P6KE6.8(C)A THRU P6KE440(C)A
Breakdown Voltage:6.8-440 Volts Peak Pulse P ower:600 Watts
GLASS PASSIVAED JUNCTION TRANSIENT VOLTAGE SUPPRESSOR
Features
DO-15
600w peak pulse power capability
Excellent clamping capability
Low incremental surge resistance
Fast response time:typically less than 1.0ps from 0v to
1.0(25.4)
MIN.
VBR for unidirectional and 5.0ns ror bidirectional types.
High temperature soldering guaranteed:
0.140 (3.6)
0.104(2.6)
DIA.
265°C/10S/9.5mm lead length at 5 lbs tension
0.300(7.6)
0.230(5.8)
Mechanical Data
0.034 (0.86)
0.028 (0.70)
DIA.
Case : JEDEC DO-15 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.014 ounce, 0.40 grams
1.0 (25.4)
MIN.
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS
VALUE
UNITS
Peak power dissipation
sipation
Pppm
Minimum 600
W
peak power dissipation (Note 1)
Ippm
See Table 1
A
Steady state power dissapation (Note 2)
PM(AV)
5.0
W
IFSM
100
A
VF
3.5/5.0
V
TSTG,TJ
-55 to + 175
C
Peak forward surPeak forward surge current(Note 3)
Maximum instantaneous forward voltage at 50A
for unidirectional only
(Note 4)
Operating junction and storage temperature range
Notes:
1.10/1000µs waveform non-repetitive current pulse,per Fig.3 and derated above Ta=25 C per Fig.2
2.TL=75 C,lead lengths 9.5mm,Mounted on copper pad atea of (40x40mm)Fig.5
3.Measured on 8.3ms single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum.
4.VF=3.5V max.for devices of V(BR)200V
http://www.microdiode.com
Rev:2024A2
Page :1
ELECTRICAL CHARACTERISTICS (at TA=25°C unless otherwise noted)
Device Type
P6KE6.8A
P6KE6.8CA
P6KE7.5A
P6KE7.5CA
P6KE8.2A
P6KE8.2CA
P6KE9.1A
P6KE9.1CA
P6KE10A
P6KE10CA
P6KE11A
P6KE11CA
P6KE12A
P6KE12CA
P6KE13A
P6KE13CA
P6KE15A
P6KE15CA
P6KE16A
P6KE16CA
P6KE18A
P6KE18CA
P6KE20A
P6KE20CA
P6KE22A
P6KE22CA
P6KE24A
P6KE24CA
P6KE27A
P6KE27CA
P6KE30A
P6KE30CA
P6KE33A
P6KE33CA
P6KE36A
P6KE36CA
P6KE39A
P6KE39CA
P6KE43A
P6KE43CA
P6KE47A
P6KE47CA
P6KE51A
P6KE51CA
P6KE56A
P6KE56CA
Maximum
Breakdown Voltage
Maximum
Reverse
V(BR)
Test Stand-off
Peak Pulse
Leakage
(Volts)(NOTES 1)
Current Voltage
Reverse Current
VWM
atVWM
IT(mA)
IPPM(NOTE2)
(Volts) ID(NOTE3)(µA)
MIN
MAX
(Amps)
6.45
6.45
7.13
7.13
7.79
7.79
8.65
8.65
9.50
9.50
10.5
10.5
11.4
11.4
12.4
12.4
14.3
14.3
15.2
15.2
17.1
17.1
19.0
19.0
20.9
20.9
22.8
22.8
25.7
25.7
28.5
28.5
31.4
31.4
34.2
34.2
37.1
37.1
40.9
40.9
44.7
44.7
48.5
48.5
53.2
53.2
7.14
7.14
7.88
7.88
8.61
8.61
9.55
9.55
10.5
10.5
11.6
11.6
12.6
12.6
13.7
13.7
15.8
15.8
16.8
16.8
18.9
18.9
21.0
21.0
23.1
23.1
25.2
25.2
28.4
28.4
31.5
31.5
34.7
34.7
37.8
37.8
41.0
41.0
45.2
45.2
49.4
49.4
53.6
53.6
58.8
58.8
10.0
10.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
5.80
5.80
6.40
6.40
7.02
7.02
7.78
7.78
8.55
8.55
9.40
9.40
10.2
10.2
11.1
11.1
12.8
12.8
13.6
13.6
15.3
15.3
17.1
17.1
18.8
18.8
20.5
20.5
23.1
23.1
25.6
25.6
28.2
28.2
30.8
30.8
33.3
33.3
36.8
36.8
40.2
40.2
43.6
43.6
47.8
47.8
1000.0
1000.0
500.0
500.0
200.0
200.0
50.0
50.0
10.0
10.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
50.
