PUSB3FA0X
PUSB3FA0X
    NEXPERIA(安世)
    DFN2510A-10
    ESD保护 4通道 VRWM=1.5 V VBR(Min)=6 V VC=4.6 V IPP=5.2 A Ppp=Original DFN2510A-10
PUSB3FA0X 数据手册
PUSB3FA0 ESD protection for ultra high-speed interfaces Rev. 1 — 1 February 2018 1 Product data sheet Product profile 1.1 General description The device is designed to protect high-speed interfaces such as SuperSpeed USB, High-Definition Multimedia Interface (HDMI), DisplayPort, external Serial Advanced Technology Attachment (eSATA) and Low Voltage Differential Signaling (LVDS) interfaces against ElectroStatic Discharge (ESD). The device includes four high-level ESD protection diode structures for ultra high-speed signal lines and is encapsulated in a leadless small DFN2510A-10 (SOT1176-1) plastic package. All signal lines are protected by a special diode configuration offering ultra low line capacitance of only 0.5 pF. These diodes utilize a unique snap-back structure in order to provide protection to downstream components from ESD voltages up to ±10 kV contact exceeding IEC 61000-4-2, level 4. 1.2 Features and benefits • System ESD protection for USB 2.0 and SuperSpeed USB 3.1, HDMI 2.0, DisplayPort, eSATA and LVDS • All signal lines with integrated rail-to-rail clamping diodes for downstream ESD protection of ±10 kV exceeding IEC 61000-4-2, level 4 • Matched 0.5 mm trace spacing • Signal lines with ≤ 0.05 pF matching capacitance between signal pairs • Line capacitance of only 0.5 pF for each channel • Design-friendly ‘pass-through’ signal routing 1.3 Applications The device is designed for high-speed receiver and transmitter port protection: • • • • TVs and monitors DVD recorders and players Notebooks, main board graphic cards and ports Set-top boxes and game consoles PUSB3FA0 Nexperia ESD protection for ultra high-speed interfaces 2 Pinning information Table 1. Pinning Pin Symbol Description 1 CH1 channel 1 ESD protection 2 CH2 channel 2 ESD protection 3 GND ground 4 CH3 channel 3 ESD protection 5 CH4 channel 4 ESD protection 6 n.c. not connected 7 n.c. not connected 8 GND ground 9 n.c. not connected 10 n.c. not connected 3 Simplified outline 10 9 8 7 6 Graphic symbol 1 2 4 5 1 2 3 4 5 Transparent top view 3, 8 018aaa001 Ordering information Table 2. Ordering information Type number Package PUSB3FA0 4 Name Description Version DFN2510A-10 plastic extremely thin small outline package; no leads;10 terminals; body 1 × 2.5 × 0.5 mm SOT1176-1 Marking Table 3. Marking codes Type number Marking code PUSB3FA0 96 5 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions VI input voltage VESD electrostatic discharge voltage Min Max Unit -0.5 +1.5 V • contact discharge -10 +10 kV • air discharge -15 +15 kV IEC 61000-4-2, level 4 [1] Tamb ambient temperature -40 +85 °C Tstg storage temperature -55 +125 °C [1] All pins to ground. PUSB3FA0 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 12 PUSB3FA0 Nexperia ESD protection for ultra high-speed interfaces 6 Characteristics Table 5. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VBR breakdown voltage II = 1 mA 6 - - V ILR reverse leakage current per channel; VI = 1.5 V - - 1 μA VF forward voltage II = 1 mA - 0.7 - V Cline line capacitance [1] - 0.5 0.6 pF ΔCline line capacitance difference [1] - 0.05 - pF rdyn dynamic resistance - 0.41 - Ω - 0.26 - Ω - 0.43 - Ω - 0.28 - Ω - 4.6 - V - -2.2 - V f = 1 MHz; VI = 1.5 V f = 1 MHz; VI = 1.5 V surge [2] • positive transient • negative transient TLP [3] • positive transient • negative transient VCL clamping voltage IPP = 5.2 A [2] • positive transient IPP = -4.4 A • negative transient [1] [2] [3] [2] This parameter is guaranteed by design. According to IEC 61000-4-5 (8/20 μs current waveform). 100 ns Transmission Line Pulse (TLP); 50 Ω; pulser at 80 ns. PUSB3FA0 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 12 PUSB3FA0 Nexperia ESD protection for ultra high-speed interfaces aaa-009367 2 Sdd21 (dB) aaa-027971 1.2 a -2 0.8 -6 0.4 -10 -14 106 107 108 109 f (MHz) 1010 0.0 0 0.5 1 VI (V) 1.5 differential mode Figure 1. Insertion loss; typical values Figure 2. Relative capacitance as a function of input voltage; typical values aaa-009369 0 aaa-009370 120 Zdif (Ω) Sdd21 (dB) 110 -20 (2) 100 -40 90 (1) -60 106 107 108 109 f (MHz) 1010 Sdd21 normalized to 100 Ω;differential pairs CH1/CH2 versus CH3/CH4 Figure 3. Crosstalk; typical values 80 40.0 40.5 41.0 41.5 t (ns) 42.0 tr = 200 ps; differential pair CH1 + CH2 (1) PUSB3FA0 on reference board (2) Reference board without device under test (DUT) Figure 4. Differential Time Domain Reflectometer (TDR) plot; typical values PUSB3FA0 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 12 PUSB3FA0 Nexperia ESD protection for ultra high-speed interfaces Data rate: 10 Gbit/s; Vertical scale: 200 mV/div; Horizontal scale: 20 ps/div 3.1 dB de-emphasis 2.2 dB pre-shoot Figure 5. USB 3.1 eye diagram, Printed-Circuit Board (PCB) with PUSB3FA0 Data rate: 10 Gbit/s; Vertical scale: 200 mV/div; Horizontal scale: 20 ps/div 3.1 dB de-emphasis 2.2 dB pre-shoot Figure 6. USB 3.1 eye diagram, PCB without PUSB3FA0 (reference) PUSB3FA0 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 12 PUSB3FA0 Nexperia ESD protection for ultra high-speed interfaces aaa-014159 Test frequency: 148.5 MHz Differential swing