PZU5.6BF
PZU5.6BF
    NEXPERIA(安世)
    SOD323F
    安世 SOD-323F 0.9V 0.55W 5mA
PZU5.6BF 数据手册
PZUxB series Single Zener diodes in a SOD323F package Rev. 4 — 10 May 2019 Product data sheet 1. Product profile 1.1. General description General-purpose Zener diodes in an SOD323F (SC-90) very small and flat lead Surface Mounted Device (SMD) plastic package. 1.2. Features • • • • Total power dissipation: ≤ 310 mW Tolerance series: B: approximately ±5 %; B1, B2, B3: sequential, approximately ±2 % Small plastic package suitable for surface mounted design Wide working voltage range: nominal 2.4 V to 36 V 1.3. Applications • General regulation functions 1.4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions VF forward voltage IF = 100 mA Ptot total power dissipation Tamb ≤ 25 °C [1] [2] [3] Min Typ Max Unit [1] - - 1.1 V [2] - - 310 mW [3] - - 550 mW Pulse test: tp ≤ 300 μs; δ ≤ 0.02 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1cm . PZUxB series Nexperia Single Zener diodes in a SOD323F package 2. Pinning information Table 2. Pinning Pin Description 1 cathode 2 anode Simplified outline [1] 1 Symbol 2 2 1 sym068 [1] The marking bar indicates the cathode 3. Ordering information Table 3. Ordering information Type number Package PZU2.4B to PZU36B [1] [1] Name Description Version SC-90 plastic surface mounted package; 2 leads SOD323F The series consists of 97 types with nominal working voltages from 2.4 V to 36 V. 4. Marking Table 4. Marking codes Type number Marking code PZUXB_SER Product data sheet Type number Marking code B B1 B2 B3 B B1 B2 B3 PZU2.4 G3 - - - PZU10 GJ FH HF KB PZU2.7 G4 F3 H1 - PZU11 GK FJ HG KC PZU3.0 G5 F4 H2 - PZU12 GL FK HH KD PZU3.3 G6 F5 H3 - PZU13 GM FL HJ KE PZU3.6 G7 F6 H4 - PZU14 - - HK - PZU3.9 G8 F7 H5 - PZU15 GN FM HL KF PZU4.3 G9 F8 H6 HS PZU16 GP FN HM KG PZU4.7 GA F9 H7 HT PZU18 GQ FP HN KH PZU5.1 GB FA H8 HU PZU20 GR FQ HP KJ PZU5.6 GC FB H9 HV PZU22 GS FR HQ KK PZU6.2 GD FC HA HW PZU24 GT FS HR KL PZU6.8 GE FD HB HX PZU27 GU - - - PZU7.5 GF FE HC HY PZU30 GV - - - PZU8.2 GG FF HD HZ PZU33 GW - - - PZU9.1 GH FG HE KA PZU36 GX - - - All information provided in this document is subject to legal disclaimers. Rev. 4 — 10 May 2019 © Nexperia B.V. 2019. All rights reserved 2 / 10 PZUxB series Nexperia Single Zener diodes in a SOD323F package 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter IF Min Max Unit forward current - 200 mA IZSM non-repetitive peak reverse current - see: Table 8 PZSM non-repetitive peak reverse power dissipation [1] - 40 W Ptot total power dissipation [2] - 310 mW [3] - 550 mW Tj junction temperature - 150 °C Tamb ambient temperature -65 +150 °C Tstg storage temperature -65 +150 °C [1] [2] [3] Conditions Tamb ≤ 25 °C tp = 100 μs; square wave; Tj = 25 °C prior to surge Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1cm . 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) in free air Rth(j-sp) [1] [2] [3] thermal resistance from junction to ambient Min thermal resistance from junction to solder point Typ Max Unit [1] - - 400 K/W [2] - - 230 K/W [3] - - 55 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1cm . Soldering point of cathode tab 7. Characteristics Table 7. Characteristics Tj = 25 °C unless otherwise specified Symbol Parameter Conditions VF forward voltage IF = 10 mA IF = 100 mA [1] PZUXB_SER Product data sheet Min Typ Max Unit [1] - - 0.9 V [1] - - 1.1 V Pulse test: tp ≤ 300 μs; δ ≤ 0.02 All information provided in this document is subject to legal disclaimers. Rev. 4 — 10 May 2019 © Nexperia B.V. 2019. All rights reserved 3 / 10 PZUxB series Nexperia Single Zener diodes in a SOD323F package Table 8. Characteristics per type; PZU2.4B to PZU36B Tj = 25 °C unless otherwise specified PZU Sel xxx Working voltage VZ (V); IZ = 5 mA Maximum differential resistance rdif (Ω) Reverse