P6SMB6.8CA
P6SMB6.8CA
    MDD(辰达半导体)
    SMB(DO-214AA)
    ESD抑制器/TVS二极管 双向 5.8V 58.1A 600W SMB(DO-214AA)
P6SMB6.8CA 数据手册
P6SMB6.8(C)A P6SMB550(C)A Stand-off Voltage - 6.8 to 550 Volts Peak Pulse Power: 600 Watts SURFACE MOUNT TRANSISIENT VOLTAGE SUPPRESSOR Features DO-214AA/SMB  For surface mounted applications in order to optimize board  space Low profile package  Built-in strain relief  Glass passivated junction 0.155(3.94) 0.130(3.30) 0.086 (2.20) 0.071 (1.80)  Low inductance  Excellent clamping capability  600W peak pulse power capability at 10/1000μs waveform, 0.185(4.70) 0.160(4.06)  repetition rate (duty cycle): 0.01%  Fast response time 0.012(0.305) 0.006(0.152)  Typical IR less than 1μA above 12V  High Temperature soldering: 260℃/ 40 seconds at terminals  Plastic package has underwriters laboratory flammability 94V-0 0.096(2.44) 0.084(2.13) 0.060(1.52) 0.030(0.76) 0.008(0.203)MAX. Mechanical Data 0.220(5.59) 0.200(5.08) Case : JEDEC DO-214AA/SMB molded plastic body Terminals : Solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Dimensions in inches and (millimeters) Mounting Position : Any Weight : 0.003 ounce, 0.095 grams Applications I/O interface AC/DC power supply Industrial and Consumer electronic applications. MAXIMUM RATINGS AND CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Peak Pulse Power Dissipation at TA=25ºC by 10x1000μs waveform (Fig.1) (Note 1), (Note 2) Power Dissipation on infinite heat sink at TA=50O C Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3) Maximum Instantaneous Forward Voltage at 50A for Unidirectional only (Note 4) Operating Junction and Storage Temperature Range PPPM 600 Watts PM(AV) 5.0 Watts IFSM 100 Amps VF 3.5V/5.0 V TJ,TSTG -65 to +150 ℃ Typical Thermal Resistance Junction to Lead RθJL 20 ℃/W Typical Thermal Resistance Junction to Ambient RθJA 100 ℃/W Notes: (1)Non-repetitive current pulse , per Fig. 3 and derated above TA = 25℃per Fig. 2. (2) Mounted on 0.2 x 0.2" (5.0 x 5.0 mm) copper pads to each terminal (3) VF
P6SMB6.8CA
物料型号:P6SMB6.8A THRU P6SMB550CA
器件简介:P6SMB系列瞬态电压抑制二极管专为保护敏感电子设备免受雷电和其他瞬态电压事件引起的电压瞬态而设计。
引脚分配:文档中未明确列出引脚分配,但通常这类器件为表面贴装型,具体引脚分配需参考器件的封装规格。
参数特性: - 工作温度范围:-65℃ 至 +150℃ - 峰值脉冲功率:600瓦特 - 峰值脉冲电流:100安培(单向)/ 200安培(双向) - 典型响应时间:小于1皮秒 - 低增量浪涌电阻:在12伏以上小于1微安培 - 高温焊接保证:260℃/40秒
功能详解: - 瞬态电压抑制二极管用于保护I/O接口、总线和其他易受电信、计算机、工业和消费电子应用中使用的电路。
应用信息: - 适用于电信、计算机、工业和消费电子应用中的I/O接口、总线和其他易受电路的保护。
封装信息: - 封装类型:SMB/DO-214AA - 封装尺寸:以英寸和毫米为单位提供,具体尺寸需参考数据手册中的详细图纸。
P6SMB6.8CA 价格&库存
很抱歉,暂时无法提供与“P6SMB6.8CA”相匹配的价格&库存,您可以联系我们找货
P6SMB6.8CA
  • 10+0.20720
  • 100+0.20180
  • 300+0.19900
  • 1000+0.19630
库存:45080
P6SMB6.8CA
  • 1+0.29715
  • 200+0.19110
  • 1500+0.16590
  • 3000+0.14700
库存:18010
P6SMB6.8CA
  • 1+0.22540
库存:540
P6SMB6.8CA
  • 10+0.19018
  • 100+0.18652
  • 600+0.18404
  • 1200+0.18220
  • 3000+0.17856
库存:6687
