PSMN8R5-100PSF
NextPower 100 V, 8.7 mΩ N-channel MOSFET in TO220
package
10 April 2017
Product data sheet
1. General description
NextPower 100 V standard level gate drive MOSFET. Qualified to 175 °C and recommended for
industrial & consumer applications.
2. Features and benefits
Optimised for fast switching, low spiking, high efficiency
Low QG x RDSon FOM for high efficiency switching applications
Low body diode losses (Qrr) and fast recovery (trr)
Strong avalanche energy rating (EAS)
Avalanche rated & 100% tested
Ha-free & RoHS compliant TO220 package
3. Applications
Synchronous rectification in AC-to-DC and DC-to-DC applications
Brushed & BLDC motor control
UPS & solar inverter
LED lighting
Battery protection
Full-bridge & half-bridge applications
Flyback & resonant topologies
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
25 °C ≤ Tj ≤ 175 °C
100
V
ID
drain current
VGS = 10 V; Tmb = 25 °C; Fig. 2
98
A
Ptot
total power dissipation
Tmb = 25 °C; Fig. 1
183
W
Tj
junction temperature
-55
175
°C
VGS = 10 V; ID = 25 A; Tj = 25 °C;
Fig. 10
7.5
8.7
mΩ
VGS = 10 V; ID = 25 A; Tj = 100 °C;
Fig. 11
11.2
13.5
mΩ
ID = 25 A; VDS = 50 V; VGS = 10 V;
Fig. 12; Fig. 13
8.7
nC
44.5
nC
[1]
Static characteristics
RDSon
drain-source on-state
resistance
Dynamic characteristics
QGD
gate-drain charge
QG(tot)
total gate charge
PSMN8R5-100PSF
Nexperia
NextPower 100 V, 8.7 mΩ N-channel MOSFET in TO220 package
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
281
mJ
Avalanche ruggedness
EDS(AL)S
[1]
[2]
non-repetitive drainsource avalanche
energy
ID = 34 A; Vsup ≤ 100 V; RGS = 50 Ω;
VGS = 10 V; Tj(init) = 25 °C; Fig. 4;
Unclamped
[2]
Avalanche current is limited by IAS
Protected by 100% test
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
Simplified outline
1
G
gate
2
D
drain
3
S
source
mb
D
mounting base; connected to
drain
Graphic symbol
D
mb
G
mbb076
S
1 2 3
TO-220AB (SOT78)
6. Ordering information
Table 3. Ordering information
Type number
PSMN8R5-100PSF
Package
Name
Description
Version
TO-220AB
plastic, single-ended package (heatsink mounted, 1 mounting
hole); 3 leads; 2.54 mm pitch; 15.6 mm x 10 mm x 4.4 mm body
SOT78
7. Marking
Table 4. Marking codes
Type number
Marking code
PSMN8R5-100PSF
PSMN8R5-100PSF
PSMN8R5-100PSF
Product data sheet
All information provided in this document is subject to legal disclaimers.
10 April 2017
Nexperia B.V. 2017. All rights reserved
2 / 13
PSMN8R5-100PSF
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
25 °C ≤ Tj ≤ 175 °C
100
V
VDGR
drain-gate voltage
25 °C ≤ Tj ≤ 175 °C; RGS = 20 kΩ
100
V
VGS
gate-source voltage
-20
V
Ptot
Tmb = 25 °C; Fig. 1
183
W
ID
drain current
98
A
VGS = 10 V; Tmb = 100 °C; Fig. 2
69
A
pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3
391
A
[1]
IDM
peak drain current
Tstg
storage temperature
-55
175
°C
Tj
-55
175
°C
Tsld(M)
peak soldering
temperature
260
°C
Source-drain diode
IS
source current
Tmb = 25 °C
98
A
ISM
peak source current
391
A
[2]
281
mJ
[2]
34
A
EDS(AL)S
energy
IAS
non-repetitive avalanche Vsup ≤ 100 V; VGS = 10 V; Tj(init) = 25 °C;
current
RGS = 50 Ω
[1]
[2]
Unclamped
PSMN8R5-100PSF
Product data sheet
10 April 2017
3 / 13
PSMN8R5-100PSF
Nexperia
03aa16
120
Pder
aaa-026175
100
ID
(A)
80
80
60
40
40
100
150
Tmb (°C)
50
75
100
125
150 175
Tmb (°C)
200
VGS ≥ 10 V
Fig. 2.
Fig. 1.
