PSMN3R7-100BSEJ
PSMN3R7-100BSEJ
    NEXPERIA(安世)
    SOT404
    MOS管 N-channel Id=120A VDS=100V SOT404
PSMN3R7-100BSEJ 数据手册
PSMN3R7-100BSE N-channel 100 V, 3.95 mΩ, standard level MOSFET in D2PAK 3 September 2018 Product data sheet 1. General description Standard level gate drive N-channel enhancement mode MOSFET in a D2PAK package qualified to 175 °C. Part of Nexperia's "NextPower Live" portfolio, the PSMN3R7-100BSE delivers very low RDSon and a very strong linear-mode (SOA) performance. PSMN3R7-100BSE complements the latest "hot-swap" controllers - robust enough to withstand 2 substantial inrush currents during turn on, low RDSon to minimize I R losses and deliver optimum efficiency when turned fully ON. 2. Features and benefits • • Fully optimized Safe Operating Area (SOA) for superior linear mode operation 2 Low RDSon for low I R conduction losses 3. Applications • • • • • Hot swap Load switch Soft start E-fuse Telecommunication systems based on a 48 V backplane/supply rail 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - - 100 V ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 - - 120 A IDM peak drain current pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3 - - 780 A Ptot total power dissipation Tmb = 25 °C; Fig. 1 - - 405 W VGS = 10 V; ID = 25 A; Tj = 25 °C; Fig. 12 - 3.36 3.95 mΩ ID = 25 A; VDS = 50 V; VGS = 10 V; Fig. 14; Fig. 15 - 45.2 77 nC - 176 246 nC ID = 120 A; Vsup ≤ 100 V; RGS = 50 Ω; VGS = 10 V; Tj(init) = 25 °C; unclamped; Fig. 4 - - 542 mJ [1] Static characteristics RDSon drain-source on-state resistance Dynamic characteristics QGD gate-drain charge QG(tot) total gate charge Avalanche ruggedness EDS(AL)S [1] non-repetitive drainsource avalanche energy Continuous current is limited by package PSMN3R7-100BSE Nexperia N-channel 100 V, 3.95 mΩ, standard level MOSFET in D2PAK 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 D drain[1] 3 S source mb D mounting base; connected to drain Graphic symbol mb D G mbb076 2 1 S 3 D2PAK (SOT404) [1] It is not possible to make connection to pin 2. 6. Ordering information Table 3. Ordering information Type number Package PSMN3R7-100BSE Name Description Version D2PAK plastic, single-ended surface-mounted package (D2PAK); 3 terminals (one lead cropped); 2.54 mm pitch; 11 mm x 10 mm x 4.3 mm body SOT404 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - 100 V VDGR drain-gate voltage 25 °C ≤ Tj ≤ 175 °C; RGS = 20 kΩ - 100 V VGS gate-source voltage -20 20 V Ptot total power dissipation Tmb = 25 °C; Fig. 1 - 405 W ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 [1] - 120 A VGS = 10 V; Tmb = 100 °C; Fig. 2 [1] - 120 A - 780 A IDM peak drain current pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3 Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C Source-drain diode IS source current Tmb = 25 °C - 120 A ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 780 A - 542 mJ Avalanche ruggedness EDS(AL)S [1] non-repetitive drainID = 120 A; Vsup ≤ 100 V; RGS = 50 Ω; source avalanche energy VGS = 10 V; Tj(init) = 25 °C; unclamped; Fig. 4 Continuous current is limited by package PSMN3R7-100BSE Product data sheet All information provided in this document is subject to legal disclaimers. 