PHPT61002PYCLH
100 V, 2 A PNP high power bipolar transistor
13 July 2017
Product data sheet
1. General description
PNP high power bipolar transistor in a SOT669 (LFPAK56) Surface-Mounted Device (SMD) power
plastic package.
NPN complement: PHPT61002NYCLH.
2. Features and benefits
High thermal power dissipation capability
Suitable for high temperature applications up to 175 °C
Reduced Printed-Circuit Board (PCB) requirements comparing to transistors in DPAK
High energy efficiency due to less heat generation
3. Applications
Power management
Load switch
Linear mode voltage regulator
Backlighting applications
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCEO
collector-emitter
voltage
open base
-100
V
IC
collector current
-2
A
ICM
peak collector current
single pulse; tp ≤ 1 ms
-5
A
RCEsat
collector-emitter
saturation resistance
IC = -2 A; IB = -200 mA; Tamb = 25 °C
150
250
mΩ
[1]
Pulse test: tp ≤ 300 µs; δ ≤ 0.02
[1]
PHPT61002PYCLH
Nexperia
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
1
E
emitter
2
E
emitter
3
E
emitter
4
B
base
mb
C
collector
Simplified outline
Graphic symbol
C
mb
B
E
sym132
1 2 3 4
LFPAK56; PowerSO8 (SOT669)
6. Ordering information
Table 3. Ordering information
Type number
PHPT61002PYCLH
Package
Name
Description
Version
LFPAK56;
Power-SO8
Plastic single-ended surface-mounted package (LFPAK56;
Power-SO8); 4 leads
SOT669
7. Marking
Table 4. Marking codes
Type number
Marking code
PHPT61002PYCLH
1002PCC
PHPT61002PYCLH
Product data sheet
All information provided in this document is subject to legal disclaimers.
13 July 2017
Nexperia B.V. 2017. All rights reserved
2 / 15
PHPT61002PYCLH
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
-100
V
VCEO
collector-emitter voltage
open base
-100
V
VEBO
emitter-base voltage
open collector
-8
V
IC
collector current
-2
A
ICM
-5
A
IB
base current
-0.5
A
Ptot
total power dissipation
[1]
1.25
W
[2]
3
W
[3]
5
W
[4]
25
W
Tamb ≤ 25 °C
Tj
junction temperature
175
°C
Tamb
ambient temperature
-55
175
°C
Tstg
storage temperature
-65
175
°C
[1]
[2]
[3]
[4]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint.
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated mounting pad for collector 6 cm .
Device mounted on a ceramic PCB, Al2O3, standard footprint.
Power dissipation from junction to mounting base.
aaa-010424
8
Ptot
(W)
6
(1)
4
(2)
2
(3)
25
125
Tamb (°C)
225
(1) Ceramic PCB, Al2O3, standard footprint
2
(2) FR4 PCB, mounting pad for collector 6 cm
(3) FR4 PCB, standard footprint
Fig. 1.
Power derating curves
PHPT61002PYCLH
Product data sheet
13 July 2017
3 / 15
PHPT61002PYCLH
Nexperia
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance
from junction to
ambient
in free air
Rth(j-sp)
[1]
[2]
[3]
Min
Typ
Max
Unit
[1]
115
K/W
[2]
50
K/W
[3]
30
K/W
6
K/W
thermal resistance
from junction to solder
point
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
2
aaa-010427
103
Zth(j-a)
(K/W)
duty cycle = 1
102
0.75
0.33
0.2
10
0.5
0.1
0.05
0.02
0.01
1
10-1
10-5
0.25
10-3
10-2
10-1
1
10
102
tp (s)
103
Fig. 2.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
PHPT61002PYCLH
Product data sheet
13 July 2017
4 / 15
PHPT61002PYCLH
Nexperia
aaa-010428
102
duty cycle = 1
Zth(j-a)
(K/W)
0.75
0.33
10
0.5
0.2
0.1
0.05
1
0.01
10-1
10-5
0.02
0.25
10-3
10-2
Fig. 3.