ID
(A)
Normalized total power dissipation as a
function of mounting base temperature
Continuous drain current as a function of
aaa-026177
103
Limit RDSon = VDS / ID
102
tp = 10 µs
DC
100 µs
10
1
10-1
1 ms
10 ms
100 ms
1
102
10
VDS (V)
103
Tmb = 25 °C; IDM is a single pulse
Fig. 3.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
PSMN8R5-100PSF
Product data sheet
10 April 2017
4 / 13
PSMN8R5-100PSF
Nexperia
IAL
(A)
aaa-026176
102
(1)
10
(2)
1
(3)
10-1
10-3
10-2
10-1
1
tAL (ms)
10
(1) Tj (init) = 25 °C; (2) Tj (init) = 150 °C; (3) Repetitive Avalanche
Fig. 4.
Avalanche rating; avalanche current as a function of avalanche time
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance
from junction to
mounting base
Fig. 5
0.71
0.82
K/W
Zth(j-mb)
(K/W)
aaa-026178
1
δ = 0.5
0.2
10-1
0.1
0.05
0.02
10-2
single shot
P
δ=
Fig. 5.
10-5
10-4
10-3
10-2
T
t
tp
10-3
10-6
tp
T
10-1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration
PSMN8R5-100PSF
Product data sheet
10 April 2017
5 / 13
PSMN8R5-100PSF
Nexperia
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
100
V
ID = 250 µA; VGS = 0 V; Tj = -55 °C
90
V
gate-source threshold
voltage
ID = 1 mA; VDS=VGS; Tj = -55 °C
3.6
V
ID = 1 mA; VDS=VGS; Tj = 175 °C
1.8
V
ID = 1 mA; VDS=VGS; Tj = 25 °C; Fig. 9
2
3.1
4
V
V(BR)DSS
VGS(th)
ΔVGS(th)/ΔT
voltage variation with
temperature
25 °C ≤ Tj ≤ 175 °C
-8.4
mV/K
IDSS
drain leakage current
VDS = 100 V; VGS = 0 V; Tj = 25 °C
0.05
1
µA
VDS = 100 V; VGS = 0 V; Tj = 125 °C
100
µA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
5
100
nA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
5
100
nA
Fig. 10
7.5
8.7
mΩ
VGS = 7 V; ID = 25 A; Tj = 25 °C; Fig. 10
8.9
13.2
mΩ
Fig. 11
11.2
13.5
mΩ
VGS = 10 V; ID = 25 A; Tj = 175 °C;
Fig. 11
16
19
mΩ
f = 1 MHz
1.54
Ω
Fig. 12; Fig. 13
44.5
nC
ID = 0 A; VDS = 0 V; VGS = 10 V
22.9
nC
Fig. 12; Fig. 13
14.5
nC
8.8
nC
IGSS
RDSon
RG
gate leakage current
resistance
gate resistance
QG(tot)
total gate charge
QGS
gate-source charge
QGS(th)
pre-threshold gatesource charge
QGS(th-pl)
post-threshold gatesource charge
5.6
nC
QGD
gate-drain charge
8.7
nC
VGS(pl)
gate-source plateau
voltage
ID = 25 A; VDS = 50 V; Fig. 12; Fig. 13
4.8
V
Ciss
input capacitance
3181
pF
Coss
output capacitance
VDS = 50 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; Fig. 14
551
pF
Crss
reverse transfer
capacitance
12
pF
td(on)
turn-on delay time
16.8
ns
tr
rise time
26.8
ns
PSMN8R5-100PSF
Product data sheet
VDS = 50 V; RL = 2 Ω; VGS = 10 V;
RG(ext) = 5 Ω; Tj = 25 °C
10 April 2017
6 / 13
PSMN8R5-100PSF
Nexperia
Symbol
Parameter
td(off)
tf
Conditions
Min
Typ
Max
Unit
turn-off delay time
31.5
ns
fall time
23.6
ns
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 0 V; Tj = 25 °C; Fig. 15
0.83
1.2
V
trr
reverse recovery time
51
ns
Qr
recovered charge
IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 50 V; Fig. 16
70
nC
aaa-026179
200
ID
(A)
10 V
8V
7V
6.5 V
160
6V
120
aaa-026180
30
RDSon
(mΩ)
25
15
VGS = 5.5 V
80
10
5V
40
5
4.5 V
Fig. 6.