50.
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
57.1
57.1
53.1
53.1
49.6
49.6
44.8
44.8
41.4
41.4
38.5
38.5
35.9
35.9
33.0
33.0
28.3
28.3
26.7
26.7
23.8
23.8
21.7
21.7
19.6
19.6
18.1
18.1
16.0
16.0
14.5
14.5
13.1
13.1
12.0
12.0
11.1
11.1
10.1
10.1
9.3
9.3
8.6
8.6
7.8
7.8
Maximum
Clamping
Voltage at
IPPM
Vc(Volts)
Maximum
Temperature
Coefficient
of V(BR)
(%/ C)
10.5
10.5
11.3
11.3
12.1
12.1
13.4
13.4
14.5
14.5
15.6
15.6
16.7
16.7
18.2
18.2
21.2
21.2
22.5
22.5
25.2
25.2
27.7
27.7
30.6
30.6
33.2
33.2
37.5
37.5
41.4
41.4
45.7
45.7
49.9
49.9
53.9
53.9
59.3
59.3
64.8
64.8
70.1
70.1
77.0
77.0
0.057
0.057
0.061
0.061
0.065
0.065
0.068
0.068
0.073
0.073
0.075
0.075
0.078
0.078
0.081
0.081
0.084
0.084
0.086
0.086
0.088
0.088
0.090
0.090
0.092
0.092
0.094
0.094
0.096
0.096
0.097
0.097
0.098
0.098
0.099
0.099
0.100
0.100
0.101
0.101
0.101
0.101
0.102
0.102
0.103
0.103
The electrical characteristics above is for reference only.
Rev:20214A2
Page :2
Device Type
P6KE62A
P6KE62CA
P6KE68A
P6KE68CA
P6KE75A
P6KE75CA
P6KE82A
P6KE82CA
P6KE91A
P6KE91CA
P6KE100A
P6KE100CA
P6KE110A
P6KE110CA
P6KE120A
P6KE120CA
P6KE130A
P6KE130CA
P6KE150A
P6KE150CA
P6KE160A
P6KE160CA
P6KE170A
P6KE170CA
P6KE180A
P6KE180CA
P6KE200A
P6KE200CA
P6KE220A
P6KE220CA
P6KE250A
P6KE250CA
P6KE300A
P6KE300CA
P6KE350A
P6KE350CA
P6KE400A
P6KE400CA
P6KE440A
P6KE440CA
Breakdown Voltage
V(BR)
(Volts)(NOTES 1)
Test Stand-off
Current Voltage
VWM
IT(mA)
(Volts)
Maximum
Reverse
Leakage
atVWM
ID(NOTE3)(µA)
Maximum
Peak Pulse
Reverse Current
IPPM(NOTE2)
(Amps)
Maximum
Clamping
Voltage at
IPPM
Vc(Volts)
Maximum
Temperature
Coefficient
of V(BR)
(%/ C)
MIN
MAX
58.9
58.9
65.1
65.1
1.0
1.0
53.0
53.0
5.0
5.0
7.1
7.1
85.0
85.0
0.104
0.104
64.6
64.6
71.4
71.4
1.0
1.0
58.1
58.1
5.0
5.0
6.5
6.5
92.0
92.0
0.104
0.104
71.3
71.3
78.8
78.8
1.0
1.0
64.1
64.1
5.0
5.0
5.8
5.8
103
103
0.105
0.105
77.9
77.9
86.1
86.1
1.0
1.0
70.1
70.1
5.0
5.0
5.3
5.3
113
113
0.105
0.105
86.5
86.5
95.5
95.5
1.0
1.0
77.8
77.8
5.0
5.0
4.8
4.8
125
125
0.106
0.106
95.0
95.0
105
105
1.0
1.0
85.5
85.5
5.0
5.0
4.4
4.4
137
137
0.106
0.106
105
105
116
116
1.0
1.0
94.0
94.0
5.0
5.0
3.9
3.9
152
152
0.107
0.107
114
114
126
126
1.0
1.0
102
102
5.0
5.0
3.6
3.6
165
165
0.107
0.107
124
124
137
137
1.0
1.0
111
111
5.0
5.0
3.4
3.4
179
179
0.107
0.107
143
143
158
158
1.0
1.0
128
128
5.0
5.0
2.9
2.9
207
207
0.108
0.108
152
152
168
168
1.0
1.0
136
136
5.0
5.0
2.7
2.7
219
219
0.108
0.108
162
162
179
179
1.0
1.0
145
145
5.0
5.0
2.6
2.6
234
234
0.108
0.108
171
171
189
189
1.0
1.0
154
154
5.0
5.0
2.4
2.4
246
246
0.108
0.108
190
190
210
210
1.0
1.0
171
171
5.0
5.0
2.2
2.2
274
274
