A3963-TP
A3963-TP
    CJT(长江连接器)
    胶壳端子 18-22AWG
A3963-TP 数据手册
A3963 SERIES 3.96~7.92mm pitch wire to board connector Specifications Current rating:10A AC,DC(AWG #16) Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:10m ΩMax. Insulation resistance:1000M ΩMin. Withstanding voltage:1500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,GWT/Glow wire Test (IEC60335-1) request,need to customize* *Contact CJT for details* Standards E326732 E326732 10.62 7.75 2.10 2.10 1.60 2.40 7.50 REF. 1.60 20.60 REF. 1.60 16.50 REF. 1.60 10.48 REF. 2.00 1.60 16.70 REF. 2.10 1.60 10.62 21.30 REF. 7.75 2.10 16.60 REF. 10.58 REF. 20.30 REF. CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-539 A3963 SERIES A3963-T 3.96mm pitch wire to board connector 3.96mm pitch Crimp Terminal Reference Informations: *Used in CJT A3963H,HA,HB,HC-XP,A5001H,HA-XP,A7921H-2P series Housing 0.25 0.85 5.30±0.25 2.45±0.25 SEC:A-A 4.00±0.25 B 3.70±0.10 B 2.00 A 10.65±0.25 A 3.90±0.25 1.20 4.00±0.25 2.40±0.25 SEC:B-B 1.00±0.10 Unit:mm Ordering information & Specifications: Wire Range Part NO. A3963-TB A3963-TP A3963-GB A3963-GP AWG#18-#22 AWG#18-#22 AWG#18-#22 AWG#18-#22 Insulation O.D. 3.00mm(max) 3.00mm(max) 3.00mm(max) 3.00mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 4,000 PCS 4,000 PCS 4,000 PCS 4,000 PCS Optional Gold plating available but MOQ requested A3963-T-H 3.96mm pitch Crimp Terminal Reference Informations: *Used in CJT A3963H,HA,HB,HC-XP,A5001H,HA-XP,A7921H-2P series Housing 0.25 2.00 SEC:A-A 2.85±0.25 0.85 5.30±0.25 4.00 B 3.70±0.10 B 9.50±0.25 A 10.65±0.25 A 2.00 1.35 4.15±0.25 4.25±0.25 2.90±0.25 SEC:B-B 1.20±0.10 3.00±0.10 Unit:mm Ordering information & Specifications: Part NO. A3963-TB-H A3963-TP-H A3963-GB-H A3963-GP-H Wire Range AWG#16-#20 AWG#16-#20 AWG#16-#20 AWG#16-#20 Insulation O.D. 3.40mm(max) 3.40mm(max) 3.40mm(max) 3.40mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 4,000 PCS 4,000 PCS 4,000 PCS 4,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-540 A3963 SERIES A3963M-T 3.96mm pitch wire to board connector 3.96mm pitch Crimp Terminal Reference Informations: *Used in CJT A3963HM-XP series Housing 0.25 A 4.90±0.20 2.30±0.25 14.00±0.20 2.90±0.10 SEC: B-B 1.14±0.10 Unit:mm Ordering information & Specifications: Wire Range Part NO. A3963M-TB A3963M-TP A3963M-GB A3963M-GP AWG#18-#22 AWG#18-#22 AWG#18-#22 AWG#18-#22 2.30±0.25 B 20.70±0.25 B SEC: A-A 2.00 A 4.00±0.25 1.20 5.00±0.25 Insulation O.D. 3.00mm(max) 3.00mm(max) 3.00mm(max) 3.00mm(max) Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 4,000 PCS 4,000 PCS 4,000 PCS 4,000 PCS Optional Gold plating available but MOQ requested A3963H-XP 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A3963-T(-H) series Terminal *Mates with CJT A3963WV,WR-XP(-A),A3963WVD,WRD-XP(-A), A3963WVD-F-XP(-A),A3963WVD-F-XP-H(-A), A3963WVD-S,WRD-S-XP(-A),A3963WRH-XP(-A),A7921WR-F-2P Wafer or CJT A3963HM,HMA-XP Housing *Color:White 3.96±0.10 A±0.20 5.76±0.25 Circuit 1 Ordering Information: A3963H-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (Blank):White BK:Black RD:Red BL:Blue GN:Green OR:Orange YL:Yellow PK:Pink GY:Gray B±0.25 