SM4001PL THRU SM4007PL
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT GENERAL PURPOSE SILICON RECTIFIER
Features
SOD-123FL
Glass passivated device
Ideal for surface mouted applications
Low reverse leakage
Metallurgically bonded construction
0.075(1.90)
0.067(1.70)
0.031 (0.80)
0.043 (1.10)
0.114(2.90)
0.102(2.60)
High temperature soldering guaranteed:
250°C/10 seconds,0.375”(9.5mm) lead length, 5
0.051(1.30)
0.039(1.00)
lbs. (2.3kg) tension
0.010(0.25)
0.004(0.10)
0.035(0.90)
0.028(0.70)
0.154(3.90)
0.141(3.60)
Mechanical Data
Case: JEDEC 6OD-123FL molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body
Mounting Position: Any
Weight : 0.0053ounce, 0.015grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
SM4001PL SM4002PL SM4003PL SM4004PL SM4005PL SM4006PL SM4007PL
A1
A2
A3
A4
A5
A6
A7
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
Maximum average forward rectified current
at TL(NOTE 1)
I(AV)
1.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
25
A
Maximum instantaneous forward voltage at 1.0A
VF
V
Maximum DC reverse current
at rated DCblocking voltage
IR
1.1
10
50
uA
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction temperature range
Storage temperature range
CJ
RJA
4
pF
180
℃/W
TJ
-55 to +150
TSTG
-55 to +150
Note: 1.Averaged over any 20ms period.
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.Thermal resistance from junction to ambient at 0.375” (9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2024A2
Page :1
Typical Characterisitics
Fig.2 Typical Instaneous Reverse
Characteristics
Fig.1 Forward Current Derating Curve
1.2
100
TJ= 150°C
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz resistive
or inductive load
0.0
25
75
50
100
125
150
175
Instaneous Reverse Current (uA)
Average Forward Current (A)
1.0
TJ=125°C
10
1.0
TJ=75°C
0.1
TJ=25°C
1N4007W
0.01
200
600
800
Instaneous Reverse Voltage (V)
Case Temperature (°C)
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
100
1.0
Junction Capacitance (pF)
C
TJ=
25°
0°
TJ=
10
15
0°
C
C
0.5
TJ=
Instaneous Forward Current (A)
TJ=25°C
0.8
0.9
0.2
10
1
0.1
0.5
0.6
0.7
1.0
1.1
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
35
30
25
10
05
8.3 ms Single Half Sine Wave (JEDEC
Method)
00
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SOD-123FL
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
E
F
B
A
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
W
P
D2
T
D1
C
W1
D
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-123FL
7"
3,000
4.0
45,000
210*208*203
178
430*430*235
180,000
APPROX.
GROSS WEIGHT
(kg)
9.0
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
1.2
0.047
B
1.2
3.2
0.126
D
2
0.079
E
4.4
0.173
C
0.047
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“SM4007PL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.05520
- 1000+0.04400
- 3000+0.03100
- 9000+0.02730
- 51000+0.02590
- 99000+0.02490
- 国内价格
- 100+0.05562
- 1000+0.04439
- 3000+0.03132
- 9000+0.02754
- 51000+0.02603
- 99000+0.02506
- 国内价格
- 1+0.03230
- 3000+0.02570
- 国内价格
- 50+0.05098
- 600+0.04069
- 1200+0.04008
- 3000+0.02871
- 15000+0.02524
- 30000+0.02486
