ES1A THRU ES1J
SURFACE MOUNT SUPER FAST RECTIFIER
Reverse Voltage - 50 to 600 Volts
Forward Current - 1.0 Ampere
FEATURES
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds at terminals
Glass passivated chip junction
0.110(2.80)
0.100(2.54)
0.067 (1.70)
0.051 (1.30)
0.177(4.50)
0.157(3.99)
0.012(0.305)
0.006(0.152)
0.096(2.42)
0.078(1.98)
0.060(1.52)
0.030(0.76)
MECHANICAL DATA
Case: JEDEC DO-214AC molded plastic body over passivated chip
Terminals: Solder plated, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.002 ounce, 0.07 grams
0.008(0.203)MAX.
0.208(5.28)
0.188(4.80)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=55 C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Maximum reverse recovery time
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
SYMBOLS
VRRM
VRMS
VDC
ES1A ES1B ES1C
50
35
50
100
70
100
150
105
150
ES1D ES1E
200
140
200
300
210
300
ES1G
400
280
400
ES1J
UNITS
600
420
600
VOLTS
VOLTS
VOLTS
I(AV)
1.0
Amp
IFSM
30.0
Amps
VF
0.95
1.25
1.7
Volts
IR
5.0
50.0
trr
35
ns
15.0
60.0
-50 to +150
pF
C/W
C
CJ
RθJA
TJ,TSTG
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
MDD ELECTRONIC
µA
FIG. 1- FORWARD CURRENT DERATING CURVE
1.0
0.8
0.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.4
0.2
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES ES1A THRU ES1J
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
25
10
175
5.0
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
1
0.1
ES1A-ES1D
ES1E-ES1G
ES1J
0.01
0.8
1.2
1.6
1.8
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
10
1,000
100
10
TJ=100 C
1
0.1
TJ=25 C
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
TJ=25 C
10
60
80
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
1
0.1
1.0
10
100
PERCENT OF PEAK REVERSE VOLTAGE,%
TRANSIENT THERMAL IMPEDANCE,
C/W
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
200
100
100
NUMBER OF CYCLES AT 60 Hz
100
REVERSE VOLTAGE,VOLTS
MDD ELECTRONIC
t,PULSE DURATION,sec.
100
很抱歉,暂时无法提供与“ES1J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07187
- 400+0.07079
- 800+0.05910
- 2000+0.05821
- 10000+0.03881
- 20000+0.03823
- 国内价格
- 100+0.07841
- 1000+0.06448
- 5000+0.04698
- 10000+0.04234
- 50000+0.04040
- 100000+0.03921
- 国内价格
- 1+0.21780
- 500+0.07271
- 2500+0.04851
- 5000+0.03960
- 国内价格
- 1+0.05970
- 5000+0.04310
- 国内价格
- 1000+0.04351
- 5000+0.03729
- 国内价格
- 100+0.07780
- 1000+0.06400
- 5000+0.04660
- 10000+0.04190
- 50000+0.04000
- 100000+0.03880