13.40±0.25 7.30±0.25 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 3.96 8.02 7.92 11.98 11.88 15.94 15.84 19.90 19.80 23.86 23.76 27.82 27.72 31.78 31.68 35.74 35.64 39.70 39.60 43.66 43.56 47.62 47.52 51.58 51.48 55.54 55.44 59.50 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-541 A3963 SERIES A3963HA-XP 3.96mm pitch wire to board connector 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A3963-T(-H) series Terminal *Mates with CJT A3963WV,WR-XP(-A),A3963WVD,WRD-XP(-A), A3963WVD-F-XP(-A),A3963WVD-F-XP-H(-A), A3963WVD-S,WRD-S-XP(-A),A3963WRH-XP(-A) series Wafer *Color:White 5.76±0.25 Ordering Information: A3963HA-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (Blank):White BK:Black RD:Red BL:Blue GN:Green Circuit 1 OR:Orange YL:Yellow PK:Pink GY:Gray 3.96±0.10 A±0.25 B±0.25 Ordering Information & Dimensions: PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 13.40±0.25 7.73±0.25 Dimensions A B 3.96 8.02 7.92 11.98 11.88 15.94 15.84 19.90 19.80 23.86 23.76 27.82 31.78 27.72 31.68 35.74 35.64 39.70 39.60 43.66 43.56 47.62 47.52 51.58 55.54 51.48 55.44 59.50 Unit: mm A3963HB-XP 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A3963-T(-H) series Terminal *Mates with CJT A3963WVB,WRB-XP(-A) series Wafer *Color:White 3.96±0.10 A±0.20 5.85±0.25 Circuit 1 Ordering Information: A3963HB-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C Ordering Information & Dimensions: PART NO. 6.75±0.25 13.50±0.25 14.80±0.20 B±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 3.96 8.10 7.92 12.06 11.88 16.02 15.84 19.98 19.80 23.94 23.76 27.90 27.72 31.86 31.68 35.82 35.64 39.78 39.60 43.74 43.56 47.70 47.52 51.66 51.48 55.62 55.44 59.58 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-542 A3963 SERIES A3963HC-XP 3.96mm pitch wire to board connector 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A3963-T(-H) series Terminal *Mates with CJT A3963S-XP series Interface Seal, A3963WV,WR-XP(-A),A3963WRH-XP(-A) series Wafer *Color:White Circuit 1 Ordering Information: A3963HC-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.96±0.10 Ordering Information & Dimensions: A±0.20 7.70±0.20 PART NO. 1.05 13.50±0.25 7.25±0.20 10.00±0.20 B±0.25 C±0.25 9.50±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P A 3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 Dimensions B 9.63 13.59 17.55 21.51 25.47 29.43 33.39 37.35 41.31 45.27 49.23 53.19 57.15 61.11 C ---------------19.80 19.80 19.80 19.80 27.72 27.72 27.72 27.72 27.72 Unit: mm A3963S-XP 3.96mm pitch Interface Seal Reference Informations: *Material:Insulator:Nylon 66,UL94V-0 *Mates with CJT A3963HC-XP series Housing *Color:Red Ordering Information: A3963S-XP - *** 1 2 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.96±0.10 A±0.20 Ordering Information & Dimensions: 8.20±0.25 C±0.20 B±0.25 3.40±0.20 2.40 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P A ------3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 Dimensions B 9.58 13.54 17.50 21.46 25.42 29.38 33.34 37.30 41.26 45.22 49.18 53.14 57.10 61.06 C ---------------19.80 19.80 19.80 19.80 27.72 27.72 27.72 27.72 27.72 