PSMNR70-40SSHJ
PSMNR70-40SSHJ
    NEXPERIA(安世)
    SOT-1235
    MOS管 N-channel Id=425A VDS=40V SOT1235
PSMNR70-40SSHJ 数据手册
PSMNR70-40SSH N-channel 40 V, 0.7 mΩ, 425 Amps continuous, standard level MOSFET in LFPAK88 using NextPowerS3 Technology 19 June 2019 Product data sheet 1. General description 425 Amp continuous current, standard level gate drive, N-channel enhancement mode MOSFET in LFPAK88 package. NextPowerS3 family using Nexperia’s unique “SchottkyPlus” technology delivers high efficiency and low spiking performance usually associated with MOSFETs with an integrated Schottky or Schottky-like diode but without problematic high leakage current. NextPowerS3 is particularly suited to high efficiency applications at high switching frequencies, and also safe and reliable switching at high load-current. 2. Features and benefits • • • • • • • • • • • • 425 Amp continuous current capability LFPAK88 (8 x 8 mm) LFPAK-style low-stress exposed lead-frame for ultimate reliability, optimum soldering and easy solder-joint inspection Copper-clip and solder die attach for low package inductance and resistance, and high ID (max) rating Ideal replacement for D2PAK and 10 x 12 mm leadless package types Qualified to 175 °C Meets UL2595 requirements for creepage and clearance Avalanche rated, 100 % tested Low QG, QGD and QOSS for high efficiency, especially at higher switching frequencies Superfast switching with soft body-diode recovery for low-spiking and ringing, recommended for low EMI designs Unique “SchottkyPlus” technology for Schottky-like switching performance and low IDSS leakage Narrow VGS(th) rating for easy paralleling and improved current sharing Very strong linear-mode / safe operating area characteristics for safe and reliable switching at high-current conditions 3. Applications • • • • • Brushless DC motor control Synchronous rectifier in high-power AC-DC applications, e.g. server power supplies Battery protection eFuse and load switch Hotswap / in-rush current management 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - - 40 V ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 - - 425 A Ptot total power dissipation Tmb = 25 °C; Fig. 1 - - 375 W [1] PSMNR70-40SSH Nexperia N-channel 40 V, 0.7 mΩ, 425 Amps continuous, standard level MOSFET in LFPAK88 using NextPowerS3 Technology Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from Fig. 5 junction to mounting base - 0.35 0.4 K/W VGS = 10 V; ID = 25 A; Tj = 25 °C; Fig. 11 0.43 0.62 0.7 mΩ ID = 25 A; VDS = 32 V; VGS = 10 V; Fig. 13; Fig. 14 - 144 202 nC - 25 50 nC IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V; [2] VDS = 20 V; Fig. 17 - 74 - nC Static characteristics RDSon drain-source on-state resistance Dynamic characteristics QG(tot) total gate charge QGD gate-drain charge Source-drain diode Qr [1] [2] recovered charge 425A. Continuous current has been successfully demonstrated during application. Practically, the current will be limited by the PCB, thermal design and operating temperature. includes capacitive recovery 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline Graphic symbol 1 G gate 2 S source 3 S source G 4 S source mbb076 mb D mounting base; connected to drain D 1 2 3 S 4 LFPAK88 (SOT1235) 6. Ordering information Table 3. Ordering information Type number Package PSMNR70-40SSH Name Description Version LFPAK88 plastic, single-ended surface-mounted package (LFPAK88); 4 leads; 2 mm pitch; 8 mm x 8 mm x 1.6 mm body SOT1235 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage 25 °C ≤ Tj ≤ 175 °C - 40 V VDSM peak drain-source voltage tp ≤ 20 ns; f ≤ 500 kHz; EDS(AL) ≤ 200 nJ; pulsed - 45 V VDGR drain-gate voltage 25 °C ≤ Tj ≤ 175 °C; RGS = 20 kΩ - 40 V VGS gate-source voltage -20 20 V Ptot total power dissipation - 375 W PSMNR70-40SSH Product data sheet Tmb = 25 °C; Fig. 1 All information provided in this document is subject to legal disclaimers. 