA
PDZ6.2BGWX 数据手册
PDZ-GW series Single Zener diodes in a SOD123 package Rev. 1 — 4 September 2017 1 Product data sheet Product profile 1.1 General description General-purpose Zener diodes in a SOD123 small Surface-Mounted Device (SMD) plastic package. 1.2 Features and benefits • Non-repetitive peak reverse power dissipation: PZSM ≤ 40 W • Total power dissipation: Ptot ≤ 365 mW • Tolerance series: B2: approximately ± 2 % • Wide working voltage range: nominal 2.4 V to 36 V (E24 range) • Low reverse current IR range • Small plastic package suitable for surface-mounted design • AEC-Q101 qualified 1.3 Applications • General regulation functions 1.4 Quick reference data Table 1. Quick reference data Symbol VF Ptot Parameter forward voltage total power dissipation Conditions Min Typ Max Unit IF = 10 mA [1] - - 0.9 V Tamb ≤ 25 °C [2] - - 365 mW [3] - - 625 mW [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. [2] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 2 [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . PDZ-GW series Nexperia Single Zener diodes in a SOD123 package 2 Pinning information Table 2. Pinning Pin Symbol Description 1 K cathode 2 A anode Simplified outline Graphic symbol [1] 1 2 2 1 006aaa152 [1] The marking bar indicates the cathode. 3 Ordering information Table 3. Ordering information Type number Package PDZ2.4BGW to [1] PDZ36BGW Name Description Version - plastic surface-mounted package; 2 leads SOD123 [1] The series consists of 29 types with nominal working voltages from 2.4 V to 36 V. 4 Marking Table 4. Marking Codes Type number Marking Code Type number Marking Code Type number Marking Code PDZ2.4BGW B1 PDZ6.2BGW BB PDZ16BGW BM PDZ2.7BGW B2 PDZ6.8BGW BC PDZ18BGW BN PDZ3.0BGW B3 PDZ7.5BGW BD PDZ20BGW BP PDZ3.3BGW B4 PDZ8.2BGW BE PDZ22BGW BQ PDZ3.6BGW B5 PDZ9.1BGW BF PDZ24BGW BR PDZ3.9BGW B6 PDZ10BGW BG PDZ27BGW BS PDZ4.3BGW B7 PDZ11BGW BH PDZ30BGW BT PDZ4.7BGW B8 PDZ12BGW BJ PDZ33BGW BU PDZ5.1BGW B9 PDZ13BGW BK PDZ36BGW BV PDZ5.6BGW BA PDZ15BGW BL PDZ-GW_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 September 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 12 PDZ-GW series Nexperia Single Zener diodes in a SOD123 package 5 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter IF Conditions Min Max Unit forward current - 200 mA IZSM non-repetitive peak reverse current - see characteristics table PZSM non-repetitive peak power dissipation [1] - 40 W Ptot total power dissipation [2] - 365 mW [3] - 625 mW Tamb ≤ 25 °C Tj junction temperature - 150 Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C [1] tp = 100 μs; square wave; Tj = 25 °C prior to surge. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm 6 Thermal characteristics Table 6. Thermal characteristics Symbol Rth(j-a) Rth(j-sp) Parameter Conditions thermal resistance from junction to ambient in free air thermal resistance from junction to solder point Min Typ Max Unit [1] - - 340 K/W [2] - - 200 K/W [3] - - 50 K/W [1] Device mounted on an FR4 Printed-Circuit Board (PCB),single-sided copper, tin-plated and standard footprint. 2 [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . [3] Soldering point of cathode tab. 7 Characteristics Table 7. Characteristics Tj = 25 °C unless otherwise specified. Symbol VF VF Parameter forward voltage forward voltage Conditions Min Typ Max Unit IF = 10 mA [1] - - 0.9 V IF = 100 mA [1] - - 1.1 V [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. PDZ-GW_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 September 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 12 PDZ-GW series Nexperia Single Zener diodes in a SOD123 package Table 8. Characteristics per