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-543 A3963 SERIES A3963HM(A)-XP 3.96mm pitch Housing Ordering Information: A3963HM(A)-XP - ** - ** 1 2 3 1.Part No. 2.Color : (Blank):White RD:Red YL:Yellow BL:Blue BK:Black GN:Green 3.Material: (Blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C Reference Informations: *Material:Nylon 66,UL94V-0 *Suitable CJT A3963M-T series Terminal *Mates with CJT A3963H-XP series Housing *Color:White 3.96±0.10 3.96mm pitch wire to board connector Circuit 1 A±0.20 B±0.25 7.90±0.25 Ordering Information & Dimensions: 25.20±0.25 12.60±0.20 PART NO. 0.60 A3963HMA-XP 5.70±0.20 A3963WV(-F1)-XP 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 3.96 10.64 7.92 14.60 11.88 18.56 15.84 22.52 19.80 26.48 23.76 30.44 34.40 27.72 31.68 38.36 35.64 42.32 39.60 46.28 43.56 50.24 47.52 54.20 51.48 58.16 55.44 62.12 Unit: mm 3.96mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3963H,HA,HC-XP series Housing *Color:White +0.10 Ø1.65-0.00 3.18±0.05 2P 3.96±0.05 Ordering Information: A3963WV(-F1)-XP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (Blank):White BK:Black RD:Red BL:Blue GN:Green OR:Orange YL:Yellow PK:Pink GY:Gray 4.Finish: (blank):Tin over Nickel G:Gold over Nickel A3963WV-F1-XP 2P 3.96±0.10 1.98±0.05 Ø1.68~Ø1.57 A±0.25 Ordering Information & Dimensions: P.C.B LAYOUT PART NO. Ø1.73±0.05 PIN 1.14 SQ Circuit 1 1.98±0.20 9.50±0.25 3.70±0.20 14.60±0.25 2.54±0.10 4.80±0.20 3.20±0.20 B±0.25 A3963WV-F1-XP 3.18±0.10 8.15±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 27.72 31.68 31.68 35.64 35.64 39.60 39.60 43.56 43.56 47.52 47.52 51.48 51.48 55.44 55.44 59.40 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-544 A3963 SERIES A3963WR-XP 3.96mm pitch wire to board connector 3.96mm pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3963H,HA,HC-XP series Housing *Color:White Ordering Information: A3963WR-XP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (Blank):White BK:Black RD:Red BL:Blue GN:Green OR:Orange YL:Yellow PK:Pink GY:Gray 4.Finish: (blank):Tin over Nickel G:Gold over Nickel 3.96±0.05 +0.10 Ø1.65-0.00 P.C.B LAYOUT 3.96±0.10 Ordering Information & Dimensions: A±0.25 PART NO. 4.80±0.20 4.00±0.20 14.90±0.25 3.20±0.20 PIN 1.14 SQ 9.50±0.20 3.70±0.20 B±0.25 Circuit 1 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Unit: mm A3963WVB-XP 3.96mm pitch 180° Wafer 7.50±0.25 6.60±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3963HB-XP series Housing *Color:White Ordering Information: A3963WVB-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 3.96±0.05 3.96±0.10 +0.10 Ø1.56-0.00 A±0.20 Ordering Information & Dimensions: P.C.B LAYOUT PART NO. B±0.25 PIN 1.14 SQ 8.90±0.20 3.60±0.20 14.70±0.25 3.20±0.20 4.50±0.10 Circuit 1 Dimensions A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 31.68 27.72 31.68 35.64 35.64 39.60 39.60 43.56 43.56 47.52 47.52 51.48 55.44 51.48 55.44 59.40 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 3.96 11.92 7.92 15.88 11.88 19.84 15.84 23.80 19.80 27.76 23.76 31.72 27.72 35.68 31.68 39.64 35.64 43.60 39.60 47.56 43.56 51.52 47.52 55.48 51.48 59.44 55.44 63.40 