PIMC31F
PIMC31F
    NEXPERIA(安世)
    SOT457-6
    500 mA,50 V NPN/PNP双电阻晶体管
PIMC31F 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PIMC31 500 mA, 50 V NPN/PNP double resistor-equipped transistor; R1 = 1 kΩ, R2 = 10 kΩ Rev. 01 — 24 March 2009 Product data sheet 1. Product profile 1.1 General description 500 mA, 50 V NPN/PNP double Resistor-Equipped Transistor (RET) in a small SOT457 (SC-74) Surface-Mounted Device (SMD) plastic package. NPN/NPN complement: PIMN31 1.2 Features n n n n n n 500 mA output current capability Built-in bias resistors Simplifies circuit design Reduces component count Reduces pick and place costs AEC-Q101 qualified 1.3 Applications n Digital application in automotive and industrial segments n Switching loads 1.4 Quick reference data Table 1. Symbol Quick reference data Parameter Conditions Min Typ Max Unit - - 50 V - - 500 mA kΩ Per transistor; for the PNP transistor with negative polarity VCEO collector-emitter voltage open base IO output current R1 bias resistor 1 (input) 0.7 1 1.3 R2/R1 bias resistor ratio 9 10 11 PIMC31 NXP Semiconductors 500 mA, 50 V NPN/PNP double RET; R1 = 1 kΩ, R2 = 10 kΩ 2. Pinning information Table 2. Pinning Pin Description Simplified outline 1 GND (emitter) TR1 2 input (base) TR1 3 output (collector) TR2 4 GND (emitter) TR2 5 input (base) TR2 6 output (collector) TR1 6 5 4 1 2 3 Graphic symbol 6 5 R1 4 R2 TR2 TR1 R2 1 R1 2 3 006aaa143 3. Ordering information Table 3. Ordering information Type number Package Name Description Version PIMC31 SC-74 plastic surface-mounted package (TSOP6); 6 leads SOT457 Table 4. Marking codes 4. Marking Type number Marking code PIMC31 ZH 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Per transistor; for the PNP transistor with negative polarity VCBO collector-base voltage open emitter - 50 V VCEO collector-emitter voltage open base - 50 V VEBO emitter-base voltage open collector - 5 V VI input voltage TR1 positive - +10 V negative - −5 V input voltage TR2 positive - +5 V negative - −10 V PIMC31_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 24 March 2009 2 of 13 PIMC31 NXP Semiconductors 500 mA, 50 V NPN/PNP double RET; R1 = 1 kΩ, R2 = 10 kΩ Table 5. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions IO output current Min Max Unit - 500 mA - 290 mW - 420 mW total power dissipation Tamb ≤ 25 °C [1] Ptot total power dissipation Tamb ≤ 25 °C [1] Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C Ptot Per device [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 006aab531 500 Ptot (mW) 400 300 200 100 0 −75 −25 25 75 125 175 Tamb (°C) FR4 PCB, standard footprint Fig 1. Power derating curve 6. Thermal characteristics Table 6. Symbol Thermal characteristics Parameter Conditions Min Typ Max Unit - - 431 K/W - - 105 K/W - - 298 K/W Per transistor Rth(j-a) thermal resistance from junction to ambient Rth(j-sp) thermal resistance from junction to solder point in free air [1] Per device Rth(j-a) [1] thermal resistance from junction to ambient in free air Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. PIMC31_1 Product data sheet [1] © NXP B.V. 2009. All rights reserved. Rev. 01 — 24 March 2009 3 of 13 PIMC31 NXP Semiconductors 500 mA, 50 V NPN/PNP double RET; R1 = 1 kΩ, R2 = 10 kΩ 006aaa494 103 Zth(j-a) (K/W) δ=1 0.75 0.50 0.33 102 0.20 0.10 0.05 10 0.02 0.01 0 1 10−5 10−4 10−3 10−2 10−1 1 102 10 103 tp (s) FR4 PCB, standard footprint Fig 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Per transistor; for the PNP transistor with negative polarity ICBO collector-base cut-off current VCB = 50 V; IE = 0 A - - 100 nA ICEO collector-emitter cut-off current VCE = 50 V; IB = 0 A - - 0.5 µA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 0.72 mA hFE DC current gain VCE = 5 V; IC = 50 mA 70 - - VCEsat collector-emitter saturation voltage IC = 50 mA; IB = 2.5 mA - - 0.3 VI(off) off-state input voltage VCE = 5 V; IC = 100 µA 0.3 0.6 1 V VI(on) on-state input voltage VCE = 0.3 V; IC = 20 mA 0.4 0.8 1.4 V R1 bias resistor 1 (input) 0.7 1 1.3 kΩ R2/R1 bias resistor ratio 9 10 11 Cc collector capacitance TR1 (NPN) - 7 - pF TR2 (PNP) - 11 - pF VCB = 10 V; IE = ie = 0 A; f = 1 MHz PIMC31_1 Product data sheet V © NXP B.V. 2009. All rights reserved. Rev. 01 — 24 March 2009 4 of 13 PIMC31 NXP Semiconductors 500 mA, 50 V NPN/PNP double RET; R1 = 1 kΩ, R2 = 10 kΩ 006aaa314 103 (1) (1) (2) (3) hFE 006aaa315 10−1 (2) (3) VCEsat (V) 102 10 1 10−1 1 10 102 10−2 103 10 1 VCE = 5 V IC/IB = 20 (1) Tamb = 100 °C (1) Tamb = 100 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = −40 °C (3) Tamb = −40 °C Fig 3. 