19 June 2019 © Nexperia B.V. 2019. All rights reserved 2 / 13 PSMNR70-40SSH Nexperia N-channel 40 V, 0.7 mΩ, 425 Amps continuous, standard level MOSFET in LFPAK88 using NextPowerS3 Technology Symbol Parameter Conditions Min Max Unit ID drain current VGS = 10 V; Tmb = 25 °C; Fig. 2 - 425 A VGS = 10 V; Tmb = 100 °C; Fig. 2 - 350 A pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3 [1] IDM peak drain current - 1983 A Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Tsld(M) peak soldering temperature - 260 °C - 500 A - 1983 A - 940 mJ - 294 A Source-drain diode IS source current Tmb = 25 °C [2] ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C Avalanche ruggedness EDS(AL)S non-repetitive drainID = 120 A; Vsup ≤ 40 V; RGS = 50 Ω; source avalanche energy VGS = 10 V; Tj(init) = 25 °C; unclamped; Fig. 4 IAS non-repetitive avalanche Vsup = 40 V; VGS = 10 V; Tj(init) = 25 °C; current RGS = 50 Ω [1] [2] [3] [3] 425A. Continuous current has been successfully demonstrated during application. Practically, the current will be limited by the PCB, thermal design and operating temperature. 500A. Continuous current has been successfully demonstrated during application. Practically, the current will be limited by the PCB, thermal design and operating temperature. Protected by 100% test 03aa16 120 Pder (%) aaa-029500 500 ID (A) (1) 400 80 300 200 40 100 0 Fig. 1. 0 50 100 150 Tmb (°C) 0 200 Fig. 2. Product data sheet 25 50 75 100 125 150 175 Tmb (°C) 200 VGS ≥ 10 V (1) 425A continuous current has been successfully demonstrated during application tests. Practically the current will be limited by PCB, thermal design and operating temperature. Normalized total power dissipation as a function of mounting base temperature PSMNR70-40SSH 0 Continuous drain current as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. 19 June 2019 © Nexperia B.V. 2019. All rights reserved 3 / 13 PSMNR70-40SSH Nexperia N-channel 40 V, 0.7 mΩ, 425 Amps continuous, standard level MOSFET in LFPAK88 using NextPowerS3 Technology ID (A) aaa-029490 104 Limit RDSon = VDS / ID 103 tp = 10 µs 100 µs DC 102 10 1 ms 10 ms 100 ms 1 10-1 1 10 VDS (V) 102 Tmb = 25 °C; IDM is a single pulse Fig. 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage IAL (A) aaa-029189 103 (1) 102 (2) 10 (3) 1 10-1 10-3 10-2 10-1 1 tAL (ms) 10 (1) Tj (init) = 25 °C; (2) Tj (init) = 150 °C; (3) Repetitive Avalanche Fig. 4. Avalanche rating; avalanche current as a function of avalanche time 8. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from Fig. 5 junction to mounting base - 0.35 0.4 K/W Rth(j-a) thermal resistance from Fig. 6 junction to ambient Fig. 7 - 35 - K/W - 70 - K/W PSMNR70-40SSH Product data sheet All information provided in this document is subject to legal disclaimers. 19 June 2019 © Nexperia B.V. 2019. All rights reserved 4 / 13 PSMNR70-40SSH Nexperia N-channel 40 V, 0.7 mΩ, 425 Amps continuous, standard level MOSFET in LFPAK88 using NextPowerS3 Technology aaa-029191 1 Zth(j-mb) (K/W) δ = 0.5 10-1 0.2 0.1 0.05 P 10-2 0.02 δ= single shot Fig. 5. 10-5 10-4 10-3 10-2 T 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration aaa-029383 aaa-029384 Copper square 25.4 mm x 25.4 mm; 70 μm thick on FR4 board Fig. 6. T t tp 10-3 10-6 tp PCB layout for resistance from junction to ambient 70 μm thick copper on FR4 board Fig. 7. PCB layout with minimum footprint for thermal resistance from junction to ambient 9. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 40 43 - V ID = 250 µA; VGS = 0 V; Tj = -55 °C 36 40 - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS=VGS; Tj = 25 °C 2.4 3 3.6 V ΔVGS(th)/ΔT gate-source threshold voltage variation with temperature 25 °C ≤ Tj ≤ 175 °C - -8.2 - mV/K IDSS drain leakage current VDS = 32 V; VGS = 0 V; Tj = 25 °C - - 1.6 µA VDS = 32 V; VGS = 0 V; Tj = 175 °C - 264 - µA IGSS gate leakage current VGS = 20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 25 A; Tj = 25 °C; Fig. 11 0.43 0.62 0.7 mΩ Static characteristics V(BR)DSS RDSon drain-source on-state resistance PSMNR70-40SSH Product data sheet All information provided in this document is subject to legal disclaimers. 