current IR (μA) Temperature coefficient SZ (mV/K); IZ = 5 mA Diode capacitance Cd (pF) ; f = 1 MHz; VR = 0 V Non-repetitive peak reverse current IZSM (A) tp = 100 μs; square wave; Tj = 25 °C ; prior to surge Min Max IZ = 0.5 mA IZ = 5 mA Max VR (V) Typ Max Max 2.4 B 2.3 2.6 1000 100 50 1 -1.6 450 8 2.7 B 2.5 2.9 1000 100 20 1 -2.0 440 8 B1 2.5 2.75 B2 2.65 2.9 B 2.80 3.20 1000 95 10 1 -2.1 425 8 B1 2.80 3.05 B2 2.95 3.20 B 3.10 3.50 1000 95 5 1 -2.4 410 8 B1 3.10 3.35 B2 3.25 3.50 B 3.40 3.80 1000 90 5 1 -2.4 390 8 B1 3.40 3.65 B2 3.55 3.80 B 3.70 4.10 1000 90 3 1 -2.5 370 8 B1 3.70 3.97 B2 3.87 4.10 B 4.01 4.48 1000 90 3 1 -2.5 350 8 B1 4.01 4.21 B2 4.15 4.34 B3 4.28 4.48 B 4.42 4.90 800 80 2 1 -1.4 325 8 B1 4.42 4.61 B2 4.55 4.75 B3 4.69 4.90 B 4.84 5.37 250 60 2 1.5 0.3 300 5.5 B1 4.84 5.04 B2 4.98 5.20 B3 5.14 5.37 3.0 3.3 3.6 3.9 4.3 4.7 5.1 PZUXB_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 10 May 2019 © Nexperia B.V. 2019. All rights reserved 4 / 10 PZUxB series Nexperia Single Zener diodes in a SOD323F package Diode capacitance Cd (pF) ; f = 1 MHz; VR = 0 V Non-repetitive peak reverse current IZSM (A) tp = 100 μs; square wave; Tj = 25 °C ; prior to surge VR (V) Typ Max Max 1000 2.5 1.9 275 5.5 30 500 3 2.7 250 5.5 60 20 500 3.5 3.4 215 5.5 60 10 500 4 4.0 170 3.5 60 10 500 5 4.6 150 3.5 60 10 500 6 5.5 120 3.5 9.15 9.55 B 9.45 10.55 60 10 100 7 6.4 110 3.5 B1 9.45 9.87 B2 9.77 10.21 B3 10.11 10.55 B 10.44 11.56 60 10 100 8 7.4 108 3 B1 10.44 10.88 B2 10.76 11.22 B3 11.10 11.56 B 11.42 12.60 80 10 100 9 8.4 105 3 B1 11.42 11.90 B2 11.74 12.24 B3 12.08 12.60 PZU Sel xxx 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 Working voltage VZ (V); IZ = 5 mA Maximum differential resistance rdif (Ω) Reverse current IR (nA) Min Max IZ = 0.5 mA IZ = 5 mA Max B 5.31 5.92 100 40 B1 5.31 5.55 B2 5.49 5.73 B3 5.67 5.92 B 5.86 6.53 80 B1 5.86 6.12 B2 6.06 6.33 B3 6.26 6.53 B 6.47 7.14 B1 6.47 6.73 B2 6.65 6.93 B3 6.86 7.14 B 7.06 7.84 B1 7.06 7.36 B2 7.28 7.60 B3 7.52 7.84 B 7.76 8.64 B1 7.76 8.10 B2 8.02 8.36 B3 8.28 8.64 B 8.56 9.55 B1 8.56 8.93 B2 8.85 9.23 B3 PZUXB_SER Product data sheet Temperature coefficient SZ (mV/K); IZ = 5 mA All information provided in this document is subject to legal disclaimers. Rev. 4 — 10 May 2019 © Nexperia B.V. 2019. All rights reserved 5 / 10 PZUxB series Nexperia Single Zener diodes in a SOD323F package PZU Sel xxx Diode capacitance Cd (pF) ; f = 1 MHz; VR = 0 V Non-repetitive peak reverse current IZSM (A) tp = 100 μs; square wave; Tj = 25 °C ; prior to surge VR (V) Typ Max Max 100 10 9.4 103 2.5 Working voltage VZ (V); IZ = 5 mA Maximum differential resistance rdif (Ω) Reverse current IR (nA) Min IZ = 0.5 mA IZ = 5 mA Max 10 Max Temperature coefficient SZ (mV/K); IZ = 5 mA B 12.47 13.96 80 B1 12.47 13.03 B2 12.91 13.49 B3 13.37 13.96 14 B2 13.70 14.30 80 10 100 11 10.4 101 2 15 B 13.84 15.52 80 15 50 11 11.4 99 2 B1 13.84 14.46 B2 14.34 14.98 B3 14.85 15.52 B 15.37 17.09 80 20 50 12 12.4 97 1.5 B1 15.37 16.01 B2 15.85 16.51 B3 16.35 17.09 B 16.94 19.03 80 20 50 13 14.4 93 1.5 B1 16.94 17.70 B2 17.56 18.35 B3 18.21 19.03 B 18.86 21.08 100 20 50 15 16.4 88 1.5 B1 18.86 19.70 B2 19.52 20.39 B3 20.21 21.08 B 20.88 23.17 100 25 50 17 18.4 84 1.3 B1 20.88 21.77 B2 21.54 22.47 B3 22.23 23.17 B 22.93 25.57 120 30 50 19 20.4 80 1.3 B1 22.93 23.96 B2 23.72 24.78 B3 24.54 25.57 27 B 25.1 28.9 150 40 50 21 23.4 73 1 30 B 28 32 200 40 50 23 26.6 66 1 33 B 31 35 250 40 50 25 29.7 60 0.9 36 B 34 38 300 60 50 27 33.0 59 0.8 13 16 18 20 22 24 PZUXB_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 10 May 2019 © Nexperia B.V. 2019. All rights reserved 6 / 10 PZUxB series Nexperia Single Zener diodes in a SOD323F package 300 mgl273 0 mbg781 SZ (mV/K) IF (mA) 4.3 -1 3.9 200 3.6 -2 3.3 100 3.0 2.4 2.7 -3 0 0.6 0.8 VF (V) 1 20 40 IZ (mA) 60 PZU2.4B to PZU4.3B Tj = 25 °C to 150 °C Tj = 25 °C Fig. 1. 