102 103 IC (mA) IC (mA) TR1 (NPN): DC current gain as a function of collector current; typical values Fig 4. TR1 (NPN): Collector-emitter saturation voltage as a function of collector current; typical values 006aab055 1 VCEsat (V) (1) (2) (3) 10−1 10−2 1 10 102 103 IC (mA) IC/IB = 50 (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −40 °C Fig 5. TR1 (NPN): Collector-emitter saturation voltage as a function of collector current; typical values PIMC31_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 24 March 2009 5 of 13 PIMC31 NXP Semiconductors 500 mA, 50 V NPN/PNP double RET; R1 = 1 kΩ, R2 = 10 kΩ 006aaa316 10 006aaa317 1 (1) (2) VI(off) (V) VI(on) (V) 1 (3) (1) (2) (3) 10−1 10−1 1 10 102 103 10−1 10−1 VCE = 0.3 V (1) Tamb = −40 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C (3) Tamb = 100 °C TR1 (NPN): On-state input voltage as a function of collector current; typical values Fig 7. TR1 (NPN): Off-state input voltage as a function of collector current; typical values PIMC31_1 Product data sheet 10 VCE = 5 V (1) Tamb = −40 °C Fig 6. 1 IC (mA) IC (mA) © NXP B.V. 2009. All rights reserved. Rev. 01 — 24 March 2009 6 of 13 PIMC31 NXP Semiconductors 500 mA, 50 V NPN/PNP double RET; R1 = 1 kΩ, R2 = 10 kΩ 006aaa349 103 006aaa350 −10−1 (1) hFE (1) (2) (2) (3) VCEsat (V) (3) 102 10 1 −10−1 −1 −10 −102 −10−2 −103 −1 −10 VCE = −5 V IC/IB = 20 (1) Tamb = 100 °C (1) Tamb = 100 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = −40 °C (3) Tamb = −40 °C Fig 8. −103 −102 IC (mA) IC (mA) TR2 (PNP): DC current gain as a function of collector current; typical values Fig 9. TR2 (PNP): Collector-emitter saturation voltage as a function of collector current; typical values 006aab428 −1 VCEsat (V) (1) (2) (3) −10−1 −10−2 −1 −10 −103 −102 IC (mA) IC/IB = 50 (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −40 °C Fig 10. TR2 (PNP): Collector-emitter saturation voltage as a function of collector current; typical values PIMC31_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 24 March 2009 7 of 13 PIMC31 NXP Semiconductors 500 mA, 50 V NPN/PNP double RET; R1 = 1 kΩ, R2 = 10 kΩ 006aaa351 −10 006aaa352 −10 VI(off) (V) VI(on) (V) (1) (1) (2) −1 −10−1 −10−1 −1 (2) −1 (3) −10 −102 −103 (3) −10−1 −10−1 IC (mA) −10 IC (mA) VCE = −0.3 V VCE = −5 V (1) Tamb = −40 °C (1) Tamb = −40 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C (3) Tamb = 100 °C Fig 11. TR2 (PNP): On-state input voltage as a function of collector current; typical values Fig 12. TR2 (PNP): Off-state input voltage as a function of collector current; typical values PIMC31_1 Product data sheet −1 © NXP B.V. 2009. All rights reserved. Rev. 01 — 24 March 2009 8 of 13 PIMC31 NXP Semiconductors 500 mA, 50 V NPN/PNP double RET; R1 = 1 kΩ, R2 = 10 kΩ 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 9. Package outline 3.1 2.7 6 3.0 2.5 1.7 1.3 1.1 0.9 5 4 2 3 0.6 0.2 pin 1 index 1 0.40 0.25 0.95 0.26 0.10 1.9 Dimensions in mm 04-11-08 Fig 13. Package outline SOT457 (SC-74) 10. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PIMC31 Package SOT457 Description 3000 10000 4 mm pitch, 8 mm tape and reel; T1 [2] -115 -135 4 mm pitch, 8 mm tape and reel; T2 [3] -125 -165 [1] For further information and the availability of packing methods, see Section 14. [2] T1: normal taping [3] T2: reverse taping PIMC31_1 Product data sheet Packing quantity © NXP B.V. 2009. All rights reserved. Rev. 01 — 24 March 2009 9 of 13 PIMC31 NXP Semiconductors 500 mA, 50 V NPN/PNP double RET; R1 = 1 kΩ, R2 = 10 kΩ 11. Soldering 3.45 1.95 0.45 0.55 (6×) (6×) 0.95 solder lands solder resist 3.3 2.825 0.95 solder paste occupied area 0.7 (6×) Dimensions in mm 0.8 (6×) 2.4 sot457_fr Fig 14. Reflow soldering footprint SOT457 (SC-74) 5.3 1.5 (4×) solder lands 1.475 0.45 (2×) 5.05 solder resist occupied area 1.475 Dimensions in mm preferred transport direction during soldering 1.45 (6×) 2.85 sot457_fw Fig 15. Wave soldering footprint SOT457 (SC-74) PIMC31_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 24 March 2009 10 of 13 PIMC31 NXP Semiconductors 500 mA, 50 V NPN/PNP double RET; R1 = 1 kΩ, R2 = 10 kΩ 12. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PIMC31_1 20090324 Product data sheet - - PIMC31_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 24 March 2009 11 of 13 PIMC31 NXP Semiconductors 500 mA, 50 V NPN/PNP double RET; R1 = 1 kΩ, R2 = 10 kΩ 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 13.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PIMC31_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 24 March 2009 12 of 13 PIMC31 NXP Semiconductors 500 mA, 50 V NPN/PNP double RET; R1 = 1 kΩ, R2 = 10 kΩ 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics. . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9 Quality information . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Packing information. . . . . . . . . . . . . . . . . . . . . . 9 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 24 March 2009 Document identifier: PIMC31_1
PIMC31F 价格&库存
很抱歉,暂时无法提供与“PIMC31F”相匹配的价格&库存,您可以联系我们找货