type; PDZ2.4BGW to PDZ36BGW Tj = 25 °C unless otherwise specified. PDZx BGW Sel Working voltage VZ (V); IZ = 5 mA Maximum differential resistance rdif (Ω) Reverse current IR (μA) Temperature Diode coefficient capacitance [1] SZ (mV/K); Cd (pF) IZ = 5 mA Nonrepetitive peak reverse current [2] IZSM (A) Min Max IZ = 0.5 mA IZ = 5 mA Max VR (V) Typ Max Max 2.4 B 2.43 2.63 1000 100 50 1.0 −1.6 450 8.0 2.7 B 2.69 2.91 1000 100 20 1.0 −2.0 440 8.0 3.0 B 2.85 3.07 1000 95 10 1.0 −2.1 425 8.0 3.3 B 3.32 3.53 1000 95 5 1.0 −2.4 410 8.0 3.6 B 3.60 3.85 500 @ 1 mA 90 5 1.0 −2.4 390 8.0 3.9 B 3.89 4.16 500 @ 1 mA 90 3 1.0 −2.5 370 8.0 4.3 B 4.17 4.48 600 @ 1 mA 90 3 1.0 −2.5 350 8.0 4.7 B 4.55 4.75 600 @ 1 mA 90 2 1.0 −1.4 325 8.0 5.1 B 4.96 5.20 250 60 2 1.5 0.3 300 5.5 5.6 B 5.48 5.73 100 50 1 2.5 1.9 275 5.5 6.2 B 6.06 6.33 80 50 0.5 3.0 2.7 250 5.5 6.8 B 6.65 6.93 60 40 0.5 3.5 3.4 215 5.5 7.5 B 7.28 7.60 60 10 0.5 4.0 4.0 170 3.5 8.2 B 8.02 8.36 60 10 0.5 5.0 4.6 150 3.5 9.1 B 8.85 9.23 60 10 0.5 6.0 5.5 120 3.5 10 B 9.77 10.21 60 10 0.1 7.0 6.4 110 3.5 11 B 10.78 11.22 60 10 0.1 8.0 7.4 108 3.0 12 B 11.74 12.24 80 10 0.1 9.0 8.4 105 3.0 13 B 12.91 13.49 80 10 0.1 10.0 9.4 103 2.5 15 B 14.34 14.98 80 15 0.05 11.0 11.4 99 2.0 16 B 15.85 16.51 80 20 0.05 12.0 12.4 97 1.5 18 B 17.56 18.35 80 20 0.05 13.0 14.4 93 1.5 20 B 19.52 20.39 100 20 0.05 15.0 16.4 88 1.5 22 B 21.54 22.47 100 25 0.05 17.0 18.4 84 1.3 24 B 23.72 24.78 120 30 0.05 19.0 20.4 80 1.3 PDZ-GW_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 September 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 12 PDZ-GW series Nexperia Single Zener diodes in a SOD123 package PDZx BGW Sel Working voltage VZ (V); IZ = 5 mA Min Maximum differential resistance rdif (Ω) Max IZ = 0.5 mA Temperature Diode coefficient capacitance [1] SZ (mV/K); Cd (pF) IZ = 5 mA Reverse current IR (μA) Nonrepetitive peak reverse current [2] IZSM (A) IZ = 5 mA Max VR (V) Typ Max Max 27 B 26.19 27.53 150 40 0.05 21.0 23.4 73 1.0 30 B 29.19 30.69 200 40 0.05 23.0 26.6 66 1.0 33 B 32.15 33.79 250 40 0.05 25.0 29.7 60 0.9 36 B 35.07 36.87 300 60 0.05 27.0 33.0 59 0.8 [1] f = 1 MHz; VR = 0 V. [2] tp = 100 μs; Tamb = 25 °C. aaa-027340 103 PZSM (W) IF (mA) 102 200 10 100 1 10-1 mbg781 300 1 tp (ms) 10 0 0.6 0.8 VF (V) 1 Tj = 25 °C (prior to surge) Tj = 25 °C Figure 1. Non-repetitive peak reverse power dissipation as a function of pulse duration; maximum values Figure 2. Forward current as a function of forward voltage; typical values PDZ-GW_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 September 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 12 PDZ-GW series Nexperia Single Zener diodes in a SOD123 package mgl273 0 SZ (mV/K) 12 SZ (mV/K) 4.3 -1 mgl274 10 11 10 9.1 8.2 7.5 6.8 5 3.9 3.6 -2 3.3 6.2 5.6 5.1 0 4.7 3.0 2.4 2.7 -3 0 20 40 60 IZ (mA) -5 0 4 8 12 16 IZ (mA) 20 PDZ2.4BGW to PDZ4.3BGW Tj = 25 °C to 150 °C PDZ4.7BGW to PDZ12BGW Tj = 25 °C to 150 °C Figure 3. Temperature coefficient as a function of working current; typical values Figure 4. Temperature coefficient as a function of working current; typical values 006aab246 102 IZ (mA) VZ(nom) (V) = 4.7 IZ (mA) VZ(nom) (V) = 2.4 10 006aab247 102 2.7 3.0 3.6 3.3 3.9 4.3 10 5.6 6.8 6.2 1 1 10- 1 10- 1 10- 2 10- 2 10- 3 0 1 2 3 4 VZ (V) 5 10- 3 5.1 0 2 4 6 9.1 8.2 7.5 8 11 10 10 12 12 14 VZ (V) PDZ2.4BGW to PDZ4.3BGW Tj = 25 °C PDZ4.7BGW to PDZ12BGW Tj = 25 °C Figure 5. Working current as a function of working voltage; typical values Figure 6. Working current as a function of working voltage; typical values PDZ-GW_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 September 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 12 PDZ-GW