0.108
0.108
209
209
231
231
1.0
1.0
185
185
5.0
5.0
1.8
1.8
328
328
0.108
0.108
237
237
263
263
1.0
1.0
214
214
5.0
5.0
1.7
1.7
344
344
0.110
0.110
285
285
315
315
1.0
1.0
256
256
5.0
5.0
1.4
1.4
414
414
0.110
0.110
332
332
368
368
1.0
1.0
300
300
5.0
5.0
1.2
1.2
482
482
0.110
0.110
380
380
420
420
1.0
1.0
342
342
5.0
5.0
1.1
1.1
548
548
0.110
0.110
418
418
462
462
1.0
1.0
376
376
5.0
5.0
1.0
1.0
602
602
0.110
0.110
NOTES:
1.V(BR)measured after IT applied for 300µs,IT=square wave pulse or equivalent
2. Surge current waveform per Fig.3 and derated per Fig.2
3.For bidirectional types having VWM of 10 volts and less,the ID limit is doubled
4.All items and symbols are consistent with ANSI/IEEE C62.35
Rev:2024A2
Page :3
PppM,PEAK PULSE POWER,kw
PEAK PULSE POWER(PppM)or CURRENT(IppM)
DERATING IN PERCENTAGE,%
FIG. 1-PEAK PULSE POWER RATING CURVE
100
NON-REPETITIVE
PULSE WAVEFORM
SHOWN in FIG.3
TA=25 C
10
1.0
0.1
0.1µs
1.0µs
10µs
100µs
1.0ms
10ms
td,PULSE WIDTH,sec.
FIG.3-PULSE WAVEFORM
150
IppM,PEAK PULSE CURRENT,%
75
50
25
75
100
125
150
175
200
TA AMBIENT TEMPERATURE,( C)
FIG. 4-TYPICAL JUNCTIONAL CAPACITANCE
UNIDIRECTIONAL
PEAK VALUE IppM
10,000
100
HALF VALUE
MEASURED at
ZERO BIAS
IPPM
2
CJ,JINCTION CAPACITANCE,pF
10/1000µsec WAVEFORM
as DFINED by R.E.A
50
td
2.0
3.0
4.0
t,TIME,ms
FIG.5-STEADY STATE POWER DERATING CURVE
5.00
L=0.375” (9.5mm)
lLEAD LENGTHS
60Hz RESISTIVE
OR INDUCTIVE LOAD
TA=25 C
f=1.0MHz
Vsig=50mVp-p
1,000
MEASURED at
STAND-OFF
VOLTAGE,VwM
100
3.75
10
1.0
2.50
1.6 1.6 0.040”
(40 40 1mm)
COPPER HEAT SINKS
10
100
200
V(BR),BREAKDOWN VOLTAGE,VOLTS
1.25
IFSM,PEAK FORWARD SURAGE CURRENT
AMPERES
PM(AV),STEADY STATE POWER
DISSIPATION,WATTS
25
PULSE WIDTH (td) is DEFINED
as the POINT WHERE the PEAK
CURRENT DECAYS to 50% of IppM
tr=10µsec
50
75
100
125
150
175
200
TL,LEAD TEMPERATURE, C
INSTANTANEOUS REVERSE LEAKAGE
CURRENT,MICROAMPERES
FIG. 2-PULSE DERATING CURVE
100
FIG.7-TYPICAL REVERSE LEAKAGE CHARCTERISTICS
1000
100
MEASURED AT DEVICES
STAND-OFF
VOLTAGE,Vwm
10
1
TA=25 C
0.1
200
100
TJ=TJmax.
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
10
1.0
10
100
NUMBER OF CYCLES AT 60Hz
0.01
0.001
FIG.6-MAXIMUM NON-REPETITIVE FORWARD SURGE
CURRENT UNIDIRECTIONAL ONLY
200
300
400
500
The curve characteristics above is for reference only.
https://www.microdiode.com
Rev:2024A2
Page :4
很抱歉,暂时无法提供与“P6KE200A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.50550
- 100+0.41350
- 300+0.36700
- 2500+0.28270
- 5000+0.25500
- 10000+0.24130
- 国内价格
- 100+0.27968
- 500+0.26725
- 国内价格
- 10+0.50966
- 100+0.41688
- 300+0.37055
- 2500+0.28545
- 5000+0.25758
- 10000+0.24365