19 June 2019 © Nexperia B.V. 2019. All rights reserved 5 / 13 PSMNR70-40SSH Nexperia N-channel 40 V, 0.7 mΩ, 425 Amps continuous, standard level MOSFET in LFPAK88 using NextPowerS3 Technology Symbol RG Parameter gate resistance Conditions Min Typ Max Unit VGS = 10 V; ID = 25 A; Tj = 175 °C; Fig. 12 0.85 1.23 1.53 mΩ f = 1 MHz; Tj = 25 °C 0.5 1.2 3 Ω ID = 25 A; VDS = 32 V; VGS = 10 V; Fig. 13; Fig. 14 - 144 202 nC ID = 0 A; VDS = 0 V; VGS = 10 V - 72 - nC ID = 25 A; VDS = 32 V; VGS = 10 V; Fig. 13; Fig. 14 - 40 60 nC - 29 43 nC Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGS(th) pre-threshold gatesource charge QGS(th-pl) post-threshold gatesource charge - 11 17 nC QGD gate-drain charge - 25 50 nC VGS(pl) gate-source plateau voltage ID = 25 A; VDS = 32 V; Fig. 13; Fig. 14 - 4.1 - V Ciss input capacitance 11228 15719 pF output capacitance VDS = 25 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; Fig. 15 - Coss - 2363 3308 pF Crss reverse transfer capacitance - 415 913 pF td(on) turn-on delay time - 35 - ns tr rise time - 30 - ns td(off) turn-off delay time - 94 - ns tf fall time - 41 - ns Qoss output charge VGS = 0 V; VDS = 25 V; f = 1 MHz; Tj = 25 °C - 102 - nC VDS = 30 V; RL = 1.2 Ω; VGS = 10 V; RG(ext) = 5 Ω Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; Fig. 16 - 0.75 1 V trr reverse recovery time - 53 - ns Qr recovered charge IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 20 V; Fig. 17 [1] - 74 - nC ta reverse recovery rise time - 30 - ns tb reverse recovery fall time - 23 - ns [1] includes capacitive recovery PSMNR70-40SSH Product data sheet All information provided in this document is subject to legal disclaimers. 19 June 2019 © Nexperia B.V. 2019. All rights reserved 6 / 13 PSMNR70-40SSH Nexperia N-channel 40 V, 0.7 mΩ, 425 Amps continuous, standard level MOSFET in LFPAK88 using NextPowerS3 Technology aaa-029192 400 ID (A) RDSon (mΩ) 5V 320 10 V 3 7V 240 aaa-029193 4 6V 4.5 V VGS = 5.5 V 2 160 1 80 4V 0 Fig. 8. 0 1 2 3 VDS (V) 0 4 0 4 8 12 16 VGS (V) 20 Tj = 25 °C Tj = 25 °C; ID = 25 A Output characteristics; drain current as a Fig. 9. function of drain-source voltage; typical values Drain-source on-state resistance as a function of gate-source voltage; typical values aaa-029194 400 ID (A) RDSon (mΩ) aaa-029195 4 4.5 V 320 3.2 240 2.4 160 1.6 5V 5.5 V 6V 175°C 25°C 80 7V 0.8 Tj = -55°C 0 0 1 2 3 4 5 6 7 VGS (V) VGS = 10 V 0 8 VDS = 8 V Product data sheet 80 160 240 320 ID (A) 400 Tj = 25 °C Fig. 10. Transfer characteristics; drain current as a function of gate-source voltage; typical values PSMNR70-40SSH 0 Fig. 11. Drain-source on-state resistance as a function of drain current; typical values All information provided in this document is subject to legal disclaimers. 19 June 2019 © Nexperia B.V. 2019. All rights reserved 7 / 13 PSMNR70-40SSH Nexperia N-channel 40 V, 0.7 mΩ, 425 Amps continuous, standard level MOSFET in LFPAK88 using NextPowerS3 Technology a aaa-026897 2.4 VGS (V) 2 aaa-029196 10 8 1.6 6 32 V 1.2 VDS = 14 V 4 0.8 2 0.4 0 -60 -30 0 30 60 90 120 150 Tj (°C) 0 180 0 25 50 75 100 125 QG (nC) 150 Tj = 25 °C; ID = 25 A Fig. 12. Normalized drain-source on-state resistance factor as a function of junction temperature Fig. 13. Gate-source voltage as a function of gate charge; typical values aaa-029197 105 VDS C (pF) ID Ciss 104 VGS(pl) VGS(th) Coss VGS QGS2 QGS1 QGS 103 QGD QG(tot) Crss 003aaa508 102 10-1 Fig. 14. Gate charge waveform definitions 1 10 VDS (V) 102 VGS = 0 V; f = 1 MHz Fig. 15. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values PSMNR70-40SSH Product data sheet All information provided in this document is subject to legal disclaimers. 