S1A THRU S1M
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT GENERAL RECTIFIER
Features
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
0.110(2.80)
0.094(2.40)
0.067 (1.70)
0.039 (1.00)
Idea for printed circuit board
Glass passivated Junction chip
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
0.177(4.50)
0.157(3.99)
0.012(0.305)
0.006(0.152)
250℃/ 10 seconds at terminals
0.096(2.42)
0.078(1.98)
0.059(1.50)
0.035(0.90)
Mechanical Data
0.008(0.203)MAX.
0.205(5.20)
0.188(4.80)
Case : JEDEC DO-214AC/SMA Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Dimensions in inches and (millimeters)
Mounting Position : Any
Weight : 0.0023 ounce, 0.07 grams
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=110℃
SYMBOLS
MDD
S1A
MDD
S1B
MDD
S1D
MDD
S1G
MDD
S1J
MDD
S1K
MDD
S1M
UNITS
VRRM
VRMS
VDC
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
I(AV)
1.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
30
A
Maximum instantaneous forward voltage at 1.0A
VF
1.10
V
Maximum DC reverse current
at rated DC blocking voltage
IR
uA
CJ
5
50
15.0
RJA
75.0
℃/W
-55 to +150
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction and storage temperature range TJ,TSTG
pF
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
S1A THRU S1M
FIG. 1- FORWARD CURRENT DERATING CURVE
1.0
0.8
0.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.4
0.2
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
25
10
175
5.0
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
1
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
0.01
0.6
0.8
1.0
1.2
1.4
1.5
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
0.1
1,000
100
TJ=150 C
10
TJ=100 C
1
0.1
TJ=25 C
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
TJ=25 C
10
TRANSIENT THERMAL IMPEDANCE,
C/W
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
200
100
100
NUMBER OF CYCLES AT 60 Hz
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
1
0.1
1.0
10
100
REVERSE VOLTAGE,VOLTS
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A2
Page :2
S1A THRU S1M
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SMA
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
5.33
2.36
1.50
330.00
50.00
178.00
62.00
13.00
1.75
5.50
4.00
4.00
2.00
0.28
12.00
18.00
E
F
B
A
W
P
D2
D1
T
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMA
REEL SIZE
7"
APPROX.
GROSS WEIGHT
(kg)
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
2,000
4.0
4,000
183*155*183
178
382*356*392
10,000
290*290*38
330
310*310*360
80,000
11.0
15,000
335*335*38
330
350*330*360
120,000
14.5
SMA
11"
5,000
4.0
SMA
13"
7,500
4.0
CARTON
SIZE
(m/m)
CARTON
(pcs)
80,000
16.0
Suggested Pad Layout
Symbol
Unit (mm)
A
1.68
Unit (inch)
0.066
B
1.52
0.060
C
3.93
0.154
D
2.41
0.095
E
5.45
0.215
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“S1B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16720
- 100+0.10360
- 500+0.06840
- 5000+0.04890
- 10000+0.04650
- 50000+0.04300
- 国内价格
- 50+0.07695
- 400+0.06093
- 800+0.06002
- 2000+0.05202
- 国内价格
- 1+0.21230
- 500+0.07095
- 2500+0.04719
- 5000+0.03883
- 国内价格
- 50+0.09234
- 500+0.07312
- 1500+0.06243
- 5000+0.05411
- 25000+0.04860
- 50000+0.04558