3 September 2018 © Nexperia B.V. 2018. All rights reserved 2 / 12 PSMN3R7-100BSE Nexperia N-channel 100 V, 3.95 mΩ, standard level MOSFET in D2PAK 03aa16 120 aaa-028866 200 ID (A) Pder (%) 150 80 (1) 100 40 50 0 0 50 100 150 Tmb (°C) 0 200 0 25 50 75 100 125 150 175 Tmb (°C) 200 VGS ≥ 10 V (1) Capped at 120A due to package Fig. 1. ID (A) Normalized total power dissipation as a function of mounting base temperature Fig. 2. Continuous drain current as a function of mounting base temperature aaa-028222 103 Limit RDSon = VDS / ID tp = 10 µs 102 100 µs DC 1 ms 10 10 ms 100 ms 1 10-1 10-1 1 10 102 VDS (V) 103 Tmb = 25 °C; IDM is a single pulse Fig. 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage PSMN3R7-100BSE Product data sheet All information provided in this document is subject to legal disclaimers. 3 September 2018 © Nexperia B.V. 2018. All rights reserved 3 / 12 PSMN3R7-100BSE Nexperia N-channel 100 V, 3.95 mΩ, standard level MOSFET in D2PAK IAL (A) aaa-028867 103 102 (1) (2) 10 1 10-3 10-2 10-1 1 tAL (ms) 10 (1) Tj (init) = 25 °C; (2) Tj (init) = 100 °C Fig. 4. Avalanche rating; avalanche current as a function of avalanche time 8. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Min Typ Max Unit Rth(j-mb) thermal resistance from Fig. 5 junction to mounting base Conditions - 0.3 0.37 K/W Rth(j-a) thermal resistance from junction to ambient - 50 - K/W aaa-028868 1 Zth(j-mb) (K/W) δ = 0.5 10-1 0.2 0.1 0.05 P 10-2 0.02 δ= tp T single shot t tp 10-3 10-6 Fig. 5. 10-5 10-4 10-3 10-2 T 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration 9. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics PSMN3R7-100BSE Product data sheet All information provided in this document is subject to legal disclaimers. 3 September 2018 © Nexperia B.V. 2018. All rights reserved 4 / 12 PSMN3R7-100BSE Nexperia N-channel 100 V, 3.95 mΩ, standard level MOSFET in D2PAK Symbol Parameter Conditions Min Typ Max Unit V(BR)DSS drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 100 - - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 90 - - V gate-source threshold voltage ID = 1 mA; VDS=VGS; Tj = 25 °C; Fig. 10; Fig. 11 2 2.66 4 V ID = 1 mA; VDS=VGS; Tj = 175 °C; Fig. 11 1 - - V ID = 1 mA; VDS=VGS; Tj = -55 °C; Fig. 11 - - 4.6 V VDS = 100 V; VGS = 0 V; Tj = 25 °C - 0.026 2 µA VDS = 100 V; VGS = 0 V; Tj = 175 °C - - 500 µA VGS = 20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 25 A; Tj = 25 °C; Fig. 12 - 3.36 3.95 mΩ VGS = 10 V; ID = 25 A; Tj = 100 °C; Fig. 13 - - 7.3 mΩ VGS = 10 V; ID = 25 A; Tj = 175 °C; Fig. 13 - - 10.7 mΩ f = 1 MHz 0.49 0.98 1.96 Ω ID = 25 A; VDS = 50 V; VGS = 10 V; Fig. 14; Fig. 15 - 176 246 nC ID = 0 A; VDS = 0 V; VGS = 10 V - 71 99 nC ID = 25 A; VDS = 50 V; VGS = 10 V; Fig. 14; Fig. 15 - 49.5 74 nC - 30 - nC VGS(th) IDSS IGSS RDSon RG drain leakage current gate leakage current drain-source on-state resistance gate resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGS(th) pre-threshold gatesource charge QGS(th-pl) post-threshold gatesource charge - 19.7 - nC QGD gate-drain charge - 45.2 77 nC VGS(pl) gate-source plateau voltage ID = 25 A; VDS = 50 V; Fig. 14; Fig. 15 - 4.9 - V Ciss input capacitance - 11692 16370 pF