19 June 2019 © Nexperia B.V. 2019. All rights reserved 8 / 13 PSMNR70-40SSH Nexperia N-channel 40 V, 0.7 mΩ, 425 Amps continuous, standard level MOSFET in LFPAK88 using NextPowerS3 Technology 003aal160 aaa-029198 400 IS (A) ID (A) 320 trr 240 ta tb 0 160 0.25 IRM 175°C 80 0 Tj = 25°C 0 0.2 0.4 0.6 0.8 1 VSD (V) IRM t (s) 1.2 VGS = 0 V Fig. 17. Reverse recovery timing definition Fig. 16. Source-drain (diode forward) current as a function of source-drain (diode forward) voltage; typical values PSMNR70-40SSH Product data sheet All information provided in this document is subject to legal disclaimers. 19 June 2019 © Nexperia B.V. 2019. All rights reserved 9 / 13 PSMNR70-40SSH Nexperia N-channel 40 V, 0.7 mΩ, 425 Amps continuous, standard level MOSFET in LFPAK88 using NextPowerS3 Technology 10. Package outline Plastic single-ended surface-mounted package (LFPAK88); 4 leads SOT1235 b2 E1 D1 A1 C A3 θ L y C detail X A A2 E c2 mounting base D H L2 1 2 3 e e 4 e c b (4x) w X A 0 4 8 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A1 A2 0.15 1.7 0.00 1.5 A3 0.25 b b2 c c2 D(1) D1(1) E(1) E1(1) 1.1 7.3 0.24 0.55 6.3 5.1 8.1 6.9 0.9 7.1 0.18 0.45 6.1 4.9 7.9 6.7 e 2.0 H(1) L L2 8.1 0.8 1.3 7.8 0.6 0.9 w y 0.25 0.10 Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. Outline version References IEC JEDEC JEITA θ 8° 0° sot1235_po European projection Issue date 17-08-02 17-08-07 SOT1235 Fig. 18. Package outline LFPAK88 (SOT1235) PSMNR70-40SSH Product data sheet All information provided in this document is subject to legal disclaimers. 19 June 2019 © Nexperia B.V. 2019. All rights reserved 10 / 13 PSMNR70-40SSH Nexperia N-channel 40 V, 0.7 mΩ, 425 Amps continuous, standard level MOSFET in LFPAK88 using NextPowerS3 Technology 11. Soldering Footprint information for reflow soldering of LFPAK88 package SOT1235 9.2 8.8 8.6 0.3 1.85 1.7 2.05 0.1 1.76 0.2 2.1 0.7 1.2 0.2 0.7 1.25 0.2 4.275 5.7 2.925 1.15 3.74 9.4 7.8 0.2 1.225 1.9 1.6 1.4 1.3 1.6 6.55 6.8 7 1.2 1.1 2 1.4 7.8 recommended stencil thickness: 0.125 mm occupied area solder resist solder land solder paste Dimensions in mm Issue date 18-12-12 18-12-13 sot1235_fr Fig. 19. Reflow soldering footprint for LFPAK88 (SOT1235) PSMNR70-40SSH Product data sheet All information provided in this document is subject to legal disclaimers. 19 June 2019 © Nexperia B.V. 2019. All rights reserved 11 / 13 PSMNR70-40SSH Nexperia N-channel 40 V, 0.7 mΩ, 425 Amps continuous, standard level MOSFET in LFPAK88 using NextPowerS3 Technology 12. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal PSMNR70-40SSH Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. 19 June 2019 © Nexperia B.V. 2019. All rights reserved 12 / 13 PSMNR70-40SSH Nexperia N-channel 40 V, 0.7 mΩ, 425 Amps continuous, standard level MOSFET in LFPAK88 using NextPowerS3 Technology Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Limiting values............................................................. 2 8. Thermal characteristics............................................... 4 9. Characteristics.............................................................. 5 10. Package outline........................................................ 10 11. Soldering................................................................... 11 12. Legal information......................................................12 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 19 June 2019 PSMNR70-40SSH Product data sheet All information provided in this document is subject to legal disclaimers. 19 June 2019 © Nexperia B.V. 2019. All rights reserved 13 / 13
PSMNR70-40SSHJ 价格&库存
很抱歉,暂时无法提供与“PSMNR70-40SSHJ”相匹配的价格&库存,您可以联系我们找货
PSMNR70-40SSHJ
  • 2000+20.617372000+2.67067
库存:2911
PSMNR70-40SSHJ
  • 1+37.074931+4.80250
  • 10+32.1025310+4.15840
  • 25+30.0088925+3.88720
PSMNR70-40SSHJ
  • 1+56.624261+7.33483
  • 10+37.9262010+4.91277
  • 100+27.32822100+3.53996
  • 500+25.23557500+3.26889
库存:2911
PSMNR70-40SSHJ
  • 1+34.47268
  • 10+29.84918
  • 25+27.90874