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-545 A3963 SERIES A3963WRB-XP 3.96mm pitch wire to board connector 3.96mm pitch 90° Wafer Ordering Information: A3963WRB-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 7.50±0.25 6.60±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3963HB-XP series Housing *Color:Beige 3.96±0.05 +0.10 Ø1.56-0.00 3.96±0.10 A±0.20 Ordering Information & Dimensions: P.C.B LAYOUT PART NO. B±0.25 8.90±0.20 3.60±0.20 14.70±0.25 3.20±0.20 Circuit 1 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 4.50±0.10 4.00±0.20 PIN 1.14 SQ Dimensions A B 3.96 11.92 7.92 15.88 11.88 19.84 15.84 23.80 19.80 27.76 23.76 31.72 35.68 27.72 31.68 39.64 35.64 43.60 39.60 47.56 43.56 51.52 47.52 55.48 51.48 59.44 55.44 63.40 Unit: mm 3.96mm pitch 180° Wafer Ordering Information: A3963WVD-F-XP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (blank):PBT+30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750°C 3.Color: (Blank):White BK:Black RD:Red BL:Blue GN:Green OR:Orange YL:Yellow PK:Pink GY:Gray 4.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:PBT+30%GF,UL94V-0 *Mates with CJT A3963H,HA-XP series Housing *Color:White A±0.20 3.96±0.10 8.10±0.20 3.96±0.10 3.40±0.05 A3963WVD-F-XP A±0.20 3.96±0.05 +0.10 Ø1.650 +0.10 1.500 P.C.B LAYOUT +0.10 Ø1.400 Ordering Information & Dimensions: Circuit 1 Pin 1.14 SQ 2~3P Ø1.14 3.70±0.20 ∅1.14 PART NO. 9.70±0.20 11.00±0.20 B±0.25 1.50 B±0.25 3.40±0.20 5.37±0.20 4~15P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 3.96 9.80 7.92 13.76 11.88 17.72 15.84 21.68 19.80 25.64 23.76 29.60 27.72 33.56 31.68 37.52 35.64 41.48 39.60 45.44 43.56 49.40 47.52 53.36 51.48 57.32 55.44 61.28 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-546 A3963 SERIES A3963WVD-F1-XP 3.96mm pitch wire to board connector 3.96mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A3963H,HA-XP series Housing *Color:White A±0.20 Circuit 1 +0.10 Ø1.65-0.00 3.20 1.98±0.05 2P 3.20 2P Ø1.68~Ø1.57 B±0.25 7.91±0.20 12.00±0.25 3.62±0.30 7.78±0.25 6.15±0.20 2.54±0.10 Ø1.73±0.05 P.C.B LAYOUT Ordering Information & Dimensions: PART NO. Pin 1.14 SQ 3.96±0.05 3.18±0.05 3.96±0.10 5.82±0.20 3P~12P 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P Dimensions A B 3.96 11.17 7.92 15.13 11.88 19.09 15.84 23.05 19.80 27.01 23.76 30.97 27.72 34.93 31.68 38.89 35.64 42.85 39.60 46.81 43.56 50.77 Unit: mm A3963WVD-FT-XP 3.96mm pitch 180° Wafer Ordering Information: A3963WVD-FT-XP - ** 1 2 1.Part No. 2.Color: (blank):White BK:Black Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A3963H,HA-XP series Housing *Color:White A±0.20 3.96±0.10 Circuit 1 1.08 3.96±0.10 3.40 Ø1.78±0.05 3.20 Ø1.81±0.05 P.C.B LAYOUT 3.20 B±0.25 Ordering Information & Dimensions: 7.91±0.20 Pin 1.14 SQ Ø1.15 1.08 3.40 5.82±0.20 12.00±0.25 3.62±0.30 6.15±0.20 7.78±0.25 1.50±0.15 PART NO. 