voltage: 810 mV Horizontal scale: 34 ps/div Figure 7. HDMI 2.0 TP1 eye diagram, PCB with PUSB3FA0 (2160p, 60 Hz aaa-014160 Test frequency: 148.5 MHz Differential swing voltage: 800 mV Horizontal scale: 34 ps/div Figure 8. HDMI 2.0 TP1 eye diagram, PCB without PUSB3FA0 (2160p, 60 Hz, reference) PUSB3FA0 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 12 PUSB3FA0 Nexperia ESD protection for ultra high-speed interfaces aaa-014161 Test frequency: 148.5 MHz Differential swing voltage: 809 mV Horizontal scale: 34 ps/div Remark: Measured at Test Point 2 (TP2) worst cable emulator, reference cable equalizer and worst case positive skew. Figure 9. HDMI 2.0 TP2 eye diagram, PCB with PUSB3FA0 (2160p, 60 Hz) aaa-014162 Test frequency: 148.5 MHz Differential swing voltage: 820 mV Horizontal scale: 34 ps/div Remark: Measured at Test Point 2 (TP2) worst cable emulator, reference cable equalizer and worst case positive skew. Figure 10. HDMI 2.0 TP2 eye diagram, PCB without PUSB3FA0 (2160p, 60 Hz, reference) PUSB3FA0 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 12 PUSB3FA0 Nexperia ESD protection for ultra high-speed interfaces aaa-009371 6 IPP (A) aaa-009372 0 IPP (A) 4 -2 2 -4 0 0 2 4 VCL (V) -6 -2.5 6 -2.0 -1.5 -1.0 -0.5 0 VCL (V) IEC 61000-4-5; tp = 8/20 μs; positive pulse IEC 61000-4-5; tp = 8/20 μs; negative pulse Figure 11. Dynamic resistance with positive clamping; typical values Figure 12. Dynamic resistance with negative clamping; typical values aaa-009373 14 I (A) 12 I (A) -2 10 -4 8 -6 6 -8 4 -10 2 -12 0 0 4 8 VCL (V) 12 aaa-009374 0 -14 -6 -4 -2 VCL (V) 0 tp = 100 ns; Transmission Line Pulse (TLP) tp = 100 ns; Transmission Line Pulse (TLP) Figure 13. Dynamic resistance with positive clamping; typical values Figure 14. Dynamic resistance with negative clamping; typical values The device uses an advanced clamping structure showing a negative dynamic resistance. This snap-back behavior strongly reduces the clamping voltage to the system behind the ESD protection during an ESD event. Do not connect unlimited DC current sources to the data lines to avoid keeping the ESD protection device in snap-back state after exceeding breakdown voltage (due to an ESD pulse for instance). PUSB3FA0 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 12 PUSB3FA0 Nexperia ESD protection for ultra high-speed interfaces 7 Application information The device is designed to provide high-level ESD protection for high-speed serial data buses such as HDMI, DisplayPort, eSATA and LVDS data lines. When designing the Printed-Circuit Board (PCB), give careful consideration to impedance matching and signal coupling. Do not connect the signal lines to unlimited current sources like, for example, a battery. 8 Package outline Table 6. Package outline 1.1 0.9 5 0.2 min 0.127 6 2.6 2 2.4 0.25 0.15 0.5 1 10 0.45 0.35 Dimensions in mm 0.4 0.3 0.05 max 0.5 max 12-05-23 Figure 15. Package outline DFN2510A-10 (SOT1176-1) PUSB3FA0 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 12 PUSB3FA0 Nexperia ESD protection for ultra high-speed interfaces 9 Soldering Table 7. Soldering Footprint information for reflow soldering of DFN2510A-10 package SOT1176-1 Hx C Hy Ay By 0.05 D P 0.05 Generic footprint pattern Refer to the package outline drawing for actual layout solder land solder paste deposit solder land plus solder paste occupied area solder resist Dimensions in mm P Ay By C D Hx Hy 0.5 1.25 0.3 0.475 0.2 2.45 1.5 Remark: Stencil of 75 m is recommended. A stencil of 75 m gives an aspect ratio of 0.77 With a stencil of 100 m one will obtain an aspect ratio of 0.58 sot1176-1_fr Figure 16. Reflow soldering footprint DFN2510A-10 (SOT1176-1) PUSB3FA0 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 12 PUSB3FA0 Nexperia ESD protection for ultra high-speed interfaces 10 Revision history Table 8. Revision history Document ID Release date Data sheet status Change notice Supersedes PUSB3FA0 v.1 20180201 Product data sheet - - PUSB3FA0 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 12 PUSB3FA0 Nexperia ESD protection for ultra high-speed interfaces Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 8 9 10 Product profile .................................................... 1 General description ............................................1 Features and benefits ........................................1 Applications ........................................................1 Pinning information ............................................ 2 Ordering information .......................................... 2 Marking .................................................................2 Limiting values .................................................... 2 Characteristics .................................................... 3 Application information ......................................9 Package outline ...................................................9 Soldering ............................................................10 Revision history ................................................ 11 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 1 February 2018 Document identifier: PUSB3FA0 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: PUSB3FA0X
PUSB3FA0X 价格&库存
很抱歉,暂时无法提供与“PUSB3FA0X”相匹配的价格&库存,您可以联系我们找货