Coss output capacitance VDS = 50 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; Fig. 16 - 657 887 pF Crss reverse transfer capacitance - 353 494 pF td(on) turn-on delay time - 40 60 ns tr rise time - 64 97 ns td(off) turn-off delay time - 98 147 ns tf fall time - 69 104 ns VDS = 50 V; RL = 2 Ω; VGS = 10 V; RG(ext) = 5 Ω Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; Fig. 17 - 0.79 1.2 V trr reverse recovery time - 70 91 ns Qr recovered charge IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 50 V; Fig. 18 - 195 254 nC PSMN3R7-100BSE Product data sheet All information provided in this document is subject to legal disclaimers. 3 September 2018 © Nexperia B.V. 2018. All rights reserved 5 / 12 PSMN3R7-100BSE Nexperia N-channel 100 V, 3.95 mΩ, standard level MOSFET in D2PAK aaa-028869 160 ID (A) 10 V 7V aaa-028870 30 RDSon (mΩ) 25 6.5 V 120 20 6V 80 15 VGS = 5.5 V 10 40 5V 5 4.5 V 0 Fig. 6. 3.5 V 0 1 2 3 VDS (V) 0 4 0 4 8 12 16 VGS (V) 20 Tj = 25 °C Tj = 25 °C; ID = 25 A Output characteristics; drain current as a Fig. 7. function of drain-source voltage; typical values Drain-source on-state resistance as a function of gate-source voltage; typical values aaa-028871 100 gfs (S) aaa-028872 160 ID (A) 80 120 60 80 40 40 20 0 175°C 0 20 40 60 80 ID (A) 0 100 Tj = 25 °C; VDS = 8 V Fig. 8. Product data sheet 1 2 3 4 5 6 7 VGS (V) 8 VDS = 8 V Forward transconductance as a function of drain current; typical values PSMN3R7-100BSE 0 Tj = 25°C Fig. 9. Transfer characteristics; drain current as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 3 September 2018 © Nexperia B.V. 2018. All rights reserved 6 / 12 PSMN3R7-100BSE Nexperia N-channel 100 V, 3.95 mΩ, standard level MOSFET in D2PAK aaa-028873 10-1 ID (A) VGS(th) (V) 10-2 aaa-028874 5 4 10-3 Min Typ Max 3 Max Typ 10-4 2 Min 10-5 10-6 1 0 1 2 3 4 0 -60 5 VGS (V) Tj = 25 °C; VDS = 5 V 5.5 V 30 60 90 120 150 Tj (°C) 180 Fig. 11. Gate-source threshold voltage as a function of junction temperature aaa-028875 5V 0 ID = 1 mA ; VDS = VGS Fig. 10. Sub-threshold drain current as a function of gate-source voltage 30 RDSon (mΩ) 25 -30 a 6V 003aak756 3 2.4 6.5 V 20 1.8 15 10 7V 5 8V 0 1.2 0.6 VGS = 10 V 0 20 40 60 80 100 120 140 ID (A) 0 -60 160 -30 0 30 60 90 120 150 Tj (°C) 180 Tj = 25 °C Fig. 12. Drain-source on-state resistance as a function of drain current; typical values PSMN3R7-100BSE Product data sheet Fig. 13. Normalized drain-source on-state resistance factor as a function of junction temperature All information provided in this document is subject to legal disclaimers. 3 September 2018 © Nexperia B.V. 2018. All rights reserved 7 / 12 PSMN3R7-100BSE Nexperia N-channel 100 V, 3.95 mΩ, standard level MOSFET in D2PAK VGS (V) aaa-028877 10 VDS ID 8 VGS(pl) 80 V 6 50 V VGS(th) VDS = 20 V 4 VGS QGS1 2 0 QGS2 0 40 80 120 160 QG (nC) QGS QGD QG(tot) 003aaa508 Fig. 15. Gate charge waveform definitions 200 Tj = 25 °C; ID = 25 A Fig. 14. Gate-source voltage as a function of gate charge; typical values aaa-028878 105 C (pF) aaa-028879 160 IS (A) 120 Ciss 104 80 103 Coss 40 175°C Crss 102 10-1 1 10 VDS (V) 0 102 VGS = 0 V; f = 1 MHz 0 0.2 0.4 Tj = 25°C 0.6 0.8 1 VSD (V) 1.2 VGS = 0 V Fig. 16. Input, output and reverse transfer capacitances Fig. 17. Source-drain (diode forward) current as a as a function of drain-source voltage; typical function of source-drain (diode forward) values voltage; typical values 003aal160 ID (A) trr ta tb 0 0.25 IRM IRM t (s) Fig. 18. Reverse recovery timing definition PSMN3R7-100BSE Product data sheet All information provided in this document is subject to legal disclaimers. 