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P Dimensions A B 3.96 11.17 7.92 15.13 11.88 19.09 15.84 23.05 19.80 27.01 23.76 30.97 34.93 27.72 31.68 38.89 35.64 42.85 39.60 46.81 43.56 50.77 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-547 A3963 SERIES A3963WRD-XP 3.96mm pitch wire to board connector 3.96mm pitch 90° Wafer Ordering Information: A3963WRD-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):PBT+30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:PBT+30%GF,UL94V-0 *Mates with CJT A3963H,HA-XP series Housing *Color:White A±0.20 3.96±0.10 3.96±0.10 3.96±0.05 Circuit 1 Circuit 1 +1.00 Ø1.65-0.00 P.C.B LAYOUT 8.10±0.20 Ordering Information & Dimensions: PART NO. 9.70±0.20 B±0.25 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 4.00±0.20 11.00±0.20 B±0.25 Pin 1.14 SQ 3.70±0.20 2~3P 4~15P Dimensions A B 3.96 9.80 7.92 13.76 11.88 17.72 15.84 21.68 19.80 25.64 23.76 29.60 33.56 27.72 31.68 37.52 35.64 41.48 39.60 45.44 43.56 49.40 47.52 53.36 51.48 57.32 55.44 61.28 Unit: mm A3963WRD-XP-A 3.96mm pitch 90° Wafer Ordering Information: A3963WRD-XP-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank):PBT+30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:PBT+30%GF,UL94V-0 *Mates with CJT A3963H,HA-XP series Housing *Color:White Circuit 1 8.95±0.20 Circuit 1 7.92±0.05 +0.10 Ø1.65-0.00 7.92±0.10 7.92±0.10 A±0.20 B±0.25 Ø1.14 3P Pin 1.14 SQ Ø1.14 4.00±0.20 11.00±0.20 9.70±0.20 1.50 B±0.25 P.C.B LAYOUT 3.70±0.20 5~15P Ordering Information & Dimensions: PART NO. 3P 5P 7P 9P 11P 13P 15P Dimensions A B 7.92 13.76 15.84 21.68 23.76 29.60 31.68 37.52 39.60 45.44 47.52 53.36 55.44 61.28 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-548 A3963 SERIES A3963WVD-S-XP 3.96mm pitch wire to board connector 3.96mm pitch 180° Wafer - SMT TYPE Ordering Information: A3963WVD-S-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 9T,UL94V-0 GWT:Nylon 9T,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel Circuit 1 G:Gold over Nickel 1.50±0.05 1.00 Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:Nylon 9T,UL94V-0 *Mates with CJT A3963H,HA-XP series Housing *Color:Ivory 3.96±0.10 Pin 1.14 SQ 6.00 3.00±0.05 2.50±0.05 2.70±0.05 3.96±0.05 A±0.20 P.C.B LAYOUT B±0.25 Ordering Information & Dimensions: 9.25±0.25 1.04 Dimensions A B 3.96 11.88 7.92 15.84 11.88 19.80 15.84 23.76 19.80 27.72 23.76 31.68 35.64 27.72 31.68 39.60 35.64 43.56 11.60±0.25 PART NO. 2.00±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P Unit: mm A3963WRD-S-XP 3.96mm pitch 90° Wafer - SMT TYPE 2.50±0.05 4.00±0.05 Circuit 1 Ordering Information: A3963WRD-S-XP - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 9T,UL94V-0 GWT:Nylon 9T,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 3.96±0.10 A±0.20 3.00±0.05 3.96±0.10 6.00±0.05 5.00±0.05 Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:Nylon 9T,UL94V-0 *Mates with CJT A3963H,HA-XP series Housing *Color:Ivory B±0.25 1.00±0.05 P.C.B LAYOUT 9.55±0.25 1.04 Ordering Information & Dimensions: 2.00±0.20 13.00±0.25 PART NO. Pin 1.14 SQ 2P 3P 4P 5P 6P 7P 8P 9P 10P Dimensions A B 3.96 11.88 7.92 15.84 11.88 19.80 15.84 23.76 19.80 27.72 23.76 31.68 27.72 35.64 31.68 39.60 35.64 43.56 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-549 A3963 SERIES A3963WV-XP-A 7.92mm pitch wire to board connector 7.92mm pitch 180° Wafer Ordering Information: A3963WV-XP-A - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (Blank):White