10-1
1
10
102
2
tp (s)
103
PHPT61002PYCLH
Product data sheet
13 July 2017
5 / 15
PHPT61002PYCLH
Nexperia
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICBO
collector-base cut-off
current
VCB = -80 V; IE = 0 A; Tamb = 25 °C
-100
nA
VCB = -80 V; IE = 0 A; Tj = 150 °C
-50
µA
ICES
collector-emitter cut-off VCE = -80 V; VBE = 0 V; Tamb = 25 °C
current
-100
nA
IEBO
emitter-base cut-off
current
VEB = -8 V; IC = 0 A; Tamb = 25 °C
-100
nA
hFE
DC current gain
VCE = -1.5 V; IC = -500 mA;
Tamb = 25 °C
[1]
80
160
VCE = -10 V; IC = -500 mA;
Tamb = 25 °C
[1]
100
180
VCE = -5 V; IC = -1 A; Tamb = 25 °C
[1]
70
150
260
VCE = -10 V; IC = -1 A; Tamb = 25 °C
[1]
90
160
VCE = -10 V; IC = -2 A; Tamb = 25 °C
[1]
-75
-130
mV
[1]
-300
-500
mV
VCEsat
collector-emitter
saturation voltage
IC = -0.5 A; IB = -50 mA; Tamb = 25 °C
RCEsat
collector-emitter
[1]
150
250
mΩ
VBEsat
base-emitter saturation
voltage
[1]
-1.02
-1.2
V
VBEon
base-emitter turn-on
voltage
VCE = -2 V; IC = -0.1 A; Tamb = 25 °C
[1]
-0.67
-0.9
V
td
delay time
ns
tr
rise time
VCC = -12.5 V; IC = -1 A; IBon = -50 mA;
IBoff = 50 mA; Tamb = 25 °C
190
ns
ton
turn-on time
210
ns
ts
storage time
300
ns
tf
fall time
170
ns
toff
turn-off time
470
ns
fT
transition frequency
VCE = -10 V; IC = -100 mA;
f = 100 MHz; Tamb = 25 °C
125
MHz
Cc
collector capacitance
VCB = -10 V; IE = 0 A; ie = 0 A;
f = 1 MHz; Tamb = 25 °C
28
pF
[1]
PHPT61002PYCLH
Product data sheet
13 July 2017
6 / 15
PHPT61002PYCLH
Nexperia
aaa-026967
300
aaa-026968
-2.5
IC
(A)
hFE
(1)
IB = -50 mA
-2.0
-45
-40 -35
-30 -25
-1.5
-20
200
(2)
-10
-1.0
100
-15
-5
(3)
-0.5
-1
-10
-102
-104
IC (mA)
VCE = −1 V
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig. 4.
-2
-3
-4
VCE (V)
-5
Tamb = 25 °C
Fig. 5.
Collector current as a function of collectoremitter voltage; typical values
DC current gain as a function of collector
current; typical values
aaa-010432
-1.6
aaa-010433
-1.2
VBEsat
(V)
VBE
(V)
-1.0
-1.2
-0.8
(1)
-0.8
(1)
-0.6
(2)
(2)
-0.4
-0.4
(3)
-1
-10
-102
-0.2
-10-1
-103
-104
IC (mA)
VCE = −2 V
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
Fig. 6.
Product data sheet
-1
-10
-102
-103
-104
IC (mA)
IC/IB = 20
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
Base-emitter voltage as a function of collector
PHPT61002PYCLH
(3)
Fig. 7.
Base-emitter saturation voltage as a function of
collector current; typical values
13 July 2017
7 / 15
PHPT61002PYCLH
Nexperia
aaa-026969
-10
aaa-026970
-10
VCEsat
(V)
VCEsat
(V)
-1
-1
-10-1
-10-1
(1)
(1)
(3)
(2)
(2)
(3)
-10-2
-10-1
-1
-10
-10-2
-10-2
-10-1
-10-3
-10-4
IC (mA)
IC/IB = 20
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig. 8.
-1
-10-2
-10
-10-3
-10-4
IC (mA)
Tamb = 25 °C
(1) IC/IB = 50
(2) IC/IB = 20
(3) IC/IB = 10
Collector-emitter saturation voltage as a
function of collector current; typical values
Fig. 9.