2
3
VDS (V)
8
12
16
VGS (V)
Tj = 25 °C
Tj = 25 °C; ID = 25 A
Output characteristics; drain current as a
Fig. 7.
function of drain-source voltage; typical values
Drain-source on-state resistance as a function
of gate-source voltage; typical values
aaa-026181
200
ID
(A)
160
10-2
120
10-3
80
10-4
10-5
40
175°C
aaa-011501
10-1
ID
(A)
4
Tj = 25°C
6
8
VGS (V)
10-6
10
2
3
4
VGS (V)
5
VDS = 12 V
Fig. 8.
Transfer characteristics; drain current as a
function of gate-source voltage; typical values
PSMN8R5-100PSF
Product data sheet
Fig. 9.
Sub-threshold drain current as a function of
gate-source voltage
10 April 2017
7 / 13
PSMN8R5-100PSF
Nexperia
aaa-026182
40
RDSon
(mΩ)
5V
5.5 V
a
6V
2
6.5 V
30
aaa-011504
2.4
1.6
7V
8V
0.8
10
0.4
VGS = 10 V
80
120
160
ID (A)
200
-30
60
90
120 150
Tj (°C)
180
Tj = 25 °C
Fig. 10. Drain-source on-state resistance as a function
of drain current; typical values
VGS
(V)
Fig. 11. Normalized drain-source on-state resistance
factor as a function of junction temperature
aaa-026183
10
VDS
50 V
8
ID
VGS(pl)
VDS = 20 V
6
VGS(th)
80 V
4
VGS
QGS1
2
QGS2
40
QG (nC)
50
QGS
QGD
QG(tot)
003aaa508
Fig. 13. Gate charge waveform definitions
Fig. 12. Gate-source voltage as a function of gate
charge; typical values
PSMN8R5-100PSF
Product data sheet
10 April 2017
8 / 13
PSMN8R5-100PSF
Nexperia
aaa-026184
104
C
(pF)
aaa-026185
200
IS
(A)
Ciss
160
103
120
Coss
80
102
40
175°C
Crss
10
10-1
1
10
VDS (V)
0.6
Tj = 25°C
0.9
1.2
VSD (V)
1.5
VGS = 0 V
Fig. 14. Input, output and reverse transfer capacitances Fig. 15. Source-drain (diode forward) current as a
as a function of drain-source voltage; typical
function of source-drain (diode forward)
values
003aaf444
ID
(A)
trr
ta
tb
0.25 IRM
tb
S= t
a
IRM
t (s)
Fig. 16. Reverse recovery timing definition
PSMN8R5-100PSF
Product data sheet
10 April 2017
9 / 13
PSMN8R5-100PSF
Nexperia
11. Package outline
Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB
SOT78
E
A
A1
p
q
mounting
base
D1
D
L1(1)
L2(1)
Q
L
b1(2)
(3×)
b2(2)
(2×)
1
2
3
b(3×)
e
c
e
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1(2)
b2(2)
c
D
D1
E
e
L
L1(1)
L2(1)
max.
p
q
Q
mm
4.7
4.1
1.40
1.25
0.9
0.6
1.6
1.0
1.3
1.0
0.7
0.4
16.0
15.2
6.6
5.9
10.3
9.7
2.54
15.0
12.8
3.30
2.79
3.0
3.8
3.5
3.0
2.7
2.6
2.2
Notes
1. Lead shoulder designs may vary.
2. Dimension includes excess dambar.
OUTLINE
VERSION
SOT78
REFERENCES
IEC
JEDEC
JEITA
3-lead TO-220AB
SC-46
EUROPEAN
PROJECTION
ISSUE DATE
08-04-23
08-06-13
Fig. 17. Package outline TO-220AB (SOT78)
PSMN8R5-100PSF
Product data sheet
10 April 2017
10 / 13
PSMN8R5-100PSF
Nexperia
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
12. Legal information
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Data sheet status
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to the accuracy
or completeness of information included herein and shall have no liability for
the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’ aggregate and cumulative liability towards customer
PSMN8R5-100PSF
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’ warranty of the product
for such automotive applications, use and specifications, and (b) whenever
10 April 2017
11 / 13
PSMN8R5-100PSF
Nexperia
customer uses the product for automotive applications beyond Nexperia’
specifications such use shall be solely at customer’s own risk, and (c)
customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’ standard warranty and Nexperia’
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
PSMN8R5-100PSF
Product data sheet
10 April 2017
12 / 13
PSMN8R5-100PSF
Nexperia
13. Contents
1. General description......................................................1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 5
10. Characteristics............................................................ 6
11. Package outline........................................................ 10
12. Legal information..................................................... 11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 10 April 2017
PSMN8R5-100PSF
Product data sheet
10 April 2017
13 / 13
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
PSMN8R5-100PSFQ