BK:Black RD:Red BL:Blue GN:Green OR:Orange YL:Yellow PK:Pink GY:Gray 4.Finish: (blank):Tin over Nickel G:Gold over Nickel 7.92±0.05 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3963H,HA,HC-XP,A7921H-2P series Housing *Color:White 3.96±0.10 7.92±0.10 A±0.25 +0.10 Ø1.65-0.00 B±0.25 9.50±0.25 P.C.B LAYOUT 3.70±0.20 14.60±0.25 3.20±0.20 4.80±0.20 8.15±0.20 Circuit 1 PIN 1.14 SQ Ordering Information & Dimensions: PART NO. 3P 5P 7P 9P 11P 13P 15P Dimensions A B 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 Unit: mm A3963WR-XP-A 7.92mm pitch 90° Wafer Ordering Information: A3963WR-XP-A - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (Blank):White BK:Black RD:Red BL:Blue GN:Green OR:Orange YL:Yellow PK:Pink GY:Gray 4.Finish: (blank):Tin over Nickel G:Gold over Nickel 7.92±0.05 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3963H,HA,HC-XP,A7921H-2P series Housing *Color:White 3.96±0.10 7.92±0.10 +0.10 Ø1.65-0.00 A±0.25 4.80±0.20 P.C.B LAYOUT Circuit 1 PIN 1.14 SQ 4.00±0.20 9.50±0.20 Ordering Information & Dimensions: 14.90±0.25 3.20±0.20 B±0.25 3.70±0.20 PART NO. 3P 5P 7P 9P 11P 13P 15P Dimensions A B 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-550 A3963 SERIES A3963WVB-XP-A 7.92mm pitch wire to board connector 7.92mm pitch 180° Wafer Ordering Information: A3963WVB-XP-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 6.60±0.20 7.50±0.25 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3963HB-XP series Housing *Color:White 7.92±0.05 3.96±0.10 7.92±0.10 +0.10 Ø1.56-0.00 A±0.20 P.C.B LAYOUT B±0.25 8.90±0.20 3.60±0.20 14.70±0.25 3.20±0.20 4.50±0.10 Circuit 1 PIN 1.14 SQ Ordering Information & Dimensions: PART NO. 3P 5P 7P 9P 11P 13P 15P Dimensions A B 7.92 15.88 15.84 23.80 23.76 31.72 31.68 39.64 39.60 47.56 47.52 55.48 55.44 63.40 Unit: mm A3963WRB-XP-A 7.92mm pitch 90° Wafer Ordering Information: A3963WRB-XP-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 7.50±0.25 6.60±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3963HB-XP series Housing *Color:White 7.92±0.05 3.96±0.10 +0.10 Ø1.56-0.00 7.92±0.10 P.C.B LAYOUT A±0.20 B±0.25 3.60±0.20 8.90±0.20 Ordering Information & Dimensions: 14.70±0.25 3.20±0.20 4.50±0.10 4.00±0.20 Circuit 1 PIN 1.14 SQ PART NO. 3P 5P 7P 9P 11P 13P 15P Dimensions A B 7.92 15.88 15.84 23.80 23.76 31.72 31.68 39.64 39.60 47.56 47.52 55.48 55.44 63.40 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-551 A3963 SERIES A3963WVD-F-XP-H A±0.20 Circuit 1 8.10±0.20 3.96±0.10 Ordering Information: A3963WVD-F-XP-H - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (blank):PBT+30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750°C 3.Color: (Blank):White BK:Black RD:Red BL:Blue GN:Green OR:Orange YL:Yellow PK:Pink GY:Gray 4.Finish: (blank):Tin over Nickel G:Gold over Nickel 3.40±0.05 3.96mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:PBT+30%GF,UL94V-0 *Mates with CJT A3963H,HA-XP series Housing *Color:White 3.96±0.10 7.92mm pitch wire to board connector A±0.20 3.96±0.05 +0.10 Ø1.650 +0.10 +0.10 1.500 Ø1.400 P.C.B LAYOUT B±0.25 Ordering Information & Dimensions: B±0.25 9.70±0.20 Dimensions A B 3.96 9.80 7.92 