3 September 2018 © Nexperia B.V. 2018. All rights reserved 8 / 12 PSMN3R7-100BSE Nexperia N-channel 100 V, 3.95 mΩ, standard level MOSFET in D2PAK 10. Package outline Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped) SOT404 A A1 E mounting base D1 D HD 2 Lp 1 3 b2 c b e e Q 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A A1 b b2 c 4.5 1.40 0.85 1.45 0.64 4.1 1.27 0.60 1.05 0.46 D D1 E e 11 1.6 10.3 1.2 9.7 2.54 HD Lp Q 15.8 2.9 2.6 14.8 2.1 2.2 sot404_po Outline version References IEC JEDEC JEITA European projection Issue date 06-03-16 13-02-25 SOT404 Fig. 19. Package outline D2PAK (SOT404) PSMN3R7-100BSE Product data sheet All information provided in this document is subject to legal disclaimers. 3 September 2018 © Nexperia B.V. 2018. All rights reserved 9 / 12 PSMN3R7-100BSE Nexperia N-channel 100 V, 3.95 mΩ, standard level MOSFET in D2PAK 11. Soldering Footprint information for reflow soldering of D2PAK package SOT404 10.85 10.60 10.50 1.50 0.30 2.25 2.15 8.15 8.35 8.275 1.50 4.60 16.35 0.30 0.20 1.70 7.40 4.85 5.40 7.50 7.95 8.075 3.10 3.00 0.20 2.54 1.55 1.30 1.20 occupied area solder resist solder lands solder paste Dimensions in mm Issue date 17-05-24 17-05-26 sot404_fr Fig. 20. Reflow soldering footprint for D2PAK (SOT404) PSMN3R7-100BSE Product data sheet All information provided in this document is subject to legal disclaimers. 3 September 2018 © Nexperia B.V. 2018. All rights reserved 10 / 12 PSMN3R7-100BSE Nexperia N-channel 100 V, 3.95 mΩ, standard level MOSFET in D2PAK 12. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal PSMN3R7-100BSE Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. 3 September 2018 © Nexperia B.V. 2018. All rights reserved 11 / 12 PSMN3R7-100BSE Nexperia N-channel 100 V, 3.95 mΩ, standard level MOSFET in D2PAK Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Limiting values............................................................. 2 8. Thermal characteristics............................................... 4 9. Characteristics.............................................................. 4 10. Package outline.......................................................... 9 11. Soldering................................................................... 10 12. Legal information......................................................11 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 3 September 2018 PSMN3R7-100BSE Product data sheet All information provided in this document is subject to legal disclaimers. 3 September 2018 © Nexperia B.V. 2018. All rights reserved 12 / 12
PSMN3R7-100BSEJ 价格&库存
很抱歉,暂时无法提供与“PSMN3R7-100BSEJ”相匹配的价格&库存,您可以联系我们找货
PSMN3R7-100BSEJ
  • 1+49.239841+6.39998
  • 10+32.7230410+4.25320
  • 50+25.6544550+3.33446
  • 100+23.37772100+3.03854
库存:4796
PSMN3R7-100BSEJ
    PSMN3R7-100BSEJ
