PESD5V0U1BAF
PESD5V0U1BAF
    NEXPERIA(安世)
    SOD-323
    ESD抑制器/TVS二极管 VRWM=5V VBR(Min)=5.5V SOD323
PESD5V0U1BAF 数据手册
PESD5V0U1BA; PESD5V0U1BB; PESD5V0U1BL Ultra low capacitance bidirectional ESD protection diodes Rev. 01 — 25 April 2007 Product data sheet 1. Product profile 1.1 General description Ultra low capacitance bidirectional ElectroStatic Discharge (ESD) protection diodes in small Surface-Mounted Device (SMD) plastic packages designed to protect one data line from the damage caused by ESD. Table 1. Product overview Type number Package NXP JEITA Package configuration PESD5V0U1BA SOD323 SC-76 very small PESD5V0U1BB SOD523 SC-79 flat lead ultra small PESD5V0U1BL SOD882 - leadless ultra small 1.2 Features n Bidirectional ESD protection of one line n Ultra low leakage current: IRM = 5 nA n Ultra low diode capacitance: Cd = 2.9 pF n ESD protection of up to 10 kV n IEC 61000-4-2; level 4 (ESD) 1.3 Applications n Computers and peripherals n Audio and video equipment n Cellular handsets and accessories n 10/100/1000 Ethernet n Local Area Network (LAN) equipment n Communication systems n Portable electronics n Subscriber Identity Module (SIM) card protection n FireWire n High-speed data lines 1.4 Quick reference data Table 2. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit - - 5 V - 2.9 3.5 pF Per diode VRWM reverse standoff voltage Cd diode capacitance f = 1 MHz; VR = 0 V PESD5V0U1BA/BB/BL NXP Semiconductors Ultra low capacitance bidirectional ESD protection diodes 2. Pinning information Table 3. Pinning Pin Description Simplified outline Symbol SOD323; SOD523 1 cathode 1 2 cathode 2 [1] 1 2 1 2 sym045 001aab540 SOD882 1 cathode 1 2 cathode 2 [1] 1 2 1 2 sym045 Transparent top view [1] The marking bar indicates the cathode. 3. Ordering information Table 4. Ordering information Type number Package Name Description Version PESD5V0U1BA SC-76 plastic surface-mounted package; 2 leads SOD323 PESD5V0U1BB SC-79 plastic surface-mounted package; 2 leads SOD523 PESD5V0U1BL - leadless ultra small plastic package; 2 terminals; body 1.0 × 0.6 × 0.5 mm SOD882 4. Marking Table 5. Marking codes Type number Marking code PESD5V0U1BA AA PESD5V0U1BB B3 PESD5V0U1BL AN PESD5V0U1BA_BB_BL_1 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 01 — 25 April 2007 2 of 12 PESD5V0U1BA/BB/BL NXP Semiconductors Ultra low capacitance bidirectional ESD protection diodes 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Per device Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C Min Max Unit - 10 kV - 8 kV Table 7. Symbol ESD maximum ratings Parameter Conditions electrostatic discharge voltage IEC 61000-4-2 (contact discharge) Per diode VESD [1][2] MIL-STD-883 (human body model) [1] Device stressed with ten non-repetitive ESD pulses. [2] Measured from pin 1 to pin 2. Table 8. ESD standards compliance Standard Conditions Per diode IEC 61000-4-2; level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3 (human body model) > 4 kV 001aaa631 IPP 100 % 90 % 10 % tr = 0.7 ns to 1 ns t 30 ns 60 ns Fig 1. ESD pulse waveform according to IEC 61000-4-2 PESD5V0U1BA_BB_BL_1 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 01 — 25 April 2007 3 of 12 PESD5V0U1BA/BB/BL NXP Semiconductors Ultra low capacitance bidirectional ESD protection diodes 6. Characteristics Table 9. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Per diode VRWM reverse standoff voltage - - 5 V IRM reverse leakage current VRWM = 5 V - 5 100 nA VBR breakdown voltage IR = 5 mA 5.5 7 9.5 V Cd diode capacitance f = 1 MHz VR = 0 V - 2.9 3.5 pF VR = 5 V - 1.9 - pF - - 100 Ω differential resistance rdif IR = 1 mA 006aab036 3.0 IPP Cd (pF) 2.6 −VCL −VBR −VRWM IR IRM −IRM −IR VRWM VBR VCL 2.2 − 1.8 0 1 2 3 4 + −IPP 5 VR (V) 006aaa676 f = 1 MHz; Tamb = 25 °C Fig 2. Diode capacitance as a function of reverse voltage; typical values Fig 3. V-I characteristics for a bidirectional ESD protection diode PESD5V0U1BA_BB_BL_1 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 01 — 25 April 2007 4 of 12 PESD5V0U1BA/BB/BL NXP Semiconductors Ultra low capacitance bidirectional ESD protection diodes ESD TESTER 450 Ω RZ RG 223/U 50 Ω coax 4 GHz DIGITAL OSCILLOSCOPE 10× ATTENUATOR 50 Ω CZ IEC 61000-4-2 network CZ = 150 pF; RZ = 330 Ω DUT (DEVICE UNDER TEST) vertical scale = 10 A/div horizontal scale = 15 ns/div vertical scale = 10 V/div horizontal scale = 100 ns/div GND GND unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) clamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) pin 1 to 2 vertical scale = 10 A/div horizontal scale = 15 ns/div GND GND vertical scale = 10 V/div horizontal scale = 100 ns/div unclamped −8 kV ESD pulse waveform (IEC 61000-4-2 network) clamped −8 kV ESD pulse waveform (IEC 61000-4-2 network) pin 1 to 2 006aab037 Fig 4. ESD clamping test setup and waveforms PESD5V0U1BA_BB_BL_1 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 01 — 25 April 2007 5 of 12 PESD5V0U1BA/BB/BL NXP Semiconductors Ultra low capacitance bidirectional ESD protection diodes 7. Application information The PESD5V0U1Bx series is designed for the bidirectional protection of one signal line from the damage caused by ESD pulses. The PESD5V0U1Bx series may be used on lines where the signal polarities are either positive or negative with respect to ground. signal line PESD5V0U1Bx GND 006aab038 Fig 5. Bidirectional protection of one line Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: 1. Place the PESD5V0U1Bx as close to the input terminal or connector as possible. 2. The path length between the PESD5V0U1Bx and the protected line should be minimized. 3. Keep parallel signal paths to a minimum. 4. Avoid running protected conductors in parallel with unprotected conductors. 5. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. 6. Minimize the length of the transient return path to ground. 7. Avoid using shared transient return paths to a common ground point. 8. Ground planes should be used whenever possible. For multilayer PCBs, use ground vias. PESD5V0U1BA_BB_BL_1 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 01 — 25 April 2007 6 of 12 PESD5V0U1BA/BB/BL NXP Semiconductors Ultra low capacitance bidirectional ESD protection diodes 8. Package outline 1.35 1.15 0.45 0.15 1 2.7 2.3 0.85 0.75 1.1 0.8 0.65 0.58 1 1.65 1.25 1.55 1.15 1.8 1.6 2 2 0.40 0.25 0.25 0.10 0.34 0.26 Dimensions in mm 03-12-17 Fig 6. Package outline SOD323 (SC-76) 0.17 0.11 Dimensions in mm 02-12-13 Fig 7. Package outline SOD523 (SC-79) 0.50 0.46 0.62 0.55 2 0.30 0.22 0.65 0.30 0.22 1.02 0.95 1 0.55 0.47 cathode marking on top side Dimensions in mm 03-04-17 Fig 8. Package outline SOD882 PESD5V0U1BA_BB_BL_1 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 01 — 25 April 2007 7 of 12 PESD5V0U1BA/BB/BL NXP Semiconductors Ultra low capacitance bidirectional ESD protection diodes 9. Packing information Table 10. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package Description Packing quantity 3000 8000 10000 PESD5V0U1BA SOD323 4 mm pitch, 8 mm tape and reel -115 - -135 PESD5V0U1BB SOD523 2 mm pitch, 8 mm tape and reel - -315 - 4 mm pitch, 8 mm tape and reel -115 - -135 2 mm pitch, 8 mm tape and reel - - -315 PESD5V0U1BL [1] SOD882 For further information and the availability of packing methods, see Section 13. 10. Soldering 3.05 2.80 2.10 1.60 solder lands solder resist 1.65 0.95 0.50 0.60 occupied area solder paste 0.50 (2×) msa433 Dimensions in mm Fig 9. Reflow soldering footprint SOD323 (SC-76) 5.00 4.40 1.40 solder lands solder resist occupied area 2.75 1.20 msa415 preferred transport direction during soldering Dimensions in mm Fig 10. Wave soldering footprint SOD323 (SC-76) PESD5V0U1BA_BB_BL_1 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 01 — 25 April 2007 8 of 12 PESD5V0U1BA/BB/BL NXP Semiconductors Ultra low capacitance bidirectional ESD protection diodes 2.15 0.50 0.60 1.20 solder lands solder paste 0.30 0.40 solder resist 1.80 1.90 occupied area mgs343 Reflow soldering is the only recommended soldering method. Dimensions in mm Fig 11. Reflow soldering footprint SOD523 (SC-79) 1.30 R = 0.05 (8×) 0.30 0.60 0.70 0.80 (2×) (2×) (2×) 0.90 solder lands solder paste solder resist R = 0.05 (8×) 0.30 (2×) 0.40 (2×) 0.50 (2×) occupied area mbl872 Reflow soldering is the only recommended soldering method. Dimensions in mm Fig 12. Reflow soldering footprint SOD882 PESD5V0U1BA_BB_BL_1 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 01 — 25 April 2007 9 of 12 PESD5V0U1BA/BB/BL NXP Semiconductors Ultra low capacitance bidirectional ESD protection diodes 11. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes PESD5V0U1BA_BB_BL_1 20070425 Product data sheet - - PESD5V0U1BA_BB_BL_1 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 01 — 25 April 2007 10 of 12 PESD5V0U1BA/BB/BL NXP Semiconductors Ultra low capacitance bidirectional ESD protection diodes 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 12.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For additional information, please visit: http://www.nxp.com For sales office addresses, send an email to: salesaddresses@nxp.com PESD5V0U1BA_BB_BL_1 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 01 — 25 April 2007 11 of 12 PESD5V0U1BA/BB/BL NXP Semiconductors Ultra low capacitance bidirectional ESD protection diodes 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Application information. . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Packing information. . . . . . . . . . . . . . . . . . . . . . 8 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2007. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 25 April 2007 Document identifier: PESD5V0U1BA_BB_BL_1
PESD5V0U1BAF
物料型号:PESD5V0U1BA 器件简介:PESD5V0U1BA 是 Nexperia 公司生产的 ESD 保护二极管,具有低电容特性,适用于高速数据线路的 ESD 保护。
引脚分配:PESD5V0U1BA 有 2 个引脚,分别为阳极和阴极。
参数特性:工作电压 5.0V,最大箝位电压 9.3V,电容 3.0pF,封装类型 SOT-23。
功能详解:PESD5V0U1BA 能够保护高速数据线路免受静电放电的损害,具有快速响应时间和低电容特性。
应用信息:适用于 USB 3.0、HDMI、DisplayPort 等高速数据传输接口的 ESD 保护。
封装信息:SOT-23,是一种小型表面贴装封装,适用于自动贴装。
PESD5V0U1BAF 价格&库存
很抱歉,暂时无法提供与“PESD5V0U1BAF”相匹配的价格&库存,您可以联系我们找货
PESD5V0U1BAF
  • 1+3.784251+0.48983