13.76 11.88 17.72 15.84 21.68 19.80 25.64 23.76 29.60 33.56 27.72 31.68 37.52 35.64 41.48 39.60 45.44 43.56 49.40 47.52 53.36 51.48 57.32 55.44 61.28 1.50 Ø1.14 Pin 1.14 SQ 2~3P 4~15P Ø1.14 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P 3.70±0.20 15.80±0.20 PART NO. 3.40±0.20 5.37±0.20 Unit: mm A3963WVD-F-XP-H-A Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:PBT+30%GF,UL94V-0 *Mates with CJT A3963H,HA-XP series Housing *Color:White A±0.20 7.92±0.10 7.92±0.10 3.96±0.10 Circuit 1 8.10±0.20 3.96±0.10 Ordering Information: A3963WVD-F-XP-H-A - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (blank):PBT+30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750°C 3.Color: (Blank):White BK:Black RD:Red BL:Blue GN:Green OR:Orange YL:Yellow PK:Pink GY:Gray 4.Finish: (blank):Tin over Nickel G:Gold over Nickel 3.40±0.05 7.92mm pitch 180° Wafer A±0.20 7.92±0.05 B±0.25 B±0.25 9.70±0.20 +0.10 +0.10 Ø1.650 Ø1.40-0 +0.10 1.500 Ø1.14 3P Pin 1.14 SQ Ø1.14 Ordering Information & Dimensions: 3.70±0.20 1.50 15.80±0.20 P.C.B LAYOUT 3.40±0.20 5.37±0.20 5~15P PART NO. 3P 5P 7P 9P 11P 13P 15P Dimensions A B 7.92 13.76 15.84 21.68 23.76 29.60 31.68 37.52 39.60 45.44 47.52 53.36 55.44 61.28 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-552 A3963 SERIES A3963WVD-F-XP-A 7.92mm pitch 180° Wafer A±0.20 7.92±0.10 3.96±0.10 8.10±0.20 3.96±0.10 Ordering Information: A3963WVD-F-XP-A - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (blank):PBT+30%GF,UL94V-0 GWT:PBT,UL94V-0,GWT 750°C 3.Color: (Blank):White BK:Black RD:Red BL:Blue GN:Green OR:Orange YL:Yellow PK:Pink GY:Gray 4.Finish: (blank):Tin over Nickel G:Gold over Nickel A±0.20 3.40±0.05 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:PBT+30%GF,UL94V-0 *Mates with CJT A3963H,HA-XP series Housing *Color:White 7.92±0.10 7.92mm pitch wire to board connector 7.92±0.05 +0.10 Ø1.650 Circuit 1 +0.10 +0.10 1.500 B±0.25 B±0.25 Ø1.14 3.70±0.20 11.00±0.20 Ordering Information & Dimensions: A3963WVD-S-XP-A PART NO. 3P 5P 7P 9P 11P 13P 15P 3.40±0.20 5.37±0.20 5~15P 3P P.C.B LAYOUT 9.70±0.20 1.50 Pin 1.14 SQ ∅1.14 Ø1.40-0 Dimensions A B 7.92 13.76 15.84 21.68 23.76 29.60 31.68 37.52 39.60 45.44 47.52 53.36 55.44 61.28 Unit: mm 7.92mm pitch 180° Wafer - SMT TYPE Ordering Information: A3963WVD-S-XP-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 9T,UL94V-0 GWT:Nylon 9T,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:Nylon 9T,UL94V-0 *Mates with CJT A3963H,HA-XP series Housing *Color:Ivory Circuit 1 1.00 1.50±0.05 7.92±0.10 6.00 3.00±0.05 2.50±0.05 Pin 1.14 SQ 2.70±0.05 A±0.20 7.92±0.05 P.C.B LAYOUT B±0.25 9.25±0.25 11.60±0.25 1.04 2.00±0.20 Ordering Information & Dimensions: PART NO. 3P 5P 7P 9P Dimensions A B 7.92 15.84 15.84 23.76 23.76 31.68 31.68 39.60 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-553 A3963 SERIES A3963WRD-S-XP-A 3.96mm pitch wire to board connector 7.92mm pitch 90° Wafer - SMT TYPE Reference Informations: *Material:Pin:Phosphor Bronze/Tin over Nickel Insulator:Nylon 9T,UL94V-0 *Mates with CJT A3963H,HA-XP series Housing *Color:Ivory 3.00±0.05 7.92±0.10 5.00±0.05 4.00±0.05 2.50±0.05 6.00±0.05 Circuit 