MMBT2907A
SOT-23 Plastic-Encapsulate Transistors
MMBT2907A
TRANSISTOR (PNP)
SOT-23
FEATURES
z
Epitaxial planar die construction
z
Complementary NPN Type available(MMBT2222A)
1. BASE
2. EMITTER
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
-60
V
VCEO
Collector-Emitter Voltage
-60
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current
-600
mA
PC
Collector Power Dissipation
250
mW
Thermal Resistance From Junction To Ambient
500
℃/W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
RΘJA
3. COLLECTOR
MARKING: 2F
(3)C
2F
(1)B
(2)E
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
IC=-10μA,IE 0
V(BR)CBO
-60
V
Collector-emitter breakdown voltage
IC=-10mA,IB 0
V(BR)CEO*
-60
V
Emitter-base breakdown voltage
IE=-10μA,IC 0
V(BR)EBO
-5
V
Collector cut-off current
VCB=-50V,IE 0
I=
CBO
-20
nA
Base cut-off current
VEB=-3V, IC 0
IEBO
-10
nA
ICEX
VCE=-30 V, VBE(off) = -0.5V
-50
nA
hFE(1)
VCE= -10V,IC= -150mA
100
hFE(2)
VCE=-10V,IC=-0.1mA
75
hFE(3)
VCE=-10V,IC=-1mA
100
hFE(4)
VCE=-10V,IC=-10mA
100
hFE(5)
VCE=-10V,IC=-500mA
50
DC current gain
Collector-emitter saturation voltage
Base-emitter saturation voltage
VCE(sat)*
IC=-150mA,IB=-5mA
-0.4
V
VCE(sat)*
IC=-500mA,IB -50mA
-1.6
V
VBE(sat)*
IC=-150mA,IB -15mA
-1.3
V
VBE(sat)*
IC=-500mA,IB -50mA
-2.6
V
Transition frequency
fT
Delay time
td
Rise time
tr
Storage time
tS
Fall time
tf
*Pulse test: tp≤300μs, δ≤0.02.
http://www.microdiode.com
300
VCE=-20V,I
=C -50mA,f
= 100MHz
200
MHz
10
VCE=-30V,IC=-150mA,B1=-15mA
VCE=-6V,IC=-150mA,
IB1=- IB2=- 15mA
CLASSIFICATION OF hFE
ns
25
ns
225
ns
60
ns
RANK
L
H
RANGE
100-200
200-300
Rev:2025A3
Page :1
MMBT2907A
Typical Characteristics
Static Characteristic
-0.25
hFE
500
—— IC
COMMON EMITTER
VCE=-10V
-800uA
-0.20
hFE
-640uA
-0.15
DC CURRENT GAIN
COLLECTOR CURRENT
400
-720uA
IC
(A)
COMMON EMITTER
Ta=25℃
-560uA
-480uA
-0.10
-400uA
-320uA
-240uA
-0.05
300
Ta=100℃
Ta=25℃
200
100
-160uA
IB=-80uA
-0.00
-0
-2
-4
-6
-8
COLLECTOR-EMITTER VOLTAGE
VCEsat
-0.9
-10
VCE
-12
IC
-100
-10
COLLECTOR CURRENT
VBEsat
-1.2
β=10
IC
-0.6
Ta=100℃
-0.3
Ta=25℃
-0.0
—— IC
Ta=25℃
-0.8
Ta=100℃
-0.4
-0.0
-1
-100
-10
COLLECTOR CURRENT
IC
IC
-1
-600
(mA)
-100
-10
COLLECTOR CURRENT
—— VBE
100
-600
Cob/ Cib
IC
—— VCB/ VEB
f=1MHz
IE=0/ IC=0
(pF)
IC
(mA)
Ta=25℃
Cib
-100
CAPACITANCE
Ta=25℃
-1
-0.1
-0.0
-0.2
-0.4
-0.6
-0.8
-1.0
BASE-EMMITER VOLTAGE VBE (V)
Pc
300
Cob
C
Ta=100℃
-10
-600
(mA)
COMMON EMITTER
VCE=-10V
COLLECTOR CURRENT
-600
(mA)
β=10
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (V)
-1
(V)
10
1
-0.1
-1
REVERSE VOLTAGE
-10
V
-20
(V)
Ta
COLLECTOR POWER DISSIPATION
Pc (mW)
250
200
150
100
50
50
75
AMBIENT TEMPERATURE
100
Ta
125
150
Rev:2025A3
Page :2
MMBT2907A
Outlitne Drawing
SOT-23 Package Outline Dimensions
1
e
Suggested Pad Layout
0.037
0.95
0.037
0.95
L
L1
E
E1
Symbol
A
A1
b
c
D
E
E1
e
L
L1
θ
Dimensions In Millimeters
Min
Typ
Max
0.65
1.40
0.20
0.00
0.30
0.55
0.20
0.08
2.70
3.10
1.15
1.65
2.80
2.10
1.70
2.10
0.15
0.50
0.35
0°
0.70
12°
Note:
1. Controlling dimension:in/millimeters.
2. General tolerance: ±0.05mm.
3. The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
Rev:2025A3
Page :3
MMBT2907A
SOT-23 Tape and Reel
Packaging Description:
SOT-23 parts are shipped in tape. The carrier
tape is made from a dissipative (carbon filled)
polycarbonate resin. The cover tape is a multilayer
film (Heat Activated Adhesive in nature) primarily
composed of polyester film,adhesive laye,sealant,
and anti-static sprayed agent.These reeled parts In
standard option are shipped with 3,000 units per 7"
or 17.8cm diameter reel. The reels are clear in color
and is made of polystyrene plastic (anti-static
coated).
3000 pcs
7 Inch
45,000 pcs
203×203×195
180,000 pcs
438×438×220
Rev:2025A3
Page :4
很抱歉,暂时无法提供与“MMBT2907A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.30250
- 200+0.10076
- 1500+0.06303
- 3000+0.04994
- 国内价格
- 50+0.10898
- 500+0.08392
- 3000+0.07290
- 6000+0.06448
- 24000+0.05724
- 51000+0.05336
- 国内价格
- 20+0.09081
- 600+0.07071
- 2400+0.06210