0 Forward current as a function of forward voltage; typical values Fig. 2. Temperature coefficient as a function of working current; typical values mgl274 10 12 SZ (mV/K) Ptot (mW) 10 9.1 8.2 7.5 6.8 5 006aaa687 400 11 300 6.2 5.6 5.1 0 200 4.7 100 -5 0 4 8 12 16 IZ (mA) 20 0 PZU4.7B to PZU12B Tj = 25 °C to 150 °C Fig. 3. Temperature coefficient as a function of working current; typical values PZUXB_SER Product data sheet 0 50 100 150 200 Tamb (°C) FR4 PCB, standard footprint Fig. 4. Power derating curve All information provided in this document is subject to legal disclaimers. Rev. 4 — 10 May 2019 © Nexperia B.V. 2019. All rights reserved 7 / 10 PZUxB series Nexperia Single Zener diodes in a SOD323F package 8. Package outline 1.35 1.15 0.80 0.65 0.5 0.3 1 2.7 2.3 1.8 1.6 2 0.40 0.25 0.25 0.10 Dimensions in mm Fig. 5. 04-09-13 Package outline SOD323F (SC-90) 9. Soldering 3.05 2.2 2.1 solder lands solder resist 1.65 0.95 0.5 (2×) 0.6 (2×) solder paste occupied area 0.5 (2×) 0.6 (2×) Dimensions in mm sod323f_fr Reflow soldering is the only recommended soldering method. Fig. 6. Reflow soldering footprint for SOD323F (SC-90) 10. Revision history Table 9. Revision history Document ID Release date Data sheet status Supersedes PZUXB_SER v. 4 20190510 Product data sheet PZUXB_SER v. 3 Modifications: • PZUXB_SER v. 3 20180115 PZUXB_SER_2 v. 2 20091115 PZUXB_SER_1 v. 1 20060307 PZUXB_SER Product data sheet Characteristics: Reverse current (IR) unit corrected to nA for all values PZU5.6 - PZU36 Product data sheet PZUXB_SER_2 v. 2 PZUXB_SER_1 v. 1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 10 May 2019 - © Nexperia B.V. 2019. All rights reserved 8 / 10 PZUxB series Nexperia Single Zener diodes in a SOD323F package 11. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal PZUXB_SER Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 4 — 10 May 2019 © Nexperia B.V. 2019. All rights reserved 9 / 10 PZUxB series Nexperia Single Zener diodes in a SOD323F package Contents 1. Product profile.............................................................. 1 1.1. General description......................................................1 1.2. Features.......................................................................1 1.3. Applications................................................................. 1 1.4. Quick reference data................................................... 1 2. Pinning information......................................................2 3. Ordering information....................................................2 4. Marking.......................................................................... 2 5. Limiting values............................................................. 3 6. Thermal characteristics............................................... 3 7. Characteristics.............................................................. 3 8. Package outline............................................................ 8 9. Soldering....................................................................... 8 10. Revision history..........................................................8 11. Legal information........................................................9 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 May 2019 PZUXB_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 10 May 2019 © Nexperia B.V. 2019. All rights reserved 10 / 10
PZU5.6BF 价格&库存
很抱歉,暂时无法提供与“PZU5.6BF”相匹配的价格&库存,您可以联系我们找货
PZU5.6BF
    PZU5.6BF
    • 1+2.385921+0.30602
    • 10+1.4775610+0.18952
    • 100+0.92110100+0.11814
    • 500+0.67775500+0.08693
    • 1000+0.598831000+0.07681
    • 2000+0.532292000+0.06828
    • 5000+0.460045000+0.05901
    库存:10000
    PZU5.6BF
    • 1+2.648251+0.33967