1 1.00±0.05 P.C.B LAYOUT 7.92±0.10 Ordering Information: A3963WRD-S-XP-A - *** - ** 1 2 3 1.Part No. 2.Material: (blank):Nylon 9T,UL94V-0 GWT:Nylon 9T,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel A±0.20 B±0.25 9.55±0.25 2.00±0.20 13.00±0.25 1.04 Ordering Information & Dimensions: PART NO. 3P 5P 7P 9P Pin 1.14 SQ Dimensions A B 7.92 15.84 15.84 23.76 23.76 31.68 31.68 39.60 Unit: mm A3963WRH-XP 3.96mm pitch 90° Wafer Ordering Information: A3963WRH-XP - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (Blank):White BK:Black RD:Red BL:Blue GN:Green YL:Yellow 4.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3963H,HA,HC-XP series Housing *Color:White 8.60±0.20 6.80±0.20 3.96±0.05 +0.10 Ø1.65-0.00 P.C.B LAYOUT 3.96±0.10 Ordering Information & Dimensions: A±0.20 PART NO. 2.00 Circuit 1 Pin 1.14 SQ 4.50 9.40±0.25 7.70±0.20 13.40±0.25 7.80±0.20 3.00±0.20 B±0.30 3.60±0.20 2P 3P 4P 5P 6P 7P 8P 9P 10P 11P 12P 13P 14P 15P Dimensions A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 27.72 31.68 31.68 35.64 35.64 39.60 39.60 43.56 43.56 47.52 47.52 51.48 51.48 55.44 55.44 59.40 CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-554 A3963 SERIES 7.92mm pitch wire to board connector Unit: mm A3963WRH-XP-A 7.92mm pitch 90° Wafer Ordering Information: A3963WRH-XP-A - *** - ** - ** 1 2 3 4 1.Part No. 2.Material: (blank):Nylon 66,UL94V-0 GWT:Nylon 66,UL94V-0,GWT 750°C 3.Color: (Blank):White BK:Black RD:Red BL:Blue GN:Green YL:Yellow 4.Finish: (blank):Tin over Nickel G:Gold over Nickel Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3963H,HA,HC-XP series Housing *Color:White 8.60±0.20 6.80±0.20 7.92±0.05 +0.10 Ø1.65-0.00 P.C.B LAYOUT A±0.20 2.00 Circuit 1 Ordering Information & Dimensions: 9.40±0.25 7.70±0.20 3P 5P 7P 9P 11P 13P 15P 3.60±0.20 Pin 1.14 SQ Dimensions A B 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 PART NO. 4.50 13.40±0.25 7.80±0.20 3.00±0.20 B±0.30 Unit: mm 7.92mm pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:PBT,UL94V-0 *Mates with CJT A3963H-3P Housing *Color:White 9.50±0.25 4.40±0.25 7.92±0.10 9.50±0.25 7.80±0.20 3.70±0.20 2.00±0.20 CJT(S) A-1 Circuit 1 PIN 1.14 SQ Ordering Information: A7921WR-F-2P - *** - ** 1 2 3 1.Part No. 2.Material: (blank):PBT,UL94V-0 GWT:PBT,UL94V-0,GWT 750°C 3.Finish: (blank):Tin over Nickel G:Gold over Nickel 2.40±0.20 6.30±0.20 11.75±0.25 2.00±0.05 A7921WR-F-2P 6.30±0.05 3.96±0.05 2.80±0.05 +0.10 Ø1.65-0.00 7.92±0.05 P.C.B LAYOUT Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-555
A3963-TP
物料型号: - A3963系列:3.96~7.92mm间距的线对板连接器。
器件简介: - 该系列连接器适用于多种电气连接,具有不同的电流和电压等级,以及不同的温度范围。
引脚分配: - 提供了详细的组装布局和引脚参考信息,例如A3963-T和A3963-T-H系列的引脚尺寸和公差。
参数特性: - 电流等级:10A AC/DC(AWG #16)。 - 电压等级:250V AC/DC。 - 温度范围:-40°C~+105°C。 - 接触电阻:最大10mΩ。 - 绝缘电阻:最小1000MΩ。 - 耐电压:1500V AC/分钟。
功能详解: - 连接器符合RoHS和REACH标准,可提供无卤/无卤素、GWT/Glow Wire Test(IEC60335-1)的定制服务。
应用信息: - 适用于多种电气设备和应用场景,具体应用需根据连接器的规格和性能确定。
封装信息: - 提供了不同系列连接器的封装尺寸和颜色选项,例如A3963H-XP、A3963HA-XP、A3963HB-XP等。
A3963-TP 价格&库存
很抱歉,暂时无法提供与“A3963-TP”相匹配的价格&库存,您可以联系我们找货
A3963-TP
    • 100+0.10951
    • 500+0.10318
    • 1000+0.09368
    • 5000+0.08102
    • 10000+0.07343
    库存:57334
