TIP142T
TIP142T
    SPTECH(质超)
    TO-220C
    NPN 100V 10A
TIP142T 数据手册
SPTECH Product Specification SPTECH Silicon NPN Darlington Power Transistor TIP142T DESCRIPTION ·High DC Current Gain: hFE = 1000(Min)@ IC= 5A ·Collector-Emitter Sustaining Voltage: VCEO(SUS) = 100V(Min) ·Complement to Type TIP147T APPLICATIONS ·Designed for general purpose amplifier and low speed switching applications. ABSOLUTE MAXIMUM RATINGS(Ta=25℃) SYMBOL PARAMETER VALUE UNIT VCBO Collector-Base Voltage 100 V VCEO Collector-Emitter Voltage 100 V VEBO Emitter-Base Voltage 5 V IC Collector Current-Continuous 10 A ICM Collector Current-Peak 15 A IB Base Current- Continuous 0.5 A PC Collector Power Dissipation @TC=25℃ 80 W Tj Junction Temperature 150 ℃ -55~150 ℃ Tstg Storage Temperature Range THERMAL CHARACTERISTICS SYMBOL Rth j-c PARAMETER Thermal Resistance, Junction to Case SPTECH website:www.superic-tech.com MAX UNIT 1.56 ℃/W 1 SPTECH Product Specification SPTECH Silicon NPN Darlington Power Transistor TIP142T ELECTRICAL CHARACTERISTICS TC=25℃ unless otherwise specified SYMBOL PARAMETER CONDITIONS MIN TYP. MAX VCEO(SUS) Collector-Emitter Sustaining Voltage IC= 30mA, IB= 0 VCE(sat)-1 Collector-Emitter Saturation Voltage IC= 5A ,IB= 10mA 2.0 V VCE(sat)-2 Collector-Emitter Saturation Voltage IC= 10A ,IB= 40mA 3.0 V VBE(sat) Base-Emitter Saturation Voltage IC= 10A ,IB= 40mA 3.5 V VBE(on) Base-Emitter On Voltage IC= 10A ; VCE= 4V 3.0 V ICBO Collector Cutoff current VCB= 100V, IE= 0 1 mA ICEO Collector Cutoff current VCE= 50V, IB= 0 2 mA IEBO Emitter Cutoff Current VEB= 5V; IC= 0 2 mA hFE-1 DC Current Gain IC= 5A ; VCE= 4V 1000 hFE-2 DC Current Gain IC= 10A ; VCE= 4V 500 100 UNIT V Switching Times td Delay Time tr Rise Time tstg tf Storage Time VCC = 30 V, IC = 5.0 A, IB1= -IB2= 20 mA; tp= 20μs Duty Cycle≤20% Fall Time SPTECH website:www.superic-tech.com 0.15 μs 0.55 μs 2.5 μs 2.5 μs 2
TIP142T
物料型号:TIP142T
器件简介:SPTECH Silicon NPN Darlington Power Transistor,具有高直流电流增益(hFE=1000最小值@ I_C=5 A),集电极-发射极维持电压(V_CEO(SUS)=100 V最小值),是TIP147T的互补型号。
引脚分配:1.BASE,2.COLLECTOR,3.EMITTER,封装为TO-220C。
参数特性:包括集电极-基极电压(VCBO 100 V)、集电极-发射极电压(VCEO 100 V)、发射极-基极电压(VEBO 5 V)、连续集电极电流(IC 10 A)、峰值集电极电流(ICM 15 A)、连续基极电流(IB 0.5 A)、集电极功耗(PC 80 W)、结温(Tj 150 ℃)和存储温度范围(Tstg -55~150 ℃)。
功能详解:设计用于一般用途放大和低速开关应用。
应用信息:适用于一般用途的放大器和低速开关。
封装信息:TO-220C封装,提供了详细的封装尺寸数据。
TIP142T 价格&库存
很抱歉,暂时无法提供与“TIP142T”相匹配的价格&库存,您可以联系我们找货
TIP142T
  • 1+5.31468
  • 10+4.33998
  • 50+3.74490
  • 100+3.26268
  • 500+2.97540
  • 1000+2.82150
库存:11