aaa-026971
103
aaa-026972
103
RCEsat
RCEsat
102
102
10
10
(1)
(2)
1
1
(1)
(3)
(2)
(3)
10-1
-10-1
-1
-10
-102
10-1
-10-1
-103
-104
IC (mA)
IC/IB = 20
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Product data sheet
-10
-102
-103
-104
IC (mA)
Tamb = 25 °C
(1) IC/IB = 50
(2) IC/IB = 20
(3) IC/IB = 10
Fig. 10. Collector-emitter saturation resistance as a
PHPT61002PYCLH
-1
Fig. 11. Collector-emitter saturation resistance as a
13 July 2017
8 / 15
PHPT61002PYCLH
Nexperia
11. Test information
- IB
input pulse
(idealized waveform)
90 %
- I Bon (100 %)
10 %
- I Boff
output pulse
- IC
90 %
- I C (100 %)
10 %
t
td
ts
tr
t on
tf
t off
006aaa266
Fig. 12. BISS transistor switching time definition
VBB
RB
VCC
RC
(probe)
oscilloscope
450 Ω
Vo
(probe)
450 Ω
R2
VI
oscilloscope
DUT
R1
mgd624
Fig. 13. Test circuit for switching times
PHPT61002PYCLH
Product data sheet
13 July 2017
9 / 15
PHPT61002PYCLH
Nexperia
12. Package outline
Plastic single-ended surface-mounted package (LFPAK56; Power-SO8); 4 leads
E
A2
A
SOT669
C
c2
b2
E1
b3
L1
mounting
base
b4
D1
D
H
L2
1
2
3
e
4
w
b
A
X
c
1/2 e
A
(A3)
A1
C
q
L
detail X
y C
θ
5 mm
8°
scale
0°
Dimensions (mm are the original dimensions)
Unit(1)
mm
A
A1
A2
A3
b
b2
max 1.20 0.15 1.10
0.50 4.41
nom
0.25
min 1.01 0.00 0.95
0.35 3.62
c
c2
D(1) D1(1) E(1) E1(1)
b3
b4
2.2
0.9
0.25 0.30 4.10 4.20
5.0
3.3
2.0
0.7
0.19 0.24 3.80
4.8
3.1
e
1.27
H
L
L1
L2
6.2
0.85
1.3
1.3
5.8
0.40
0.8
0.8
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
Outline
version
SOT669
References
IEC
JEDEC
JEITA
w
y
0.25
0.1
sot669_po
European
projection
Issue date
11-03-25
13-02-27
MO-235
Fig. 14. Package outline LFPAK56; Power-SO8 (SOT669)
PHPT61002PYCLH
Product data sheet
13 July 2017
10 / 15
PHPT61002PYCLH
Nexperia
13. Soldering
Footprint information for reflow soldering
SOT669
4.7
4.2
0.9
(3×)
0.25
(2×)
0.25
(2×)
0.6
(4×)
3.45
0.6
(3×)
2
3.5
2.55
0.25
(2×)
SR opening =
Cu + 0.075
1.1
2.15
3.3
SP opening =
Cu - 0.050
0.7
(4×)
1.27
3.81
solder lands
solder paste
125 µm stencil
solder resist
occupied area
Dimensions in mm
sot669_fr
Fig. 15. Reflow soldering footprint for LFPAK56; Power-SO8 (SOT669)
PHPT61002PYCLH
Product data sheet
13 July 2017
11 / 15
PHPT61002PYCLH
Nexperia
14. Revision history
Table 8. Revision history
Data sheet ID
Release date
Data sheet status
Change
notice
Supersedes
PHPT61002PYCLH v.1
20170713
Product data sheet
PHPT61002PYCLH
Product data sheet
13 July 2017
12 / 15
PHPT61002PYCLH
Nexperia
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
15. Legal information
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Data sheet status
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to the accuracy
or completeness of information included herein and shall have no liability for
the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’ aggregate and cumulative liability towards customer
PHPT61002PYCLH
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’ warranty of the product
for such automotive applications, use and specifications, and (b) whenever
13 July 2017
13 / 15
PHPT61002PYCLH
Nexperia
customer uses the product for automotive applications beyond Nexperia’
specifications such use shall be solely at customer’s own risk, and (c)
customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’ standard warranty and Nexperia’
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
PHPT61002PYCLH
Product data sheet
13 July 2017
14 / 15
PHPT61002PYCLH
Nexperia
16. Contents
1. General description......................................................1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 4
10. Characteristics............................................................ 6
11. Test information......................................................... 9
12. Package outline........................................................ 10
13. Soldering................................................................... 11
14. Revision history........................................................12
15. Legal information..................................................... 13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 13 July 2017
PHPT61002PYCLH
Product data sheet
13 July 2017
15 / 15