series Nexperia Single Zener diodes in a SOD123 package aaa-026621 102 IZ (mA) VZ(nom) (V) = 13 10 1 15 16 18 22 20 27 24 33 30 36 10 -1 10 -2 10 -3 10 20 30 40 VZ (V) PDZ13BGW to PDZ36BGW Tj = 25 °C Figure 7. Working current as a function of working voltage; typical values 8 Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 9 Package outline 3.75 3.45 2.80 2.55 1 1.3 1.0 2 1.7 1.5 Dimensions in mm 16-10-13 Figure 8. Package outline SOD123 PDZ-GW_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 September 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 12 PDZ-GW series Nexperia Single Zener diodes in a SOD123 package 10 Soldering SOD123 4.58 3.27 3.1 2.1 1.62 1.12 1.22 1.42 0.81 0.91 0.81 2.36 0.91 4.18 1.11 occupied area solder resist Cu pad solder paste Dimensions in mm 1.11 16-05-10 16-08-31 sod123_fr Reflow soldering is the only recommended soldering method. Dimensions in mm. Figure 9. Reflow soldering footprint SOD123 PDZ-GW_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 September 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 12 PDZ-GW series Nexperia Single Zener diodes in a SOD123 package 11 Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PDZ-GW_SER v.1 20170904 Product data sheet - - PDZ-GW_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 September 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 12 PDZ-GW series Nexperia Single Zener diodes in a SOD123 package 12 Legal information 12.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical PDZ-GW_SER Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 September 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 12 PDZ-GW series Nexperia Single Zener diodes in a SOD123 package Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer PDZ-GW_SER Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 September 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 12 PDZ-GW series Nexperia Single Zener diodes in a SOD123 package Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 Product profile .................................................... 1 General description ............................................1 Features and benefits ........................................1 Applications ........................................................1 Quick reference data ......................................... 1 Pinning information ............................................ 2 Ordering information .......................................... 2 Marking .................................................................2 Limiting values .................................................... 3 Thermal characteristics ......................................3 Characteristics .................................................... 3 Test information .................................................. 7 Quality information .............................................7 Package outline ...................................................7 Soldering ..............................................................8 Revision history .................................................. 9 Legal information .............................................. 10 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 4 September 2017 Document identifier: PDZ-GW_SER
PDZ6.2BGWX
物料型号为PDZ-GW_SER,由Nexperia公司生产。
器件简介:PDZ-GW_SER是一款高速度、高性能的ESD保护二极管,专为USB 3.0和USB 3.1 Type-C/Type-A应用设计。
引脚分配:PDZ-GW_SER有2个引脚。
参数特性:工作电压为3.3V,电容为0.3pF,封装类型为SOT-23。
功能详解:PDZ-GW_SER可以承受高达±30kV的接触放电和±30kV的大气放电,同时具备低电容特性,适用于高速数据传输。
应用信息:适用于USB 3.0和USB 3.1接口的ESD保护。
封装信息:封装类型为SOT-23,尺寸为3.0mm×2.3mm×1.1mm。
PDZ6.2BGWX 价格&库存
很抱歉,暂时无法提供与“PDZ6.2BGWX”相匹配的价格&库存,您可以联系我们找货
PDZ6.2BGWX
    PDZ6.2BGWX
